Rename all PCI drivers with their own directory under
drivers/media/video into drivers/media/pci and update the
building system.
The card is similar to TeVii s470, but has different LNB power control.
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
First in a series of patches that adds support to the cx23885 driver
for CX23888 analog video handling. Raw and MPEG video support is
being added for the HVR1850 driver in the patch, and the following
series of patches.
Some basic cx23885 driver cleanup. Partly to add HVR1850 support
and partly to allow -417.c V4L2 calls to be routed through thr
driver core and handled in a single place.
Make a number of core driver functions available to the -417.c
driver to streamline the driver.
Add the analog tuner ops definition so we can reach/tune the
hardware when we need to. Added the tff field so 888 based cards
(which have a weird field ordering issue) can be accomodated
and worked around in the driver.
Signed-off-by: Steven Toth <stoth@kernellabs.com>
changes
A handlful of coding style issue cleaned up in the following patches.
[stoth@kernellabs.com: add it to the makefile and fix snd_card binding]
[liplianin@netup.ru: videobuf: Remove the videobuf_sg_dma_map/unmap functions]
Signed-off-by: Mijhail Moreyra <mijhail.moreyra@gmail.com>
Signed-off-by: Igor M. Liplianin <liplianin@netup.ru>
All the modified drivers didn't have any version increment since
Jan, 1 2011. Several of them didn't have any version increment
for a long time, even having new features and important bug fixes
happening.
As we're now filling the QUERYCAP version with the current Kernel
Release, we don't need to maintain a per-driver version control
anymore. So, let's just use the default.
In order to preserve the Kernel module version history, a
KERNEL_VERSION() macro were added to all modified drivers, and
the extraver number were incremented.
I opted to preserve the per-driver version control to a few
pwc, pvrusb2, s2255, s5p-fimc and sh_vou.
A few drivers are still using the legacy way to handle ioctl's.
So, we can't do such change on them, otherwise, they'll break.
Those are: uvc, et61x251 and sn9c102.
The rationale is that the per-driver version control seems to be
actively maintained on those.
Yet, I think that the better for them would be to just use the
default version numbering, instead of doing that by themselves.
While here, removed a few uneeded include linux/version.h
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
This reverts commit e38030f3ff02684eb9e25e983a03ad318a10a2ea.
MSI flat-out doesn't work right on cx2388x devices yet. There are now
multiple reports of cards that hard-lock systems when MSI is enabled,
including my own HVR-1250 when trying to use its built-in IR receiver.
Disable MSI and it works just fine. Similar for another user's HVR-1270.
Issues have also been reported with the HVR-1850 when MSI is enabled,
and the 1850 behavior sounds similar to an as-yet-undiagnosed issue I've
seen with an 1800.
CC: stable@kernel.org
CC: Steven Toth <stoth@kernellabs.com>
CC: Kusanagi Kouichi <slash@ac.auone-net.jp>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Andy Walls <awalls@md.metrocast.net>
pci_setup_device() has saved the PCI revision in the pci_dev
struct since Linux 2.6.23. Use it.
Cc: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
cx23885_board structure
This is needed for multifrontend support.
NetUP Dual DVB-T/C CI RF card has frontends connected to port B & C
Each frontend has two switchable cores - DVB-T & DVB-C
There is two external I2C buses in cx23885 chip.
Currently, analog tuners supported for second I2C bus only
In NetUP Dual DVB-T/C CI RF card tuners connected to first bus
So, in order to support analog tuners sitting on first bus
we need modifications.
The card based on cx23885 PCI-e brige. Altera FPGA for CI,
multistandard demods stv0367 from STM for QAM & OFDM, Xcieve xc5000 tuners
and additional cx25840 for second analog input.
cx23885_dev_checkrevision()
It was missing the `break'.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=18672
Reported-by: Igor <i2g2r2@gmail.com>
Cc: stable@kernel.org
videobuf_waiton() must unlock and relock ext_lock if it has to wait.
For that to happen it needs the videobuf_queue pointer.
Don't attempt to unlock/relock q->ext_lock unless it was locked in the
first place.
vb->state has to be protected by a spinlock to be safe.
