path: root/drivers/media/video/ov772x.c
2011-07-27[media] V4L: soc-camera: remove soc-camera bus and devices on itGuennadi Liakhovetski
Now that v4l2 subdevices have got their own device objects, having one more device in soc-camera clients became redundant and confusing. This patch removes those devices and the soc-camera bus, they used to reside on. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] v4l: ov772x: simplify pointer dereferenceGuennadi Liakhovetski
Use a more direct way to obtain a pointer to struct ov772x_priv, where the subdevice is available. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l: Use v4l2_get_subdevdata instead of accessing v4l2_subdev::privLaurent Pinchart
Replace direct access to the v4l2_subdev priv field with the inline v4l2_get_subdevdata method. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: mediabus: fix ambiguous pixel code namesGuennadi Liakhovetski
Endianness notation is meaningless for 8 bit YUYV codes. Switch pixel code names to explicitly state the order of colour components in the data stream. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-04Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (87 commits) V4L/DVB: ivtv: Timing tweaks and code re-order to try and improve stability V4L/DVB: ivtv: Avoid accidental video standard change V4L/DVB: ivtvfb : Module load / unload fixes V4L/DVB: cx2341x: Report correct temporal setting for log-status V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email address V4L/DVB: drivers/media: Eliminate a NULL pointer dereference V4L/DVB: dvb-core: Fix ULE decapsulation bug V4L/DVB: Bug fix: make IR work again for dm1105 V4L/DVB: media/IR: nec-decoder needs to select BITREV V4L/DVB: video/saa7134: change dprintk() to i2cdprintk() V4L/DVB: video/saa7134: remove duplicate break V4L/DVB: IR/imon: add auto-config for 0xffdc rf device V4L/DVB: IR/imon: clean up usage of bools V4L/DVB: em28xx: remove unneeded null checks V4L/DVB: ngene: remove unused #include <linux/version.h> V4L/DVB: ak881x needs slab.h V4L/DVB: FusionHDTV: Use quick reads for I2C IR device probing V4L/DVB: Technotrend S2-3200 ships with a TT 1500 remote V4L/DVB: drivers/media: Use kzalloc V4L/DVB: m920x: Select simple tuner ...
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-01V4L/DVB: v4l2-subdev.h: fix enum_mbus_fmt prototypeHans Verkuil
enum_mbus_fmt received an index argument that was defined as an int instead of an unsigned int. This is now fixed. This had the knock-on effect that the index argument in the callback get_formats in soc_camera.h also had to be changed to unsigned int. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26soc-camera: ov772x: Modify buswidth controlKuninori Morimoto
This patch removes "buswidth" struct member, and sets the default buswidth to the natively supported 10 bit. You can select 8 bit buswidth by new flag. This patch also modify ap325rxa/migor setup.c Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13659): soc-camera: convert to the new mediabus APIGuennadi Liakhovetski
Convert soc-camera core and all soc-camera drivers to the new mediabus API. This also takes soc-camera client drivers one step closer to also be usable with generic v4l2-subdev host drivers. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13650): soc-camera: switch drivers and platforms to use .priv in ↵Guennadi Liakhovetski
struct soc_camera_link After this change drivers can be further extended to not fail, if they don't get platform data, but to use defaults. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-11-09tree-wide: fix typos "selct" + "slect" -> "select"Uwe Kleine-König
This patch was generated by git grep -E -i -l 's(le|el)ct' | xargs -r perl -p -i -e 's/([Ss])(le|el)ct/$1elect/ with only skipping net/netfilter/xt_SECMARK.c and include/linux/netfilter/xt_SECMARK.h which have a struct member called selctx. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19V4L/DVB (12536): soc-camera: remove .gain and .exposure struct ↵Guennadi Liakhovetski
soc_camera_device members This makes the soc-camera interface for V4L2 subdevices thinner yet. Handle gain and exposure internally in each driver just like all other controls. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12534): soc-camera: V4L2 API compliant scaling (S_FMT) and cropping ↵Guennadi Liakhovetski
(S_CROP) The initial soc-camera scaling and cropping implementation turned out to be incompliant with the V4L2 API, e.g., it expected the user to specify cropping in output window pixels, instead of input window pixels. This patch converts the soc-camera core and all drivers to comply with the standard. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12531): soc-camera: Use I2C device for dev_{dbg,info,...} output in ↵Guennadi Liakhovetski
all clients Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12529): soc-camera: switch to s_crop v4l2-subdev video operationGuennadi Liakhovetski
Remove set_crop soc-camera device method and switch to s_crop from v4l2-subdev video operations. Also extend non-i2c drivers to also hold a pointer to their v4l2-subdev instance in control device driver-data, i.e., in dev_get_drvdata((struct device *)to_soc_camera_control(icd)) Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12526): ov772x: do not use scaling for croppingGuennadi Liakhovetski
OV772x sensors cannot crop, they only support two fixed formats: VGA and QVGA. We should not change the format when requested to crop, only S_FMT can do this. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12518): ov772x: S_CROP must return actually configured geometryGuennadi Liakhovetski
V4L2 drivers are allowed to configure a geometry different than what has been requested by the user with S_CROP, but then they have to adjust the input rectangle accordingly. Fix ov772x to comply with this requirement. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12516): ov772x: successful S_FMT and S_CROP must update ↵Guennadi Liakhovetski
