The argument isn't used anymore by the functions, remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, replace the hardcoded module name passed to those
functions by NULL.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the drivers
modified here use.
param
The CX23885 IR controller was reported to cause an interrupt storm
on a TeVii S470 card, but was reported fine on an HVR-1250. Keep
integrated IR disabled by default on CX2388[57] based cards to avoid
a bad user experience in the general case.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
This patch encapsulates access to the PCI_INT_MSK register and
dev->pci_irqmask variable and protects them with a spinlock.
This is needed because both the hard IRQ handler and a workhandler
will need to manipulate the mask to disable the AV_CORE interrupt.
Add initial IR Rx support using the intergrated IR controller in the
A/V core of the CX23885 bridge chip.
This initial support is flawed in that I2C transactions should not
be performed in a hard irq context. That will be fixed in a
follow on patch.
The TeVii S470 support is reported to generate perptual interrupts
that renders a user' system nearly unusable. The TeVii S470 IR
will be disabled by default in a follow on patch.
AV core
Explicitly configure the IR Tx and IR Rx pins to be driven by the
IR Rx and Tx pads from the AV core for CX23888 IR.
For the HVR-1850 and HVR-1290 configure the IR Tx level inversion,
so the Tx LED is off when idle.
The offset in the eeprom data for the 79501 version of the HVR-1250 is at 0xc0
vs. the standard 0x80.
family
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
I tested only tv and composite. Video works fine but no audio.
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
The new hardware design applied for this cards.
Silicon Labs C8051F300 microcontroller is used for LNB power control.
It connected to cx23885 GPIO pins:
GPIO0 - P0.3 data
GPIO1 - P0.2 reset
GPIO2 - P0.1 clk
GPIO3 - P0.0 busy
Tevii S470 based on Montage Technology M88TS2020 digital satellite tuner
and M88DS3000 advanced DVB-S/S2 demodulator.
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
Adds support for cx23885 card Mygica X8558 Pro DMB-TH
Signed-off-by: David T. L. Wong <davidtlwong@gmail.com>
Hauppauge WinTV HVR-1290
The IR on the HVR-1290 is identical to that of the HVR-1850
WinTV-HVR1290
Signed-off-by: David T.L. Wong <davidtlwong@gmail.com>
notification handling
Add integrated IR subdevice interrupt and notification handling. This is in
preparation of input keypress handling changes for the cx23885 module.
Signed-off-by: Andy Walls <awalls@radix.net>
running for IR
For the IR controller on the CX23888 to work for the HVR-1850 and in
general, the A/V core must be initialized to get the VID_CLK going.
The VID_CLK is the timing reference for the CX23888's integrated
IR controller.
integrated IR controller
This change adds a skeletal implementation of a v4l2_subdevice to provide
encapsulation and abstraction of the CX23888's integrated consumer infrared
controller. This change also instantiates the cx23888_ir subdev for the
HVR-1850 which has IR hardware physically wired up to a CX23888.
The cx23888_ir subdev code is being written with long-term objectives to:
1. port it to the cx25840 module for the CX2584x, CX2583x, CX23885, & CX231xx
IR controllers
2. possibly port it to the cx18 module for the CX23418 IR controller
3. have the IR subdevice accessed abstractly in the cx23885 module, so the
driver can ignore the difference between the CX23885 and CX23888.
Adding Compro VideoMate E800 (DVB-T part only)
Cc: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Vladimir Geroy <geroin22@yandex.ru>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Rewrite v4l2_i2c_new_subdev as a simplified version of v4l2_i2c_new_subdev_cfg
and remove v4l2_i2c_new_probed_subdev and v4l2_i2c_new_probed_subdev_addr.
This simplifies this API substantially.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
cx23885: Add support for ATSC/QAM on Hauppauge HVR-1850
Signed-off-by: Steven Toth <stoth@kernellabs.com>
... improves readability and routes the calls through a specific single point.
The encoder driver has hardcoded GPIO bits set for the HVR1800, regardless
of whether it's being used by a HVR1800 or not. I've implemented some generic
GPIO manipulation routines and I'm calling them only when appropriate.
cx23885: add card Magic-Pro ProHDTV Extreme 2 PCI-E.
