As Simon reported, digital TV broke with mt20xx tuner due to
commit ad020dc2fe9039628cf6cef42cd1b76531ee8411.
The mt20xx tuner passes V4L2_TUNER_DIGITAL_TV to tuner core. However, the
check_mode code now doesn't handle it well. Change the logic there to
avoid the breakage, and fix a test for analog-only at g_tuner.
Reported-by: Simon Arlott <simon@fire.lp0.eu>
Tested-by: Simon Arlott <simon@fire.lp0.eu>
Cc: stable@kernel.org
The tuner core should not silently change the type field in g_tuner and
g_frequency. If the tuner is in a different mode than the one that was
requested, then just fill in what you can and don't attempt to read afc,
signal or rxsubchans values.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Drivers must be able to rely on s_power to power up subdevices.
Note that at this moment no driver attempts to power up tuners. This probably
isn't surprising since s_power(1) was never implemented in tuner-core.c until
now.
Get rid of a number of unnecessary tuner_dbg messages by simplifying
the std fixup function.
The tuner ops g_frequency, g_tuner and s_tuner require that the tuner type
field is filled in. Document this.
The tuner-core doc is based on a patch from Mauro Carvalho Chehab <mchehab@redhat.com>.
set_mode is called with t->type, which is the tuner type. Instead, use
t->mode which is the actual tuner mode (i.e. radio vs tv).
Both s_std and s_tuner are broken because set_mode_freq is called before the
new std (for s_std) and audmode (for s_tuner) are set.
This patch splits set_mode_freq in a set_mode and a set_freq and in s_std/s_tuner
first calls set_mode, and if that returns 0 (i.e. the mode is supported)
then they set t->std/t->audmode and call set_freq.
This fixes a bug where changing std or audmode would actually change it to
the previous value.
Discovered while testing analog TV standards for cx18 with a tda18271 tuner.
It makes no sense that tuner_lookup would touch at the standby
state. Remove it.
Thanks-to: Hans Verkuil <hverkuil@xs4all.nl>
Group a few functions together and add/fix comments for each
block of the driver.
This is just a cleanup patch meant to improve driver readability.
No functional changes in this patch.
This driver is complex, and used by everyone. Better to have it
properly documented.
No functional changes are done in this patch.
tuner-core has no business to do with digital TV. So, don't use
T_DIGITAL_TV on it, as it has no code to distinguish between
them, and nobody fills T_DIGITAL_TV right.
Remove the now obsolete set_freq. Also merge set_addr and set_type_addr.
In the past, it used to have two different setup calls, one to set just
the tuner type to any tuner found, and another to set the type only if
the address matches. Those two internal calls were grouped together,
but the functions weren't merged, making the code uglier.
A static var is evil, especially if a device has two boards with
xc5000. Instead, just like the other drivers, use stack to store
its config during setup.
Power down tuners at suspend. At resume, if the tuner is in standby,
calls set_mode, that will turn it on and set the latest frequencies.
In the past, T_STANDBY were used on devices with a separate radio tuner to
mark a tuner that were disabled. With the time, it got newer meanings.
Also, due to a bug at the logic, the driver might incorrectly return
T_STANDBY to userspace.
So, instead of keeping the abuse, just use a boolean for storing
such information.
We can't remove T_STANDBY yet, as this is used on two other drivers. A
latter patch will address its usage outside tuner-core.
Thanks-to: Devin Heitmueller <dheitmueller@kernellabs.com>
Properly document those functions and do some cleanups around that.
There's just one behavior change on this patchset: it will now restore
TV frequency when changing from radio to TV mode.
This is a big patch with no functional changes. It just
rearranges everything inside the driver, and prepares to
break TV and Radio into two separate fops groups.
Currently, it has an heuristics logic to determine if the
call came from radio or video. However, the caller driver
knows for sure, so tuner-core shouldn't try to guess it.
Move the frequency set debug printk's to the code that actually
are changing it.
Nobody is using this legacy call. Just remove it.
V4L1 was removed. So, the code there is just dead code.
By default, tda18271 tries to optimize I2C bus by updating all registers
at the same time. Unfortunately, some devices doesn't support it.
The current logic has a problem when small_i2c is equal to 8, since there
are some transfers using 11 + 1 bytes.
Fix the problem by enforcing the max size at the right place, and allows
reducing it to max = 3 + 1.
Acked-by: Michael Krufky <mkrufky@kernellabs.com>
Acked-by: Sri Deevi <Srinivasa.Deevi@conexant.com>
Configure the tda18271 to use a smaller transaction size by default, which
works around some sort of i2c bug in the Polaris driver (which needs to be
debugged).