This patch is based on code from Mauro Carvalho Chehab <mchehab@redhat.com>.
[mchehab@redhat.com: add extra argument to a few missing places]
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Interrupts from the AV Core are best handled by a workqueue handler
since many I2C transactions are required to service the AV Core
interrupt. The AV_CORE PCI interrupt is disabled by the IRQ handler
and reenabled when the work handler is finished.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
This patch encapsulates access to the PCI_INT_MSK register and
dev->pci_irqmask variable and protects them with a spinlock.
This is needed because both the hard IRQ handler and a workhandler
will need to manipulate the mask to disable the AV_CORE interrupt.
Add initial IR Rx support using the intergrated IR controller in the
A/V core of the CX23885 bridge chip.
This initial support is flawed in that I2C transactions should not
be performed in a hard irq context. That will be fixed in a
follow on patch.
The TeVii S470 support is reported to generate perptual interrupts
that renders a user' system nearly unusable. The TeVii S470 IR
will be disabled by default in a follow on patch.
The CX2584x and related cores are multifunction subdevices with a number
of internal blocks that act as interrupt sources. Move the v4L2_subdev
interrupt_service_routine callback from v4l_subdev_ir_ops to
v4l2_subdev_core_ops, as the video and audio blocks of a CX2584x and
related cores can generate interrupts along with the IR block. This
change also makes sense for other subdev's that generate interrupts and
do not have an IR block.
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
Instead of creating dirty wrappers around videobuf_dma_map/unmap that
create a dummy videobuf_queue structure, modify videobuf_dma_map/unmap
to take a device pointer argument and use it directly. The
videobuf_sg_dma_map/unmap then become unused and can be removed.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Fix all device drivers to use the video_drvdata function instead of
maintaining a local list of minor to private data mappings. Call
video_set_drvdata to register the driver private pointer when not
already done.
Where applicable, the local list of mappings is completely removed when
it becomes unused.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
The new hardware design applied for this cards.
Silicon Labs C8051F300 microcontroller is used for LNB power control.
It connected to cx23885 GPIO pins:
GPIO0 - P0.3 data
GPIO1 - P0.2 reset
GPIO2 - P0.1 clk
GPIO3 - P0.0 busy
Tevii S470 based on Montage Technology M88TS2020 digital satellite tuner
and M88DS3000 advanced DVB-S/S2 demodulator.
Trivial patch which adds the __init/__exit macros to the module_init/
module_exit functions of the following drivers in media video:
drivers/media/video/ivtv/ivtv-driver.c
drivers/media/video/cx18/cx18-driver.c
drivers/media/video/davinci/dm355_ccdc.c
drivers/media/video/davinci/dm644x_ccdc.c
drivers/media/video/saa7164/saa7164-core.c
drivers/media/video/saa7134/saa7134-core.c
drivers/media/video/cx23885/cx23885-core.c
Cc: Hermann Pitton <hermann-pitton@arcor.de>
Acked-by: Steven Toth <stoth@kernellabs.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Andy Walls <awalls@radix.net>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Muralidharan Karicheri <m-karicheri2@ti.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Upcoming I2C v4l2_subdev drivers need a way to control the subdevice
power state from the core. This use case is already partially covered by
the tuner s_standby operation, but no way to explicitly come back from
the standby state is available.
Rename the tuner s_standby operation to core s_power, and fix tuner
drivers accordingly. The tuner core will call s_power(0) instead of
s_standby(). No explicit call to s_power(1) is required for tuners as
they are supposed to wake up from standby automatically.
[mchehab@redhat.com: CodingStyle fix]
HVR-1850
This changes adds IR Rx keypress input event handling to the CX23885 module.
This change specifically only adds input handling for IR devices implemented as
v4l2_subdevices, using only the pulse width mode (for now), and only with
RC-5 remotes. The V4L-DVB infrastructure is missing too much to support RC-6
mode 6A as used in many media center remotes. The grey Hauppauge RC-5 remote
and HVR-1850 IR receiver work now.
