path: root/drivers/media/video/saa7134/saa7134-empress.c
2012-08-15[media] rename most media/video pci drivers to media/pciMauro Carvalho Chehab
Rename all PCI drivers with their own directory under drivers/media/video into drivers/media/pci and update the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] Stop using linux/version.h on most video driversMauro Carvalho Chehab
All the modified drivers didn't have any version increment since Jan, 1 2011. Several of them didn't have any version increment for a long time, even having new features and important bug fixes happening. As we're now filling the QUERYCAP version with the current Kernel Release, we don't need to maintain a per-driver version control anymore. So, let's just use the default. In order to preserve the Kernel module version history, a KERNEL_VERSION() macro were added to all modified drivers, and the extraver number were incremented. I opted to preserve the per-driver version control to a few pwc, pvrusb2, s2255, s5p-fimc and sh_vou. A few drivers are still using the legacy way to handle ioctl's. So, we can't do such change on them, otherwise, they'll break. Those are: uvc, et61x251 and sn9c102. The rationale is that the per-driver version control seems to be actively maintained on those. Yet, I think that the better for them would be to just use the default version numbering, instead of doing that by themselves. While here, removed a few uneeded include linux/version.h Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] saa7134-empress: add missing MPEG controlsHans Verkuil
Reported by, and based on a patch from, Martin Dauskardt. The AUDIO_AC3_BITRATE control is still missing from this list, but such optional controls are a bit hard to handle. This will be fixed automatically when we switch to the control framework. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Reported-by: Martin Dauskardt <martin.dauskardt@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-24media/video: don't use flush_scheduled_work()Tejun Heo
This patch converts the remaining users of flush_scheduled_work() in media/video. * bttv-input.c and cx23885-input.c don't use workqueue at all. No need to flush. * Make omap24xxcam.c and saa7134-empress.c flush the used work directly. * In fd_defio.c, replace cancel_delayed_work() + flush_scheduled_work() with cancel_delayed_work_sync(). While at it, replace the deprecated cancel_rearming_delayed_work() with cancel_delayed_work_sync(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21V4L/DVB: videobuf: add ext_lock argument to the queue init functionsHans Verkuil
Add an ext_lock argument to the videobuf init functions. This allows drivers to pass the vdev->lock pointer (or any other externally held lock) to videobuf. For now all drivers just pass NULL. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: saa7134: convert to use the new mbus APIHans Verkuil
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-29V4L/DVB: saa7134: remove stray unlock_kernelHans Verkuil
An earlier commit removed the lock_kernel/unlock_kernel pair but forgot to remove the unlock_kernel call in the cleanup path at the end of the function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13556): v4l: Remove unneeded video_device::minor assignmentsLaurent Pinchart
Now that the video_device registration is tested using video_is_registered(), drivers don't need to initialize the video_device::minor field to -1 anymore. Remove those unneeded assignments. [mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13555): v4l: Use video_device_node_name() instead of the minor numberLaurent Pinchart
Instead of using the minor number in kernel log messages, use the device node name as returned by the video_device_node_name() function. This makes debug, informational and error messages easier to understand for end users. [mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13554a): v4l: Use the video_drvdata function in driversLaurent Pinchart
Fix all device drivers to use the video_drvdata function instead of maintaining a local list of minor to private data mappings. Call video_set_drvdata to register the driver private pointer when not already done. Where applicable, the local list of mappings is completely removed when it becomes unused. [mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13550): v4l: Use the new video_device_node_name functionLaurent Pinchart
Fix all device drivers to use the new video_device_node_name function. This also strips kernel log messages from the "/dev/" prefix, has the device node location is a userspace policy decision unknown to the kernel. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16V4L/DVB (11938): big rework of TS for saa7134Dmitri Belimov
1. Add start/stop TS function. 2. Move setup DMA of TS to DMA function. 3. Write support cupture via MMAP 4. Rework startup and finish process, remove simple FSM. Tested-by: Hermann Pitton <hermann-pitton@arcor.de> Tested-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Alexey Osipov <lion-simba@pridelands.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11734): remove hw reset of MPEG encoder when lost/found seq.Dmitri Belimov
When we capture signal from composite input offen lost and found syncro sequence. In this case the MPEG coder hardware reset after each lost/found event. The image has a lot of artefactes. This patch remove hardware reset of MPEG encoder. This is patch from our customer. I checked this. With my best regards, Dmitry. Signed-off-by: Alexey Osipov <lion-simba@pridelands.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11253): saa7134: fix RTD Embedded Technologies VFG7350 support.Hans Verkuil
