The logic at em28xx_isoc_dvb_max_packetsize() sucks, at least for newer
the needed packet size. Yet, it is better than nothing.
Rewrite the code in order to change the default to 752 for em2884 and
newer chips and provide a better way to handle per-chipset specifics.
For em2874, the current default should be enough, as the only em2874
board is currently a 1-seg ISDB-T board, so, it needs only a limited
amount of bandwidth.
Both ngene and ddbrige calls dvb_attach once for drxk_attach.
The logic used there, and by tda18271c2dd driver is different
from similar logic on other frontends.
The right fix is to change them to use the same logic, but,
while we don't do that, we need to patch em28xx-dvb in order
to do cope with ngene/ddbridge magic.
While here, document why drxk_t_release should do nothing.
Use a name convention for the firmware file that matches on the
current firmware namespacing. Also, add it to the firmware
download script.
On em28xx, tda18271C2 is accessible when the i2c port
is not touched. Touching on it breaks the driver.
The microcode firmware provided on Terratec H5 seems to be
different. Add a parameter to allow specifying a different
firmware per-device.
Not working yet. There are some fixes at the DRX-K that are needed
for it to work.
All boards use EM28xxx_BOARD, to identify that the macro
refers to a card entry. So:
EM2874_LEADERSHIP_ISDBT -> EM2874_BOARD_LEADERSHIP_ISDBT
Supports DVB-T/T2/C, USB ID: 2013:024f.
Empia EM28174, Sony CXD2820R and NXP TDA18271HD/C2.
Signed-off-by: Antti Palosaari <crope@iki.fi>
Register multiple FEs for same adapter. After that it is
possible to register two FEs for same adapter. For example
one for DVB-T and one for DVB-C.
Add the calls necessary to use the new drx-d driver for the PCTV 330e
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
If the tuner is not actually behind an i2c gate, using the i2c gate control
function can wedge the i2c bus. Provide the ability to control on a per-board
basis whether it should be used.
Problem was noticed on the HVR-900 R2, where it resulted in the first tuning
attempt succeeding, and then all subsequent attempts to access the xc3028
being treated as failures (including the call to sleep the tuner).
Add the required board initialization required for the drx-d to work with
the 900R2.
This device uses an em2874B + Sharp 921 One Seg frontend.
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
This adds support for the KWorld PlusTV 340U and KWorld UB345-Q ATSC
sticks, which are really the same device. The sticks have an eMPIA
em2870 usb bridge chipset, an LG Electronics LGDT3304 ATSC/QAM
demodulator and an NXP TDA18271HD tuner -- early versions of the 340U
have a a TDA18271HD/C1, later models and the UB435-Q have a C2.
The stick has been tested succesfully with both VSB_8 and QAM_256 signals.
Its using lgdt3304 support added to the lgdt3305 driver by a prior patch,
rather than the current lgdt3304 driver, as its severely lacking in
functionality by comparison (see said patch for details).
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
Serialize DVB initialization, to avoid it to happen while analog
initialization is still happening.
This patch adapts the changes submitted by Dainius Ridzevicius to the
linux-media mailing list on 8/14/09, to the current sources in order
to make the Kworld VS-DVB-T 323UR usb device work.
I also removed the "not validated" flag since I own the device and validated
that it works fine after the patch is applied.
Thanks to Devin Heitmueller for his guidance with the code.
Signed-off-by: Antonio Larrosa <larrosa@kde.org>
Acked-by: Devin Heitmueller <dheitmueller@kernellabs.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
I succeeded in running Cinergy Hybrid T USB XS FR in both modes.
Adds digital and analogue tv support for Dikom DK300 hybrid usb card.
Not working: remote controller
To be done: it seems that with the proposed patch the digital demodulator
remains activated if the tuner is switched from digital to analogue mode.
Workaround is to unplug and replug the device when switching from digital to
analogue. If someone can explain how to verify the gpio settings using the
usbsnoop, the above issue perhaps can be resolved.
