Now that v4l2 subdevices have got their own device objects, having
one more device in soc-camera clients became redundant and confusing.
This patch removes those devices and the soc-camera bus, they used to
reside on.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Paul Mundt <lethal@linux-sh.org>
These function are needed to use camera.
This patch was tested with sh_mobile_ceu_camera
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
enum_mbus_fmt received an index argument that was defined as an int instead
of an unsigned int. This is now fixed. This had the knock-on effect that the
index argument in the callback get_formats in soc_camera.h also had to be
changed to unsigned int.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Convert soc-camera core and all soc-camera drivers to the new mediabus
API. This also takes soc-camera client drivers one step closer to also be
usable with generic v4l2-subdev host drivers.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
g_skip_top_lines in soc-camera
Introduce new v4l2-subdev sensor operations, move .enum_framesizes() and
.enum_frameintervals() methods to it, add a new .g_skip_top_lines() method
and switch soc-camera to use it instead of .y_skip_top soc_camera_device
member, which can now be removed.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Reviewed-by: Sergio Aguirre <saaguirre@ti.com>
Since we are not using v4l2_device_call_* calls any more, we don't need to
initialise subdevice .grp_id any more. This also fixes compiler warnings on
64-bit platforms.
soc_camera_device members
This makes the soc-camera interface for V4L2 subdevices thinner yet. Handle
gain and exposure internally in each driver just like all other controls.
(S_CROP)
The initial soc-camera scaling and cropping implementation turned out to be
incompliant with the V4L2 API, e.g., it expected the user to specify cropping
in output window pixels, instead of input window pixels. This patch converts
the soc-camera core and all drivers to comply with the standard.
Remove set_crop soc-camera device method and switch to s_crop from v4l2-subdev
video operations. Also extend non-i2c drivers to also hold a pointer to their
v4l2-subdev instance in control device driver-data, i.e., in
dev_get_drvdata((struct device *)to_soc_camera_control(icd))
Switch to using struct v4l2_rect in struct soc_camera_device for uniformity and
simplicity.
Convert the soc-camera framework to use the v4l2-(sub)dev API. Start using
v4l2-subdev operations. Only a part of the interface between the
soc_camera core, soc_camera host drivers on one side and soc_camera device
drivers on the other side is replaced so far. The rest of the interface
will be replaced in incremental steps, and will require extensions and,
possibly, modifications to the v4l2-subdev code.
Convert soc-camera core and all drivers to platform device API. We already
converted platforms to register a platform device for each soc-camera client,
now we remove the compatibility code and switch completely to the new scheme.
This is a preparatory step for the v4l2-subdev conversion.
As host and camera drivers become more complex, differences between S_FMT and
S_CROP functionality grow, this patch separates them.
operations checks
Simplify multiple drivers by replacing f->fmt.pix.* with a single pointer
dereference, merge some needlessly broken lines, verify host and camera
operations pointers on registration.
We anyway don't follow the s_fmt_vid_cap / g_fmt_vid_cap / try_fmt_vid_cap
naming, and soc-camera is so far only about video capture, let's simplify
operation names a bit further. set_fmt_cap / try_fmt_cap wasn't a very good
choice too.
soc_camera_platform.c
Switching sensors on and off is now done by sensor drivers themselves,
typically using platform-provided hooks. Update soc_camera_platform.c to
do the same. Also remove a refundant struct soc_camera_platform_info
definition from soc_camera_platform.c.
Tested-by: Magnus Damm <damm@igel.co.jp>
So, platform_driver_unregister() doesn't actually have a return value,
nor do any of the void __exit routines. It's reassuring to know that
people copy and paste blindly. This completely blew up my compiler.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This patch adds a simple platform camera device. Useful for testing
cameras with SoC camera host drivers. Only one single pixel format
and resolution combination is supported.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de>
