path: root/drivers/media/video/ivtv/Kconfig
2008-11-11V4L/DVB (9486): ivtv/ivtvfb: no longer experimentalHans Verkuil
Remove the EXPERIMENTAL tag. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9485): ivtv: remove incorrect V4L1 & tvaudio dependencyHans Verkuil
ivtv used tvaudio in the past and at the time tvaudio required V4L1. Since tvaudio is no longer dependent on V4L1 and since ivtv actually no longer uses tvaudio at all, this is no removed from Kconfig. Without this patch ivtv won't be build if V4L1 is disabled. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-27V4L/DVB (8534): remove select's of FW_LOADERAdrian Bunk
After commit d9b19199e4894089456aaad295023263b5225c1a (always enable FW_LOADER unless EMBEDDED=y) we can remove the FW_LOADER select's and corresponding dependencies on HOTPLUG. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7851): Fix FW_LOADER depencency at v4l/dvbMauro Carvalho Chehab
Since: 1) FW_LOADER is defined as: config FW_LOADER tristate "Userspace firmware loading support" depends on HOTPLUG 2) several V4L/DVB driver just selects it; 3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER. So, All drivers that select FW_LOADER should also depend on HOTPLUG. An easier solution (for the end-user perspective) would be to "select HOTPLUG". However, live is not simple. This would cause recursive dependency issues like this one: drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD -> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA -> USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7846): Re-creates VIDEO_TUNERMauro Carvalho Chehab
VIDEO_TUNER is responsible for compilation of tuners.ko module. This were the previous behaviour before the creation of MEDIA_TUNER. Before this patch, tuner.ko were created even for drivers that don't need a tuner (like webcam drivers). Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Rename common tuner Kconfig names to use the sameMauro Carvalho Chehab
namespace for all of them.
2008-04-24V4L/DVB (7535): saa717x: add new audio/video decoder i2c driverHans Verkuil
Added the last remaining out-of-tree kernel driver from the ivtv project. The saa717x is used in several Japanese cards and a Russian card. The driver is not complete in that only NTSC is supported and no PAL/SECAM. Hopefully this will be added in the future. Signed-off-by: Takahiro Adachi <tadachi@tadachi-net.com> Signed-off-by: Kyuma Ohta <whatisthis@jcom.home.ne.jp> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6764): ivtv: select VIDEO_IR in KconfigHans Verkuil
2008-01-25V4L/DVB (6488): ivtv: add ASUS Falcon2 supportHans Verkuil
2007-10-09V4L/DVB (6120): ivtvfb: rename some missed ivtv-fb references to ivtvfbHans Verkuil
2007-10-09V4L/DVB (6119): ivtvfb: renamed ivtv-fb to ivtvfb, move header to include/linuxHans Verkuil
The convention for framebuffer devices is to call them xxxfb, not xxx-fb. Conform to this. Also move the ivtvfb.h header to include/linux: it is a public header. The FBIO_WAITFORVSYNC ioctl is now also defined in the ivtvfb.h header, no more need to include matroxfb.h for just this ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5929): Add vp27smpx driverHans Verkuil
This device is internal to the Panasonic VP27S tuner and is used to set the mono/stereo/bilingual setting of the tuner. It is used by two Japanese cx23416-based cards. Signed-off-by: Takahiro Adachi <tadachi@tadachi-net.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5902): Add ivtv-fb framebuffer driver.Hans Verkuil
Add the ivtv-fb framebuffer driver for cx23415 devices (currently only the Hauppauge PVR-350 cards). This makes it possible to use the On-Screen Display functionality of these cards, either for menus during MPEG playback, or as a console or X display. Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: John P Harvey <john.p.harvey@btinternet.com> Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-20V4L/DVB (5855): ivtv: fix Kconfig typo and refer to the driver homepage.Hans Verkuil
2007-07-20V4L/DVB (5851): ivtv: fix missing I2C_ALGOBIT config optionHans Verkuil
I2C_ALGOBIT must also be selected when ivtv is selected. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-22V4L/DVB (5639): Fix Kconfig dependencies for ivtvMauro Carvalho Chehab
ivtv were wrongly marked as dependent of USB. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-15em28xx and ivtv should depend on PCIAl Viro
.. because video-buf.c requires PCI, and VIDEO_EM28XX selects it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27V4L/DVB (5376): Add dependency on VIDEO_V4L1Hans Verkuil
VIDEO_V4L1 is needed to get tvaudio to be built. Stupid really as ivtv is only using the v4l2 API to communicate with tvaudio. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5375): Add missing VIDEO_CX25840 dep, remove unused ↵Hans Verkuil
VIDEO_TLV320AIC23B dep VIDEO_CX25840 was missing in the ivtv dependencies. VIDEO_TLV320AIC23B was removed since it isn't used by ivtv. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5345): ivtv driver for Conexant cx23416/cx23415 MPEG encoder/decoderHans Verkuil
It took three core maintainers, over four years of work, eight new i2c modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac support from Axel Thimm, (hardware) support from Hauppauge, support and assistance from the v4l-dvb people and the many, many users of ivtv to finally make it possible to merge this driver into the kernel. Thank you all! Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: John P Harvey <john.p.harvey@btinternet.com> Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
