add ov5640 yuv sensor support - initial.
bug 921322
Change-Id: I813afa8963e39afe475f9fdd43152cfaf1a16ae1
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/99506
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
The sequence of read fuse id is:
1. write to OTP index register 0x3d00.
2. read out byte from ox3d04.
3. repeat step 1 to the next byte with its index respectively.
also fixed ov5650_read_reg always fail issue.
bug 957657
Change-Id: I649a7765320d0d4be8111a7f523d8487b872b620
Reviewed-on: http://git-master/r/98330
Reviewed-by: Wei Chen <wechen@nvidia.com>
- Abort initialization if an I2C error to avoid excessive load on the I2C bus
since it is heavily used during initialization.
- Updated to the latest NVC framework.
- Added feature that allows for the key focus points to be set at runtime
and the relative positions recalculated.
Bug 929133
Bug 938934
Change-Id: Ida4ab885bf35057ae6df131e3ec3587a891a7dc9
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/93944
Change line_length for 1080p mode in order to change
frame rate from 31.30 to 29.50 fps.
The reason that new fps is not 30 is because flicker
detection requires fps not to be multiples of 60/50Hz.
This change helps save power and lower the chance of frame
drop.
Bug 928296
Change-Id: I4fda13d9334c725754b3f5eab034309a1dfef3dc
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/83636
Reviewed-by: Simone Willett <swillett@nvidia.com>
There are a couple of issues found in tegra_camera.
1. clock enable/disable is controlled by user space.
-> If client process crashes, there is no way to disable clock.
2. power enable/disable is associated with clock enable.
-> There is no reason to relate power with clock.
-> There is only one regulator for this driver.
-> As same as #1, it may leave power up when client process crashes.
3. driver allows multiple clients to access.
-> This is not the case for this driver.
This changes addresses the problems described above.
Bug 948780
Change-Id: Ie534771327175f56cf0e138f1c07096ddba470a8
Reviewed-on: http://git-master/r/92386
Reviewed-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Add nvavp_force_clock_stay_on ioctl which provides way for user-mode driver
to stay on AVP clock state. This change is to fix LP0 resume fail during
Widevine playback. Since VDE/BSEV clocks are used by OTF driver in secure
world during closing sesssion, the change makes VDE/BSEV clocks running
while entering LP0.
Bug 960130
Bug 961015
Change-Id: I7eaaa9a33537a72b6ae0a016372bc513fef532e2
Reviewed-on: http://git-master/r/96302
Reviewed-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Tested-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Remove CONFIG_TEGRA_SMMU_BASE_AT_E0000000 workaround as T30 A01 is no
longer supported.
Change-Id: Ic47d0aa16c555bd7821416fff29d723924c6118b
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/95645
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Gerrit_Virtual_Submit
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Removing the checking whether dma req queue is empty or not
before canceling/stopping dma.
This function cannot guarantee correct result as there may be the
race between hw and sw status update.
If client wants to cancel dma req, it can directly call tegra_dma_cancel().
As the function tegra_dma_is_empty() does not return correct result,
it will be depreciated from the dma apis.
Change-Id: I3f5ebee8a7be345b02fcd8a69530c9b53207ef28
Reviewed-on: http://git-master/r/95090
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Add wake_avp ioctl which provides way for user-mode driver to
simply wake-up the AVP.
bug 914504
Change-Id: I3075ba944d39749559f2c340a4851902821c344f
Signed-off-by: Mandar Potdar <mpotdar@nvidia.com>
Reviewed-on: http://git-master/r/93877
Reviewed-by: Gajanan Bhat <gbhat@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
- With this fix NVAVP works with CONFIG_TEGRA_SMMU_BASE_AT_E0000000.
Change-Id: I9c267bc9b008a57f6f0cc4e9b27dbee0501e6a77
Signed-off-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Reviewed-on: http://git-master/r/91316
Update nvmap_alloc api to take heap_mask as arg.
This is to let clients specify the specific heap needed.
