Two xc5000 tuners connected to same i2c bus.
Experiments shows that situation when one tuner is not initialized
while other is tuned to channel causes TS errors.
Signed-off-by: Abylay Ospan <aospan@netup.ru>
It decreases I2C traffic.
Signed-off-by: Igor M. Liplianin <liplianin@netup.ru>
The card based on cx23885 PCI-e brige. Altera FPGA for CI,
multistandard demods stv0367 from STM for QAM & OFDM, Xcieve xc5000 tuners
and additional cx25840 for second analog input.
Add an ext_lock argument to the videobuf init functions. This allows
drivers to pass the vdev->lock pointer (or any other externally held lock)
to videobuf. For now all drivers just pass NULL.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com>
DVB_MAX_ADAPTERS limit
Fix kernel Oops when number of NetUP Dual DVB-S2-CI cards more than
DVB_MAX_ADAPTERS limit.
[mchehab@redhat.com: move the return to the proper place]
This patch retrieve the correct mac address from the eeprom for TeVii
S470 card.
Signed-off-by: Pierre Gronlier <pierre.gronlier@gmail.com>
Cc: Steven Toth <stoth@kernellabs.com>
Use the %pM kernel extension to display the MAC address.
Improves ATBM8830 reception by using per card AGC configuration rather
than register default.
Signed-off-by: David T. L. Wong <davidtlwong@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (345 commits)
V4L/DVB (13542): ir-keytable: Allow dynamic table change
V4L/DVB (13541): atbm8830: replace 64-bit division and floating point usage
V4L/DVB (13540): ir-common: Cleanup get key evdev code
V4L/DVB (13539): ir-common: add __func__ for debug messages
V4L/DVB (13538): ir-common: Use a dynamic keycode table
V4L/DVB (13537): ir: Prepare the code for dynamic keycode table allocation
V4L/DVB (13536): em28xx: Use the full RC5 code on HVR-950 Remote Controller
V4L/DVB (13535): ir-common: Add a hauppauge new table with the complete RC5 code
V4L/DVB (13534): ir-common: Remove some unused fields/structs
V4L/DVB (13533): ir: use dynamic tables, instead of static ones
V4L/DVB (13532): ir-common: Add infrastructure to use a dynamic keycode table
V4L/DVB (13531): ir-common: rename the debug routine to allow exporting it
V4L/DVB (13458): go7007: subdev conversion
V4L/DVB (13457): s2250: subdev conversion
V4L/DVB (13456): s2250: Change module structure
V4L/DVB (13528): em28xx: add support for em2800 VC211A card
em28xx: don't reduce scale to half size for em2800
em28xx: don't load audio modules when AC97 is mis-detected
em28xx: em2800 chips support max width of 640
V4L/DVB (13523): dvb-bt8xx: fix compile warning
Fix up trivial conflicts due to spelling fixes from the trivial tree in
Documentation/video4linux/gspca.txt
drivers/media/video/cx18/cx18-mailbox.h
The new hardware design applied for this cards.
Silicon Labs C8051F300 microcontroller is used for LNB power control.
It connected to cx23885 GPIO pins:
GPIO0 - P0.3 data
GPIO1 - P0.2 reset
GPIO2 - P0.1 clk
GPIO3 - P0.0 busy
Tevii S470 based on Montage Technology M88TS2020 digital satellite tuner
and M88DS3000 advanced DVB-S/S2 demodulator.
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
Adds support for cx23885 card Mygica X8558 Pro DMB-TH
WinTV-HVR1290
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
It has positive effect for NetUP Dual DVB-S2 CI card.
Upcoming I2C v4l2_subdev drivers need a way to control the subdevice
power state from the core. This use case is already partially covered by
the tuner s_standby operation, but no way to explicitly come back from
the standby state is available.
Rename the tuner s_standby operation to core s_power, and fix tuner
drivers accordingly. The tuner core will call s_power(0) instead of
s_standby(). No explicit call to s_power(1) is required for tuners as
they are supposed to wake up from standby automatically.
