path: root/drivers/media/video/soc_camera.c
2011-07-27[media] V4L: soc-camera: remove soc-camera bus and devices on itGuennadi Liakhovetski
Now that v4l2 subdevices have got their own device objects, having one more device in soc-camera clients became redundant and confusing. This patch removes those devices and the soc-camera bus, they used to reside on. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: soc-camera: un-export the soc-camera busGuennadi Liakhovetski
The soc-camera bus is now completely local again. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: soc-camera: group struct field initialisations togetherGuennadi Liakhovetski
2011-07-27[media] V4L: soc-camera: remove now unused soc-camera specific PM hooksGuennadi Liakhovetski
soc-camera host drivers shall be implementing their PM, using standard kernel methods, soc-camera specific hooks can die. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: soc-camera: remove several now unused soc-camera client operationsGuennadi Liakhovetski
This patch removes .enum_input(), .suspend() and .resume() soc-camera client operations. Functionality, provided by .enum_input(), if needed, can be implemented using the v4l2-subdev API. As for .suspend() and .resume(), the only client driver, implementing these methods has been mt9m111, and the only host driver, using them has been pxa-camera. Now that both those drivers have been converted to the standard subdev .s_power() operation, .suspend() and .resume() can be removed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-06-01[media] soc_camera: preserve const attributeMauro Carvalho Chehab
drivers/media/video/soc_camera.c: In function ‘soc_camera_video_start’: drivers/media/video/soc_camera.c:1515: warning: initialization discards qualifiers from pointer target type Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] V4L: soc-camera: a missing mediabus code -> fourcc translation is ↵Guennadi Liakhovetski
not critical soc_mbus_get_fmtdesc() returning NULL means only, that no standard mediabus code -> fourcc conversion is known, this shouldn't be treated as an error by drivers. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] V4L: soc-camera: add a livecrop host operationGuennadi Liakhovetski
Add an soc-camera host livecrop operation to implement live zoom. If a host driver implements it, it should take care to preserve output frame format, then live crop doesn't break streaming. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-04[media] V4L: soc-camera: regression fix: calculate .sizeimage in soc_camera.cSergio Aguirre
A recent patch has given individual soc-camera host drivers a possibility to calculate .sizeimage and .bytesperline pixel format fields internally, however, some drivers relied on the core calculating these values for them, following a default algorithm. This patch restores the default calculation for such drivers. Based on initial patch by Guennadi Liakhovetski, found here: http://www.spinics.net/lists/linux-media/msg31282.html Except that this covers try_fmt aswell. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-13[media] soc-camera: don't dereference I2C client after it has been removedGuennadi Liakhovetski
i2c_unregister_device() frees the I2C client, so, dereferencing it afterwards is a bug, that leads to Oopses. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-13[media] soc-camera: fix a recent multi-camera breakage on sh-mobileGuennadi Liakhovetski
With the introduction of CSI2 support on sh-mobile, the host driver switched to using v4l2_device_call_until_err() with grp_id == 0 to call subdev operations on the sensor and the CSI2 subdev. However, this has broken multi-client set ups like the one on migor, because that way all operations get called on both clients. To fix this add a grp_id and set it to the client private context. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTUREGuennadi Liakhovetski
The soc-camera core accesses the "pix" member of the struct v4l2_format::fmt union, which is only valid for V4L2_BUF_TYPE_VIDEO_CAPTURE streams. This patch adds explicit checks for this to {g,s,try}_fmt methods. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: soc-camera: Store negotiated buffer settingsSergio Aguirre
This fixes the problem in which a host driver sets a personalized sizeimage or bytesperline field, and gets ignored when doing G_FMT. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] V4L: soc-camera: extend to also support videobuf2Guennadi Liakhovetski
Extend soc-camera core to also support the videobuf2 API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] V4L: soc-camera: start stream after queueing the buffersAnatolij Gustschin
Some camera systems have strong requirement for capturing an exact number of frames after starting the stream and do not tolerate losing captured frames. By starting the stream after the videobuf has queued the buffers, we ensure that no frame will be lost. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] V4L: soc-camera: add enum-frame-size ioctlQing Xu
