path: root/drivers/media/video/cx25840
2011-03-02[media] cx25840: fix probing of cx2583x chipsSven Barth
Fix the probing of cx2583x chips, because two controls were clustered that are not created for these chips. This regression was introduced in 2.6.36. Signed-off-by: Sven Barth <pascaldragon@googlemail.com> Signed-off-by: Andy Walls <awalls@md.metrocast.net> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] v4l2-subdev: remove core.s_config and v4l2_i2c_new_subdev_cfg()Hans Verkuil
The core.s_config op was meant for legacy drivers that needed to work with old pre-2.6.26 kernels. This is no longer relevant. Unfortunately, this op was incorrectly called from several drivers. Replace those occurences with proper i2c_board_info structs and call v4l2_i2c_new_subdev_board. After these changes v4l2_i2c_new_subdev_cfg() was no longer used, so remove that function as well. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (255 commits) [media] radio-aimslab.c: Fix gcc 4.5+ bug [media] cx25821: Fix compilation breakage due to BKL dependency [media] v4l2-compat-ioctl32: fix compile warning [media] zoran: fix compiler warning [media] tda18218: fix compile warning [media] ngene: fix compile warning [media] DVB: IR support for TechnoTrend CT-3650 [media] cx23885, cimax2.c: Fix case of two CAM insertion irq [media] ir-nec-decoder: fix repeat key issue [media] staging: se401 depends on USB [media] staging: usbvideo/vicam depends on USB [media] soc_camera: Add the ability to bind regulators to soc_camedra devices [media] V4L2: Add a v4l2-subdev (soc-camera) driver for OmniVision OV2640 sensor [media] v4l: soc-camera: switch to .unlocked_ioctl [media] v4l: ov772x: simplify pointer dereference [media] ov9640: fix OmniVision OV9640 sensor driver's priv data retrieving [media] ov9640: use macro to request OmniVision OV9640 sensor private data [media] ivtv-i2c: Fix two warnings [media] staging/lirc: Update lirc TODO files [media] cx88: Remove the obsolete i2c_adapter.id field ...
2011-01-03[media] cx25840: Prevent device probe failure due to volume control ERANGE errorAndy Walls
This patch fixes a regression that crept into 2.6.36. The volume control scale in the cx25840 driver has an unusual mapping from register values to v4l2 volume control values. Enforce the mapping limits, so that the default volume control setting does not fall out of bounds to prevent the cx25840 module device probe from failing. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Cc: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] rc: rename the remaining things to rc_coreMauro Carvalho Chehab
The Remote Controller subsystem is meant to be used not only by Infra Red but also for similar types of Remote Controllers. The core is not specific to Infra Red. As such, rename: - ir-core.h to rc-core.h - IR_CORE to RC_CORE - namespace inside rc-core.c/rc-core.h To be consistent with the other changes. No functional change on this patch. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-25[media] IR: initialize ir_raw_event in few more driversMaxim Levitsky
Few drivers still have assumption that ir_raw_event consists of duration and pulse flag. Fix that. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] cx25840: Remove a now unused variableMauro Carvalho Chehab
drivers/media/video/cx25840/cx25840-core.c: In function ‘cx25840_s_frequency’: drivers/media/video/cx25840/cx25840-core.c:1563: warning: unused variable ‘state’ Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] Add support for AUX_PLL on cx2583x chipsSven Barth
This adds support for the AUX_PLL in cx2583x chips which is available in those although the audio part of the chip is not. The AUX_PLL is used at least by Terratec in their Grabster AV400 device. Signed-off-by: Sven Barth <pascaldragon@googlemail.com> Acked-by: Mike Isely <isely@pobox.com> Reviewed-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: cx25840: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: cx25840: Fix typo in volume control initialization: 65335 vs. 65535Andy Walls
The wrong value for the volume control limit, 65335 vs. 65535, prevents proper cx25840 v4l2_subdevice initialization. Reported-by: Igor M. liplianin <liplianin@me.by> Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: cx25840: convert to the new control frameworkHans Verkuil
2010-08-08V4L/DVB: cx25840/ivtv: replace ugly priv control with s_configHans Verkuil
The cx25840 used a private control CX25840_CID_ENABLE_PVR150_WORKAROUND to be told whether to enable a workaround for certain pvr150 cards. This is really config data that it needs to get at load time. Implemented this in cx25840 and ivtv. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: v4l2_subdev: Get rid of now unused IR pulse width definesAndy Walls
2010-08-08V4L/DVB: cx23885, cx25840: Change IR measurment records to use struct ↵Andy Walls
ir_raw_event The CX23885 and CX25840 modules were using their own simple IR pulse width measurement record type which required conversion when passing to the new IR core. This change makes that record type consistent with the new IR core and removes a data conversion. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: cx23885, cx25840: Report the actual length of an IR Rx timeout eventAndy Walls
Instead of reporting an IR Rx timeout event as a ridiculously long space, report it as a space of the lenght of the timeout. This partially fixes operation with LIRC without breaking interoperation with the in kernel decoders. The gaps lengths reported to LIRC are still not real however. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: cx23885, cx25840: Report IR max pulse width regardless of mod/demod useAndy Walls
Compute and report the maximum IR pulse measurment width, even if we are set to perform carrier modulation or demodulation and the number is fixed by the carrier freq. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: cx25840: Add support for CX2388[57] A/V core integrated IR controllersAndy Walls
