cx18 has now switched over completely to the new mediabus subdev ops.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
v4l2_prio_init/open/close returned an int when in fact they would
always return 0. Make these void functions.
v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a
pointer for no good reason. Replace with a normal enum v4l2_priority
argument.
These changes will simplify the work of moving priority handling into
the v4l core.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This mistakenly tested against sizeof(freqs) instead of the array size. Due to
the mask the only illegal value possible was 3.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Andy Walls <awalls@radix.net>
A previous change (v4l2-common: remove v4l2_ctrl_query_fill_std) broke
the handling of class controls in VIDIOC_QUERYCTRL. The MPEG class control
was broken for all drivers that use the cx2341x module and the USER class
control was broken for ivtv and cx18.
This change adds back proper class control support.
DVD streams
Both the MPEG-2 SVCD stream format and the MPEG-2 DVD stream format should
use an MPEG-2 PS container. This makes it safe to stuff IVTV Private Stream 1
VBI packets in these stream types using the existing cx18 driver routines.
Reported-by: Helen Buus <mythtv@hbuus.com>
for an MPEG PS
The cx18 private packet insertion code only expects to operate on an MPEG PS
when inserting private packets of sliced VBI data. This patch keeps the cx18
driver from corrupting the MPEG TS or other non-PS stream types, in case the
user enables sliced VBI insertion for these MPEG stream types.
v4l2_subdevices
Convert GPIO line functions, such a audio routing and device resets, to
v4l2_subdevices. This essentially completes the conversion of cx18 to the
v4l2_device/v4l2_subdevice framework. No regression testing has taken place as
of yet. Also an ivtv legacy bug with GPIO mux routing and going to/from radio
mode was commented, but not fixed.
This is a major perturbation to cx18 I2C device handling to convert it to the
v4l2_device/subdeivce framework. This change breaks GPIO audio multiplexer
control for the time being. It will be fixed in a coming change.
to v4l2_subdev
Added a new chip identifer to v4l2-chip-ident for the integrated A/V broadcast
decoder core internal to the CX23418. Completed separation and encapsulation
of the A/V decoder core interface as a v4l2_subdevice. The cx18 driver now
compiles and links again.
Control arrays as are used with v4l2_ctrl_next must be sorted from
low to high. Add a comment at the top of all such arrays to warn
about this.
Removed legacy ivtv state variables, added comments, and cleaned
up sliced VBI related code. Enabled sliced VBI.
CX2341x parameters
cx18: Use a known open task handle when setting stream CX2341x parameters
Sometimes, we might only have VBI or YUV stream open instead of an MPEG stream.
Let's make sure we use a valid task handle to perform the CX2341x control
settings.
through s/g_ext_ctrl
videodev converts old-style controls to an extended control so the ivtv and
cx18 drivers no longer have to handle both.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The cx18 can support transport streams with newer firmwares. Add a TS
capability to the generic cx2341x module.
Completely rely on the video_ioctl2 debugging facilities rather than
doing it ourselves.
Fill in some missing fields in ivtv with VIDIOC_G_FBUF.
cx18: convert driver to use video_ioctl2(). Pushed down ioctl debug
messages and priority checks as well. Still left serialization lock in
place for now. #if 0'ed out sliced vbi ioctl code for now.
Patch heavily based on similar changes made to ivtv by Hans Verkuil.
The HVR-1600 can do both analog and digital capture at the same time.
Due to a driver bug -EBUSY would be returned when attempting to setup an
analog capture while a digital capture was already in progress.
Separate the two internally.
LD drivers/media/video/built-in.o
drivers/media/video/cx18/built-in.o: In function `get_service_set':
/home/v4l/tokernel/git/drivers/media/video/cx18/cx18-ioctl.c:118: multiple definition of `get_service_set'
drivers/media/video/ivtv/built-in.o:/home/v4l/tokernel/git/drivers/media/video/ivtv/ivtv-ioctl.c:119: first defined here
drivers/media/video/cx18/built-in.o: In function `expand_service_set':
/home/v4l/tokernel/git/drivers/media/video/cx18/cx18-ioctl.c:92: multiple definition of `expand_service_set'
drivers/media/video/ivtv/built-in.o:/home/v4l/tokernel/git/drivers/media/video/ivtv/ivtv-ioctl.c:92: first defined here
drivers/media/video/cx18/built-in.o: In function `service2vbi':
/home/v4l/tokernel/git/drivers/media/video/cx18/cx18-ioctl.c:44: multiple definition of `service2vbi'
drivers/media/video/ivtv/built-in.o:/home/v4l/tokernel/git/drivers/media/video/ivtv/ivtv-ioctl.c:42: first defined here
make[2]: ** [drivers/media/video/built-in.o] Erro 1
make[1]: ** [drivers/media/video] Erro 2
make: ** [drivers/media/] Erro 2
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from
Conexant for their support. I am in particular thankful to Hauppauge
since without their help this driver would not exist. It should also
be noted that Steve did the work to get the DVB part up and running.
Thank you!
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: G. Andrew Walls <awalls@radix.net>
