asked for
get_user_pages() may return fewer page than we ask for. As we give up and
return an error in this case, we need to put_page() each of the pages we
did get.
[Andy Walls modified the patch, only removing the braces in the 'for'
statement, to eliminate a checkpatch warning.]
Signed-off-by: Paul Cassella <fortytwo-ivtv@manetheren.bigw.org>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
There are several DMA related interrupts which wake up the dma_waitq. The udma
routines use this queue while they wait for their transfer to complete. When
woken, the udma routine will check the IVTV_F_I_UDMA_PENDING & IVTV_F_I_UDMA
flags to see if the transfer is still queued or has finished. However, a small
window exists between the IVTV_F_I_UDMA_PENDING flag being cleared and the
IVTV_F_I_UDMA flag being set. Given that the completion of an unrelated DMA
transfer may wake up the udma routine, it's possible for this check to fail
and the udma routine will start unmapping pages when the transfer has only
just started. The result of this is unpredictable.
This fix simply delays the clearing of the IVTV_F_I_UDMA_PENDING flag until
after IVTV_F_I_UDMA has been set.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Signed-off-by: Andy Walls <awalls@radix.net>
Use consistent naming for pci_dev, v4l2_device and video_device.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Most drivers need to set length and offset as well, so may as well fold
those three lines into one.
Add sg_assign_page() for those two locations that only needed to set
the page, where the offset/length is set outside of the function context.
- add guards
- remove unused header includes
- move card-specific stuff from ivtv-driver.h to ivtv-cards.h
- move YUV-specific stuff from ivtv-driver.h to ivtv-yuv.h
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The return value of ivtv_udma_fill_sg_list() was changed by the
highmem bugfix, but that return value was still used in ivtv-yuv.c.
Revert to the old return value, but in addition return -1 in case of
a memory allocation error.
When trying to DMA userspace buffers to the cx23415 you need to check
whether the page is in highmem. If this is the case, then bounce buffers
have to be used to allow DMA.
It took three core maintainers, over four years of work, eight new i2c
modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced
VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding
API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac
support from Axel Thimm, (hardware) support from Hauppauge, support and
assistance from the v4l-dvb people and the many, many users of ivtv to
finally make it possible to merge this driver into the kernel.
Thank you all!
Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com>
Signed-off-by: Chris Kennedy <c@groovy.org>
Signed-off-by: John P Harvey <john.p.harvey@btinternet.com>
