CSI host controller of Tegra can support Bayer Raw8 and Raw 10 data
input, it also output data as extended 16-bit data format in memory
directly.
Raw data output should be handled by the second output channel.
This patch add supporting for Raw data input/output and the second
output channel.
All were tested on Cardhu board.
Change-Id: Ifd1d8c94671a1d4571dcf176774e2d3cffafc399
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/200225
GVS: Gerrit_Virtual_Submit
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
drivers/media/video/tegra_v4l2_camera.c
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
Setting the resolution to 1088p (as of now), since
there are flickers observed for 1080p and also
the encoder is not compatible with alignement of
the RM surfaces of 1080p. 1088p is a stop-gap solution
until the issues with 1080p are resolved.
Bug 1369083
Change-Id: I3e73076451e7671d90603c6496ad14733591edeb
Reviewed-on: http://git-master/r/309543
Tested-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Bug 1369083
Change-Id: I1a81bcb62e8f6bb654ffbebba09661187ab4b512
Reviewed-on: http://git-master/r/309536
The tweaks are only specific to r16-r2 branch
and will not go into mainline.
- Pass nvmap memory handle to the user through
the mmap'd buffer allocated by videobuf2 client.
- Allow the "user" nvmap client to access the
nvmap memory handle of "videobuf2-dma-nvmap" client.
Re-arranging the copyright message in nvmap_dev.c
for Automatic validation to pass.
Bug 1369083
Change-Id: Ia27d172253860e79557911c2e848bc9084d662d4
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/309494
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3.
The config changes (for V4L2) can be done manually as per need
basis for V4L2, followed by compiling the kernel.
Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5
Reviewed-on: http://git-master/r/327607
- Disables TEGRA_CAMERA
- Enables SOC_CAMERA and OV5640 sensor support
Bug 1369083
Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb
Reviewed-on: http://git-master/r/309491
Bug 1369083
Change-Id: I1522b688e0681e52592c0f26a8e335937372836a
Reviewed-on: http://git-master/r/279989
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Add support for dual cameras from both CSI-A and CSI-B:
- move all the CSI settings into video buffer struct
- queue the video buffer struct to a dedicated queue
- process one video buffer struct from the queue at one time
Bug 1369083
Change-Id: Ie64d69282ab991b66e97327e288a2bacde088bd6
Reviewed-on: http://git-master/r/246269
(cherry picked from commit 228b0c2d9ae3fa1121f88836626d654ae0fc4ff0)
Reviewed-on: http://git-master/r/279987
soc_camera_link supports passing power on/off control callback to
soc_camera stack. So the power control can be handled by soc_camera
stack instead of our Tegra V4L2 host driver.
Also pass other platform_data fields via soc_camera_link instead of
a hacking nvhost_device_data struct.
Bug 1240806
Bug 1369083
Change-Id: I443a7d28196cc8292805da70d2d5ff1c3cd50a5d
Reviewed-on: http://git-master/r/246267
(cherry picked from commit 9083d270bf93b583cd5bf5151a52ea250f8541a3)
Reviewed-on: http://git-master/r/279986
Bug 1369083
Change-Id: I43acb0d1dd6ca182291895d294a8458bfc99da05
Reviewed-on: http://git-master/r/279985
Reviewed-by: Allen Martin <amartin@nvidia.com>
Use right buffer flag NVMAP_HANDLE_WRITE_COMBINE to allocate buffer,
which can be shared by VI/CSI and CPU. Don't use NVMAP_HEAP_SYSMEM.
It is validated to old T20 silicon and can't support big buffers. By
default, our nvmap_alloc() will use IOVMM to allocate buffers.
nvmap_pin() gives us IOVA for hardware engines like VI/CSI module
with IOMMU enabled in kernel. nvmap_mmap() gives us VA for CPU
read/write operations. So we need to convert VA address to physical
address of the buffer and map that buffer to user space processor's
memory space "page by page".