[mchehab@redhat.com: CodingStyle fix]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: David T.L. Wong <davidtlwong@gmail.com>
override set_frontend to allow rf input path switching on the HVR1275
override frontend ioctls
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Adding Compro VideoMate E800 (DVB-T part only)
Cc: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Vladimir Geroy <geroin22@yandex.ru>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
standby mode
Enable the standby mode optimization to disable the tda18271
slave tuner output / loop thru options when in low power mode
cx23885: Add support for ATSC/QAM on Hauppauge HVR-1850
Signed-off-by: Steven Toth <stoth@kernellabs.com>
cx23885: add card Magic-Pro ProHDTV Extreme 2 PCI-E.
add FIXME comment to indicate that the set_frontend override is a
temporary hack. This will be done a better way in the next kernel.
Use separate RF input spigots for Antennae and Cable.
Reviewed-by: Steven Toth <stoth@kernellabs.com>
Ensure that we're programming the tda18271 tuner with the correct
IF frequencies to match the programming of the TDA10048 DVB-T demod
for the HVR1200 and HVR1700 products.
This patch add cx23885 support for card "Mygica X8506 DMB-TH".
It should work on "Magic-Pro ProHDTV Extreme" as well, as they are
same hardware with different branding.
Sign-off-by: David T.L. Wong <davidtlwong@gmail.com>
WinTV-HVR1210
Steve missed the HVR1210 config struct for the TDA10048 in his IF freq patch.
cx23885: Ensure we specify I/F's for all bandwidths
devices
WinTV-HVR1255
WinTV-HVR1275
WinTV-HVR1270
Signed-off-by: Steven Toth <stoth@linuxtv.org>
The boards control struct wasn't updated when (presumably) all of the
other drivers migrated from using scode_table to specifying the demod.
Two fixes for DViCO FusionHDTV DVB-T Dual Express:
* Reset correct tuner when reinitializing xc3028.
* Disable the I2C gate control to avoid locking up the I2C bus.
Tested-by: John Knops <jknops@australiaonline.net.au>
Reviewed-by: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Christopher Pascoe <linuxdvb@itee.uq.edu.au>
Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org>
s_standby is only used to put the tuner in powersaving mode, so move it
from core to tuner.
Convert this driver to v4l2_subdev. Note that currently the only card with
analog support in this driver is the HVR-1800. The analog tuner support in
this driver is limited to what is needed for this board. When analog support
is added for other cards, then the tuner load code will probably have to be
expanded to take care of those boards. For example, there is currently no
support for either radio tuners or tda9887 demods.
I'd like to thank Steven Toth for testing this on his HVR-1800.
Tested-by: Steven Toth <stoth@linuxtv.org>
The new support for the CX23885_BOARD_NETUP_DUAL_DVBS2_CI board broke the
existing boards. Interrupts for the netup part were enabled and handled
without testing whether the current board actually had a netup -> instant
and fatal crash.
I've added tests to do this only for the CX23885_BOARD_NETUP_DUAL_DVBS2_CI
board.
Reviewed-by: Michael Krufky <mkrufky@linuxtv.org>
Add support for NetUP Dual DVB-S2 CI card
The card based on cx23885 PCI-e bridge, CiMax SP2 Common Interface chips,
STM lnbh24 LNB power chip, stv6110 tuners and stv0900 demodulator.
http://www.linuxtv.org/wiki/index.php/NetUP_Dual_DVB_S2_CI
DVBWorld DVBS2 PCI-e 2005 card contains cx23885 PCI-e bridge
and cx24116 demodulator.
http://www.linuxtv.org/wiki/index.php/DVBWorld_DVB-S2_2005_PCI-Express_Card
The card tested by me (Igor).
TeVii S470 DVB-S2 PCI-e card contains cx23885 PCI-e bridge
http://www.linuxtv.org/wiki/index.php/TeVii_S470
