path: root/drivers/media/video/m52790.c
2012-08-15[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Move ancillary I2C drivers into drivers/media/i2c, in order to better organize them. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-08[media] convert drivers/media/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/media/* to use the module_i2_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Heungjun Kim <riverful.kim@samsung.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Andrew Chew <achew@nvidia.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Michael Grzeschik <m.grzeschik@pengutronix.de> Cc: Johannes Obermaier <johannes.obermaier@gmail.com> Cc: Steven Toth <stoth@kernellabs.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] v4l: make sure drivers supply a zeroed struct v4l2_subdevHerton Ronaldo Krzesinski
Some v4l drivers currently don't initialize their struct v4l2_subdev with zeros, and this is a problem since some of the v4l2 code expects this. One example is the addition of internal_ops in commit 45f6f84, after that we are at risk of random oopses with these drivers when code in v4l2_device_register_subdev tries to dereference sd->internal_ops->*, as can be shown by the report at http://bugs.launchpad.net/bugs/745213 and analysis of its crash at https://lkml.org/lkml/2011/4/1/168 Use kzalloc within problematic drivers to ensure we have a zeroed struct v4l2_subdev. BugLink: http://bugs.launchpad.net/bugs/745213 Cc: <stable@kernel.org> Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: m52790: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11304): v4l2: remove v4l2_subdev_command calls where they are no ↵Hans Verkuil
longer needed. Several i2c drivers still used v4l2_subdev_command, even though they were converted to v4l2_subdev. Remove those unused .command callbacks. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10409): v4l: remove unused I2C_DRIVERIDs.Hans Verkuil
I2C_DRIVERIDs are phased out. Remove those that are unused at the moment. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9824): m52790: convert to v4l2_subdev.Hans Verkuil
2008-07-26V4L/DVB (8487): videodev: replace videodev.h includes by videodev2.h where ↵Hans Verkuil
possible Several V4L2 drivers still included videodev.h. Fix this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20v4l-dvb: remove legacy checks to allow support for kernels < 2.6.10Hans Verkuil
Also remove some blank lines that were used to split compat code at -devel tree. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-18i2c: Convert remaining new-style drivers to use module aliasingJean Delvare
Update all the remaining new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. Note that the tuner driver is a bit quirky at the moment, as it overwrites i2c_client.name with arbitrary strings. We write "tuner" back on remove, to make sure that driver cycling will work properly, but there may still be troublesome corner cases. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-01-25V4L/DVB (6862): ivtv: really remove i2c legacy support from drivers that no ↵Hans Verkuil
longer need it For some reason the include header wasn't changed from v4l2-i2c-drv-legacy.h to v4l2-i2c-drv.h in the previous patch. This is now corrected. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6766): ivtv: remove i2c legacy support from drivers that no longer ↵Hans Verkuil
need it Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6486): m52790: add new Mitsubishi A/V switch i2c driverHans Verkuil
This driver is used by the ASUS Falcon2 cx23416-based cards. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