This should be safe for other boards (being in tuner-core means it will be
enabled by default), although testing needs to be done.
Signed-off-by: Devin Heitmueller <dheitmueller@hauppauge.com>
Remove a hack in the tuner code for the mxb board. This hack is no longer
needed since the tuner is now probed on its correct address as specified
by the mxb driver.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Stanse found a memory leak in tuner_probe. It is not freed/assigned
on all paths. Fix that.
Setting the tuner frequency at the same time as initializing the other devices
on the i2c bus can cause problems on devices that require firmware download or
extensive calibration proceduces during initialization.
This change allows us to prevent the tune at startup for devices that perform
better without it.
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
The variables are unsigned so the test `>= 0' is always true,
the `< 0' test always fails. In these cases the other part of
the test catches wrapped values.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Upcoming I2C v4l2_subdev drivers need a way to control the subdevice
power state from the core. This use case is already partially covered by
the tuner s_standby operation, but no way to explicitly come back from
the standby state is available.
Rename the tuner s_standby operation to core s_power, and fix tuner
drivers accordingly. The tuner core will call s_power(0) instead of
s_standby(). No explicit call to s_power(1) is required for tuners as
they are supposed to wake up from standby automatically.
[mchehab@redhat.com: CodingStyle fix]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add support for NXP TDA18271 as a standalone tuner, allowing the use of
analog demodulators other than the Philips/NXP TDA829x.
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@haskernel@
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
// </smpl>
init routine
This patch removes some remaining dead code. Warning showed up in Hans
Verkuil's daily report after I committed hg changeset 7f2eea75118b.
Thanks to Michael Krufky for bringing the warning to my attention.
Cc: Michael Krufky <mkrufky@kernellabs.com>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Defer loading of the xc5000 firmware until it is actually needed. This helps
on distros that have hald, which results in the device not being available
for use for around ten seconds in cases where the i2c bus is slow (such as
the HVR-950Q). Also, the firmware load isn't really useful since we
immediately put the device to sleep afterward, which means a firmware reload
will be required anyway.
Support for tuners with i2c addresses >= 0x65 is dropped since no tuners
with addresses in the range 0x65-0x6f have been found.
This patch removes addresses 0x65-0x6f from the list of tuner probe addresses,
it removes the kernel warning that warned if addresses in this range appeared,
and it removed a hack for the cx88 that is no longer needed now that the
tuner address range is reduced.
< 2.6.22
Originally the intention was to switch to the new style i2c API starting with
the introduction of the API in 2.6.22. However, the i2c_new_probed_device()
function has a lethal bug that wasn't fixed until 2.6.25. Or more accurately,
it was only fixed in the stable series of 2.6.25 and 2.6.26.
Given the fact that the new i2c API also changed starting with 2.6.26 (the
addition of i2c_device_id), it is easiest to switch APIs starting with
2.6.26.
This patch updates all the legacy code accordingly.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
s_standby is only used to put the tuner in powersaving mode, so move it
from core to tuner.
All drivers that use the tuner module now use v4l2_subdev, so we can remove the
legacy code from this module.
Note that TUNER_SET_CONFIG is still called by tuner-simple.c, so we have
to handle it via a .command callback. There must be a better way to do this,
but for now this will work.
No i2c modules are called with the V4L1 API anymore, so this can be removed.
Replace 'VIDIOC_' references in v4l i2c drivers by their new v4l2_subdev
callback names.
Drivers that don't set "config" directly in the set_type function will
end up with an invalid configuration value. Check that the value is sane,
otherwise initialize to 0.
Thanks to James Edward Geiger & Steven Toth for reporting this bug.
Cc: Steven Toth <stoth@linuxtv.org>
Cc: James Edward Geiger <james.e.geiger@gmail.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
than 5380
The xc5000 driver has a bug where the IF is always set to whatever the first
caller to dvb_attach() provides. This fails when the device requires an IF
other than 5380 and the analog driver is loaded first through tuner-core
(which always supplies the hard-coded value of 5380).
Thanks to Michael Krufky <mkrufky@linuxtv.org> and Steven Toth
<stoth@linuxtv.org> for providing sample hardware, engineering level support,
and testing.
Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org>
Since internal to v4l2 the ioctl prototype is the same regardless of it
being called through .ioctl or .unlocked_ioctl, we need to convert it all
to the long return type of unlocked_ioctl.
Thanks to Jean-Francois Moine for posting an initial patch for this and
thus bringing it to our attention.
Cc: Jean-Francois Moine <moinejf@free.fr>
disabled.