Change-Id: I9950b3e60e6dac0301b6dc66be3e9d0bab8e0fee
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/90471
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: If3a7c3911add67ff9f9aecd3c2b933a8553747f3
Signed-off-by: Chao Xu <cxu@nvidia.com>
Reviewed-on: http://git-master/r/87313
Added suspend/resume function in kernel model to support power
management.
fixed bug 914638
Change-Id: I2746710b6eba6d2528f27b4226383985e314943f
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/86757
emc should be set to MAX only in case of video and not otherwise
Bug 941448
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/85766
(cherry picked from commit 736072f72b468449246f5c943f87ce83092579c4)
Change-Id: I8bda6c47a07534ef35305795449835364a129864
Reviewed-on: http://git-master/r/86306
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Use correct type.
Change-Id: Ic08214f97d721311dde07ac35664bc3b766ba131
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/84948
NULL pointer caused kernel crash when tegra_dtv driver was opened. This
patch fixed the bug.
fixed Bug 940932
Change-Id: I09f8caff789ea8e1222f4afd9bf73ef890472583
Reviewed-on: http://git-master/r/84284
Add a new 1280x720@120 fps - 4lane mode to
ov14810 sensor.
Bug 935663
Change-Id: I3e8e552071e41bf6932582ae3a0b2467b380eecd
Signed-off-by: Krupal Divvela <kdivvela@nvidia.com>
Reviewed-on: http://git-master/r/84041
Reviewed-by: Amit Arora <amita@nvidia.com>
Do not set EMC rate to minimum when module other than VDE is
enabled. This reverts the max rate set when VDE was enabled
if VDE is still enabled.
Bug 930230
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
(cherry picked from commit 692291955e650c87b7cf6ecac03df2ef0445609d)
Change-Id: Ief0e1d6116f064ba09b17ba01c7df0dc7905e0a0
Reviewed-on: http://git-master/r/84057
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Set camera emc clock to 300Mhz for T20. This change
fixes the display corruption observed after video
recording and adb cable is disconnected.
Bug 930239
Signed-off-by: Shivabassu Boragalli <sboragalli@nvidia.com>
Reviewed-on: http://git-master/r/83031
(cherry picked from commit 425cabdc52868d5dca9fd9cd9a82f18d41f0a957)
Change-Id: I29b0d83f0cb3e69e48d25d896ff3c88c2e3e7673
Reviewed-on: http://git-master/r/83398
Change-Id: I6e010e39bc11291e6ff812185db0482e793784ea
Reviewed-on: http://git-master/r/83577
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Tested-by: Hiro Sugawara <hsugawara@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
yuv sensor on tegra2 uses VIP clock. This
change enables VCLK pad to get external
clock for VI.
Bug 930769
Bug 936053
Change-Id: I4958d354a59dec0a92ca9b049ff22b7ca4cac0ad
Reviewed-on: http://git-master/r/83394
Do not reprogram the micro controller everytime
camera is opened.
Bug 935336
Change-Id: Ib9f67fce07332e15e812be7a9d4efef802a7bd58
Reviewed-on: http://git-master/r/83059
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Fix bug in releasing nvmap client handles when nvavp release
is invoked.
Bug 930028
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/78594
(cherry picked from commit 232e208f6c12d6112efe96f434b34c2b8c83d809)
Change-Id: I94f6990dddf7e683adbd896e059ba1b5e5aa3a75
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82708
android-tegra-nv-3.1
Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
Reviewed-on: http://git-master/r/77465
Change-Id: I653afbb6f766493e5d458b2ba4babb8e400c30c1
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/78016
Reviewed-on: http://git-master/r/77403
Change-Id: If51967720de2f4dc1634906fa263c693aef87d75
Reviewed-on: http://git-master/r/78012
Add a mutex_unlock() that was missing in the failure case of
the mediasrv_unlocked_ioctl() function.
Bug 918148
Reviewed-on: http://git-master/r/71470
Change-Id: Id935e2eadfcd5ca3ebf7a086afbcfd4224c52604
Signed-off-by: Ron Vaughn <rvaughn@nvidia.com>
Reviewed-on: http://git-master/r/78008
Grouphold gain and coarse_time register writes.
