path: root/drivers/media/video/cx18/cx18-streams.c
2012-08-15[media] rename most media/video pci drivers to media/pciMauro Carvalho Chehab
Rename all PCI drivers with their own directory under drivers/media/video into drivers/media/pci and update the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-06[media] cx18: don't mess with vfd->debugHans Verkuil
This is now controlled by sysfs. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] ivtv/cx18: fix compiler warningsHans Verkuil
media_build/v4l/cx18-alsa-main.c: In function 'cx18_alsa_exit': media_build/v4l/cx18-alsa-main.c:282:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] media_build/v4l/cx18-mailbox.c: In function 'cx18_api_call': media_build/v4l/cx18-mailbox.c:598:6: warning: variable 'state' set but not used [-Wunused-but-set-variable] media_build/v4l/cx18-alsa-pcm.c: In function 'snd_cx18_pcm_capture_open': media_build/v4l/cx18-alsa-pcm.c:156:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] media_build/v4l/cx18-alsa-pcm.c: In function 'snd_cx18_pcm_capture_close': media_build/v4l/cx18-alsa-pcm.c:202:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] media_build/v4l/cx18-alsa-pcm.c: In function 'snd_cx18_pcm_hw_params': media_build/v4l/cx18-alsa-pcm.c:255:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] media_build/v4l/cx18-streams.c: In function 'cx18_stop_v4l2_encode_stream': media_build/v4l/cx18-streams.c:983:16: warning: variable 'then' set but not used [-Wunused-but-set-variable] media_build/v4l/ivtv-ioctl.c: In function 'ivtv_set_speed': media_build/v4l/ivtv-ioctl.c:138:22: warning: variable 's' set but not used [-Wunused-but-set-variable] media_build/v4l/ivtvfb.c: In function 'ivtvfb_init': media_build/v4l/ivtvfb.c:1286:6: warning: variable 'err' set but not used [-Wunused-but-set-variable] media_build/v4l/ivtvfb.c: In function 'ivtvfb_cleanup': media_build/v4l/ivtvfb.c:1306:6: warning: variable 'err' set but not used [-Wunused-but-set-variable] Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-18[media] cx18: Fix videobuf captureSimon Farnsworth
When we moved to 3.0, we found that the cx18 driver was oopsing on close with: NULL pointer deref at: [ 2290.461009] Call Trace: [ 2290.461009] [<c046007b>] ? pm_qos_add_request+0xc/0x6e [ 2290.461009] [<c082631c>] __mutex_lock_common+0x87/0x125 [ 2290.461009] [<f8970e92>] ? cx18_queue_flush+0x31/0x87 [cx18] [ 2290.461009] [<c0436b85>] ? __might_sleep+0x29/0xe4 [ 2290.461009] [<c0826515>] __mutex_lock_slowpath+0x25/0x27 [ 2290.461009] [<c08264b2>] ? mutex_lock+0x2e/0x3b [ 2290.461009] [<c08264b2>] mutex_lock+0x2e/0x3b [ 2290.461009] [<f88d3137>] videobuf_queue_lock+0x13/0x15 [videobuf_core] [ 2290.461009] [<f88d3f86>] __videobuf_free+0xfc/0x112 [videobuf_core] [ 2290.461009] [<f89741e6>] cx18_v4l2_close+0x158/0x172 [cx18] [ 2290.461009] [<c0507522>] ? cpumask_next+0x1a/0x1d [ 2290.461009] [<f88a319d>] v4l2_release+0x35/0x52 [videodev] [ 2290.461009] [<c04f5717>] fput+0x100/0x1a5 [ 2290.461009] [<c04f2e09>] filp_close+0x5c/0x64 [ 2290.461009] [<c04f2e70>] sys_close+0x5f/0x93 [ 2290.461009] [<c082cd5f>] sysenter_do_call+0x12/0x28 Some digging showed that a merge at some previous point partially added broken mmap() support, causing this trace. Remove the broken code completely. On top of that, the calculation in place for "buffer full" depended on UYUV instead of HM12, while our GStreamer code was picking HM12 in some circumstances. Finally, the V4L2_CAP_STREAMING capability was never exposed. Patch it into the YUV encoder node only. Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] cx18: Move spinlock and vb_type initialisation into stream_initSimon Farnsworth
The initialisation of vb_type in serialized_open was preventing REQBUFS from working reliably. Remove it, and move the spinlock into stream_init for good measure - it's only used when we have a stream that supports videobuf anyway. Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] cx18: Clean up mmap() support for raw YUVSimon Farnsworth
The initial version of this patch (commit d5976931639176bb6777755d96b9f8d959f79e9e) had some issues: * It didn't correctly calculate the size of the YUV buffer for 4:2:2, resulting in capture sometimes being offset by 1/3rd of a picture. * There were a lot of variables duplicating information the driver already knew, which have been removed. * There was an in-kernel format conversion - libv4l can do this one, and is the right place to do format conversions anyway. * Some magic numbers weren't properly explained. Fix all these issues, leaving just the move from videobuf to videobuf2 to do. Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Acked-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] cx18: mmap() support for raw YUV video captureSteven Toth
