The rc-hauppauge-new map is a messy thing, as it bundles 3
different remote controllers as if they were just one,
discarding the address byte. Also, some key maps are wrong.
With the conversion to the new rc-core, it is likely that
most of the devices won't be working properly, as the i2c
driver and the raw decoders are now providing 16 bits for
the remote, instead of just 8.
delete mode 100644 drivers/media/rc/keymaps/rc-hauppauge-new.c
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Add the same "are you ready?" i2c_master_send() poll command to
get_key_haup_xvr found in lirc_zilog, which is apparently seen in
the Windows driver for the PVR-150 w/a z8. This stabilizes what is
received from both the HD-PVR and HVR-1950, even with their polling
intervals at the default of 100, thus the removal of the custom
260ms polling_interval in pvrusb2-i2c-core.c.
Acked-by: Andy Walls <awalls@md.metrocast.net>
Acked-by: Mike Isely <isely@isely.net>
ir-kbd-i2c
When registering an IR Rx device with the I2C subsystem, provide more detailed
information about the IR device and default remote configuration for the IR
driver modules.
Also explicitly register any IR Tx device with the I2C subsystem.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Acked-by: Mike Isely <isely@pobox.com>
Signed-off-by: Mike Isely <isely@pobox.com>
There is no point in defining I2C adapter IDs when no code is using
them. As this field might go away in the future, stop using it when
we don't need to.
Now that the ir-kbd-i2c driver has been converted to a new-style i2c
driver, we can instantiate the ir_video I2C device by default. The
pvr2_disable_ir_video is kept to disable the IR receiver, either
because the user doesn't use it, or for debugging purpose.
This sets the disable_autoload_ir_video module option to being set,
which disables any attempt by the driver to autoload IR support. This
changes preserves previous behavior, for now. This change can be set
back concurrent with other changes that finally update i2c-kbd-i2c to
use the new i2c binding model.
v4l-dvb core
The ir-kbd-i2c module is about to be updated to match the new style
i2c binding model. These pvrusb2 changes maintain compatibility with
that change. Note that this does not actually break anything even
without the expected ir-kbd-i2c changes yet because previously the
pvrusb2 didn't autoload ir-kbd-i2c anyway.
the device
This change defines all possible "IR schemes" related to the pvrusb2
driver, on a per-device basis. That information is then set according
to the hardware in use. The idea here is to make possible a more
intelligent future decision on which, if any, IR receiver driver might
be loaded during initialization.
The client_register and client_unregister methods are optional so
there is no point in defining stub ones. Especially when these methods
are likely to be removed soon.
This change removes the old i2c module controlling layer from the
pvrusb2 driver. This is code that first had appeared in the driver
back in December 2005. It's history. Now we use v4l2-subdev. Please
note also that with this change, the driver will no longer be usable
in kernels older that 2.6.22.
In order to keep a sub-device from promiscuously attaching to the
pvrusb2 driver, the i2c adapter's class must be cleared. This change
clears that class by default.
Set up new mechanism for declaring and loading appropriate sub-devices
when driver initializes. This is another part of the v4l2-subdev
adoption.
This is the first step in the effort to move the pvrusb2 driver over
to using the v4l2-subdev framework. This commit involves mainly
splitting apart pvrusb2-i2c-core - part of it is the driver's I2C
adapter driver and the rest is the old i2c module handling logic. The
i2c module handling junk is moved out to pvrusb2-i2c-track and various
header references are correspondingly updated. Yes, this patch has a
huge pile of checkpatch complaints, but I'm NOT going to fix any of
it. Why? First, I'm moving a large chunk of existing code and I'm
not going to spend time adjusting it to match someone's idea of coding
style. Second, in the end I expect all that moved code to go away by
the time the rework is done so wasting time on it now to adhere to the
standard is in the end a large waste of time.
first attach
It appears that various v4l-dvb drivers are changing to require
explicit initialization before use. This change to the pvrusb2 driver
implements an automatic issuance of VIDIOC_INT_INIT when a module is
bound to the driver, thus conforming to the new behavior.
Fix sparse warnings. None are serious, but cutting down on these helps find
future serious sparse warnings/errors.
Redid the av7710.c patch based on a suggestion by Oliver Endriss.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
behavior
Disable "virtual" IR receiver on for 24xxx devices that have an
internal IR blaster. In that case there's another another IR
receiver present and to leave the virtual receiver available
just causes confusion. This means that 24xxx users will no
longer see a phantom IR chip.
This builds upon the previous pvrusb2 change to more formally
implement full cropping support. This enables access from the
driver's V4L interface, and enables access to full capabilities from
sysfs as well. Note that this is only effective when in analog mode.
