get_user_pages() may return -errno, such as -EFAULT. So don't blindly use
its return value as an offset into dma->map[] for the next get_user_pages()
call. Since we'll give up and return an error if either fails, don't even
make the second call if the first failed to give us exactly what we were
looking for.
The old code would also call put_page() on as many elements of dma->map[]
as we'd asked for, regardless of how many were valid.
[Andy Walls modified this patch to return -EFAULT instead of -EINVAL
as Paul's observation "I'm not sure -EINVAL is the best return code vs
-EFAULT or -ENOMEM, [...]" was correct. The return value bubbles up
as a return code for write(), for which the V4L2 API spec indicates
EINVAL is incorrect and EFAULT is correct.]
Signed-off-by: Paul Cassella <fortytwo-ivtv@maneteren.bigw.org>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Found the coccinelle tool.
Thanks-to: Julia Lawall <julia@diku.dk>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Use consistent naming for pci_dev, v4l2_device and video_device.
Modified yuv register update handling to remove a potential race condition
which could occur with the first video frame.
Also removed a forced yuv position update, since changing the source video
dimensions or interlace settings doesn't affect the frame already being
displayed.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
- don't show kernel backtrace when the allocation of the buffers fails: the
normal ivtv/cx18 messages are clear enough and the backtrace scares users.
- fix cleanup after the buffer allocation fails (caused kernel panic).
drivers/media/video/v4l2-common.c:719:16: warning: Using plain integer as NULL pointer
drivers/media/video/au0828/au0828-dvb.c:122:19: warning: Using plain integer as NULL pointer
drivers/media/video/ivtv/ivtv-yuv.c:1101:22: warning: Using plain integer as NULL pointer
drivers/media/video/ivtv/ivtv-yuv.c:1102:23: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-audio.c:78:39: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-video-v4l.c:84:39: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-v4l2.c:1264:9: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-context.c:197:28: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-cx2584x-v4l.c:126:39: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-dvb.c:133:32: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-dvb.c:145:31: warning: Using plain integer as NULL pointer
drivers/media/video/pvrusb2/pvrusb2-dvb.c:177:55: warning: Using plain integer as NULL pointer
drivers/media/video/videobuf-core.c:100:9: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
The existing yuv code limits output to the display area occupied by the
framebuffer. This patch allows the yuv output to be 'detached' via
V4L2_FBUF_FLAG_OVERLAY.
By default, the yuv output window will be restricted to the framebuffer
dimensions and the output position is relative to the top left corner of the
framebuffer. This matches the behaviour of previous versions.
If V4L2_FBUF_FLAG_OVERLAY is cleared, the yuv output will no longer be linked
to the framebuffer. The maximum dimensions are either 720x576 or 720x480
depending on the current broadcast standard, with the output position
relative to the top left corner of the display. The framebuffer itself can be
resized, moved and panned without affecting the yuv output.
This patch makes the following needlessly global functions static:
- ivtv_yuv_next_free()
- ivtv_yuv_setup_frame()
- ivtv_yuv_udma_frame()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
ivtv-yuv code clean up & reformat. Includes minor changes to some debug lines.
Also fixes a bug found during the reformatting, which would cause the
incorrect amount of yuv data to be sent to the card if source cropping
coordinates were used.
Apart from the bug-fix, there should be no functional difference to the
previous version.
IVTV_IOC_DMA_FRAME framework
Previously, all yuv data written to /dev/video48 had only basic support with
no double buffering to avoid display tearing.
With this patch, yuv frames written to video48 are now handled by the existing
IVTV_IOC_DMA_FRAME framework. As such, the frames are hardware buffered to
avoid tearing, and honour scaling mode & field order options. Unlike the
proprietary IVTV_IOC_DMA_FRAME ioctl, all parameters are controlled by the
V4L2 API.
Due to mpeg & yuv output restrictions being different, their V4L2 output
controls have been separated. To control the yuv output, the V4L2 calls must
be done via video48.
If the ivtvfb module is loaded, there will be one side effect to this merge.
The yuv output window will be constrained to the visible framebuffer area. In
the event that a virtual framebuffer size is being used, the limit to the
output size will be the virtual dimensions, but only the portion that falls
within the currently visible area of the framebuffer will be shown.
Like the IVTV_IOC_DMA_FRAME ioctl, the supplied frames must be padded to 720
pixels wide. However the height must only be padded up the nearest multiple
of 32. This would mean an image of 102 lines must be padded to 128. As long
as the true source image size is given, the padding will not be visible in
the final output.