Add support for mmap method streaming of raw YUV video on cx18-based hardware, in addition to the existing support for read() streaming of raw YUV and MPEG-2 encoded video. [simon.farnsworth@onelan.co.uk: I forward-ported this from Steven's original work, done under contract to ONELAN. The original code is at http://www.kernellabs.com/hg/~stoth/cx18-videobuf] Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-13[media] cx18: Fix list BUG for IDX stream, triggerable in cx18_probe() error ↵Andy Walls
clean up, If allocating stream buffers for one of the primary streams (e.g. YUV) failed during card probe, the error path clean up would try to manipulate the yet unitialized IDX stream structures. This caused a BUG due to unitialized list heads. Detect that case and ignore the uninitialized IDX stream. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l2: use new flag to enable core priority handlingHans Verkuil
Rather than guess which driver supports core priority handling, require drivers that do to explicitly set the V4L2_FL_USE_FH_PRIO flag in video_device. Updated the core prio handling accordingly and set the flag in the three drivers that do. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] cx18: Use the control frameworkHans Verkuil
2010-12-29[media] cx18: Only allocate a struct cx18_dvb for the DVB TS streamAndy Walls
The cx18_stream struct contained a struct cx18_dvb for every stream object, most of which were for analog capture. Now we only allocate the cx18_dvb object for the DTV TS stream. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-01[media] cx18: convert to unlocked_ioctlHans Verkuil
Also added locking around snd_cx18_pcm_ioctl as a precaution as requested by Andy Walls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email addressAndy Walls
A trivial change to update my email address from my dead awalls@radix.net address to my current awalls@md.metrocast.net address. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: cx18: switch to new vbi subdev opsHans Verkuil
2010-02-26V4L/DVB: cx18: export more symbols required by cx18-alsaDevin Heitmueller
Export a couple of more symbols required by the cx18-alsa module. This work was sponsored by ONELAN Limited. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13910): cx18: Fix set indextable command to properly select I/P/B ↵Andy Walls
index entries The CX18_CPU_SET_INDEXTABLE command was being called with the wrong number of arguments causing the index table frame type selection mask to be set wrong. Now the IDX stream properly sends entries for I, P, and B frames. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13907): cx18: Perform automatic rotation of very old, unread IDX ↵Andy Walls
buffers According to the v4l2 spec, very old MPEG index entries needs to be discarded in favor of newer index entries. This change ensures the firmware always has buffers for index entries at the expense of the oldest unread buffers. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13906): cx18: Start IDX streams automatically as an internal ↵Andy Walls
associated stream This change starts the IDX stream along with the MPG stream as an internal use (only) stream much like the VBI stream can be started as an internal use stream for inserting sliced VBI packets. The IDX stream is not started automatically with an MPEG strem if the IDX stream is disabled (no buffers allocated) or if sliced VBI insertion is being performed by the cx18 driver. The cx18 driver doing sliced VBI insertion makes the offsets in the IDX stream inaccurate for the final MPEG stream presented to user space. Since fixing the IDX offsets ourselves is not easy and we cannot easily do what ivtv does to fix the offsets, we'll make sliced VBI insertion and MPEG Index capture mutually exclusive for now. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13905): cx18: Allow MPEG index streams to be started and stopped ↵Andy Walls
internally This change allows the IDX stream to be started and stopped as any other stream even though it has no associated device node. This is needed for cx18 driver internal use. Also always tell the CX23418 to generate index entries when an analog capture starts and the IDX stream has had buffers allocated (i.e. is enabled). Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13904): cx18: Fix TS and IDX stream buffer memory leak on module unloadAndy Walls
Fix a long standing memory leak of stream buffers for streams that did not have a struct video_device allocated: namely the TS and IDX streams. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13903): cx18: Encapsulate check for a stream being enabled into an ↵Andy Walls
inline function Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13550): v4l: Use the new video_device_node_name functionLaurent Pinchart
Fix all device drivers to use the new video_device_node_name function. This also strips kernel log messages from the "/dev/" prefix, has the device node location is a userspace policy decision unknown to the kernel. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13432): cx18: Adjust encoder VBI MDL size to be exactly frame's ↵Andy Walls