It also will only work when the underlying digitizer's driver (saa7115
or cx25840 depending on the hardware) also implements the appropriate
functions.
The Zilog IR chip on HVR-1900 devices is held in reset when the device
initializes. We have to bring this chip out of reset before LIRC has
any chance of operating the chip. So do it.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
For Hauppauge 24xxx devices, the IR receiver is a custom piece of
logic that is very specific to the device. The pvrusb2 driver can
virtualize this to make it look like a more normal IR receiver found
in other Hauppauge devices. The decision of whether or not to enable
this virtualization however is a device-specific attribute, thus this
changeset.
place
The pvrusb2 driver currently supports two variants of the Hauppauge
PVR USB2. However there are other hardware types potentially
supportable, but the driver at the moment is not structured to make it
easy to describe these minor variations. This changeset is the first
set of changes to make such additional device support possible.
Device attributes are held in several tables all contained within
pvrusb2-devattr.c; all other device-specific driver behavior now
derives from these tables.
This is a new implementation for video pipeline control within the
pvrusb2 driver. Actual start/stop of the pipeline is moved to the
driver's kernel thread. Pipeline stages are controlled autonomously
based on surrounding pipeline or application control state. Kernel
thread management is also cleaned up and moved into the internal
control structure of the driver, solving a set up / tear down race
along the way. Better failure recovery is implemented with this new
control strategy. Also with this change comes better control of the
cx23416 encoder, building on additional information learned about the
peculiarities of controlling this part (this information was the
original trigger for this rework). With this change, overall encoder
stability should be considerably improved. Yes, this is a large
change for this driver, but due to the nature of the feature being
worked on, the changes are fairly pervasive and would be difficult to
break into smaller pieces with any semblence of step-wise stability.
This removes NOP implementations of i2c_algorithm.algo_control.
With this change, there are no implementations of this hook in
the kernel.org tree ... that hook seems about ripe to remove.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Reviewed-by: Mike Isely <isely@pobox.com>
* I2C adapters aren't expected to handle I2C_M_NOSTART unless they
really have to. As the pvrusb2 driver doesn't support it, I take it
that it doesn't need it so it shouldn't mention it at all.
* I2C_FUNC_SMBUS_EMUL includes I2C_FUNC_SMBUS_BYTE_DATA so listing
both is redundant.
Anyone using multiple PVR USB2 devices really only want one of them
acting as the actual IR receiver.
Implemented here is a new per-instance module option (ir_mode) which is
a flag to enable the IR receiver. The default is enabled.
IR reception is disabled by blocking access to the IR receiver chip in
the device.
This is a maintainability cleanup; use nice names for all the FX2
commands instead of raw bytes. This way we can easily find where we
issue FX commands.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com>
This bug caused uninitalized data to be returned during a G_TUNER status poll.
Clean up use of VIDIOC_G_TUNER; we now correctly gather info from all
the I2C client modules. Also abide by V4L2_TUNER_CAP_LOW
appropriately.
Declare the parent device of i2c_adapter devices each time we can
easily do so. It makes the i2c_adapter appear at the right place in
the device tree, rather than as a platform device.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Len Brown <len.brown@intel.com>
Cc: Jordan Crouse <jordan.crouse@amd.com>
Cc: Jody McIntyre <scjody@modernduck.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: v4l-dvb-maintainer@linuxtv.org
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Unlike 29xxx devices, the 24xxx model series does not have a dedicated
I2C device for reception of IR codes. Instead IR is handled directly
by the FX2 microcontroller and the results are communicated via
commands to the FX2. Rather than implement a whole new IR reception
pathway for 24xxx devices, this changeset instead emulates the
presence of the 29xxx device's I2C based IR receiver by intercepting
commands to that chip and issuing appropriate FX2 commands to do the
needed action. This has the result of allowing all the usual IR
frameworks (ir-kbd-i2c or lirc) to continue working unmodified for
24xxx devices.
Support for 24xxx devices was previously explicitly bracketed with
CONFIG_VIDEO_PVRUSB2_24XXX inside the code because we didn't trust the
stability of these changes. We trust it now; so there's no reason to
leave this out of the driver anymore.
This patch contains the following possible cleanups:
- make needlessly global code static
- #if 0 unused global functions
Implement V4L2 driver for the Hauppauge PVR USB2 TV tuner.
The Hauppauge PVR USB2 is a USB connected TV tuner with an embedded
cx23416 hardware MPEG2 encoder. There are two major variants of this
device; this driver handles both. Any V4L2 application which
understands MPEG2 video stream data should be able to work with this
device.
