All the modified drivers didn't have any version increment since
Jan, 1 2011. Several of them didn't have any version increment
for a long time, even having new features and important bug fixes
happening.
As we're now filling the QUERYCAP version with the current Kernel
Release, we don't need to maintain a per-driver version control
anymore. So, let's just use the default.
In order to preserve the Kernel module version history, a
KERNEL_VERSION() macro were added to all modified drivers, and
the extraver number were incremented.
I opted to preserve the per-driver version control to a few
pwc, pvrusb2, s2255, s5p-fimc and sh_vou.
A few drivers are still using the legacy way to handle ioctl's.
So, we can't do such change on them, otherwise, they'll break.
Those are: uvc, et61x251 and sn9c102.
The rationale is that the per-driver version control seems to be
actively maintained on those.
Yet, I think that the better for them would be to just use the
default version numbering, instead of doing that by themselves.
While here, removed a few uneeded include linux/version.h
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
All the functionality is now handled through V4L2.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
All of the hard problems for BKL removal appear to be solved in the
v4l-dvb/master tree. This removes the BKL from the various open
functions that do not need it, or only use it to protect an
open count.
The zoran driver is nontrivial in this regard, so I introduce
a new mutex that locks both the open/release and the ioctl
functions. Someone with access to the hardware can probably
improve that by using the existing lock in all cases.
Finally, all drivers that still use the locked version of the
ioctl function now get called under a new mutex instead of
the BKL.
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, replace the hardcoded module name passed to those
functions by NULL.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the zoran driver
uses.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
v4l2_subdev.
With all the v4l2_subdev changes that were made to these drivers it is a
good idea to increase the version number of each driver.
It's just the patch level that is increased, except for the zoran and saa7146
drivers where the minor number was increased due to the more substantial
changes that were made to those two drivers.
The zoran driver had two kinds of buffer descriptors, one for jpg buffers
and one for raw buffers. They were mostly the same with only a couple
[mchehab@redhat.com: fix compilation of tea575x-tuner.c]
MAP_NR macro.
The zoran i2c modules were still using V4L1 internally. Replace this
with V4L2. Also deleted saa7111.c and saa7114.c, we use saa7115.c instead.
[mchehab@redhat.com: fix v4l2_ctrl_query_fill_std merge conflict]
allow for kmallocs > 128 kB
Remove memory allocation madness.
'ready_to_be_freed' hack.
The driver should only use the kernel mapped io address, zr36057_mem, and
not the PCI bus address, zr36057_adr. Since the latter is only printed out
once, there is no need to save it in the driver data structure.
There was some old code that looked like it was for the Alpha architecture
which would use the PCI bus address. It probably no longer applies to
modern kernels.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
Instead of using custom code, just let the device layer look it up for us
from the pci device table. This requires extending the pci device table to
list each known card, plus a catch-all entry for the cards that don't have
sub-system vendor/device data.
Improve some of the info and error messages too.
Prevent the zoran driver sources from cluttering the video directory.
This changeset only moves the drivers and it does not fix any of the
checkpatch warnings/errors to keep the changeset clean.