Make gain and coarse_time set in one ioctl call.
Bug 924213
Reviewed-on: http://git-master/r/74622
Change-Id: I648e4c24c1a048629757abc21afba092d1484d04
Signed-off-by: Yining Deng <ydeng@nvidia.com>
Reviewed-on: http://git-master/r/77762
Mark host1x as busy only when clocks are enabled, instead of
unconditionally at load/unload and suspend/resume time. Shutdown
the avp device entirely during suspend, and restart it on resume if
if necessary.
Bug 929279
Reviewed-on: http://git-master/r/77054
Change-Id: I0c66c26302fe307bea396e1c547a67b3417e26ec
Signed-off-by: Isaac Richards <irichards@nvidia.com>
Reviewed-on: http://git-master/r/77749
Dont fail if there is no regulator device.
For all other cases return failure.
Bug 898252
Reviewed-on: http://git-master/r/73026
Change-Id: Iab987a5d948cd7f3c3373cd3d12f52d480767772
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/77745
tegra_camera_clk_set_rate sets the clock rate which is
equal to or greater than requested clock rate. In this way,
user space code doesn't have to scan through to find next
available higher clock through system call.
Remove setting VI/ICP clock to register directly.
Bug 917641
Reviewed-on: http://git-master/r/75097
Change-Id: Iecbeacecb34c6b6f71228932ba4b046658ff905d
Reviewed-on: http://git-master/r/77727
Put sensor to software standby mode before updating
registers. This helps to sync sensor internal timing.
Bug 914391
Reviewed-on: http://git-master/r/76148
Change-Id: I4ee0d918a0c792e0b40c14c9530002d3672be0f8
Signed-off-by: Frank Chen <frankc@nvidia.com>
Reviewed-on: http://git-master/r/77307
Use standard drvdata interface for storing and accessing nvhost_master.
Reviewed-on: http://git-master/r/72846
Change-Id: I191987c8f6d313a6ede9b59f723269cb6a197e8a
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/76815
sh532u focuser driver, ssl3250a torch driver and tps61050 torch driver
make references to kernel functions which are GPL-only symbols.
L4T requires that these drivers be built as modules and
without making it GPL compatible, the module fails to get loaded.
Hence GPL license is added.
Bug: 928498
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/76172
(cherry picked from commit 148d4d99066f904141c85a0fad36483bc1570d02)
Change-Id: I11ab4b20bab504cb11b04a6e7746e0bae02d9fbf
Reviewed-on: http://git-master/r/76786
Reviewed-by: Amit Pandya <apandya@nvidia.com>
Tested-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Eliminate the public omap_find_iommu_device() method, and don't
expect clients to provide the omap_iommu handle anymore.
Instead, OMAP's iommu driver now utilizes dev_archdata's private iommu
extension to be able to access the required iommu information.
This way OMAP IOMMU users are now able to use the generic IOMMU API without
having to call any omap-specific binding method.
Update omap3isp appropriately.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Hiroshi Doyu <hdoyu@nvidia.com>
drivers/media/video/omap3isp/ispccdc.c
Change-Id: Ia9b3421662fab7bb4bee298693ed6da716599ee5
This is necessary to store a pointer to the bus-specific
iommu_ops in the iommu-domain structure. It will be used
later to call into bus-specific iommu-ops.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
drivers/iommu/iommu.c
Change-Id: Iddbd561739552b663a4be293f1992314eb0f775a
Without this patch it is possible to select the VIDEO_OMAP3
driver which then selects OMAP_IOVMM. But the omap iommu
driver is not compiled without IOMMU_SUPPORT enabled. Fix
that by forcing OMAP_IOMMU and OMAP_IOVMM are enabled before
VIDEO_OMAP3 can be selected.
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: iommu@lists.linux-foundation.org
Prepend 'omap_' to OMAP's 'struct iommu' and exposed API, to prevent
namespace pollution and generally to improve readability of the code
that still uses the driver directly.