This card has the saa6752hs on 7-bit address 0x21 instead of 0x20. Add support in the card definition struct to select which address to use and update the definitions accordingly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10698): v4l2-common: remove v4l2_ctrl_query_fill_stdHans Verkuil
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had. It doesn't add anything valuable that cannot be expressed equally well with v4l2_ctrl_query_fill and only adds overhead. Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it from v4l2_common.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10544): v4l2-common: add comments warning that about the sort orderHans Verkuil
Control arrays as are used with v4l2_ctrl_next must be sorted from low to high. Add a comment at the top of all such arrays to warn about this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10247): saa7134: convert to the new v4l2 framework.Hans Verkuil
Register v4l2_device and switch to v4l2_subdev to access the i2c modules. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9327): v4l: use video_device.num instead of minor in video%dHans Verkuil
The kernel number of a v4l2 node (e.g. videoX, radioX or vbiX) is now independent of the minor number. So instead of using the minor field of the video_device struct one has to use the num field: this always contains the kernel number of the device node. I forgot about this when I did the v4l2 core change, so this patch converts all drivers that use it in one go. Luckily the change is trivial. Cc: michael@mihu.de Cc: mchehab@infradead.org Cc: corbet@lwn.net Cc: luca.risolia@studio.unibo.it Cc: isely@pobox.com Cc: pe1rxq@amsat.org Cc: royale@zerezo.com Cc: mkrufky@linuxtv.org Cc: stoth@linuxtv.org Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8917): saa7134-empress: fix changing the capture standard for ↵Hans Verkuil
non-tuner inputs When changing the standard the saa6752hs was not updated unless the input was the TV tuner. The saa6752hs should be updated regardless of the input. In addition the S_STD and G_STD ioctls for the mpeg video device didn't do anything. This is now fixed: they behave just like S_STD and G_STD on the video0 device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8795): saa7134-empress: insert leading null bytes for Beholder M6 ↵Dmitry Belimov
empress cards Additional code to improve the init sequence and add board type tests were done by Hans Verkuil. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8639): saa6752hs: cleanup and add AC-3 supportHans Verkuil
Cleaned up the saa6752hs i2c driver. Add AC-3 support. Add VIDIOC_CHIP_IDENT support. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8613): v4l: move BKL down to the driver level.Hans Verkuil
The BKL is now moved from the video_open function in v4l2-dev.c to the various drivers. It seems about a third of the drivers already has a lock of some sort protecting the open(), another third uses video_exclusive_open (yuck!) and the last third required adding the BKL in their open function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-27V4L/DVB (8506): empress: fix control handling oopsHans Verkuil
2008-07-27V4L/DVB (8505): saa7134-empress.c: fix deadlockHans Verkuil
ts_release() locked a mutex that videobuf_stop() also tried to obtain. But ts_release() shouldn't hold that mutex at all. Make empress_users atomic as well to prevent possible race condition. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8482): videodev: move all ioctl callbacks to a new v4l2_ioctl_ops ↵Hans Verkuil
struct All ioctl callbacks are now stored in a new v4l2_ioctl_ops struct. Drivers fill in a const struct v4l2_ioctl_ops and video_device just contains a const pointer to it. This ensures a clean separation between the const ops struct and the non-const video_device struct. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8428): videodev: rename 'dev' to 'parent'Hans Verkuil
The field 'dev' is not the video device, but the parent of the video device. Rename accordingly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8151): saa7134-empress: fix MPEG control supportHans Verkuil
The MPEG controls could not be enumerated and so could not be read or set through the v4l2-ctl utility or shown in control panels. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (7949): videodev: renamed the vidioc_*_fmt_* callbacksHans Verkuil
The naming for the callbacks that handle the VIDIOC_ENUM_FMT and VIDIOC_S/G/TRY_FMT ioctls was very confusing. Renamed it to match the v4l2_buf_type name. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-26V4L/DVB (8108): Fix open/close race in saa7134Arjan van de Ven
The saa7134 driver uses a (non-atomic) variable in an attempt to only allow one opener of the device (how it deals with sending the fd over unix sockets I don't know). Unfortunately, the release function first decrements this variable, and THEN goes on to disable more of the device. This allows for a race where another opener of the device comes in after the decrement of the variable, configures the hardware just to then see the hardware be disabled by the rest of the release function. This patch makes the release function use the same lock as the open function to protect the hardware as well as the variable (which now at least has some locking to protect it). Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-26V4L/DVB (8022): saa7134: fix race between opening and closing the deviceMarcin Slusarz
decrementing dev->empress_users should be done as last action of ts_release, because it sleeps and write access to dev->empress_started is not protected in any way (additionally closing thread could mute audio after opening thread unmuted it) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-26V4L/DVB (8020): Fix callbacks functions of saa7134_empressDmitri Belimov
