git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- dvb core: there is a regression found when used with xine. For
whatever unknown reason, xine (and xine-lib clients) wants that the
frontend to tell what frequency he is using even before the PLL lock
(or at least, it expects a non-zero frequency).
On DVB, the frequency is only actually known after a frequency
zig-zag seek, done by the DVB core. Anyway, the fix was trivial.
That solves Fedora BZ#808871.
- ivtv: fix a regression when selecting the language channel
- uvc: fix a race-related crash
- it913x: fixes firmware loading
- two trivial patches (a dependency issue at a radio driver at sound
Kconfig, and a warning fix on dvb).
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] uvcvideo: Fix race-related crash in uvc_video_clock_update()
[media] Drivers/media/radio: Fix build error
[media] dvb_frontend: fix compiler warning
[media] it913x: fix firmware loading errors
[media] ivtv: Fix AUDIO_(BILINGUAL_)CHANNEL_SELECT regression
[media] dvb_frontend: regression fix: userspace ABI broken for xine
When I converted ivtv to the new decoder API I introduced a regression in the
support of the old channel select API.
Thanks to Martin Dauskardt for reporting this.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Reviewed-by: Andy Walls <awalls@md.metrocast.net>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Pull media updates from Mauro Carvalho Chehab:
- V4L2 API additions to better support JPEG compression control
- media API additions to properly support MPEG decoders
- V4L2 API additions for image crop/scaling
- a few other V4L2 API DocBook fixes/improvements
- two new DVB frontend drivers: m88rs2000 and rtl2830
- two new DVB drivers: az6007 and rtl28xxu
- a framework for ISA drivers, that removed lots of common code found
at the ISA radio drivers
- a new FM transmitter driver (radio-keene)
- a GPIO-based IR receiver driver
- a new sensor driver: mt9m032
- some new video drivers: adv7183, blackfin, mx2_emmaprp, sii9234_drv,
vs6624
- several new board additions, driver fixes, improvements and cleanups.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (295 commits)
[media] update CARDLIST.em28xx
[media] partially reverts changeset fa5527c
[media] stb0899: fix the limits for signal strength values
[media] em28xx: support for 2304:0242 PCTV QuatroStick (510e)
[media] em28xx: support for 2013:0251 PCTV QuatroStick nano (520e)
[media] -EINVAL -> -ENOTTY
[media] gspca - sn9c20x: Cleanup source
[media] gspca - sn9c20x: Simplify register write for capture start/stop
[media] gspca - sn9c20x: Add automatic JPEG compression mechanism
[media] gspca - sn9c20x: Greater delay in case of sensor no response
[media] gspca - sn9c20x: Optimize the code of write sequences
[media] gspca - sn9c20x: Add the JPEG compression quality control
[media] gspca - sn9c20x: Add a delay after Omnivision sensor reset
[media] gspca - sn9c20x: Propagate USB errors to higher level
[media] gspca - sn9c20x: Use the new video control mechanism
[media] gspca - sn9c20x: Fix loss of frame start
[media] gspca - zc3xx: Lack of register 08 value for sensor cs2102k
[media] gspca - ov534_9: Add brightness to OmniVision 5621 sensor
[media] gspca - zc3xx: Add V4L2_CID_JPEG_COMPRESSION_QUALITY control support
[media] pvrusb2: fix 7MHz & 8MHz DVB-T tuner support for HVR1900 rev D1F5
Pull kmap_atomic cleanup from Cong Wang.
It's been in -next for a long time, and it gets rid of the (no longer
used) second argument to k[un]map_atomic().
Fix up a few trivial conflicts in various drivers, and do an "evil
merge" to catch some new uses that have come in since Cong's tree.
* 'kmap_atomic' of git://github.com/congwang/linux: (59 commits)
feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal
highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename]
drbd: remove the second argument of k[un]map_atomic()
zcache: remove the second argument of k[un]map_atomic()
gma500: remove the second argument of k[un]map_atomic()
dm: remove the second argument of k[un]map_atomic()
tomoyo: remove the second argument of k[un]map_atomic()
sunrpc: remove the second argument of k[un]map_atomic()
rds: remove the second argument of k[un]map_atomic()
net: remove the second argument of k[un]map_atomic()
mm: remove the second argument of k[un]map_atomic()
lib: remove the second argument of k[un]map_atomic()
power: remove the second argument of k[un]map_atomic()
kdb: remove the second argument of k[un]map_atomic()
udf: remove the second argument of k[un]map_atomic()
ubifs: remove the second argument of k[un]map_atomic()
squashfs: remove the second argument of k[un]map_atomic()
reiserfs: remove the second argument of k[un]map_atomic()
ocfs2: remove the second argument of k[un]map_atomic()
ntfs: remove the second argument of k[un]map_atomic()
Acked-by: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Cong Wang <amwang@redhat.com>
Use the macro DMA_BIT_MASK instead of the constant 0xffffffff.
Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com>
In driver ivtv, there is a mismatch between the type of the radio module
parameter and the storage variable, which leads to the following
warning:
CC [M] drivers/media/video/ivtv/ivtv-driver.o
drivers/media/video/ivtv/ivtv-driver.c: In function ‘__check_radio’:
drivers/media/video/ivtv/ivtv-driver.c:142: warning: return from incompatible pointer type
drivers/media/video/ivtv/ivtv-driver.c: At top level:
drivers/media/video/ivtv/ivtv-driver.c:142: warning: initialization from incompatible pointer type
The code was unnecessarily complex, introducing a hdl_out handler that was
not needed. Instead just add the controls to the cxhdl.hdl handler directly.
Without this we have got the warnings like following if build with "make W=1
O=/var/tmp":
cc1: warning: drivers/media/dvb/dvb-core: No such file or directory [enabled by default]
For drivers that properly use the v4l2 framework (i.e. set v4l2_dev in the
video_device struct), the start and end messages of VIDIOC_LOG_STATUS are
now generated automatically. People tended to forget these, but the v4l2-ctl
tool scans for these messages, and it also makes it easier to read the status
output in the kernel log.
The cx18, ivtv and bttv drivers were changed since they no longer need to
log these start/end messages.
In saa7164 two empty log_status functions were removed.
Also added a helper function to v4l2-ctrl.c that can be used as the
vidioc_log_status callback if all you need to do is to log the current control
values. This is now used by pwc and vivi.
Cc: Steven Toth <stoth@kernellabs.com>
Cc: Andy Walls <awalls@md.metrocast.net>
Cc: Hans de Goede <hdegoede@redhat.com>
With this private ioctl it is possible to use the ivtv decoder without
requiring the dvb/video.h and dvb/audio.h headers.
Eventually support for those DVB APIs will be dropped from ivtv.
As part of the removal of get_driver()/put_driver(), this patch
(as1510) changes driver_find(); it now drops the reference it acquires
before returning. The patch also adjusts all the callers of
driver_find() to remove the now unnecessary calls to put_driver().
In addition, the patch adds a warning to driver_find(): Callers must
make sure the driver they are searching for does not get unloaded
while they are using it. This has always been the case; driver_find()
has never prevented a driver from being unregistered or unloaded.
Hence the patch will not introduce any new bugs. The existing callers
all seem to be okay in this respect, however I don't understand the
video drivers well enough to be certain about them.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Dmitry Torokhov <dmitry.torokhov@gmail.com>
CC: Kyungmin Park <kyungmin.park@samsung.com>
CC: Andy Walls <awalls@md.metrocast.net>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (57 commits)
[media] as3645a: Fix compilation by including slab.h
[media] s5p-fimc: Remove linux/version.h include from fimc-mdevice.c
[media] s5p-mfc: Remove linux/version.h include from s5p_mfc.c
[media] ds3000: using logical && instead of bitwise &
[media] v4l2-ctrls: make control names consistent
[media] DVB: dib0700, add support for Nova-TD LEDs
[media] DVB: dib0700, add corrected Nova-TD frontend_attach
[media] DVB: dib0700, separate stk7070pd initialization
[media] DVB: dib0700, move Nova-TD Stick to a separate set
[media] : add MODULE_FIRMWARE to dib0700
[media] DVB-CORE: remove superfluous DTV_CMDs
[media] s5p-jpeg: adapt to recent videobuf2 changes
[media] s5p-g2d: fixed a bug in controls setting function
[media] s5p-mfc: Fix volatile controls setup
[media] drivers/media/video/s5p-mfc/s5p_mfc.c: adjust double test
[media] drivers/media/video/s5p-fimc/fimc-capture.c: adjust double test
[media] s5p-fimc: Fix incorrect control ID assignment
[media] dvb_frontend: Don't call get_frontend() if idle
[media] DocBook/dvbproperty.xml: Remove DTV_MODULATION from ISDB-T
[media] DocBook/dvbproperty.xml: Fix ISDB-T delivery system parameters
Instead of messing around with id's it's much easier to just compare
against a filehandle pointer.