Interlace mode selection code moved into the frame setup phase, so it's now
run before the frame is loaded into a hardware buffer. Given that it can
affect how a new frame is displayed, it was a bit stupid running it after the
frame was already visible.
A few stray interlace related variables which were linked to individual frames
have now been moved into the yuv_frame_info struct. This means that all
variables linked to a specific frame are in the same place & not scattered.
Minor code reformatting in areas touched by the above changes.
To reduce the number of display register accesses, the yuv code keeps track of
the current video settings. Should there be a change in any single parameter,
it will update the associated display registers to ensure everything is
displayed correctly.
The existing check also looks at the field order for the video. This is not
required, since field reversal does not require any display register changes.
This patch removes the field order from the check.
changes
ivtv_yuv_prep_frame is split in smaller code blocks.
Modified yuv buffer handling on the PVR350 itself. We now cycle through all 8
hardware buffers.
With this patch in place, driver behaviour should remain unchanged from the
existing release.
If the ivtvfb module isn't loaded, the valid YUV output area should be set to
full-screen. This patch fixes the case where the valid output area was not
reset when the output broadcast format was changed from NTSC to PAL. This
resulted in output being limited to the top 480 lines of the display.
display area
When the ivtvfb module is loaded, the YUV output is relative to the
framebuffer output. When a virtual screen size is used, the output area for
the YUV may actually be off screen. To prevent the hardware from crashing,
the current driver will ignore an off-screen position and leave the output
visible at the last on-screen position. This may not be desirable, so this
patch will switch off the YUV output should the image move off-screen, and
re-enable it should the image move on-screen again.
into ivtv-routing.c
- add guards
- remove unused header includes
- move card-specific stuff from ivtv-driver.h to ivtv-cards.h
- move YUV-specific stuff from ivtv-driver.h to ivtv-yuv.h
The return value of ivtv_udma_fill_sg_list() was changed by the
highmem bugfix, but that return value was still used in ivtv-yuv.c.
Revert to the old return value, but in addition return -1 in case of
a memory allocation error.
When trying to DMA userspace buffers to the cx23415 you need to check
whether the page is in highmem. If this is the case, then bounce buffers
have to be used to allow DMA.
In the current driver, the field order is global. As soon as it's changed it
takes immediate effect. This is a problem when the video changes order mid
stream. Although it mostly works okay, the video may judder / flicker.
This patch attaches the field order to the frame, so that any buffered frames
will not be displayed until the correct field. In the event that the field
order is changed mid stream, the driver will ensure that the previous frame
is displayed for a minimum of 3 fields. These are the two original fields the
frame should have occupied, plus the one extra since the new frame still has
to wait for the correct field.
The yuv output code always compares the new frame position & size with those
of the previous frame. If they are different, a flag is set to request the
yuv output registers be updated when the new frame is displayed.
If the incoming frames are delivered too fast, exhausting the buffers, the
most recent frame already buffered will be discarded. Unfortunately, any
update request will also be discarded. If the new frame matches the size &
position of the now discarded frame, the yuv registers are not flagged for
update & will remain in their old state.
This patch preserves the register update flag in the event that a frame is
dropped.
When the video standard is changed, there's no guarantee the framebuffer
dimensions are still legal. The yuv output code uses these dimensions to
calculate the size & position for the video overlay. If the framebuffer
dimensions are now illegal, the output may exceed the vertical limit of the
display, causing distortion.
This patch adds an additional check to ensure the output doesn't exceed
the limits for the current video standard, cropping if required.
Modifies automatic mode selection for yuv playback. Behaviour is now that
source video with a vertical resolution below that of the currently set
broadcast mode will be treated as progressive. Video with a vertical
resolution greater or equal to the current broadcast mode (up to 576 lines)
will be treated as interlaced.
Every file should include the headers containing the prototypes
for its global functions.
It took three core maintainers, over four years of work, eight new i2c
modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced
VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding
API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac
support from Axel Thimm, (hardware) support from Hauppauge, support and
assistance from the v4l-dvb people and the many, many users of ivtv to
finally make it possible to merge this driver into the kernel.
Thank you all!
Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com>
Signed-off-by: Chris Kennedy <c@groovy.org>
Signed-off-by: John P Harvey <john.p.harvey@btinternet.com>
