path: root/drivers/media/video/saa7127.c
2010-10-21V4L/DVB: saa7127: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: saa7127: remove obsolete g_fmt supportHans Verkuil
2010-05-19V4L/DVB: saa7127: support new vbi ops to set/get VBI formatHans Verkuil
2010-05-19V4L/DVB: v4l: move vbi-specific video ops to a new vbi ops structHans Verkuil
Only a relatively small number of video receivers and transmitters actually support VBI. So start moving the vbi specific ops to an ops struct of their own. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13913): saa7127: Add support for generating SECAM output for the ↵Andy Walls
SAA712[89] chips This change fixes up saa7127_s_std() generate SECAM out, if the user has requested a 50 Hz video standard set that only contains a request for SECAM standards and not PAL. Only the SAA712[89] chips can generate SECAM, the SAA712[67] chips cannot. I was unclear on the burst start and end values - I couldn't figure out the units - so I left them the same as for the PAL systems. A the video decoders on both a PVR-350 (SAA7115) and an HVR-1600 (CX23418) identify the SECAM signal generated by a SAA7129 with this patch as SECAM. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10731): zoran i2c modules: remove i2c autoprobing support.Hans Verkuil
Zoran doesn't do autoprobing anymore, so remove support for this from the i2c modules. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-29V4L/DVB (10216): saa7127: fix broken S-Video with saa7129Martin Dauskardt
Register 0x2d has to be set differently in the saa7129 compared to the saa7127. This was not done correctly, so S-Video was broken in certain circumstances. This fixes a regression introduced in 2.6.28. Signed-off-by: Martin Dauskardt <martin.dauskardt@gmx.de> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9827): saa7127: convert to v4l2_subdev.Hans Verkuil
2008-10-17V4L/DVB (9240): saa7127: Fix two typosJean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8379): saa7127: Make device detection optionalJean Delvare
The saa7127 driver supports all of SAA7126, SAA7127, SAA7128 and SAA1729 devices. Declare all these devices, so that board drivers can tell which device is present, instead of always relying on auto-detection (which needs to write to the chip, eek!). We still need the detection for ivtv, so a special device name "saa7127_auto" can be used when the caller doesn't know exactly which device is present. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20v4l-dvb: remove legacy checks to allow support for kernels < 2.6.10Hans Verkuil
Also remove some blank lines that were used to split compat code at -devel tree. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-18i2c: Convert remaining new-style drivers to use module aliasingJean Delvare
Update all the remaining new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. Note that the tuner driver is a bit quirky at the moment, as it overwrites i2c_client.name with arbitrary strings. We write "tuner" back on remove, to make sure that driver cycling will work properly, but there may still be troublesome corner cases. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-01-25V4L/DVB (6867): saa7127: CodingStyle cleanupsHans Verkuil
2008-01-25V4L/DVB (6862): ivtv: really remove i2c legacy support from drivers that no ↵Hans Verkuil
longer need it For some reason the include header wasn't changed from v4l2-i2c-drv-legacy.h to v4l2-i2c-drv.h in the previous patch. This is now corrected. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6766): ivtv: remove i2c legacy support from drivers that no longer ↵Hans Verkuil
need it Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6465): Use correct error codes when chip is not recognizedHans Verkuil
If the chip isn't recognized, then the correct errors should be returned. The v4l2_i2c_attach() utility function will return 0 for all errors except -ENOMEM to provide proper compatibility support for the old I2C probing function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6456): saa7127: convert to bus-based I2C APIHans Verkuil
2007-10-09V4L/DVB (6116): ivtv: VBI cleanups and fixesHans Verkuil
Besides some VBI cleanups this patch also fixes a subtle problem with the VBI re-insertion stream where the PIO work handler wasn't called quickly enough, resulting in occasional corrupt data. Furthermore the CC output didn't disable CC correctly and at the right time, causing duplicates to be sent. An saa7127 fix for VPS output was also added: the wrong data was sent. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5306): Add support for VIDIOC_G_CHIP_IDENTHans Verkuil
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be used to detect which chips are on the board and based on that information selected register dumps can be made, making it easy to debug complicated media chips containing tens or hundreds of registers. This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5290): Add support for VIDIOC_INT_G/S_STD_OUTPUTHans Verkuil