worth of VBI data Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13430): cx18: Fix YUV capture so that encoder passes a single frame ↵Andy Walls
per transfer Fix YUV capture such that the encoder will pass one frame per transfer. This will allow the application to maintain frame alignment when a transfer from the encoder is missed due to high system latency in service the CX23418 IRQ. Also force YUV buffer sizes to be specified in multiples of 33.75 kB, the smalled amount of buffer sizes need to store a complete set of HM12 4:2:0 macroblocks specifying 32 lines of the frame. A full 60Hz/525 line screen requires 15 * 33.75 kB per frame and a full 50Hz/625 line screen requires 18 * 33.75 kB per frame so the default buffer size is 3 * 33.75 kB, requiring exactly 5 or 6 buffers per MDL respectively. The bytes needed per frame and hence MDL need not be the bytes in an integer number of buffers. However, if frame artifacts are seen with scaled screen sizes, the YUV buffer size can be set 34 kB (33.75 kB) to get rid of the artifacts at the cost of more copies between the kernel and userspace. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13429): cx18: Add Memory Descriptor List (MDL) layer to buffer handlingAndy Walls
Add a Memory Descriptor List (MDL) layer to buffer handling to implement scatter-gather I/O. Currently there is still only 1 buffer per MDL. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13427): cx18: Rename struct cx18_queue.buffers to struct ↵Andy Walls
cx18_queue.depth Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12725): v4l: warn when desired devnodenr is in use & add _no_warn ↵Hans Verkuil
function Warn when the desired device node number is already in use, except when the new video_register_device_no_warn function is called since in some use-cases that warning is not relevant. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12723): ivtv/cx18: replace 'kernel number' with 'device node number'.Hans Verkuil
2009-06-16V4L/DVB (11864): cx18: Complete support for Sliced and Raw VBI for 625 line ↵Andy Walls
systems Finish changes for sliced and raw VBI for 625 line systems. Tested with VPS and WSS being emitted by a PVR-350 in field 1 lines 16 and 23. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11863): cx18: Initial attempt to get sliced VBI working for 625 ↵Andy Walls
line systems Initial changes to get sliced VBI for 625 line system working. This is patch is untested. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11619): cx18: Simplify the work handler for outgoing mailbox commandsAndy Walls
Simplify the way outgoing work handler gets scheduled to send empty buffers back to the firmware for use. Also reduced the memory required for scheduling this outgoing work, by using a single, per stream work object. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11618): cx18: Convert per stream mutex locks to per queue spin locksAndy Walls
To avoid sleeps in providing buffers to user space and in handling incoming buffers from the capture unit, converted the per stream mutex for locking queues to 3 spin locks. There is now a spin lock per queue to increase concurrency when moving buffers around. Also simplified queue manipulations and buffer handling of incoming buffers of data from the capture unit. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11616): cx18: Add a work queue for deferring empty buffer handoffs ↵Andy Walls
to the firmware This change defers sending all CX18_CPU_DE_SET_MDL commands, for a stream with an ongoing capture, by adding a work queue to handle sending such commands when needed. This prevents any sleeps, caused by notifying the firmware of new usable buffers, when a V4L2 application read() is being satisfied or when an incoming buffer is processed by the cx18-NN-in work queue thread. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10854): cx18: Correct comments about vertical and horizontal ↵Andy Walls
blanking timings This change only affects comments. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10759): cx18: Convert GPIO connected functions to act as ↵Andy Walls
v4l2_subdevices Convert GPIO line functions, such a audio routing and device resets, to v4l2_subdevices. This essentially completes the conversion of cx18 to the v4l2_device/v4l2_subdevice framework. No regression testing has taken place as of yet. Also an ivtv legacy bug with GPIO mux routing and going to/from radio mode was commented, but not fixed. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10757): cx18, v4l2-chip-ident: Finish conversion of AV decoder core ↵Andy Walls
to v4l2_subdev Added a new chip identifer to v4l2-chip-ident for the integrated A/V broadcast decoder core internal to the CX23418. Completed separation and encapsulation of the A/V decoder core interface as a v4l2_subdevice. The cx18 driver now compiles and links again. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10756): cx18: Slim down instance handling, build names from ↵Andy Walls
