Rename all PCI drivers with their own directory under
drivers/media/video into drivers/media/pci and update the
building system.
- don't show kernel backtrace when the allocation of the buffers fails: the
normal ivtv/cx18 messages are clear enough and the backtrace scares users.
- fix cleanup after the buffer allocation fails (caused kernel panic).
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
If you try to access the video device from within an udev rule,
then you get into a circular locking situation.
Changed the driver to postpone the registration of the devices until
everything else has been fully initialized, so that the newly created
device can be used immediately.
- add guards
- remove unused header includes
- move card-specific stuff from ivtv-driver.h to ivtv-cards.h
- move YUV-specific stuff from ivtv-driver.h to ivtv-yuv.h
It took three core maintainers, over four years of work, eight new i2c
modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced
VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding
API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac
support from Axel Thimm, (hardware) support from Hauppauge, support and
assistance from the v4l-dvb people and the many, many users of ivtv to
finally make it possible to merge this driver into the kernel.
Thank you all!
Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com>
Signed-off-by: Chris Kennedy <c@groovy.org>
Signed-off-by: John P Harvey <john.p.harvey@btinternet.com>
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
