path: root/drivers/media/video/cx18/cx18-gpio.c
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11370): v4l2-subdev: move s_std from tuner to core.Hans Verkuil
s_std didn't belong in the tuner ops. Stricly speaking it should be part of the video ops, but it is used by audio and tuner devices as well, so it is more efficient to make it part of the core ops. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10761): cx18: Change log lines for internal subdevs and fix ↵Andy Walls
tveeprom reads Give messages originating from internal subdevs a header using the subdev's name. Fixed an uninitialized variable problem with reading the EEPROM, noticed from log output. Got rid of the unused cx18_av_exit() function. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10759): cx18: Convert GPIO connected functions to act as ↵Andy Walls
v4l2_subdevices Convert GPIO line functions, such a audio routing and device resets, to v4l2_subdevices. This essentially completes the conversion of cx18 to the v4l2_device/v4l2_subdevice framework. No regression testing has taken place as of yet. Also an ivtv legacy bug with GPIO mux routing and going to/from radio mode was commented, but not fixed. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9728): cx18: Copyright attribution update for files modified by awallsAndy Walls
Add copyright attribution for files modified by awalls in 2008 Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9724): cx18: Streamline cx18-io[ch] wrappers and enforce MMIO retry ↵Andy Walls
strategy cx18: Streamline cx18-io[ch] wrappers and enforce MMIO retry strategy so that write retries always occur and read retries never occur (as they never help). Remove MMIO statistics logging to speed up MMIO accesses. Deprecate & ignore retry_mmio and mmio_ndelay module parameters, to essentially force retry_mmio=1 and mmio_ndelay=0. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9512): cx18: Fix write retries for registers that always change - ↵Andy Walls
part 3. cx18: Fix write retries for registers that always change - part 3. Fix the io for the rest of the registers that will often not read back the value just written. Modified register readback checks to make sure the intended effect was achieved without constantly rewriting the registers. The one outstanding register remaining is 0xc72014 CX18_AUDIO_ENABLE, whose behavior on writes I have yet to determine. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (9049): convert tuner drivers to use dvb_frontend->callbackMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8913): cx18: Create cx18_ specific wrappers for all pci mmio ↵Andy Walls
accessesors. cx18: Create cx18_ specific wrappers for all pci mmio accessesors. This is a first step in instrumenting all CX23418 PCI bus IO, to debug problems with accessing the CX23418's PCI memory mapped IO. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8332): cx18: Suport external reset of the Z8F0811 IR controller on ↵Andy Walls
HVR-1600 for lirc cx18: added in cx18_ir_reset_gpio function for lirc_pvr150 like module. Also added the ability to reset the IR chip via ioctl like ivtv. This needs the mutex to protect gpio_dir and gpio_val in struct cx18 as gpio changes can come from a few different asynchronous sources now. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8331): cx18: Add locking for struct cx18 GPIO state variablesAndy Walls
cx18: Add locking for struct cx18 GPIO state variables in anticpation of adding IR microcontroller reset support for use by external IR modules. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8089): cx18: add support for Conexant Raptor PAL/SECAM cardSri Deevi
Patch provided courtesy of Conexant http://www.conexant.com. Signed-off-by: Srinivasa Deevi <srinivasa.deevi@conexant.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-26V4L/DVB (8068): cx18: Add I2C slave reset via GPIO upon initializationAndy Walls
cx18: Add I2C slave reset via GPIO upon initialization. One user, Michael <msd4824@yahoo.com>, has reported this allows his HVR-1600 EEPROM to be consistently recognized when using (long,) 100 msec delays. The delays in this commit are nominal (10 & 40 msec) and need testing/tuning on boards with I2C problems to find the right values. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7978): cx18: explicitly test for XC2028 tunerHans Verkuil
Testing whether xceive_pin is non-zero is not good enough as 0 is a valid value. Instead explicitly test whether the Xceive tuner is used. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7934): cx18: move gpio_dir/val statics to the cx18 struct.Hans Verkuil
The gpio_dir/val statics cannot be global, they are card-specific. Thanks to Andy Walls for pointing this out. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7925): cx18: ensure that the xceive pin is always asserted on init.Hans Verkuil
2008-05-14V4L/DVB (7887): cx18: fix Compro H900 analog support.Hans Verkuil
Tuner, S-Video and Composite are all working for the Compro H900. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