Bug 1369083
Change-Id: I4629eebe206c7640adf63551968fd89260dd0082
Reviewed-on: http://git-master/r/279984
- tweak offset registers
- add test mode to output color bars
- use BGGR RAW format
Bug 1369083
Change-Id: I61352c018f8ca099ff3d39158a67052a1e185eec
Reviewed-on: http://git-master/r/279983
fix Coverity issue
Coverity id : 13692
Bug 1046331
Bug 1049868
Change-Id: Iefa6d076d4622368534710630b89b9a15d166378
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/165864
(cherry picked from commit db33c3f3f2447a52a40f4fd001fec9a2932ee4c8)
Reviewed-on: http://git-master/r/244637
Reviewed-by: Shreshtha Sahu <ssahu@nvidia.com>
Tested-by: Shreshtha Sahu <ssahu@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Re-work input selection to apply to a live camera stream.
While at it default to automatic input selection and make this option
available via IOCTL as input value 2 as well.
While at it disable the automatic I2C module loading for now as due to
our currently redundant soc-camera-pdrv registration via board specific
platform data the adv7180 driver is always automatically loaded upon
modprobe tegra_v4l2_camera invocation.
Previously only 64-lead and 40-lead models were identified. This patch
adds 48-lead and 32-lead device identification as well.
Please note that due to missing parameter negotiation functions one
might get the following message with a subsequent crash:
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could
not get parameters on device '/dev/video0'
This can be avoided by explicitly specifying the format as follows:
gst-launch v4l2src ! deinterlace tff=1 method=4 ! 'video/x-raw-yuv,
width=(int)720, height=(int)576, format=(fourcc)I420' !
nv_omx_videomixer ! nv_gl_eglimagesink
Powering on, improved interlacing.
Change-Id: I543d9d95fc14395200647e09480f25d9bc001e00
This reverts commit 080c3135b58aa700851991fb672e6c33cf16d9d9.
Fix issue with nvhost_client_device_init being issued more than once.
bug report courtesy of Mikhail Shevchuk
resolution for PAL/NTSC.
This involved adding some callback methods, and pretending that this is a
YUV sensor.
Signed-off-by: Andrew Chew <achew@nvidia.com>
directly.
output channel.
Change-Id: Ie685ad11a0847be5b51c752ec593aec857e2f0e2
Reviewed-on: http://git-master/r/200224
OV5650 is a RAW sensor outputing Bayer RAW 8 or RAW 10 data.
This driver uses SoC camera interface and supports several
different resolution.
Change-Id: I8075b63b42f7949a264bdef446f5ed8bdc0a9eee
Reviewed-on: http://git-master/r/200223
Function pointer int (*queue_setup)() of struct vb2_ops in
include/media/videobuf2-core.h is not compatible with our function
call tegra_camera_videobuf_setup(). So building will generate warning
and it will cause alloc_ctxs[] with wrong value, then introduce
memory access oops later.
Bug 1215617
Change-Id: I5d49ccd611a9435a5ee3b21e344bc0b5464ba747
Reviewed-on: http://git-master/r/190036
Reviewed-by: Andrew Chew <achew@nvidia.com>
Videobuf2-dma-nvmap driver using by Tegra v4l2 camera driver needs to
allocation memory from system memory with nvmap_alloc(). If we don't
enable config option CONFIG_NVMAP_ALLOW_SYSMEM, nvmap_alloc() will
fail and application stops working.
Bug 1215629
Change-Id: I40af697d8aee1a4981a9684953107dd070cc9bea
Reviewed-on: http://git-master/r/190037
Based on ov5642 driver. There seem to be some register differences,
so forking the driver to make those changes.
Change-Id: Idb4a79757cbbcd15d5456ce82a708f433faaff7a
Reviewed-on: http://git-master/r/169836
Change-Id: Ic4d91f4ed70fc3daf52768118f6ea537d529a5a8
Reviewed-on: http://git-master/r/169835