This patch is primarily a port of the integrated IR controller code in cx23885/cx23888-ir.c. Right now, only the CX2388[57] AV core will really try to set up IR. This IR support, by design, still requires the bridge driver to do final IO pin mux configuration and setup of the IR controller parameters. For the CX2388[578] chips, enabling the AV Core for IR also starts sending Audio and Video interrupts to the bridge driver. For CX2388[578] chips audio and video interrupts are ignored and acknowledged when they happen. IR interrupt handling and status logging is exluded for the CX23888 which does not have an IR controller on the AV core. Note that experimentation reveals that the IR irq enables on the CX23885 have an inverted logic sense. The CX23887 likely suffers from the same quirk. For these chips, those irq enable bits are handled as interrupt disables. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: cx25840: Add s_io_pin_config core subdev ops for the CX2388[578]Andy Walls
Add s_io_pin_config core subdev op for the CX2388[578] AV cores. This is complete for IR_RX, IR_TX, GPIOs 16,19-23, and IRQ_N. It likely needs work for the I2S signal direction. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: cx25840: Make cx25840 i2c register read transactions atomicAndy Walls
There was a small window between writing the cx25840 register address over the i2c bus and reading the register contents back from the cx25840 device that the i2c adapter lock was released. This change ensures the adapter lock is not released until the register read is done. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: cx24850: remove obsolete g/s_fmt opsHans Verkuil
2010-06-01V4L/DVB: cx25840: add support for s_mbus_fmtHans Verkuil
2010-05-19V4L/DVB: cx18/cx25840/saa7115/tvp5150: remove vbi support from s_fmtHans Verkuil
Now that s_fmt is no longer used for VBI format setup in subdevs, remove the VBI support from s_fmt. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: cx25840: support new vbi ops to set/get VBI formatHans Verkuil
Also removed the bogus zeroing of fmt.sliced when setting up raw VBI. Switching between raw and sliced VBI changed in 2.6.28 and this memset should have been removed at that time. It was never noticed because the bridge driver will fill in the fmt.vbi values anyway. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: v4l: move vbi-specific video ops to a new vbi ops structHans Verkuil
Only a relatively small number of video receivers and transmitters actually support VBI. So start moving the vbi specific ops to an ops struct of their own. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: cx25840: Fix composite detectionKusanagi Kouichi
If CX25840_VIN1_CH1 and the like is used, input is not detected as composite. Their value is 0x800000XX and CX25840_COMPONENT_ON is 0x80000200. So 739 else if ((vid_input & CX25840_COMPONENT_ON) == 0) this condition never be true. Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Reviewed-by: Andy Walls <awalls@radix.net> Acked-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: cx25840, v4l2-subdev, ivtv, pvrusb2: Fix ivtv/cx25840 tinny audioAndy Walls
This change attempts to fix the ivtv tinny audio problem by keeping digitizer to encoder audio clocks running, while disabling the video clocks as needed to avoid unpredictable PCI bus hangs. To accomplish this, for the cx25840 module enabling of audio streaming had to be separated from enabling video streaming, requiring an additional v4l2_subdev_audio_op and calls to this new op in the pvrusb2 and ivtv drivers. The cx231xx and cx23885 driver use the cx25840 module for affecting only video on s_stream calls, so those drivers needed no change. The CX23418 hardware does not exhibit either the tinny audio problem nor the PCI bus hang, so the cx18 driver did not need corresponding changes. CX2341[56] based cards that are not using the CX2584x family of chips do not seem to be affected by the tinny audio problem, and this change should not affect how they are configured. It will delay their first capture by starting by another 300 msec though. Many thanks go to Argus <pthorn-ivtvd@styx2002.no-ip.org> and Martin Dauskardt <martin.dauskardt@gmx.de> whose persistent testing and investigation of this problem will hopefully fix this problem once and for all for many ivtv users. Reported-by: Martin Dauskardt <martin.dauskardt@gmx.de> Reported-by: Argus <pthorn-ivtvd@styx2002.no-ip.org> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13232): cx25840 6.5MHz carrier detection fixesAleksandr V. Piskunov
cx25840: Disable 6.5MHz carrier autodetection for PAL, always assume its DK. Only try to autodetect 6.5MHz carrier for SECAM if user accepts both system DK and L. Signed-off-by: Aleksandr V. Piskunov <alexandr.v.piskunov@gmail.com> Reviewed-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13206): cx25840: add component supportDavid T.L. Wong
Signed-off-by: David T.L. Wong <davidtlwong@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13092): cx25840: Improvements to the cx23885/7/8 chip detection ↵Steven Toth
mechanism. The prior mechanism wasn't reliable with the cx23887. This new mechanism tests correctly against cx23885, 7 and 8 based products. Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13090): cx25840: Init PLLs properly for CX2388[578] A/V coresAndy Walls
The SYS and AUX PLLs need to be initialized to different values based on the chip: CX23885, CX23887, CX23888, as each uses a different crystal frequency: 28.6363 MHz, 25.0 MHz, 50.0 MHz. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13089): cx25840: Separate set_audclk_freq functionality for the ↵Andy Walls
