path: root/drivers/media/video/stk-webcam.c
2010-12-29[media] stk-webcam: remove V4L1 compatibility code, replace with V4L2 controlsHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-08[media] v4l: kill the BKLArnd Bergmann
All of the hard problems for BKL removal appear to be solved in the v4l-dvb/master tree. This removes the BKL from the various open functions that do not need it, or only use it to protect an open count. The zoran driver is nontrivial in this regard, so I introduce a new mutex that locks both the open/release and the ioctl functions. Someone with access to the hardware can probably improve that by using the existing lock in all cases. Finally, all drivers that still use the locked version of the ioctl function now get called under a new mutex instead of the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13556): v4l: Remove unneeded video_device::minor assignmentsLaurent Pinchart
Now that the video_device registration is tested using video_is_registered(), drivers don't need to initialize the video_device::minor field to -1 anymore. Remove those unneeded assignments. [mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13550): v4l: Use the new video_device_node_name functionLaurent Pinchart
Fix all device drivers to use the new video_device_node_name function. This also strips kernel log messages from the "/dev/" prefix, has the device node location is a userspace policy decision unknown to the kernel. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-12V4L/DVB (12491): remove unnecessary power management primitive in stk-webcamOliver Neukum
This patch removes an unneeded power management primitive. Power management is automatically enabled as probe ends. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-08-13V4L/DVB (12436): stk-webcam: read buffer overflowRoel Kluin
It tested the value of stk_sizes[i].m before checking whether i was in range. Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16V4L/DVB: cleanup redundant tests on unsignedRoel Kluin
Remove redundant tests on unsigned. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11265): stkwebcam: Remove buffer type check from g_parm and ↵Trent Piepho
q/dq/reqbufs The v4l2-ioctl core only allows buffer types for which the corresponding ->vidioc_try_fmt_xxx() methods are defined to be used with vidioc_(q|dq|query)bufs(), vidioc_reqbufs() and now vidioc_(s|g)_parm. This driver only defines ->vidioc_try_fmt_vid_cap() so only VIDEO_CAPTURE buffers are allowed to be used with vidioc_g_parm(), vidioc_qbuf(), vidioc_dqbuf(), and vidioc_reqbufs(). Cc: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10817): stkwebcam: Don't need to zero ioctl parameter fieldsTrent Piepho
The v4l2 core code in v4l2_ioctl will zero out the structure the driver is supposed to fill in for read-only ioctls. For read/write ioctls, all the fields which aren't supplied from userspace will be zeroed out. Zeroing code is removed from enum_fmt_vid_cap, g_fmt_vid_cap, and g_parm. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10794): v4l2: Move code to zero querybuf output struct to v4l2_ioctlTrent Piepho
For VIDIOC_QUERYBUF only the first two fields, size and type, are used as input. The rest can be filled in by the driver as output. Most drivers do not actually use all the field and unused ones should be zeroed out. Some drivers have code to do this and some drivers should but don't. So put some zero out code in v4l2_ioctl so that all drivers using that system get it. The drivers that have zeroing code get that code removed. Some drivers checked that the type field was valid, but v4l2_ioctl already does this so those checks can be removed as well. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10130): use USB API functions rather than constantsJulia Lawall
This set of patches introduces calls to the following set of functions: usb_endpoint_dir_in(epd) usb_endpoint_dir_out(epd) usb_endpoint_is_bulk_in(epd) usb_endpoint_is_bulk_out(epd) usb_endpoint_is_int_in(epd) usb_endpoint_is_int_out(epd) usb_endpoint_is_isoc_in(epd) usb_endpoint_is_isoc_out(epd) usb_endpoint_num(epd) usb_endpoint_type(epd) usb_endpoint_xfer_bulk(epd) usb_endpoint_xfer_control(epd) usb_endpoint_xfer_int(epd) usb_endpoint_xfer_isoc(epd) In some cases, introducing one of these functions is not possible, and it just replaces an explicit integer value by one of the following constants: USB_ENDPOINT_XFER_BULK USB_ENDPOINT_XFER_CONTROL USB_ENDPOINT_XFER_INT USB_ENDPOINT_XFER_ISOC An extract of the semantic patch that makes these changes is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r1@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) == - \(USB_ENDPOINT_XFER_CONTROL\|0\)) + usb_endpoint_xfer_control(epd) @r5@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) == - \(USB_DIR_IN\|0x80\)) + usb_endpoint_dir_in(epd) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9978): stkwebcam: Implement VIDIOC_ENUM_FRAMESIZES ioctlJaime Velasco Juan
This patch implements VIDIOC_ENUM_FRAMESIZES, it is used at least by gstreamer. Signed-off-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9327): v4l: use video_device.num instead of minor in video%dHans Verkuil
The kernel number of a v4l2 node (e.g. videoX, radioX or vbiX) is now independent of the minor number. So instead of using the minor field of the video_device struct one has to use the num field: this always contains the kernel number of the device node. I forgot about this when I did the v4l2 core change, so this patch converts all drivers that use it in one go. Luckily the change is trivial. Cc: michael@mihu.de Cc: mchehab@infradead.org Cc: corbet@lwn.net Cc: luca.risolia@studio.unibo.it Cc: isely@pobox.com Cc: pe1rxq@amsat.org Cc: royale@zerezo.com Cc: mkrufky@linuxtv.org Cc: stoth@linuxtv.org Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9194): stk-webcam: fix crash on close after disconnectDavid Ellingsworth