This patch add cx23885 support for card "Mygica X8506 DMB-TH".
It should work on "Magic-Pro ProHDTV Extreme" as well, as they are
same hardware with different branding.
Sign-off-by: David T.L. Wong <davidtlwong@gmail.com>
WinTV-HVR1255
WinTV-HVR1275
WinTV-HVR1270
The patch means the board will be recognised, and the parts brought
out of reset correctly. This patches depends on the centralized GPIO
patch to be merged. What's missing before the HVR-1270 will function
for DTV? The model# needs to be added to avoid 'unknown model'
output and the LG3305/Tuner need to be attached in cx23885-dvb.c
Two fixes for DViCO FusionHDTV DVB-T Dual Express:
* Reset correct tuner when reinitializing xc3028.
* Disable the I2C gate control to avoid locking up the I2C bus.
Tested-by: John Knops <jknops@australiaonline.net.au>
Reviewed-by: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Christopher Pascoe <linuxdvb@itee.uq.edu.au>
Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org>
to new_(probed)_subdev
The functions v4l2_i2c_new_subdev and v4l2_i2c_new_probed_subdev relied on
i2c_get_adapdata to return the v4l2_device. However, this is not always
possible on embedded platforms. So modify the API to pass the v4l2_device
pointer explicitly.
core->init.
The init callback was used in several places to load firmware. Make a separate
load_fw callback for that. This makes the code a lot more understandable.
Convert this driver to v4l2_subdev. Note that currently the only card with
analog support in this driver is the HVR-1800. The analog tuner support in
this driver is limited to what is needed for this board. When analog support
is added for other cards, then the tuner load code will probably have to be
expanded to take care of those boards. For example, there is currently no
support for either radio tuners or tda9887 demods.
I'd like to thank Steven Toth for testing this on his HVR-1800.
Tested-by: Steven Toth <stoth@linuxtv.org>
Add support for NetUP Dual DVB-S2 CI card
The card based on cx23885 PCI-e bridge, CiMax SP2 Common Interface chips,
STM lnbh24 LNB power chip, stv6110 tuners and stv0900 demodulator.
http://www.linuxtv.org/wiki/index.php/NetUP_Dual_DVB_S2_CI
Signed-off-by: Igor M. Liplianin <liplianin@netup.ru>
DVBWorld DVBS2 PCI-e 2005 card contains cx23885 PCI-e bridge
and cx24116 demodulator.
http://www.linuxtv.org/wiki/index.php/DVBWorld_DVB-S2_2005_PCI-Express_Card
The card tested by me (Igor).
TeVii S470 DVB-S2 PCI-e card contains cx23885 PCI-e bridge
http://www.linuxtv.org/wiki/index.php/TeVii_S470
TurboSight TBS6920 DVB-S2 PCI-e card contains cx23885 PCI-e bridge
http://www.linuxtv.org/wiki/index.php/TBS_6920
Add Compro VideoMate E650F (DVB-T part only).
The card based on cx23885 PCI-Express chip, xc3028 tuner and ce6353 demodulator.
cx23885: Checkpatch compliance
Signed-off-by: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
This patch is on behalf of Stephen Backway <stev391@email.com>, and
represents two patches I received (and some subsequent whitespace
cleanup I had due to how I pulled the patches).
From the original author:
a) Add DVB support for the Leadtek Winfast PxDVR3200 H.
b) The tuner callback previously checked the command 3 times:
1) To see if it was the XC2028_RESET_CLK
2) To see if it was not the XC2028_RESET_TUNER
3) To see if it was the XC2028_RESET_TUNER
This patch removes the third check.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Stephen Backway <stev391@email.com>
function.
Code reduction. Tuner callback now assumes that tsport is passed as the void arg.
From Chris Pascoe <c.pascoe@itee.uq.edu.au>
Support IR remote on FusionHDTV DVB-T Dual Express
Add support for the DViCO FusionHDTV DVB-T Dual Express card, based on
work by Chris Pascoe and Stephen Backway.
callback
The Hauppauge HVR1400 and HVR1500 can now use the common cx23885 tuner
callback.
