path: root/drivers/media/video/wm8775.c
2012-08-15[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Move ancillary I2C drivers into drivers/media/i2c, in order to better organize them. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-08[media] convert drivers/media/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/media/* to use the module_i2_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Heungjun Kim <riverful.kim@samsung.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Andrew Chew <achew@nvidia.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Michael Grzeschik <m.grzeschik@pengutronix.de> Cc: Johannes Obermaier <johannes.obermaier@gmail.com> Cc: Steven Toth <stoth@kernellabs.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Add proper audio support for Nova-S Plus with wm8775 ADCLawrence Rust
This patch adds audio DMA capture and ALSA mixer elements for the line input jack of the Hauppauge Nova-S-plus DVB-S PCI card. The Nova-S-plus has a WM8775 ADC that is currently not detected. This patch enables this chip and exports volume, balance mute and ALC elements for ALSA mixer controls. [mchehab@redhat.com: Changed the patch to only talk with wm8775 if board info says so. Also, added platform_data support, to avoid changing the behaviour for other boards, and fixed CodingStyle] [awalls@md.metrocast.net: Changed patch to make the WM8775_GID defintion bridge driver private and let the bridge driver set the value of v4l2_subdev.grp_id.] -- To unsubscribe from this list: send the line "unsubscribe linux-media" in the body of a message to majordomo@vger.kernel.org More majordomo info at http://vger.kernel.org/majordomo-info.html Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andy Walls <awalls@md.metrocast.net>
2011-01-03[media] wm8775: Revert changeset fcb9757333 to avoid a regressionMauro Carvalho Chehab
It seems that cx88 and ivtv use wm8775 on some different modes. The patch that added support for a board with wm8775 broke ivtv boards with this device. As we're too close to release 2.6.37, let's just revert it. Reported-by: Andy Walls <awalls@md.metrocast.net> Reported-by: Eric Sharkey <eric@lisaneric.org> Reported-by: Auric <auric@aanet.com.au> Reported by: David Gesswein <djg@pdp8online.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-23[media] Nova-S-Plus audio line inputlawrence rust
This patch adds audio DMA capture and ALSA mixer elements for the line input jack of the Hauppauge Nova-S-plus DVB-S PCI card. The Nova-S-plus has a WM8775 ADC that is currently not detected. This patch enables this chip and exports volume, balance mute and ALC elements for ALSA mixer controls. [mchehab@redhat.com: Fix CodingStyle issues] Signed-off-by: Lawrence Rust <lawrence@softsystem.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: wm8775: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: wm8775: convert to the new control frameworkHans Verkuil
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11301): wm8775: remove legacy code for old-style i2c APIHans Verkuil
All drivers that use wm8775 are now converted to v4l2_subdev, so I can remove the support for the old-style i2c API. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9834): wm8775: convert to v4l2_subdev.Hans Verkuil
2008-07-26V4L/DVB (8487): videodev: replace videodev.h includes by videodev2.h where ↵Hans Verkuil
possible Several V4L2 drivers still included videodev.h. Fix this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20v4l-dvb: remove legacy checks to allow support for kernels < 2.6.10Hans Verkuil
Also remove some blank lines that were used to split compat code at -devel tree. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-18i2c: Convert remaining new-style drivers to use module aliasingJean Delvare
Update all the remaining new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. Note that the tuner driver is a bit quirky at the moment, as it overwrites i2c_client.name with arbitrary strings. We write "tuner" back on remove, to make sure that driver cycling will work properly, but there may still be troublesome corner cases. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-01-25V4L/DVB (6737): wm8775: codingstyle cleanupHans Verkuil
2008-01-25V4L/DVB (6452): wm8775: convert to bus-based I2C APIHans Verkuil
2007-07-20V4L/DVB (5880): wm8775/wm8739: Fix memory leak when unloading moduleHans Verkuil
State struct was never freed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5355): Add VIDIOC_G_CHIP_IDENT to various i2c modulesHans Verkuil
2006-03-24V4L/DVB (3599): Implement new routing commands for wm8775 and cs53l32a.Hans Verkuil
2006-03-24V4L/DVB (3577): Cleanup audio input handlingHans Verkuil
Cleanup audio input handling in bttv and tvaudio: - inputs were specified that were never used - mute was handled as a special input which led to confusing code - confusing naming made it difficult to see if the setting was for i2c or gpio. The old audiochip.h input names moved to tvaudio.h. Currently this is used both by tvaudio and msp3400 until the msp3400 implements the new msp3400-specific inputs. Detect in bttv the tvaudio and msp3400 i2c clients and use these client pointers to set the inputs directly instead of broadcasting the command. Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be replaced again later by the new ROUTING commands. Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is a user level command and not to be used internally. It wasn't called at all anyway. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3307): Some cleanups at I2C modulesMauro Carvalho Chehab
- i2c names shorten - removed obsoleted flags on newer modules - small cleanups Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3278): convert diagnostics over to the new v4l2-common.h macros.Hans Verkuil
- Convert diagnostics over to the new v4l2-common.h macros. - deprecated tuner_debug option, the new option is debug. - renamed cx25840_debug to debug. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3247): Replace AUDC_SET_INPUT with VIDIOC_S_AUDIO in wm8775.Hans Verkuil
- Replace AUDC_SET_INPUT with VIDIOC_S_AUDIO. - Added V4L2_CID_AUDIO_MUTE. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3218): Whitespace cleanupsMichael Krufky
- minor whitespace cleanups Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3123a): remove uneeded #if from V4L subsystemMauro Carvalho Chehab
- some uneeded #if were introduced by a previous patch. this patch removes these. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 5 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers/media/video and usb/media drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Rework client usage count, 2 of 3Jean Delvare
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't hurt if the usage count is actually never used for any given driver, and allows for nice code simplifications in i2c-core. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-13[PATCH] v4l: (966) Authorship fixes for new ModulesHans Verkuil
Fixes Module Author macros Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] V4L: 915: fixes compilation problems due removal of media/id.h and ↵Hans Verkuil
i2c-algo-bit Fixes compilation problems due removal of media/id.h and I2C_ALGO_BIT Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 810: vidioc log status is added to videodev2.hHans Verkuil
- VIDIOC_LOG_STATUS is added to videodev2.h this can be enabled again in wm8775.c. Also use the v4l2 VIDIOC_S_FREQUENCY instead of VIDIOCSFREQ. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 800: whitespace cleanupsMauro Carvalho Chehab
- Whitespace Cleanups. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 771: the wm8775 is a wolfson microelectronics 24 bit 96khz adc ↵Hans Verkuil
with 4 - Support for Wolfson Microelectronics wm8775 audio processor Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