add vidioc_enum_framesizes implementation, follow default_g_parm() and g_mbus_fmt() method Signed-off-by: Qing Xu <qingx@marvell.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] soc_camera: Add the ability to bind regulators to soc_camedra devicesAlberto Panizzo
In certain machines, camera devices are supplied directly by a number of regulators. This patch add the ability to drive these regulators directly by the soc_camera driver. Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] v4l: soc-camera: switch to .unlocked_ioctlGuennadi Liakhovetski
Use the V4L mutex infrastructure in soc-camera core and drivers and switch to .unlocked_ioctl. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-25[media] v4l: soc-camera: fix multiple simultaneous user caseGuennadi Liakhovetski
A recent patch has introduced a regression, whereby a second open of an soc-camera video device breaks the running capture. This patch fixes this bug by guaranteeing, that video buffers get initialised only during the first open of the device node. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-22[media] v4l: Remove module_name argument to the v4l2_i2c_new_subdev* functionsLaurent Pinchart
The argument isn't used anymore by the functions, remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-22[media] soc_camera: Don't use module names to load I2C modulesLaurent Pinchart
With the v4l2_i2c_new_subdev* functions now supporting loading modules based on modaliases, remove the module names hardcoded in platform data and pass a NULL module name to those functions. All corresponding I2C modules have been checked, and all of them include a module aliases table with names corresponding to what the soc_camera platform data uses. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] SoC Camera: add support for g_parm / s_parm operationsJanusz Krzysztofik
This patch adds support for g_parm / s_parm operations to the SoC Camera framework. It is usefull for checking/setting camera frame rate. Example usage can be found in the previous patch from this series, "SoC Camera: add driver for OV6650 sensor". Created and tested against linux-2.6.36-rc3 on Amstrad Delta. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: soc-camera: allow only one video queue per deviceGuennadi Liakhovetski
Multiple user-space application instances can open the same video device, but it only makes sense for one of them to manage the videobuffer queue and set video format of the device. Restrict soc-camera respectively. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l: Use v4l2_get_subdevdata instead of accessing v4l2_subdev::privLaurent Pinchart
Replace direct access to the v4l2_subdev priv field with the inline v4l2_get_subdevdata method. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: soc-camera: prohibit S_CROP, if internal G_CROP has failedGuennadi Liakhovetski
There is no sense in trying to set cropping if we cannot get current one from the host driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: V4L2: soc-camera: export soc-camera bus type for notificationsGuennadi Liakhovetski
2010-06-01V4L/DVB: v4l2-subdev.h: fix enum_mbus_fmt prototypeHans Verkuil
enum_mbus_fmt received an index argument that was defined as an int instead of an unsigned int. This is now fixed. This had the knock-on effect that the index argument in the callback get_formats in soc_camera.h also had to be changed to unsigned int. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: soc-camera: update commentGuennadi Liakhovetski
soc-camera no longer requires .set_crop() implementations to update their argument. Update the commentary. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: soc-camera: add runtime pm support for subdevicesMauro Carvalho Chehab
To save power soc-camera powers subdevices down, when they are not in use, if this is supported by the platform. However, the V4L standard dictates, that video nodes shall preserve configuration between uses. This requires runtime power management, which is implemented by this patch. It allows subdevice drivers to specify their runtime power-management methods, by assigning a type to the video device. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26soc-camera: add support for VIDIOC_S_PARM and VIDIOC_G_PARM ioctlsGuennadi Liakhovetski
Just pass VIDIOC_S_PARM and VIDIOC_G_PARM down to host drivers. So far no special handling in soc-camera core. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26soc-camera: return -ENODEV if sensor is missingMagnus Damm
Update the soc-camera i2c code to return -ENODEV if a camera sensor is missing instead of -ENOMEM. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13659): soc-camera: convert to the new mediabus APIGuennadi Liakhovetski
Convert soc-camera core and all soc-camera drivers to the new mediabus API. This also takes soc-camera client drivers one step closer to also be usable with generic v4l2-subdev host drivers. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13645): soc-camera: fix multi-line comment coding styleGuennadi Liakhovetski
2009-12-16V4L/DVB (13556): v4l: Remove unneeded video_device::minor assignmentsLaurent Pinchart
