Right now the composite sound input doesn't work on AverTV 307 because of
the wrong mux setup. The composite sound is routed via an external
4channel multiplexer controlled by GPIO, while the code assumes an internal
multiplexer instead.
Presumably this was a copy/paste error, and noone have ever tested the
functionality.
With the attached patch it works properly, which gives me an ability to
finally watch the cable TV under linux.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Acked-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Sound recording doesn't work for this card because ACNI and ACPF
are not set before snd_card_saa7134_capture_prepare(). As a result
timeout occurs. These registers aren't poked because thread
never gets wake up signal. ACNI initialization is done in the
thread.
Sound is muted when capture stops. Shouldn't be because it may
be used during TV playback.
Signed-off-by: Rafal Bilski <rafalbilski@interia.pl>
Using Encore's key codes, we needn't add any additional key table.
Signed-off-by: Tony Wan <wankai@sjtu.org>
Support the 10moons TM300 TV card (so called TV Master 3), which is a
10moons saa7130 based board. Here not include features for the
IR-remote.
It has been tested using TVTIME. The card was auto-detected and all the
input sources worked correct with sound.
Maintainer's notice: I needed to re-number the board, since the board
number conflicted with a patch committed previously.
Signed-off-by: James T Klaas <jklaas@appalachian.dyndns.org>
Add support for the "Elitegroup ECS TVP3XP FM1246", the "KWorld DVB-T
210", and the Animation Technologies LR214 Rev F onwards (SAA7131) to
the saa7134 driver.
Also rename the LR214WF to the LR214 Rev E or ealier (SAA7135), to match
what we've seen on boards in the field.
Changed the comment on the Lifeview cards to indicate Rev E and earlier
versus Rev F and later, together with a chip indicator, following
feedback from Peter Missel <peter.missel@onlinehome.de>.
Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
Fix audio input source for capturing(playing) audio on AverTv Go 007 cards.
Signed-off-by: Damian Minkov <damencho@damencho.com>
The new name fits to what it is and what is on the box.
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
There are 2 new entries for p7131 boards and one correction for a board
with LNA.
It is a Lifeview Duo with a different ID
Signed-off-by: Peter Missel <peter.missel@onlinehome.de>
Signed-off-by: Markus Rechberger <mrechberger@gmail.com>
This change supplies a more generic version of the tuner callback.
The tuner struct now has a function pointer
int (*tuner_callback) (void *dev, int command, int arg)
additionally to a int config parameter.
both can be set through the TUNER_SET_TYPE_ADDR client call.
Note that the meaning of the parameters depend on the tuner type.
The patch moves the tda827x dvb tuning code to a separate module
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
There are card variants supporting FM radio through tda8275.
This patch contains
- new tuning code for the tda827xa silicon tuner.
- controls the preamplifier of some boards with this tuner.
- support for the Philips Tiger S hybrid DVB-T reference design.
- reworked the saa7134-dvb modulue to get rid of most of the
small board specific functions.
These entries mainly are to support configurations of the tda827x
silicon tuner with a preamplifier.
The values can be set throgh the attach inform or through
the extended TUNER_SET_TYPE_ADDR client call. The function pointer
will only be updated if the parameter is not NULL.
Since a typecast is necessary to set the pointer, i added a typedef for
this pointer (tuner_gpio_func_t) in tuner.h
Add support for Terratec Cinergy HT PCI
Signed-off-by: Giorgio Moscardi <software@sukkology.net>
Signed-off-by: Juan Pablo Sormani <sorman@gmail.com>
Add a board definition for the Encore ENL-TV card, and
adds its PCI subdevice to the ID table.
This makes a second CVBS input available.
Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de>
Besides adding the board specific code, this patch moves
the RC5 decoding code from bt8xx to ir-functions.c to make it available
for all drivers.
Signed-off-by: Marc Fargas <telenieko.telenieko.com>
- MSI TV@nywhere Plus. Fix radio, S-Video and external analog audio in
as far we can know currently.
This patch adds support for the remote control bundled with the
Hauppauge HVR1110
Signed-off-by: Thomas Genty <tomlohave@gmail.com>
Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
This is a hybrid cardbus module. Besides the card support, i
modified the definition names for AGC and GPIO of the tda10046.
This patch adds support for the Hauppauge WinTV-HVR1110 DVB-T/Hybrid
This board has the same PCI ID as the T200, so the exact board type
is determined from the eeprom.
The original patch was provided by Francis Barber <fedora@barber-family.id.au>
This card has no firmware eeprom. The old version still should not
need a firmware file due to an undocumented feature of the TDA10046.
The patch also includes Hermann Pitton's proposal for improved
antenna switch handling
This is just an additional analog board configuration.