Signed-off-by: Andrea Amorosi <Andrea.Amorosi76@gmail.com>
this patch fixes a memory leak which occurs when an em28xx card with DVB
extension is unplugged or its DVB extension driver is unloaded. In
dvb_fini(), dev->dvb must be freed before being set to NULL, as is done
in dvb_init() in case of error.
Note that this bug is also present in the latest stable kernel release.
Signed-off-by: Francesco Lavra <francescolavra@interfree.it>
Convert printks to em28xx_err and em28xx_info
Signed-off-by: Filipe Rosset <rosset.filipe@gmail.com>
Make analog audio, dvb and the remote work on a Terratec Cinergy Hybrid
XS (em2882).
Note by djh: Thanks go out fo Andrej Suligoi for his contribution in providing
and testing pretty much the exact same patch as provided by Uros. Between
the two of them, they got all the core functionality working for the device.
Cc: Andrej Suligoi <suligoi@gmail.com>
Signed-off-by: Uroš Vampl <mobile.leecher@gmail.com>
Support for Reddo DVB-C USB TV Box device. Remote is not working yet.
Thanks to Benjamin Larsson <banan@ludd.ltu.se>
Cc: Benjamin Larsson <banan@ludd.ltu.se>
Restore support for digital tuning caused by regression during introduction
of disable_i2c_gate parameter to zl10353 driver.
Thanks to user "Xwang" for reporting the problem and testing the fix
Cc: Xwang <xwang1976@email.it>
When the change was introduced in the zl10353 for the i2c gate behavior, this
broke the HVR-900 which was not behind a gate. Use a version of the zl10353
config profile that indicates the tuner is not behind such a gate.
Without this patch the first tune succeeds, but subsequent tuning attempts
will fail.
The change also renames the terratec zl10353 profile I wrote to be more
generic, since it is shared by the non-terratec device.
Thanks to Michael Krufky for providing a HVR-900 and DVB-T environment to test
with.
Cc: Michael Krufky <mkrufky@kernellabs.com>
(eb1a:2881)
Setup the GPIOs properly and enable support for the DVB side of the Pinnacle
Hybrid Pro USB stick.
Thanks to Andreas Lunderhage for testing patches and providing a remote debug
environment.
Cc: Andreas Lunderhage <lunderhage@home.se>
Cinergy T XS USB
Andy walls pointed out that we were passing 0x5d to the TUNER_GO register,
instead of 0x01. Set the register properly (note the code did still work with
the incorrect value, so this does not address a regression).
Thanks to Andy Walls for noticing the issue.
Cc: Andy Walls <awalls@radix.net>
(mt352 variant)
The Terratec Cinergy T XS USB can have either a zl10353 or an mt352. Add
support for the MT352 variant.
Thanks to Jelle de Jong for providing a unit to test/debug with.
Cc: Jelle de Jong <jelledejong@powercraft.nl>
version)
Fix the code so that the zl10353 version of the Terratec Cinergy T XS USB
starts working again. This includes fixing what must have been a typo in the
GPIO definition for the digital side of the board, and setting of the
disable_i2c_gate_ctrl property for the zl10353 config, so that the i2c bus
doesn't get wedged the first time something tries to close the gate.
Also, add a printk() making clear that the mt352 version still isn't
supported. This issue is still being actively debugged, but in the meantime
at least the dmesg output will show a very clear error...
Thanks to Jelle de Jong for providing sample hardware to test with.
Thanks to Simon Kenyon for testing various patches and providing SSH access to
his environment so I could debug with access to a valid signal source.
Cc: Simon Kenyon <simon@koala.ie>
Add support for the EVGA inDtube. Both ATSC and analog side validated as
fully functional.
Thanks to Jake Crimmins from EVGA for providing the correct GPIO info.
Thanks to Alan Hagge for doing all the device testing.
Thanks to Greg Williamson for providing hardware for testing.