Now that the video_device registration is tested using video_is_registered(), drivers don't need to initialize the video_device::minor field to -1 anymore. Remove those unneeded assignments. [mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-11-26V4L/DVB (13344): soc-camera: properly initialise the device object when reusingGuennadi Liakhovetski
Commit ef373189f62413803b7b816c972fc154c488cdc0 "fix use-after-free Oops, resulting from a driver-core API change" fixed the Oops, but didn't correct missing device object initialisation. This patch makes unloading and reloading of soc-camera host- and client-drivers possible again. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-11-07V4L/DVB (13132): fix use-after-free Oops, resulting from a driver-core API ↵Guennadi Liakhovetski
change Commit b4028437876866aba4747a655ede00f892089e14 has broken again re-use of device objects across device_register() / device_unregister() cycles. Fix soc-camera by nullifying the struct after device_unregister(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12580): soc-camera: remove now unneeded subdevice group ID assignmentsGuennadi Liakhovetski
Since we are not using v4l2_device_call_* calls any more, we don't need to initialise subdevice .grp_id any more. This also fixes compiler warnings on 64-bit platforms. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12536): soc-camera: remove .gain and .exposure struct ↵Guennadi Liakhovetski
soc_camera_device members This makes the soc-camera interface for V4L2 subdevices thinner yet. Handle gain and exposure internally in each driver just like all other controls. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12535): soc-camera: remove .init() and .release() methods from ↵Guennadi Liakhovetski
struct soc_camera_ops Remove unneeded soc-camera operations, this also makes the soc-camera API to v4l2 subdevices thinner. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12534): soc-camera: V4L2 API compliant scaling (S_FMT) and cropping ↵Guennadi Liakhovetski
(S_CROP) The initial soc-camera scaling and cropping implementation turned out to be incompliant with the V4L2 API, e.g., it expected the user to specify cropping in output window pixels, instead of input window pixels. This patch converts the soc-camera core and all drivers to comply with the standard. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12532): soc-camera: Use camera device object for core outputGuennadi Liakhovetski
2009-09-19V4L/DVB (12530): soc-camera: switch to using v4l2_subdev_call()Guennadi Liakhovetski
Use v4l2_subdev_call() instead of v4l2_device_call_until_err() in all host drivers and in soc-camera core. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12529): soc-camera: switch to s_crop v4l2-subdev video operationGuennadi Liakhovetski
Remove set_crop soc-camera device method and switch to s_crop from v4l2-subdev video operations. Also extend non-i2c drivers to also hold a pointer to their v4l2-subdev instance in control device driver-data, i.e., in dev_get_drvdata((struct device *)to_soc_camera_control(icd)) Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12525): soc-camera: prohibit geometry change with initialised buffersGuennadi Liakhovetski
Prohibit S_FMT and S_CROP with a different window width or height after video buffer initialisation. This simplifies the work to be done in specific host and client drivers, and it doesn't seem to make much sense to allow these changes. We do however allow S_CROP with equal width and height to just move the window, this doesn't affect video buffer management and is usually easy enough to implement. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12524): soc-camera: S_CROP V4L2 API compliance fixGuennadi Liakhovetski
V4L2 API mandates, that drivers do not update the argument of the S_CROP ioctl() with the actual geometry. Comply. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12521): soc-camera: use .s_std() from struct v4l2_subdev_core_opsGuennadi Liakhovetski
Remove .set_std() method from struct soc_camera_ops, use .s_std() from struct v4l2_subdev_core_ops instead. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12519): soc-camera: put pixel format initialisation back in probe, ↵Guennadi Liakhovetski
add .put_formats() The move of format translation initialisation into soc_camera_open() was temporary for the soc-camera as platform driver intermediate step, put it back into soc_camera_probe(). Also add a .put_formats() method to soc_camera_host_ops to free any resources host driver might have allocated in .get_formats(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12515): soc-camera: use struct v4l2_rect in struct soc_camera_deviceGuennadi Liakhovetski
Switch to using struct v4l2_rect in struct soc_camera_device for uniformity and simplicity. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12513): soc-camera: add support for camera-host controlsGuennadi Liakhovetski
Until now soc-camera only supported client (sensor) controls. This patch enables camera-host drivers to implement their own controls too. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
