path: root/drivers/media/video/cx18/cx18-fileops.h
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-05-14V4L/DVB (7856): cx18/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - cx18-i2c.c should #include "cx18-i2c.h" for getting the prototypes of it's global functions - make the following needlessly global functions static: - cx18-fileops.c:cx18_claim_stream() - cx18-fileops.c:cx18_release_stream() - cx18-queue.c:cx18_queue_move() - remove the following unused functions: - cx18-driver.c:cx18_waitq() - cx18-queue.c:cx18_buf_copy_from_user() Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
