path: root/drivers/media/video/mxb.c
2011-03-22[media] v4l2-ioctl: add priority handling supportHans Verkuil
Drivers that use v4l2_fh can now use the core framework support of g/s_priority. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] v4l: fix handling of v4l2_input.capabilitiesHans Verkuil
The v4l core sets the v4l2_input.capabilities field based on the supplied v4l2_ioctl_ops. However, several drivers do a memset or memcpy of the v4l2_input struct, thus overwriting that field incorrectly. Either remove the memset (which is already done by the v4l core), or add the proper capabilities field in case of a memcpy. The same is also true for v4l2_output, but that only affected the ivtv driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-22[media] v4l: Remove module_name argument to the v4l2_i2c_new_subdev* functionsLaurent Pinchart
The argument isn't used anymore by the functions, remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-28Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits) [media] af9015: Fix max I2C message size when used with tda18271 [media] IR: initialize ir_raw_event in few more drivers [media] Guard a divide in v4l1 compat layer [media] imon: fix nomouse modprobe option [media] imon: remove redundant change_protocol call [media] imon: fix my egregious brown paper bag w/rdev/idev split [media] cafe_ccic: Configure ov7670 correctly [media] ov7670: allow configuration of image size, clock speed, and I/O method [media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016] [media] af9015: map DigitalNow TinyTwin v2 remote [media] DigitalNow TinyTwin remote controller [media] af9015: RC fixes and improvements videodev2.h.xml: Update to reflect the latest changes at videodev2.h [media] v4l: document new Bayer and monochrome pixel formats [media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028 [media] firedtv: add parameter to fake ca_system_ids in CA_INFO [media] tm6000: fix a macro coding style issue tm6000: Remove some ugly debug code [media] Nova-S-Plus audio line input [media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers ...
2010-10-22[media] v4l: Remove hardcoded module names passed to v4l2_i2c_new_subdev*Laurent Pinchart
With the v4l2_i2c_new_subdev* functions now supporting loading modules based on modaliases, replace the hardcoded module name passed to those functions by NULL. All corresponding I2C modules have been checked, and all of them include a module aliases table with names corresponding to what the drivers modified here use. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: saa5246a/saa5249: Remove obsolete teletext driversHans Verkuil
These old i2c teletext drivers are not supported by any hardware and cannot be tested anymore. Note that while the mxb board seemingly used the saa5246a driver, in reality this teletext driver never worked. These drivers are removed as part of the vtx feature removal, originally scheduled for 2.6.35. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-06V4L/DVB: saa7146: fix regression of the av7110/budget-av driverHans Verkuil
An earlier regression fix for the mxb driver (V4L/DVB: saa7146_vv: fix regression where v4l2_device was registered too late) caused a new regression in the av7110 driver. Reverted the old fix and fixed the problem in the mxb driver instead. Tested on mxb and budget-av cards. The real problem is that the saa7146 framework has separate probe() and attach() driver callbacks which should be rolled into one. This is now done for the mxb driver, but others should do the same. Lack of hardware makes this hard to do, though. I hope to get hold of some hexium cards and then I can try to improve the framework to prevent this from happening again. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: saa7115: fix saa7111a supportHans Verkuil
When the saa7111 driver was merged into saa7115 several bugs were introduced, in particular with the saa7111a support as is used in the mxb.c driver. This patch fixes the saa7111a support. This was tested with the mxb driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: saa7146_vv: fix regression where v4l2_device was registered too lateHans Verkuil
v4l2_device_register needs to be called before the i2c subdevs are loaded. However, it was called afterwards in the saa7146 driver. This caused an oops when loading the mxb and hexium drivers. The vv_init function is now split into two: one registers the v4l2_device, the other does the rest of the initialization. The three drivers that depend on this have been updated to call the new vv_devinit function. Thanks to Michael Hunold for reporting this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13241): Cleanup redundant tests on unsignedRoel Kluin
The variables are unsigned so the test `>= 0' is always true, the `< 0' test always fails. In these cases the other part of the test catches wrapped values. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12540): v4l: simplify v4l2_i2c_new_subdev and friendsHans Verkuil
Rewrite v4l2_i2c_new_subdev as a simplified version of v4l2_i2c_new_subdev_cfg and remove v4l2_i2c_new_probed_subdev and v4l2_i2c_new_probed_subdev_addr. This simplifies this API substantially. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB: cleanup redundant tests on unsignedRoel Kluin
Remove redundant tests on unsigned. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11379): mxb: fix copy-and-paste bug in mute.Hans Verkuil
The line-in was muted twice instead of the line-in and the cd-in. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11373): v4l2-common: add explicit v4l2_device pointer as first arg ↵Hans Verkuil
to new_(probed)_subdev The functions v4l2_i2c_new_subdev and v4l2_i2c_new_probed_subdev relied on i2c_get_adapdata to return the v4l2_device. However, this is not always possible on embedded platforms. So modify the API to pass the v4l2_device pointer explicitly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11370): v4l2-subdev: move s_std from tuner to core.Hans Verkuil
