Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Dont pass devptr in xc5000_attach, dont store it in xc5000_priv.
This pointer is passed into the tuner_callback function, which always
expects a pointer to fe->dvb->priv or i2c_adapter->algo_data.
This prevents future possible bugs in new drivers, such as using a "devptr"
other that the standard fe->dvb->priv in a DVB driver.
v4l2-common.h or v4l2-ioctl.h
The functions in a header should not belong to another module. The prio functions
belong to v4l2-common.c, so move them to v4l2-common.h.
The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header
and move those functions to it.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Also remove some blank lines that were used to split compat code at -devel
tree.
check_v4l2 always returns 0, so this change is an noop for now,
but a comment says it will return something else in the future
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
change check_mode and set_mode to return negative errors and fix all callers
The tuner driver used to change i2c_client.name for its own needs, but
it really shouldn't, as this field is used by i2c-core to do the
device/driver matching. So, create and use a separate field for the
tuner driver needs.
Update all the remaining new-style i2c drivers to use standard module
aliasing instead of the old driver_name/type driver matching scheme.
Note that the tuner driver is a bit quirky at the moment, as it
overwrites i2c_client.name with arbitrary strings. We write "tuner"
back on remove, to make sure that driver cycling will work properly,
but there may still be troublesome corner cases.
The current code passes a context pointer in the xc5000_config struct.
This context pointer is used in the tuner_callback function, used to
reset the device after firmware download.
The xc5000_config struct is a static structure, whose .priv member was
being assigned before calling xc5000_attach(). If there are more than
one of the same device type installed on a single system, the last one
to assign xc5000_config.priv will "win", and all others will cease to
function properly.
This patch passes the context pointer in xc5000_attach() rather that
storing it within the static struct xc5000_config.
As pointed by Andrew Morton, the error testing were wrong. After reviewing
tea5767, it were returning a positive value for errors.
So, the double errors were cancelling each other.
This patch fix it properly. It also considers any positive value as ok, on
tuner-core.
As reported by Mike Galbraith <efault@gmx.de>:
[ 13.666587] TUNER: Unable to find symbol tda829x_probe()
[ 13.674638] tuner' 1-004b: chip found @ 0x96 (saa7133[0])
[ 13.691175] DVB: Unable to find symbol tda9887_attach()
[ 13.698968] BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
[ 13.709509] IP: [<ffffffff80302934>] strlcpy+0x11/0x36
[ 13.711135] PGD be167067 PUD be140067 PMD 0
[ 13.711137] Oops: 0000 [1] SMP
symbol_request() failed
Because it goes BUG.
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Some Kconfig names were changed. This patch reapplies the rename script,
fixing for those drivers merged after the patch that renamed those
items.
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (28 commits)
V4L-DVB(7789a): cx18: fix symbol conflict with ivtv driver
V4L/DVB (7789): tuner: remove static dependencies on analog tuner sub-modules
V4L/DVB (7785): [2.6 patch] make mt9{m001,v022}_controls[] static
V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chip
V4L/DVB (7783): drivers/media/dvb/frontends/s5h1420.c: printk fix
V4L/DVB (7782): pvrusb2: Driver is no longer experimental
V4L/DVB (7781): pvrusb2-dvb: include dvb support by default and update Kconfig help text
V4L/DVB (7780): pvrusb2: always enable support for OnAir Creator / HDTV USB2
V4L/DVB (7779): pvrusb2-dvb: quiet down noise in kernel log for feed debug
Rename common tuner Kconfig names to use the same
Fix V4L/DVB core help messages
V4L/DVB (7769): Move other terrestrial tuners to common/tuners
V4L/DVB (7768): reorganize some DVB-S Kconfig items
V4L/DVB(7767): Move tuners to common/tuners
V4L/DVB (7766): saa7134: add another PCI ID for Beholder M6
V4L/DVB (7765): Add support for Beholder BeholdTV H6
V4L/DVB (7763): ivtv: add tuner support for the AverMedia M116
V4L/DVB (7762): ivtv: fix tuner detection for PAL-N/Nc
V4L/DVB (7761): ivtv: increase the DMA timeout from 100 to 300 ms
V4L/DVB (7759): ivtv: increase version number to 1.2.1
namespace for all of them.
Based on earlier work by Jon Smirl and Jochen Friedrich.
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Jochen Friedrich <jochen@scram.de>
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
set_addr log were almost useless: discarded SET_TYPE_ADDR commands weren't
reported.
This patch changed set_addr printk to print a message only if set_addr is
wrong.
It also fix printk at set_type, since, if an attach were failing, nothing
were reported.