For some reason the /dev/radio device was implemented as an exclusive open:
you could open it only once and not a second time.
Remove this limitation.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (655 commits)
[media] revert patch: HDIC HD29L2 DMB-TH USB2.0 reference design driver
mb86a20s: Add a few more register settings at the init seq
mb86a20s: Group registers into the same line
[media] [PATCH] don't reset the delivery system on DTV_CLEAR
[media] [BUG] it913x-fe fix typo error making SNR levels unstable
[media] cx23885: Query the CX25840 during enum_input for status
[media] cx25840: Add support for g_input_status
[media] rc-videomate-m1f.c Rename to match remote controler name
[media] drivers: media: au0828: Fix dependency for VIDEO_AU0828
[media] convert drivers/media/* to use module_platform_driver()
[media] drivers: video: cx231xx: Fix dependency for VIDEO_CX231XX_DVB
[media] Exynos4 JPEG codec v4l2 driver
[media] doc: v4l: selection: choose pixels as units for selection rectangles
[media] v4l: s5p-tv: mixer: fix setup of VP scaling
[media] v4l: s5p-tv: mixer: add support for selection API
[media] v4l: emulate old crop API using extended crop/compose API
[media] doc: v4l: add documentation for selection API
[media] doc: v4l: add binary images for selection API
[media] v4l: add support for selection api
[media] hd29l2: fix review findings
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
There's one comment that has been copied from bttv to many other
media/video drivers:
/* init + register i2c algo-bit adapter */
Meanwhile, many drivers use hardware I2C implementations instead of
relying on i2c-algo-bit, so this comment is misleading. Remove the
reference to "algo-bit" from all drivers, to avoid any confusion. This
is the best way to ensure that the comments won't go out of sync
again. Anyone interested in the implementation details would rather
look at the code itself.
Although the ivtv driver reports radio support through the V4L2 API, it fails
to actually enable it. This patch fixes that.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
The service_set field of struct v4l2_sliced_vbi_cap was never filled in.
The v4l2-compliance tool complained about this, so this is now fixed.
Usage of these flags has been deprecated for nearly 4 years by:
commit f77bf01425b11947eeb3b5b54685212c302741b8
Author: Sam Ravnborg <sam@neptun.(none)>
Date: Mon Oct 15 22:25:06 2007 +0200
kbuild: introduce ccflags-y, asflags-y and ldflags-y
Moreover, these flags (at least EXTRA_CFLAGS) have been documented for command
line use. By default, gmake(1) do not override command line setting, so this is
likely to result in build failure or unexpected behavior.
Replace their usage by Kbuild's `{as,cc,ld}flags-y'.
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: linux-media@vger.kernel.org
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
just per-fh
The driver had to decide how many events to allocate when the v4l2_fh struct
was created. It was possible to add more events afterwards, but there was no
way to ensure that you wouldn't miss important events if the event queue
would fill up for that filehandle.
In addition, once there were no more free events, any new events were simply
dropped on the floor.
For the control event in particular this made life very difficult since
control status/value changes could just be missed if the number of allocated
events and the speed at which the application read events was too low to keep
up with the number of generated events. The application would have no idea
what the latest state was for a control since it could have missed the latest
control change.
So this patch makes some major changes in how events are allocated. Instead
of allocating events per-filehandle they are now allocated when subscribing an
event. So for that particular event type N events (determined by the driver)
are allocated. Those events are reserved for that particular event type.
This ensures that you will not miss events for a particular type altogether.
In addition, if there are N events in use and a new event is raised, then
the oldest event is dropped and the new one is added. So the latest event
is always available.
This can be further improved by adding the ability to merge the state of
two events together, ensuring that no data is lost at all. This will be
added in the next patch.
This also makes it possible to allow the user to determine the number of
events that will be allocated. This is not implemented at the moment, but
would be trivial.
Drivers that supported events used to be rare, but now that controls can also
raise events this will become much more common since almost all drivers have
controls.
This means that keeping struct v4l2_events as a separate struct make no more
sense. Merging it into struct v4l2_fh simplifies things substantially as it
is now an integral part of the filehandle struct.