s_std didn't belong in the tuner ops. Stricly speaking it should be part of the video ops, but it is used by audio and tuner devices as well, so it is more efficient to make it part of the core ops. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10870a): remove all references for video_decoder.hMauro Carvalho Chehab
changeset 04934e44e3784a1b969582e2d59afcec278470c6 removed the last implementation that were still using the V4L1 obsoleted header. Now, video_decoder.h is not used anymore by any driver. Let's remove it and all references for it in Kernel. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10499): saa7146: convert saa7146 and mxb in particular to v4l2_subdev.Hans Verkuil
Modified mxb to load the i2c modules through v4l2_subdev. So no more probing. Modified tea6415c and tea6420 to use the standard routing ops to do the routing, rather than using private commands. Dropped the private commands from tda9840 (they were never used except during initialization of the module). Added saa7146 support for VIDIOC_DBG_G_CHIP_IDENT. Converted saa5246a and saa5249 to v4l2_subdev. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10271): saa7146: convert to video_ioctl2.Hans Verkuil
The conversion to video_ioctl2 is the first phase to converting this driver to the latest v4l2 framework. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8945): mxb: use unique i2c adapter nameHans Verkuil
2008-10-12V4L/DVB (8942): mxb: coding style cleanupsHans Verkuil
2008-10-12V4L/DVB (8941): mxb/tda9840: cleanups, use module saa7115 instead of saa7111.Hans Verkuil
Cleanup tda9840 and use a v4l2 API to get the tuner subchannels. Do some cleanups in mxb and switch to saa7115 instead of the saa7111 module. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8630): First mxb cleanup phaseHans Verkuil
2008-09-03V4L/DVB (8757): v4l-dvb: fix a bunch of sparse warningsHans Verkuil
Fixed a lot of sparse warnings: mostly warnings about shadowed variables and signed/unsigned mismatches. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-30NULL noise: drivers/mediaAl Viro
Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-27i2c: Drivers stop using the redundant client listJean Delvare
The redundant i2c client list maintained by i2c-core is going away soon, so drivers should stop using it now. Instead, they can use the standard iterator provided by the device driver model (device_for_each_child). Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Cc: Michael Hunold <michael@mihu.de>
2007-10-10V4L/DVB (6316): Change list_for_each+list_entry to list_for_each_entryTrent Piepho
The rest of V4L files. There is one list_for_each+list_entry in cpia_pp.c that wasn't changed because it expects the loop iterator to remain NULL if the list is empty. A bug in vivi is fixed; the 'safe' version needs to be used because the loop deletes the list entries. Simplify a second loop in vivi and get rid if an un-used variable in that loop. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4894): Mxb: fix to load the proper i2c modulesMichael Hunold
Change order of module requests, so that tuner module is loaded at the end, because the tuner module probes multiple i2c addresses and might grab an i2c address that is not a tuner but something else. Signed-off-by: Michael Hunold <hunold@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3584): Implement V4L2_TUNER_MODE_LANG1_LANG2 audio modeHans Verkuil
Add a new audio mode V4L2_TUNER_MODE_LANG1_LANG2 (used by VIDIOC_G/S_TUNER). This mode allows the user to select both languages of a bilingual transmission, one language on the left, one on the right audio channel. If there is no bilingual transmission, or it is not supported, then this mode should act like V4L2_TUNER_MODE_STEREO. This mode is introduced for PVR-like drivers where it is useful to be able to record both languages of a bilingual broadcast. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3548): Renamed I2C_foo addresses to I2C_ADDR_fooMauro Carvalho Chehab
I2C_foo were used for some i2c addresses. Bad, since those constants could mean other i2c chip things. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3537a): Whitespace cleanupMauro Carvalho Chehab
2006-03-21Merge branch 'origin'Linus Torvalds
Conflicts: Documentation/video4linux/CARDLIST.cx88 drivers/media/video/cx88/Kconfig drivers/media/video/em28xx/em28xx-video.c drivers/media/video/saa7134/saa7134-dvb.c Resolved as in the original merge by Mauro Carvalho Chehab
2006-03-14[PATCH] Restore tuning capabilities in V4L2 MXB driverMichael Hunold
The behaviour of the all-in-one Video4Linux tuner driver apparently changed. It now wants to know the tv standard, otherwise it refuses to tune. Restore tuning functionality in my driver for the "Multimedia eXtension Board". The all-in-one tuner driver apparently changed its behaviour. Signed-off-by: Michael Hunold <hunold@linuxtv.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3269): ioctls cleanups.Michael Krufky
- Now, all internal ioctls are at v4l2-common.h - removed unused ioctl at saa6752hs.h - all debug ioctl code moved to v4l2-common.c - removed duplicated stuff from other cards Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-07-27[PATCH] v4l: fix tuning with MXB driverMichael Hunold
I noticed that some past changes to the gerneric Video4Linux tuner module for analog tuners broke my "Multimedia eXtension Board" driver. The tuner driver was made aware of Video4Linux2 tuning ioctls, but my driver was not ported and still uses the Video4Linux1 ioctls. This does not work anymore as intendend, the tuning is currently broken. The attached patch fixes non-working tuning in MXB driver introduced by some recent generic tuner changes by replacing Video4Linux1 tuner ioctls with proper Video4Linux2 tuner ioctls. - fix non-working tuning in MXB driver introduced by some recent generic tuner changes by replacing Video4Linux1 tuner ioctls with proper Video4Linux2 tuner ioctls Signed-off-by: Michael Hunold <hunold@linuxtv.org> Cc: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] v4l: MXB fix to correct tuner ioctlMauro Carvalho Chehab
- driver command adapted to use new control (TUNER_SET_TYPE_ADDR, instead of TUNER_SET_TYPE) Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