Added VIDIOC_INT_G_STD_OUTPUT and VIDIOC_INT_S_STD_OUTPUT to allow drivers to set the TV standard for video output separately from the video capture. This is needed for cx23415 support where the decoder is separate from the encoder and can have a different TV standard. Modified the saa7127 module to listen to VIDIOC_INT_G/S_STD_OUTPUT instead of VIDIOC_G/S_STD. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5304): Improve chip matching in v4l2_registerHans Verkuil
The chip matching in struct v4l2_register for VIDIOC_DBG_G/S_REGISTER was rather primitive. It could not be extended to other busses besides i2c and it lacked a way to. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5163): Add checks for CAP_SYS_ADMIN to VIDIOC_DBG_G_REGISTERTrent Piepho
Before, root privileges were only needed to set hardware registers, not to read them. On some hardware, reading from the wrong place at the wrong time can hang the machine. So, to be consistent, root privileges are required to read registers on all hardware. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5146): Make VIDIOC_INT_[SG]_REGISTER ioctls no longer internal onlyTrent Piepho
The direct register access ioctls were defined as kernel internal only, but they are very useful for debugging hardware from userspace and are used as such. Officially export them. VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER Definition of ioctl and struct v4l2_register is moved from v4l2-common.h to videodev2.h. Types used in struct v4l2_register are changed to the userspace exportable versions (u32 -> __u32, etc). Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move the check into the video_ioctl2() dispatcher so it doesn't need to be duplicated in each driver's call-back function. CAP_SYS_ADMIN check is added to pvrusb2 (which doesn't use video_ioctl2). Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4110): Small bug in saa7127.cJose Alberto Reguero
Fix wrong wss debug info. Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-12V4L/DVB (3767): Pvr350 tv out (saa7127)Jose Alberto Reguero
Witout this patch tv out don't work properly with my pvr350 card. Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3608): Implement new routing commands in saa7127.cHans Verkuil
2006-01-11V4L/DVB (3345): Fixes some bad global variablesMauro Carvalho Chehab
- Debug global var is already used inside kernel. - v4l_dbg now expects the debug var - global vars inside msp34xx renamed to msp_* Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3278): convert diagnostics over to the new v4l2-common.h macros.Hans Verkuil
- Convert diagnostics over to the new v4l2-common.h macros. - deprecated tuner_debug option, the new option is debug. - renamed cx25840_debug to debug. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3123a): remove uneeded #if from V4L subsystemMauro Carvalho Chehab
- some uneeded #if were introduced by a previous patch. this patch removes these. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 5 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers/media/video and usb/media drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Rework client usage count, 2 of 3Jean Delvare
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't hurt if the usage count is actually never used for any given driver, and allows for nice code simplifications in i2c-core. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-22V4L/DVB (3191): Fix CC outputHans Verkuil
- CC data was swapped the wrong way around. - Enabling CC disabled XDS and vice versa: these two should be independent from one another. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-01[PATCH] V4L: Some funcions now static and I2C hw code for IRMauro Carvalho Chehab
- Some funcions are now declared as static - Added a I2C code for InfraRed. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (966.1) Removes Obsoleted i2c-compat.h from newer driversMauro Carvalho Chehab
Removed obsoleted i2c-compat.h file from cx25840, saa7115 and saa7127 drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (966) Authorship fixes for new ModulesHans Verkuil
Fixes Module Author macros Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l-944-added-driver-for-saa7127-video-tidyAndrew Morton
Remove unneeded (and undesirable) casts. Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Chris Kennedy <c@groovy.org> Cc: Kevin Thayer <nufan_wfk@yahoo.com> Cc: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (944) added driver for saa7127 video decoderHans Verkuil
- Added driver for saa7127 video decoder. Driver authors:Hans Verkuil, Chris Kennedy, Kevin Thayer Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