If I try v4l2-ctl --all -d /dev/video1 or v4l2-ctl --streamon -d /dev/video1 modules crashed: *pde = 00000000 Modules linked in: ac battery loop saa7134_empress(F) saa6752hs(F) tuner_simple(F) tuner_types(F) tea5767(F) tda9887(F) tda8290(F) tea5761(F) tuner(F) snd_cmipci snd_pcm snd_page_alloc snd_opl3_lib saa7134(F) snd_mpu401 parport_pc parport snd_timer snd_hwdep snd_mpu401_uart floppy rtc psmouse videodev(F) v4l1_compat(F) compat_ioctl32(F) v4l2_common(F) videobuf_dma_sg(F) videobuf_core(F) snd_rawmidi snd_seq_device via_ircc pcspkr snd ir_kbd_i2c(F) irda soundcore ir_common(F) crc_ccitt tveeprom(F) i2c_viapro i2c_core button via_agp agpgart evdev ext3 jbd mbcache ide_cd_mod cdrom ide_disk 8139cp via82cxxx ide_core 8139too mii ehci_hcd uhci_hcd usbcore thermal processor fan EIP is at __mutex_lock_slowpath+0x29/0x7b DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process v4l2-ctl (pid: 2742, ti=ced7e000 task=cf325260 task.ti=ced7e000) d08e5411 00000000 ced7fed4 00000000 d0975acb 40045612 cfa86ee0 ffffffcd cf2b7000 ced7febc c03858d6 00000019 00000292 d089e4ec cf37b2a0 d089e4a0 Call Trace: [<c028b52b>] mutex_lock+0xa/0xb [<d08e5411>] videobuf_streamon+0xf/0x9a [videobuf_core] [<d0975acb>] __video_do_ioctl+0x136a/0x2d68 [videodev] [<d088f789>] task_end_request+0x40/0x51 [ide_core] [<d088c4aa>] ide_intr+0x187/0x192 [ide_core] [<c016a551>] mntput_no_expire+0x11/0x64 [<c0160b1c>] path_walk+0x90/0x98 [<d0977738>] video_ioctl2+0x173/0x239 [videodev] [<c0140936>] filemap_fault+0x202/0x370 [<c014930a>] __do_fault+0x2c3/0x2fe [<c014ab03>] handle_mm_fault+0x22a/0x49f [<c0162737>] vfs_ioctl+0x47/0x5d [<c0162992>] do_vfs_ioctl+0x245/0x258 [<c01629e6>] sys_ioctl+0x41/0x5b [<c01036a6>] sysenter_past_esp+0x5f/0x85 ======================= After this fix all of that commands works without problem: v4l2-ctl --all -d /dev/video1 Driver Info: Driver name : saa7134 Card type : Beholder BeholdTV M6 Extra Bus info : PCI:0000:00:0d.0 Driver version: 526 Capabilities : 0x05000001 Video Capture Read/Write Streaming Format Video Capture: Width/Height : 720/576 Pixel Format : MPEG Field : Any Bytes per Line: 0 Size Image : 58656 Colorspace : Unknown (00000000) Video input : 0 (CCIR656) Video Standard = 0x000000ff PAL-B/B1/G/H/I/D/D1/K P.S. data from /dev/video1 is not correct :(( . Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7975): saa7134_empressDmitri Belimov
This is patch for fix data structure in querycap syscall. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7526): media/video/saa7134 replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7237): Convert videobuf-dma-sg to generic DMA APIGuennadi Liakhovetski
videobuf-dma-sg does not need to depend on PCI. Switch it to using generic DMA API, convert all affected drivers, relax Kconfig restriction, improve compile-time type checking, fix some Coding Style violations while at it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7122): saa7134-empress: Remove back lockMauro Carvalho Chehab
videobuf functions at close() method already locks videobuf. It makes no sense to keep the locking at empress close() method. There is also a lock at open() method. I'm not sure if it is safe to remove the locking there. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7121): Renames videobuf lock to vb_lockMauro Carvalho Chehab
This helps to identify where vb_lock is being used, and find missusages of the locks. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6793): Convert saa7134-empress to video_ioctl2Mauro Carvalho Chehab
saa7134 were converted to video_ioctl2, but saa7134_empress weren't. This broke saa7134-empress, since it were dependent of saa7134_common_ioctl. With the conversion, the module had a size decrease of 436 bytes on x86_64: text data bss dec hex filename 5196 4912 4 10112 2780 old/saa7134-empress.ko 4760 4912 4 9676 25cc new/saa7134-empress.ko Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-12-11V4L/DVB (6602): V4L: Convert videobuf drivers to videobuf_stopBrandon Philips
Drivers were using cookie cutter code for stopping the read/stream. Use the new videobuf_stop function which is lock safe. Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-22V4L/DVB (6321): Remove obsolete VIDIOC_S/G_MPEGCOMP ioctlsHans Verkuil
Remove the obsolete VIDIOC_G_MPEGCOMP and VIDIOC_S_MPEGCOMP ioctls from the V4L2 API as per the removal schedule (October 2007). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-22V4L/DVB (6320): v4l core: remove the unused .hardware V4L1 fieldMauro Carvalho Chehab
struct video_device used to define a .hardware field. While initialized on severl drivers, this field is never used inside V4L. However, drivers using it need to include the old V4L1 header. This seems to cause compilation troubles with some random configs. Better just to remove it from all drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6314): saa7134: Replace list_for_each+list_entry with ↵Trent Piepho
list_for_each_entry A couple loops weren't changed because they expected the loop iterator to be left as NULL if the list was empty. Maybe the code should just check for that first, then loop? Adjust some of the loop logic to be simpler. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6252): Adapt drivers to use the newer videobuf modulesMauro Carvalho Chehab
PCI-dependent videobuf_foo methods were renamed as videobuf_pci_foo. Also, videobuf_dmabuf is now part of videobuf-dma-sg private struct. So, to access it, a subroutine call is needed. This patch renames all occurences of those function calls to be consistent with the video-buf split. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981 Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