user-provided rectangle Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12515): soc-camera: use struct v4l2_rect in struct soc_camera_deviceGuennadi Liakhovetski
Switch to using struct v4l2_rect in struct soc_camera_device for uniformity and simplicity. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12512): ov772x: implement a band-stop filter supportGuennadi Liakhovetski
The V4L2_CID_BAND_STOP_FILTER control is used to switch the "Banding Filter" on OV772x cameras on and off and to set the minimum AEC value in BDBASE register. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12510): soc-camera: (partially) convert to v4l2-(sub)dev APIGuennadi Liakhovetski
Convert the soc-camera framework to use the v4l2-(sub)dev API. Start using v4l2-subdev operations. Only a part of the interface between the soc_camera core, soc_camera host drivers on one side and soc_camera device drivers on the other side is replaced so far. The rest of the interface will be replaced in incremental steps, and will require extensions and, possibly, modifications to the v4l2-subdev code. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12506): soc-camera: convert to platform deviceGuennadi Liakhovetski
Convert soc-camera core and all drivers to platform device API. We already converted platforms to register a platform device for each soc-camera client, now we remove the compatibility code and switch completely to the new scheme. This is a preparatory step for the v4l2-subdev conversion. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-17soc-camera: unify i2c camera device platform dataGuennadi Liakhovetski
Unify i2c camera device platform data to point to struct soc_camera_link for a smooth transition to soc-camera as a platform driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-06V4L/DVB (11327): ov772x: add edge contrl supportKuninori Morimoto
2009-04-06V4L/DVB (11324): ov772x: wrong pointer for soc_camera_link is modifiedKuninori Morimoto
priv->client->dev.platrom_data mean ov772x_camera_info in ov772x driver. So, struct soc_camera_link doesn't exist there. This patch modify this bug. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11028): ov772x: use soft sleep mode in stop_captureKuninori Morimoto
2009-03-30V4L/DVB (11024): soc-camera: separate S_FMT and S_CROP operationsGuennadi Liakhovetski
As host and camera drivers become more complex, differences between S_FMT and S_CROP functionality grow, this patch separates them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10669): ov772x: Add image flip supportKuninori Morimoto
o ov772x_camera_info :: flags supports default image flip. o V4L2_CID_VFLIP/HFLIP supports image flip for user side. Thank Magnus for advice. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10668): ov772x: bit mask operation fix on ov772x_mask_set.Kuninori Morimoto
2009-03-30V4L/DVB (10667): ov772x: setting method to register is changed.Kuninori Morimoto
Color format regs array had been used, but it was not easy to understand what to want to do, and additional bit became complex. This patch modify this problem. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10666): ov772x: move configuration from start_capture() to set_fmt()Kuninori Morimoto
soc_camera framework requires, that camera configuration is performed in set_fmt, and start_capture and stop_capture only turn the camera on/off. This patch modifies ov772x to comply to this requirement. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10665): soc-camera: add data signal polarity flags to driversGuennadi Liakhovetski
All soc-camera camera and host drivers must specify supported data signal polarity, after all drivers are fixed, we'll add a suitable test to soc_camera_bus_param_compatible(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10098): ov772x: fix try_fmt calculation methodKuninori Morimoto
Don't modify driver's state in try_fmt, just verify format acceptability or adjust it to driver's capabilities. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10097): ov772x: clear i2c client data on error and removeKuninori Morimoto
2008-12-30V4L/DVB (10096): ov772x: change dev_info to dev_dbgKuninori Morimoto
2008-12-30V4L/DVB (10072): soc-camera: Add signal inversion flags to be used by camera ↵Guennadi Liakhovetski
drivers As reported by Antonio Ospite <ospite@studenti.unina.it> two platforms with a mt9m111 camera require opposite pixel clock polarity, which means one of them inverts it. This patch adds support for inversion flags and switches all available camera drivers to using them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10069): Add ov7725 support to ov772x driverKuninori Morimoto
2008-12-30V4L/DVB (10068): Change device ID selection method on ov772x driverKuninori Morimoto
2008-12-30V4L/DVB (10067): Remove ov772x_default_regs from ov772x driverKuninori Morimoto
2008-12-30V4L/DVB (9788): soc-camera: simplify namingGuennadi Liakhovetski
We anyway don't follow the s_fmt_vid_cap / g_fmt_vid_cap / try_fmt_vid_cap naming, and soc-camera is so far only about video capture, let's simplify operation names a bit further. set_fmt_cap / try_fmt_cap wasn't a very good choice too. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9784): Register name fix for ov772x driverKuninori Morimoto
2008-12-30V4L/DVB (9783): Change power on/off sequence on ov772xKuninori Morimoto
2008-12-29V4L/DVB (9502): ov772x: CodingStyle improvementsHans Verkuil
2008-12-29V4L/DVB (9488): Add ov772x driverKuninori Morimoto
This patch adds ov772x driver that use soc_camera framework. It was tested on SH Migo-r board. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