After discussing with Andy Walls on irc, we've agreed that this
is the best thing to do. No regressions will be introduced, as 3.x.y
is greater then the current versions for cx18 and ivtv.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
The driver shouldn't override vt->type, and the tuner name should be
based on vt->type as well.
Internally separates the setting of the broadcast standard for the encoder &
decoder. Externally there's no change in functionality.
[awalls@md.metrocast.net: Edited to fix a checkpatch gripe about multiple
assignment and to remove a now unused DEFINE_WAIT() due to this patch]
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Add sanity check to ivtvfb_pan_display() to ensure only valid values are used
to pan the display. Invalid values are rejected with -EINVAL
We must not use any information in the passed var besides xoffset,
yoffset and vmode as otherwise applications might abuse it. Also use the
aligned fix.line_length and not the (possible) unaligned xres_virtual.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Two ivtv_msleep_timeout() calls are incorrectly flagged as interruptable. The
first is in the init sequence for a capture and is required for stable
hardware setup. The second is at the end of the capture and used to handle the
last data transfer. Failure to wait for this last transfer can result in stale
data being read at the start of the next capture.
pci_setup_device() has saved the PCI revision in the pci_dev
struct since Linux 2.6.23. Use it.
Cc: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
This keymap were used for the Hauppauge Black remote controller
only. It also contains some keycodes not found there. As the
Hauppauge Black is now part of the hauppauge keymap, just remove
it.
Also, remove the modprobe hacks to select between the Gray
and the Black versions of the remote controller as:
- Both are supported by default by the keymap;
- If the user just wants one keyboard supported,
it is just a matter of changing the keymap via
the userspace tool (ir-keytable), removing
the keys that he doesn't desire. As ir-keytable
auto-loads the keys via udev, this is better than
obscure modprobe parameters.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
The rc-hauppauge-new map is a messy thing, as it bundles 3
different remote controllers as if they were just one,
discarding the address byte. Also, some key maps are wrong.
With the conversion to the new rc-core, it is likely that
most of the devices won't be working properly, as the i2c
driver and the raw decoders are now providing 16 bits for
the remote, instead of just 8.
delete mode 100644 drivers/media/rc/keymaps/rc-hauppauge-new.c
Rather than guess which driver supports core priority handling, require drivers
that do to explicitly set the V4L2_FL_USE_FH_PRIO flag in video_device.
Updated the core prio handling accordingly and set the flag in the three
drivers that do.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
ivtv-ioctl cast the 'void *fh' directly to 'ivtv_open_id *'. This should be
done properly with a contained_of since the 'void *fh' is really a
'struct v4l2_fh *'.
It worked because the v4l2_fh field is also the first field in the ivtv_open_id
struct, but it is not clean code.
Drivers that use v4l2_fh can now use the core framework support of g/s_priority.
get_user_pages() may return -errno, such as -EFAULT. So don't blindly use
its return value as an offset into dma->map[] for the next get_user_pages()
call. Since we'll give up and return an error if either fails, don't even
make the second call if the first failed to give us exactly what we were
looking for.
The old code would also call put_page() on as many elements of dma->map[]
as we'd asked for, regardless of how many were valid.
[Andy Walls modified this patch to return -EFAULT instead of -EINVAL
as Paul's observation "I'm not sure -EINVAL is the best return code vs
-EFAULT or -ENOMEM, [...]" was correct. The return value bubbles up
as a return code for write(), for which the V4L2 API spec indicates
EINVAL is incorrect and EFAULT is correct.]
Signed-off-by: Paul Cassella <fortytwo-ivtv@maneteren.bigw.org>
ivtv_write_vbi_from_user()
Fix the first, botched attempt at preventing direct use of a user pointer in
ivtv_write_vbi().
Reported-by: Dr. David Alan Gilbert <linux@treblig.org>
asked for
get_user_pages() may return fewer page than we ask for. As we give up and
return an error in this case, we need to put_page() each of the pages we
did get.
[Andy Walls modified the patch, only removing the braces in the 'for'
statement, to eliminate a checkpatch warning.]
Signed-off-by: Paul Cassella <fortytwo-ivtv@manetheren.bigw.org>
After upgrading the kernel from stock Ubuntu 7.10 to
10.04, with no hardware changes, I started getting the dreaded DMA
TIMEOUT errors, followed by inability to encode until the machine was
rebooted.