Signed-off-by: Mikhail Fedotov <mo_fedotov.mail.ru>
The driver supports analog TV, radio and DVB-T.
It is based on the preliminary patch by Pierluigi Rolando.
This changes it from TDA8290 which is allegedly very unlikely to TD1316 which
is allegedly very likely. I didn't get it to work with either, but expected
that this got applied when Mauro sent it to me, so here it goes again; feel
free to drop it to the floor. :-)
Signed-off-by: Petr Baudis <pasky@ucw.cz>
The remote as well as the GPIO interface is the same as what comes with 777.
For an example of mplayer lirc configuration, see
http://pasky.or.cz/~pasky/dev/v4l/lircrc
I didn't test it personally since I don't have this card, but A16AR uses the
same interface and that one certainly does work perfectly (see the next patch).
This patch was originally sent in
http://marc.theaimsgroup.com/?l=linux-video&m=114743413825375&w=2
https://www.redhat.com/mailman/private/video4linux-list/2006-May/msg00103.html
but never got applied. This version has some trivial modifications and drops
the weird gpio hack (it's not clear what practical purpose does it serve).
Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net>
This is a analog DVB-T hybrid board
This adds support for a hybrid PAL/DVB/FM card. Unfortunately I tested
only the DVB since I don't have any proper antenna available and I can
receive even the DVB just barely so; I can hear noise in the FM part but I
couldn't catch any station, then again I don't have an FM antenna either.
The PAL/FM and IR control data are based on what I harvested on the 'net.
Perhaps I or someone else will fix them if they turn out to be wrong.
Add card support for Proteus Pro 2309, based on saa7130 bridge
Signed-off-by: Michal Majchrowicz <mmajchrowicz@gmail.com>
Add support for Acorp TV134DS and FlyDVB-S cards (both based on
tda10086+tda826x)
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
It is just another Lifeview clone
The change is just an additional PCI ID
Analog TV, CVBS, S-video and DVB-T are working,
DVB-S not yet
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Add detection for the LifeView3000 NTSC model (right now the PAL version is
the only one in there, which is sort of annoying for me living in the US
and all.. sigh...)
This is one of those things that I like to classify "as a works for me so
take it or leave it" :-) . Not that worried because its an $18 video
capture card that didn't look it was selling to well in the US, but then
again who knows.
The documentation needs updating too I bet but its behind anyways usually
to what is in the code.
Signed-off-by: Zac Bowling <zac@zacbowling.com>
initialization
There is a missing break in card initialization function. Might screw
up initialization of Terratec Cinergy 400 TV.
Signed-off-by: Mikhail Gusarov <dottedmag@dottedmag.net>
There seem to be many variants of this cards with different
feature sets. This entry supports
analog TV, CVBS and s-video input, FM radio and DVB-T
if they are supported by the hardware.
The .vmux entry needs to be 1 instead of 0
Added ID entries for the Genius VideoWonder DVB-T
and the LifeView FlyTV Platinum Gold
The device, Medion 7134, has two saa7134 chips on it, but only one of them
is functional in the current saa7134 driver.
This patch adds autodetection for the second, unsupported saa7134 chip,
as SAA7134_BOARD_MD7134_BRIDGE_2, and displays a message to the user
(in dmesg) indicating that the second chip isn't yet functional.
This is useful for users, since two instances of the saa7134 driver
will spawn. This patch will prevent confusion by warning the user that
only one of the chips on the board are functional.
There are other versions of the SAA7134_BOARD_MD7134 with only a single
saa7134 bridge/decoder -- those devices will not be affected by this patch.
Only devices containing the second chip will display the warning.
There are already some supported devices that contain two
saa713x chips on-board, where only one of these chips is
currently functional in the driver.
We are already printing a warning message for the second
saa7134 decoder in SAA7134_BOARD_AVERMEDIA_A169_B. This
patch alters that case to make it generic, so that other
cards in the same situation can use it.
- Added support for AVerMedia A169 Dual Analog tuner card
(dual saa7134 decoders - only 1 working right now)
- Added autodetection for both parts of the card.
It shows up like 2 cards, B1 and B
- Enabled tuner B1, SVIDEO on B1 and composite1 through SVIDEO,
FIXME: B is more or less dead at this point and I suspect the
FM-radio is on the B part of the board
Signed-off-by: Rickard Osser <ricky@osser.se>
- added tuner_lg_taln_pal_secam_ranges
- renamed tuner 66 from TUNER_LG_NTSC_TALN_MINI to TUNER_LG_TALN
- updated FlyTV mini Asus Digimatrix with new tuner
Thanks-to: Rickard Osser <ricky@osser.se>