With the current code, working or not, a call to set_addr will produce a debug
printk.
also, set_type() were producing a false error message on tuner_xc2028, since
it were requesting for setting a frequency on a place where firmware name
weren't set yet.
VIDEO_V4L2_COMMON=m
This patch removes zoran checks for VIDEO_V4L2, since this API is always
present, when V4L is selected.
The video_dev parameter, on tuner-xc2028 were used to pass i2c private data to
tuner_callback. Since the driver already have a pointer to i2c_adap->algo_data,
uses this instead.
This parameter were used also as a magic number to idenfity if two drivers are
trying to register the same xc3028 tuner. This occurs with boards with DVB
support, where both DVB and V4L drivers will share the same tuner.
Instead of using the algo_data as a private number, after this patch, the
driver will use i2c_adap->dev, with seems more consistent.
Tuner refactoring broke support of tuners with LNA configurations 1 and 2
for both, analog TV and DVB-T.
Additionally, this patch initializes the saa713x gpios defined by the gpiomask
at driver init to avoid undefined stated at dvb.
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
If simple_tuner_attach fails, set t->type to TUNER_ABSENT,
set t->mode_mask to T_UNINITIALIZED, and exit the set_type function.
This patch fully removes the dependency of tuner-core on
tuner-types.
There is no longer any need to pass struct tunertype in attach-time
config structure - instead pass the tuner type ID.
Move tuner type ID check from tuner-core::set_type to simple_tuner_attach.
Since tuner-core forwards all attach requests to tuner-simple as the
default case, unless a specific attach function is specified in
set_type, this change is an appropriate cleanup.
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
tuner_list can become static - and it's anyway a way too generic name
for a global variable - see commit b00ef4b8d8c29bfb5f6f92ee60bc04b604f36ef2
for a completely different global variable of the same name I just made
static...
Signed-off-by: Adrian Bunk <bunk@kernel.org>
XC5000 tuners
We already know that the XC5000 tuner can only be located at
i2c address 0x61, 0x62, 0x63 or 0x64
We shouldn't display this warning if the XC5000 tuner is present.
xc5000: Small amount of cleanup and commenting, just for clarification.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
From Zhang: This an updated patch that adds analog support for
the xc5000 tuner driver. it was tested on a Pinnacle PCTV HD 800i
card (patches to follow).
Patch commited as-is, cleanup to follow ... Steve.
Signed-off-by: Chaogui Zhang <czhang1974@gmail.com>
tuner-core was checking if analog_ops->set_config is set. If set, it would
complain that it isn't. Fix this backwards logic to the proper behavior.
dvb_frontend
Rather than using a pointer, include struct analog_demod_ops directly
inside struct dvb_frontend. This will allow us to use dvb_attach in
the future, along with removing the need to check the ops structure
before having to check the pointer to the method being called.
struct tuner holds state for tuner-core, only -- move it into tuner-core.c
Use TUNER_SET_CONFIG to set configuration in tda9887's private state
structure, rather than storing tda9887-specific configuration within
struct tuner.
Update handling of TUNER_SET_CONFIG by tuner-core, to call
&t->fe.ops.analog_demod_ops rather than &t->fe.ops.tuner_ops
analog_demod_ops.set_config passes the request to tuner_ops.set_config,
so this does not break other drivers.
Fix type inconsistency in t->mode value, causing the following:
tuner' 1-0043: freq set: unknown mode: 0x0004!
(only visible with tuner debug enabled)
Store the analog demodulator name in fe.ops.analog_demod_ops.info.name
- remove dependency of tda8290 module on struct tuner
- move tuner_foo printk macros from tuner-driver.h into tuner-core.c
- clean up #includes of tuner-i2c.h / tuner-driver.h
set_params method
We can tell whether we are tuning television or radio by testing for
struct analog_parameters *params->mode == V4L2_TUNER_RADIO
There is no longer any need for separate set_tv_freq and
set_radio_freq functions in the analog tuner demodulator modules.
Removes uneeded parameters and adds an structure for passing the parameters
This patch is co-authored by Mauro Carvalho Chehab.
Signed-off-by: Michel Ludwig <michel.ludwig@gmail.com>
The default_mode_mask global is replaced by a list of tuner structs. The
tuner driver now walks that list to see which radio and/or tv tuner
devices are registered to a given i2c adapter.
The default_mode_mask global had to go since this is no longer supported
with the new bus-based I2C API.
Prevent the tda8295 from falsely being detected as a tda9887
Alter the tuner_foo printk macros to indicate which module is
generating the message.