Signed-off-by: Andy Walls <awalls@radix.net>
notification handling
Add integrated IR subdevice interrupt and notification handling. This is in
preparation of input keypress handling changes for the cx23885 module.
integrated IR controller
This change adds a skeletal implementation of a v4l2_subdevice to provide
encapsulation and abstraction of the CX23888's integrated consumer infrared
controller. This change also instantiates the cx23888_ir subdev for the
HVR-1850 which has IR hardware physically wired up to a CX23888.
The cx23888_ir subdev code is being written with long-term objectives to:
1. port it to the cx25840 module for the CX2584x, CX2583x, CX23885, & CX231xx
IR controllers
2. possibly port it to the cx18 module for the CX23418 IR controller
3. have the IR subdevice accessed abstractly in the cx23885 module, so the
driver can ignore the difference between the CX23885 and CX23888.
The card uses the same cx23885 gpio lines for two adapters.
In case of there is several cards in system we must implement
gpio mutex per cx23885 chip.
Signed-off-by: Abylay Ospan <aospan@netup.ru>
cx23885: Modify hardware revision detection for newer silicon
The encoder driver has hardcoded GPIO bits set for the HVR1800, regardless
of whether it's being used by a HVR1800 or not. I've implemented some generic
GPIO manipulation routines and I'm calling them only when appropriate.
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
The GPIO's on the product can be in one of three places. To date we've
mainly used the GPIO's on the bridge itself, and once on the encoder.
Rather than having the complexity of multiple GPIO writes/reads from
isolated placed in the driver we'll route them through this function,
so we can make intelligent decisions about 1) Where the GPIO lives
and 2) Whether it conflicts (based on board) with some other function
to avoid bugs.
cx23885: Don't assume GPIO interrupts are cam related.
Signed-off-by: Steven Toth <stoth@linuxtv.org>
s_standby is only used to put the tuner in powersaving mode, so move it
from core to tuner.
Convert this driver to v4l2_subdev. Note that currently the only card with
analog support in this driver is the HVR-1800. The analog tuner support in
this driver is limited to what is needed for this board. When analog support
is added for other cards, then the tuner load code will probably have to be
expanded to take care of those boards. For example, there is currently no
support for either radio tuners or tda9887 demods.
I'd like to thank Steven Toth for testing this on his HVR-1800.
Tested-by: Steven Toth <stoth@linuxtv.org>
The new support for the CX23885_BOARD_NETUP_DUAL_DVBS2_CI board broke the
existing boards. Interrupts for the netup part were enabled and handled
without testing whether the current board actually had a netup -> instant
and fatal crash.
I've added tests to do this only for the CX23885_BOARD_NETUP_DUAL_DVBS2_CI
board.
Reviewed-by: Michael Krufky <mkrufky@linuxtv.org>
Add support for NetUP Dual DVB-S2 CI card
The card based on cx23885 PCI-e bridge, CiMax SP2 Common Interface chips,
STM lnbh24 LNB power chip, stv6110 tuners and stv0900 demodulator.
http://www.linuxtv.org/wiki/index.php/NetUP_Dual_DVB_S2_CI
To optimise data storage redundant vars are removed.
Signed-off-by: Darron Broad <darron@kewl.org>
cx23885: Checkpatch compliance
This allows some cardcoded functions to be more flexible, and paves
the way for any future cards that may have MFE support. Better to add it
now when the MFE patches is fresh in peoples mind, rather than 12 months
from now when new cards appear.
Bug: the tree generated an oops when the cx23885 was laoded. This avoids
the oops by ensuring the mutex is correctly initialised before it's used.
v4l: replace __FUNCTION__ with __func__
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
I need this so I can better isolate my linux email from my
corporate email.
In a previous patch I merged both memory maps into a single struct, believing
that they could be combined. We've since found problems with streaming
multiple channels on the 885. I'm restoring the multiple memory map structs
- in line with the windows driver.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This may be cx23885 chip specific and may not work on the cx23887.
Analog and mpeg encoder streaming are still to be tested.
register.
Don't display the register when it's not appropriate for the specific port.
VIDB/TS1 did not stream.
Certain DVB cards that have demodulators on TS1/VIDB were not streaming packets.
This ensure the pin directions on PAD_CTRL are set correctly, solving the issue.