I came across a post from Andy in March
(http://www.gossamer-threads.com/lists/ivtv/users/40943#40943) where he
speculates that perhaps the corrective actions being taken after a DMA
ERROR are not sufficient to recover the situation. After some testing
I suspect that this is indeed the case, and that in fact the corrective
action may be what hangs the card's DMA engine, rather than the
original error.
Specifically these DMA ERROR IRQs seem to present with two different
values in the IVTV_REG_DMASTATUS register: 0x11 and 0x13. The current
corrective action is to clear that status register back to 0x01 or
0x03, and then issue the next DMA request. In the case of a 0x13 this
seems to result in a minor glitch in the encoded stream due to the
failed transfer that was not retried, but otherwise things continue OK.
In the case of a 0x11 the card's DMA write engine is never heard from
again, and a DMA TIMEOUT follows shortly after. 0x11 is the killer.
I suspect that the two cases need to be handled differently. The
difference is in bit 1 (0x02), which is set when the error is about to
be successfully recovered, and clear when things are about to go bad.
Bit 1 of DMASTATUS is described differently in different places either
as a positive "write finished", or an inverted "write busy". If we
take the first definition, then when an error arises with state 0x11,
it means that the write did not complete. It makes sense to start a
new transfer, as in the current code. But if we take the second
definition, then 0x11 means "an error but the write engine is still
busy". Trying to feed it a new transfer in this situation might not be
a good idea.
As an experiment, I added code to ignore the DMA ERROR IRQ if DMASTATUS
is 0x11. I.e., don't start a new transfer, don't clear our flags, etc.
The hope was that the card would complete the transfer and issue a ENC
DMA COMPLETE, either successfully or with an error condition there.
However the card still hung.
The only remaining corrective action being taken with a 0x11 status was
then the write back to the status register to clear the error, i.e.
DMASTATUS = DMASTATUS & ~3. This would have the effect of clearing the
error bit 4, while leaving the lower bits indicating DMA write busy.
Strangely enough, removing this write to the status register solved the
problem! If the DMA ERROR IRQ with DMASTATUS=0x11 is completely
ignored, with no corrective action at all, then the card will complete
the transfer and issue a new IRQ. If the status register is written to
when it has the value 0x11, then the DMA engine hangs. Perhaps it's
illegal to write to
DMASTATUS while the read or write busy bit is set? At any rate, it
appears that the current corrective action is indeed making things
worse rather than better.
I put together a patch that modifies ivtv_irq_dma_err to do the
following:
- Don't write back to IVTV_REG_DMASTATUS.
- If write-busy is asserted, leave the card alone. Just extend the
timeout slightly.
- If write-busy is de-asserted, retry the current transfer.
This has completely fixed my DMA TIMEOUT woes. DMA ERR events still
occur, but now they seem to be correctly handled. 0x11 events no
longer hang the card, and 0x13 events no longer result in a glitch in
the stream, as the failed transfer is retried. I'm happy.
I've inlined the patch below in case it is of interest. As described
above, I have a theory about why it works (based on a different
interpretation of bit 1 of DMASTATUS), but I can't guarantee that my
theory is correct. There may be another explanation, or it may be a
fluke. Maybe ignoring that IRQ entirely would be equally effective?
Maybe the status register read/writeback sequence is race condition if
the card changes it in the mean time? Also as I am using a PVR-150
only, I have not been able to test it on other cards, which may be
especially relevant for 350s that support concurrent decoding.
Hopefully the patch does not break the DMA READ path.
Mike
[awalls@md.metrocast.net: Modified patch to add a verbose comment, make minor
brace reformats, and clear the error flags in the IVTV_REG_DMASTATUS iff both
read and write DMA were not in progress. Mike's conjecture about a race
condition with the writeback is correct; it can confuse the DMA engine.]
[Comment and analysis from the ML post by Michael <mike@rsy.com>]
Cc: stable@kernel.org
The core.s_config op was meant for legacy drivers that needed to work with old
pre-2.6.26 kernels. This is no longer relevant. Unfortunately, this op was
incorrectly called from several drivers.
Replace those occurences with proper i2c_board_info structs and call
v4l2_i2c_new_subdev_board.
After these changes v4l2_i2c_new_subdev_cfg() was no longer used, so remove
that function as well.