v4l2_device.name Convert card instance handling to a lighter weight mechanism like ivtv. Also convert name strings and debug messages to use v4l2_device.name. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10446): cx18: Finally get sliced VBI working - for 525 line 60 Hz ↵Andy Walls
systems at least Sliced VBI, in the manner that ivtv implements it as a separate data stream, now works for 525 line 60 Hz systems like NTSC-M. It may work for 625 line 50 Hz systems, but I have more engineering work to do, to verify it is operating properly. Sliced data insertion into the MPEG PS should be working, but is untested. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10443): cx18: Use correct line counts per field in firmware API callAndy Walls
The driver was incorrectly setting 0 line counts in a firmware API call to set the maximum amount of lines per field. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10442): cx18: Fixes for enforcing when Encoder Raw VBI params can ↵Andy Walls
be set The Encoder will only allow the Raw VBI parameters, along with a number of other API parameters, to take effect when no analog captures are in progress. These parameters must be set before the first analog capture starts, be it MPEG, VBI, YUV, etc., and cannot be changed until the last one stops. It is not obvious to me what capture channel API parameters are shared and which ones must be set per capture channel, so set them all for every analog capture channel start up. This fixes the driver so that VBI capture can be started up after the MPEG capture is going. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10439): cx18: Clean-up and enable sliced VBI handlingAndy Walls
Removed legacy ivtv state variables, added comments, and cleaned up sliced VBI related code. Enabled sliced VBI. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10280): cx18: Rename structure members: dev to pci_dev and v4l2dev ↵Andy Walls
to video_dev Renamed structure member name to be more specific to type in anticipation of updating to the v4l2_device/v4l2_subdev framework. Too many objects named "dev" and /v4l2_\{0,1\}dev/ would be to confusing. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9894): cx18: Use a known open task handle when setting stream ↵Andy Walls
CX2341x parameters cx18: Use a known open task handle when setting stream CX2341x parameters Sometimes, we might only have VBI or YUV stream open instead of an MPEG stream. Let's make sure we use a valid task handle to perform the CX2341x control settings. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9893): cx18: Convert some list manipulations to emphasize entries ↵Andy Walls
not lists Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9891): cx18 Replace magic number 63 with CX18_MAX_FW_MDLS_PER_STREAMAndy Walls
Removed magic number that referred to firmware limit on the number of MDLs the firmware can maintain for any stream at any one time. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9806): cx18: Enable raw VBI captureAndy Walls
A combined authorship patch from Hans Verkuil and Andy Walls. Raw VBI can now be captured but requires a video capture to be in progress as well. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9805): cx18: Port fix for raw/sliced VBI mixup from ivtv and cx25840Andy Walls
This is a port of the fixes Hans Verkuil made for ivtv/cx25840: The service_set field was used to determine whether raw or sliced VBI was desired. This is incorrect since it is perfectly valid to select sliced VBI with a service_set of 0. Instead the driver should check on VIDIOC_S_FMT whether the type field matches the raw or sliced VBI type. Updated the cx18 driver accordingly, including an additional check in cx18_start_v4l2_encode_stream() that didn't exist in ivtv. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9804): cx18: Avoid making firmware API calls with the queue lock heldAndy Walls
cx18: Avoid making firmware API calls with the queue lock held. The source of MPEG strem corruption when not holding the queue lock was found to be that the MPEG buffer could be retrieved by the user app before it was sync'ed for the host cpu. Incoming buffers are now sync'ed before being put on q_full and releasing the queue lock. We can thus avoid the sometimes lengthy call to the firmware for CPU_DE_SET_MDL while holding the queue lock, so we can get better performance. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9802): cx18: Add module parameters for finer control over buffer ↵Andy Walls
allocations cx18: Add module parameters for finer control over buffer allocations. User now has the option of setting smaller buffers to get lower latency transfers from the encoder. User can also now set the number of buffers used for a stream explicitly. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
