path: root/drivers/media/video/v4l2-int-device.c
2008-10-21V4L/DVB (9322): v4l2-int-if: Export more interfaces to modulesSakari Ailus
Export v4l2_int_device_try_attach_all. This allows initiating the initialisation of int if device after the drivers have been registered. Also allow drivers to call ioctls if v4l2-int-if was compiled as module. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-04-01V4L/DVB (7485): v4l2-int-device.c: add MODULE_LICENSEAdrian Bunk
Now that it's in an own module it needs a MODULE_LICENSE. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6580): Set slave's master before master's attach call.Sakari Ailus
V4L: Int if: Set slave's master before attach, remove master argument The master also now gets its own pointer from slave's structure. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6316): Change list_for_each+list_entry to list_for_each_entryTrent Piepho
The rest of V4L files. There is one list_for_each+list_entry in cpia_pp.c that wasn't changed because it expects the loop iterator to remain NULL if the list is empty. A bug in vivi is fixed; the 'safe' version needs to be used because the loop deletes the list entries. Simplify a second loop in vivi and get rid if an un-used variable in that loop. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6218): V4L: Int if: Use -ENOIOCTLCMD for nonexistent ioctlsSakari Ailus
2007-10-09V4L/DVB (6216): V4L: Int if: add vidioc_int_g_ifparm, other updatesSakari Ailus
vidioc_int_g_ifparm can be used to obtain hardware-specific information about the interface used by the slave. Rearrange v4l2-int-device.h as well. Also remove useless & characters. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5940): Export v4l2_int_device_{, un}registerAdrian Bunk
This patch fixes the following build error: <-- snip --> ... MODPOST 2135 modules make[2]: *** [__modpost] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5883): V4L: Fix a compile warning on non-32-bit machines.Sakari Ailus
Fix a compile warning on non-32-bit machines in v4l2-int-device.h. Add internal ioctl interface fallback function for ioctls with one argument. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5862): V4L: Add internal ioctl-like interface.Sakari Ailus
This patch adds an internal ioctl-like interface which can be used in situations where a single Video4Linux device is implemented by multiple device drivers. One master device controls one or more slave devices. The slaves provide Video4Linux ioctl-like interface for the use of the master. Only a handful of ioctls are implemented at the moment. More can (and should) be added as more functionality is required. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
