The service_set field was used in saa7115 and cx25840 to determine
whether raw or sliced VBI was desired. This is incorrect since it is
perfectly valid to select sliced VBI with a service_set of 0.
Instead these drivers should checked on VIDIOC_S_FMT whether the type
field matches the raw or sliced VBI type.
Updated ivtv accordingly.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
- change the work-queue to a single threaded high prio workqueue
- use DMA instead of PIO for the sliced VBI data.
- remove some incorrect tests
- increase the internal VBI capture queue size for sliced VBI packets
- ignore duplicate VBI lines
With these changes it should finally be possible to get reliable closed
captions.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Fix conflict with cx18 driver.
Besides some VBI cleanups this patch also fixes a subtle problem with the
VBI re-insertion stream where the PIO work handler wasn't called quickly
enough, resulting in occasional corrupt data.
Furthermore the CC output didn't disable CC correctly and at the right time,
causing duplicates to be sent.
An saa7127 fix for VPS output was also added: the wrong data was sent.
into ivtv-routing.c
- Invalid VBI packets should result in an empty VBI frame, not
in an zero-sized frame that causes the reader to incorrectly
return a 0 (EOF) value.
- PIO completion should not reset the sg_pending_size field.
- The DMA offset detection code should be ignored for PIO transfers:
it somehow messes up the data on the card and is not needed anyway
for PIO.
The old service_set_out setting was still tested, even though it no longer
was ever set and was in fact obsolete. This meant that everything that was
written to /dev/vbi16 was ignored. Removed the service_set_out variable
altogether and now it works again.
workhandler
Sliced VBI transfers use PIO instead of DMA. This was done inside the
interrupt handler, but since PIO accesses are very slow this meant that
a lot of time was spent inside the interrupt handler. All PIO copies are
now moved to a workqueue. This should fix various issues with missing time
ticks and remote key hits.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
It took three core maintainers, over four years of work, eight new i2c
modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced
VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding
API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac
support from Axel Thimm, (hardware) support from Hauppauge, support and
assistance from the v4l-dvb people and the many, many users of ivtv to
finally make it possible to merge this driver into the kernel.
Thank you all!
Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com>
Signed-off-by: Chris Kennedy <c@groovy.org>
Signed-off-by: John P Harvey <john.p.harvey@btinternet.com>
