path: root/drivers/media/video/stradis.c
2010-10-21V4L/DVB: Deprecate stradis driverMauro Carvalho Chehab
The driver author seems to not worked on this driver since its conversion from 2.2 to 2.4. Nobody is known to have a stradis hardware for testing. As it still uses V4L1 API, BKL and probably some other old stuff, someone would need to work on it to preserve the driver. Instead of investing time and efforts to keep porting it to work with new API's, it seems better to just drop the driver. So, let's move it to drivers/staging and label it to die at 2.6.38, if nobody cares enough to port parallel port support to gspca or to create a new driver that uses the same gspca-cpia sub-driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13556): v4l: Remove unneeded video_device::minor assignmentsLaurent Pinchart
Now that the video_device registration is tested using video_is_registered(), drivers don't need to initialize the video_device::minor field to -1 anymore. Remove those unneeded assignments. [mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13553): v4l: Use the video_is_registered function in device driversLaurent Pinchart
Fix all device drivers to use the video_is_registered function instead of checking video_device::minor. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8783): v4l: add all missing video_device release callbacksHans Verkuil
All drivers that call video_device_register where checked to see if they set the release callback of struct video_device. Where that callback was missing it was added. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8613): v4l: move BKL down to the driver level.Hans Verkuil
The BKL is now moved from the video_open function in v4l2-dev.c to the various drivers. It seems about a third of the drivers already has a lock of some sort protecting the open(), another third uses video_exclusive_open (yuck!) and the last third required adding the BKL in their open function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8434): Fix x86_64 compilation and move some macros to v4l2-ioctl.hMauro Carvalho Chehab
2008-04-24V4L/DVB (7402): add macro validation for v4l_compat_ioctl32Douglas Schilling Landgraf
Added macro CONFIG_COMPAT for v4l_compat_ioctl32. Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-22V4L/DVB (6320): v4l core: remove the unused .hardware V4L1 fieldMauro Carvalho Chehab
struct video_device used to define a .hardware field. While initialized on severl drivers, this field is never used inside V4L. However, drivers using it need to include the old V4L1 header. This seems to cause compilation troubles with some random configs. Better just to remove it from all drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5831): stradis: use ARRAY_SIZETrent Piepho
sizeof(palette2fmt) / sizeof(u32) => ARRAY_SIZE(palette2fmt) Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-29V4L/DVB (4296): Remove stradis MODULE_DEVICE_INFO definitionAndrew de Quincey
To prevent autoloading of the driver, as it then conflicts with every other saa7146 device in existence. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-02[PATCH] irq-flags: media: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27V4L/DVB (4260): Stradis.c: make 2 functions staticAdrian Bunk
This patch makes two needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4068): Removed all references to kernel stuff from videodev.h and ↵Mauro Carvalho Chehab
videodev2.h The videodev.h and videodev2.h describe the public API for V4L and V4L2. It shouldn't have there any kernel-specific stuff. Those were moved to v4l2-dev.h. This patch removes some uneeded headers and include v4l2-common.h on all V4L driver. This header includes device implementation of V4L2 API provided on v4l2-dev.h as well as V4L2 internal ioctls that provides connections between master driver and its i2c devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-25V4L/DVB (3599b): Whitespace cleanups under drivers/mediaMauro Carvalho Chehab
2006-01-26V4L/DVB (3439a): media video stradis memory fixJiri Slaby
memset clears once set structure, there is actually no need for memset, because configure function do it for us. Next, vfree(NULL) is legal, so avoid useless labels. Thanks Dave Jones for reporting this. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344e): Stradis LindentJiri Slaby
Stradis Lindent + some handwork Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344d): Stradis video little cleanupJiri Slaby
Unused function removed. Used container_of instead of for loop. Some small changes Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344c): Pci probing for stradis driverJiri Slaby
- Pci probing functions added, some functions were rewritten. - Use PCI_DEVICE macro. - dev_ used for printing when pci_dev available. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L (926_2): Moves compat32 functions from fs to v4l subsystemArnd Bergmann
This moves the 32 bit ioctl compatibility handlers for Video4Linux into a new file and adds explicit calls to them to each v4l device driver. Unfortunately, there does not seem to be any code handling the v4l2 ioctls, so quite often the code goes through two separate conversions, first from 32 bit v4l to 64 bit v4l, and from there to 64 bit v4l2. My patch does not change that, so there is still much room for improvement. Also, some drivers have additional ioctl numbers, for which the conversion should be handled internally to that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-09-10[PATCH] vfree and kfree cleanup in drivers/Jesper Juhl
This patch does a full cleanup of 'NULL checks before vfree', and a partial cleanup of calls to kfree for all of drivers/ - the kfree bit is partial in that I only did the files that also had vfree calls in them. The patch also gets rid of some redundant (void *) casts of pointers being passed to [vk]free, and a some tiny whitespace corrections also crept in. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