different chips Separate out the set_audclk_freq() function into separate functions for the four families of cores. These cores all use slightly different sample clock schemes and may be assuming slightly (+/- 3 Hz) different reference frequencies. The code resuse was not worth the maintenance and testing headache of have all chips use the same function peppered with conditional logic. Added comments on how PLL and SRC parameters values are computed. Fixed a few bugs related to the shared code having a large number of conditional statements. Noted inconsistencies with FIXME in the comments. This is done in preparation for getting the CX2388[578] PLL/clock setting logic cleaned up for CX23888 analog video and IR (which need the VID PLL set right). Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13088): cx25840: Convert chip/core family checks to static inline ↵Andy Walls
functions Change logic to check for various chip or core families to inline functions. Checks for specific chips should be made against the state->id field now. This is in preparation for chip/core specific code for setting up PLLs for the CX2388[578] family of cores, that all run with different crystal frequencies. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13087): cx25840: Improve detection of CX2388[578] A/V coresAndy Walls
Add improved logic to detect the exact CX2388[578] A/V core that is being probed. Also cleaned up detection and logging for CX2310[12], CX2583[67], and CX2584[0123] cores and chips. Also added code to identify a CX2388[578] A/V decoder core that is not responding properly. Typical symptoms include registers 0x00-0xff responding properly but all other registers returning the same value (0x13 and 0x5 have been observed). This state will cause proper detection of '885 vs. '887 vs. '888 to fail and the chip won't respond to get configured properly anyway. I have no method of reseting the core to a working state at this time; but I didn't try too hard to work one out either. The problem likely only occurs in development. I suspect configuring the SYS PLL VCO to oscillate too slowly (286.3 MHz?) before post divide may be the root cause, when encountered. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12613): cx25840: fix determining the firmware nameHans Verkuil
Depending on the model there are three different firmwares to choose from. Unfortunately if a cx23885 is loaded first, then the global firmware name is overwritten with that firmware and if ivtv is loaded next, then it tries to load the wrong firmware. In addition, the original approach would also overwrite any firmware that the user specified explicitly. Cc: Jarod Wilson <jarod@wilsonet.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12347): cx25840: Bugfix for no DVB-T on the Hauppauge HVR-1700Steven Toth
After the i2c subdev changes the ordering of initialization changed, causing a total loss of previous GPIO settings and a loss of DTV. The generic firmware loading routine has now changed to preserve GPIO values if the device is cx23885 based (safety) and I've moved the GPIO configuration from probe() into the cx23885 init func which is a little clearer and fixes the bug. Tested-by: Sohail Syyed <linuxtv@hubstar.net> Reviewed-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11370): v4l2-subdev: move s_std from tuner to core.Hans Verkuil
s_std didn't belong in the tuner ops. Stricly speaking it should be part of the video ops, but it is used by audio and tuner devices as well, so it is more efficient to make it part of the core ops. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11369): v4l2-subdev: add load_fw and use that instead of abusing ↵Hans Verkuil
core->init. The init callback was used in several places to load firmware. Make a separate load_fw callback for that. This makes the code a lot more understandable. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (10989): cx25840: cx23885 detection was brokenHans Verkuil
An earlier commit accidentally broke the detection of the cx25837 part of the cx23885. Reinstated the commented out code. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (10953): cx25840: Fix CodingStyle errors introduced by the last patchMauro Carvalho Chehab
2009-04-06V4L/DVB (10952): cx25840: prepare it to be used by cx231xx moduleSri Deevi
cx231xx has a cx25840 inside the chip. However, some different initializations are used for this variant. Signed-off-by: Srinivasa Deevi <srinivasa.deevi@conexant.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11315): cx25840: fix 'unused variable' warning.Hans Verkuil
2009-03-30V4L/DVB (11309): cx25840: cleanup: remove intermediate 'ioctl' stepHans Verkuil
The audio and vbi functions where still called through an ioctl-like interface, even though this is no longer needed with v4l2-subdev. Just change each 'case' into a proper function and call that directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11298): cx25840: remove legacy code for old-style i2c APIHans Verkuil
All drivers that use cx25840 are now converted to v4l2_subdev, so I can remove the support for the old-style i2c API. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10698): v4l2-common: remove v4l2_ctrl_query_fill_stdHans Verkuil
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had. It doesn't add anything valuable that cannot be expressed equally well with v4l2_ctrl_query_fill and only adds overhead. Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it from v4l2_common.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10408): v4l2: fix incorrect hue range checkHans Verkuil
A hue of -128 was rejected due to an incorrect range check, which was faithfully copy-and-pasted into four drivers... Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10251): cx25840: add comments explaining what the init() does.Hans Verkuil