Cc: Jake Crimmins <jcrimmins@evga.com>
Cc: Alan Hagge <ahagge@gmail.com>
Cc: Greg Williamson <cheeseboy16@gmail.com>
Added an entry for Kworld 315 (for while, dvb only)
Signed-off-by: Franklin Meng <fmeng2002@yahoo.com>
eeprom configuration.
The em28xx actually has a register that tells the driver what the maximum
packet size is (based on a value programmed into the eeprom). Make use of
that register instead of assuming a hardcoded value of 564 (since 564 is not
correct for devices that do QAM such as the KWorld 340u).
Note that for now the em2874 code isn't there, falling back to the 564 value,
however this is not a problem since there are not any em2874 based devices in
the current v4l-dvb tree).
Thanks to Jarod Wilson for detecting the initial problem and figuring out that
the isoc configuration was wrong for his device.
Cc: Jarod Wilson <jarod@wilsonet.com>
Added EmpireTV entry.
Thanks to Xwang <xwang1976@email.it> to provide data for this board.
Fix for KWorld 330U Board
Many thanks to Devin and Mauro!!!
Signed-off-by: Robert Krakora <rob.krakora@messagenetsystems.com>
Added specific entry for WinTV-HVR 850
Signed-off-by: Douglas Schilling Landgraf <dougsland@linuxtv.org>
Several chips may be turned off when the device is not used, like audio,
video and dvb demods. This patch adds a gpio callback at the core
structs to allow turning off such devices.
Several fields are duplicated on both structs. Let's just copy em28xx_board instead.
A later cleanup could just copy the fields that are changed, in order to keep em28xx_board
const.
In dvb_init(),
case EM2880_BOARD_TERRATEC_HYBRID_XS:
case EM2880_BOARD_KWORLD_DVB_310U:
can be put in the same case than EM2880_BOARD_HAUPPAUGE_WINTV_HVR_900
since they do the same thing.
Signed-off-by: Thierry MERLE <thierry.merle@free.fr>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Fix sparse warnings. None are serious, but cutting down on these helps find
future serious sparse warnings/errors.
Redid the av7710.c patch based on a suggestion by Oliver Endriss.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Correct firmware type to MTS
Correct audio routing for composite/s-video
Add DVB-T detection.
This patch uses the eeprom hash method for detection as the vendor/product
ids are also used for the DIGIVOX_AD. This may be a clone of the same
product. Explanatory text has been added prior to the hask look-up in
anticipation that it may help others.
The following has been tested to work:
Analogue TV (PAL-I)
Composite In
DVB-T (UK Crystal Palace)
USB AUDIO
The following has not been tested but probably works:
S-Video In
Signed-off-by: Darron Broad <darron@kewl.org>
Thanks to "Devin Heitmueller" <devin.heitmueller@gmail.com> for pointing this
issue.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
em28xx-cards.c
em28xx-dvb.c
em28xx.h
- Add support for the ATI TV Wonder HD 600, based on a 94 email exchange and
USB traces provided by Ronnie Bailey
Thanks to Ronnie Bailey <purevw@wtxs.net> for testing the changes
This patch adds dvbt support for the terratec cinergy hybrid T usb xsstick.
Thanks to Devin Heitmueller and Mauro Chehab for guiding me.
Signed-off-by: Reinhard Schwab <reinhard.schwab@aon.at>
- Separate the newer variant of the HVR-900 into its own device profile
because it has a Micronas DRX397 instead of the Zarlink demod. This
doesn't make the device work, but at least we don't try to initialize it
as though it had the Zarlink device.
Signed-off-by: Devin Heitmueller <devin.heitmueller@gmail.com>
[mchehab@infradead.org: avoid compilation breakage at mainstream, where drx397xD.h doesn't exist yet]
variant 2304:0227)
support them
em28xx-audio.c
em28xx-dvb.c
- Em28xx extensions should ensure they are being only loaded against devices
that support them. Deals with case where there are multiple em28xx
devices, some of which have DVB (or ALSA) support and some do not.
not registered yet