This patch prevents stk-webcam from updating usb device information once the camera has been removed. This prevents a crash that would otherwise occur if the camera is disconnected while it is still in use. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9193): stk-webcam: minor cleanupDavid Ellingsworth
This patch: 1) removes the unnecessary kref.h include file 2) removes unnecessary pointer validation from read and poll routines. (Neither poll nor read may be called unless a call to open succeeds. A successful call to open will always set the file private_data pointer. Verifying that it is not null is therefore unnecessary. The associated release and mmap calls currently ignore this check.) 3) adds a space to syslog output. 4) removes an unused function prototype. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (9034): With the recent patch to v4l2 titled "v4l2: use ↵David Ellingsworth
register_chrdev_region instead of register_chrdev", the internal reference count is no longer necessary in order to free the internal stk_webcam struct. This patch removes the reference counter from the stk_webcam struct and frees the struct via the video_device release callback. It also fixes an associated bug in stk_camera_probe which could result from video_unregister_device being called before video_register_device. Lastly, it simplifies access to the stk_webcam struct in several places. This patch should apply cleanly against the "working" branch of the v4l-dvb git repository. This patch is identical to the patch I sent a couple of months back titled "stk-webcam: Fix video_device handling" except that it has been rebased against current modifications to stk-webcam and it no longer depends on any other outstanding patches. Acked-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8786): v4l2: remove the priv field, use dev_get_drvdata insteadHans Verkuil
Remove the priv field and let video_get/set_drvdata use dev_get_drvdata and dev_set_drvdata instead. Convert all drivers that still used priv directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8613): v4l: move BKL down to the driver level.Hans Verkuil
The BKL is now moved from the video_open function in v4l2-dev.c to the various drivers. It seems about a third of the drivers already has a lock of some sort protecting the open(), another third uses video_exclusive_open (yuck!) and the last third required adding the BKL in their open function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8491): stkwebcam: Always reuse last queued bufferJaime Velasco Juan
This change keeps the video stream going on when the application is slow queuing buffers, instead of spamming dmesg and hanging. Fixes a problem with aMSN reported by Samed Beyribey <beyribey@gmail.com> Signed-off-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8488): videodev: remove some CONFIG_VIDEO_V4L1_COMPAT code from ↵Hans Verkuil
v4l2-dev.h The video_device_create_file and video_device_remove_file functions can be removed from v4l2-dev.h, removing the dependency on videodev.h in v4l2-dev.h. Also removed a few more videodev.h includes that should have been videodev2.h. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8482): videodev: move all ioctl callbacks to a new v4l2_ioctl_ops ↵Hans Verkuil
struct All ioctl callbacks are now stored in a new v4l2_ioctl_ops struct. Drivers fill in a const struct v4l2_ioctl_ops and video_device just contains a const pointer to it. This ensures a clean separation between the const ops struct and the non-const video_device struct. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8430): videodev: move some functions from v4l2-dev.h to ↵Hans Verkuil
v4l2-common.h or v4l2-ioctl.h The functions in a header should not belong to another module. The prio functions belong to v4l2-common.c, so move them to v4l2-common.h. The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header and move those functions to it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8428): videodev: rename 'dev' to 'parent'Hans Verkuil
The field 'dev' is not the video device, but the parent of the video device. Rename accordingly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (7949): videodev: renamed the vidioc_*_fmt_* callbacksHans Verkuil
The naming for the callbacks that handle the VIDIOC_ENUM_FMT and VIDIOC_S/G/TRY_FMT ioctls was very confusing. Renamed it to match the v4l2_buf_type name. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7813): Fix compilation, when V4L1_COMPAT is disabledMauro Carvalho Chehab
This driver uses some sysfs helper functions that are available only for legacy drivers. It also requires linux/mm.h. This patch fixes compiliation when not in compat mode. Thanks to Ingo Molnar for identifying this issue. Acked-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7518): media/video/ replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7238): make stk_camera_{suspend,resume}() staticAdrian Bunk
This patch makes the needlessly global stk_camera_{suspend,resume}() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7103): make stk_camera_cleanup() staticAdrian Bunk
stk_camera_cleanup() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7090): V4L: stkwebcam: use v4l_compat_ioctl32Jaime Velasco Juan
2008-02-18V4L/DVB (7089): V4L: stkwebcam: Power management supportJaime Velasco Juan
2008-02-18V4L/DVB (7088): V4L: stkwebcam: Add support for YUYV formatJaime Velasco Juan
2008-01-25V4L/DVB (7039): Reorder headersMauro Carvalho Chehab
The backports weren't tested, but compile fine. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7019): V4L: add support for Syntek DC1125 webcamsJaime Velasco Juan
This driver supports cameras with USB ID 174f:a311 or 05e1:0501, and the ov965x sensors. These devices are found in some Asus laptops and probably somewhere else. It is based on the stk11xx driver written by Nicolas Vivien Signed-off-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