Update the users as needed as well.
Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
arch/arm/plat-omap/include/plat/iommu.h
arch/arm/plat-omap/include/plat/iovmm.h
drivers/iommu/omap-iommu.c
drivers/iommu/omap-iovmm.c
drivers/media/video/omap3isp/isp.c
drivers/media/video/omap3isp/isp.h
drivers/media/video/omap3isp/ispstat.c
drivers/media/video/omap3isp/ispvideo.c
Change-Id: I6e4825d93115596184ed3e2274fa759d13a5d6dc
Move OMAP's iommu drivers to the dedicated iommu drivers folder.
While OMAP's iovmm (virtual memory manager) driver does not strictly
belong to the iommu drivers folder, move it there as well, because
it's by no means OMAP-specific (in concept. technically it is still
coupled with OMAP's iommu).
Eventually, iovmm will be completely replaced with the generic,
iommu-based, dma-mapping API.
arch/arm/plat-omap/Kconfig
drivers/iommu/Kconfig
drivers/iommu/Makefile
Change-Id: Ie437869b8cbb92ea8fafc3d18333331a3b51ec06
Since dtv interface was designed based on SPI bus, it shares the same
dma configuration with SPI bus. However, it is not proper because DTV
interface has to transmit data in 4 words long constantly. The patch
added an option in tegra_dma_req to set burst size to be fixed 4 words.
fixed Bug 910227
Change-Id: I1436f0c8d108dd39edc57ae4c9cb750d9574b62c
Reviewed-on: http://git-master/r/75509
Reviewed-on: http://git-master/r/76461
- Avoid casting phys_addr_t to (void *)
bug 917233
Change-Id: I3cfca66ea43341ec803268aa0e4c8496eab16047
Reviewed-on: http://git-master/r/74377
Reviewed-on: http://git-master/r/75142
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Camera requires the emc clk to be a reasonable value, as sensors with
high framerates and resolutions will stress memory bandwidth. Set to
150 MHz for now. It will likely need to be fine-tuned and possibly
increased as sensors with higher framerates and resolutions come onto
the market, but for power considerations it should only be bumped
higher if camera really needs the extra throughput.
Bug 913674
Change-Id: I3e900d1a3f468dd0181c42f5a47629fd3b9551b9
Reviewed-on: http://git-master/r/73891
Reviewed-by: Nathan Lord <nlord@nvidia.com>
Tested-by: Nathan Lord <nlord@nvidia.com>
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/75141
Tegra2/3 has a dedicated Digital TV interface for receiving serial TS
stream. This is the initial version for the DTV interface. The driver
provided a device node as /dev/tegra_dtv and enabled several ioctls to
configure hardware. User land applications could get serial TS data via
system call read() on the device node. The read() operation is blocked
io.
Fixed Bug 904626
Fixed Bug 881303
Change-Id: Iad4629bed3c4c959b9178b387b084cdeaf7c3f69
Reviewed-on: http://git-master/r/66625
Reviewed-on: http://git-master/r/74891
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Move all device data from nvhost_channeldesc, nvhost_moduledesc and
nvhost_module to nvhost_device. nvhost_devices are also assigned into
a hierarchy to prepare for implementation of runtime power management.
Change-Id: I1e18daae8fe538086cd1f453d316e0f73e9d7d92
Reviewed-on: http://git-master/r/72844
Reviewed-on: http://git-master/r/74560
commit f83f71fda27650ae43558633be93652577dbc38c upstream.
With 16-bit RGB565 colour format pixels are stored by the device in memory
in the following order:
| b3 | b2 | b1 | b0 |
| R5 G6 B5 | R5 G6 B5 |
This corresponds to V4L2_PIX_FMT_RGB565 fourcc, not V4L2_PIX_FMT_RGB565X.
This change is required to avoid trouble when setting up video pipeline
with the s5p-tv devices, so the colour formats at both devices can be
properly matched.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Change-Id: I192b2a0d9c24c2906af52aa69c7c386b9c505a82
Reviewed-on: http://git-master/r/74188
commit d1ee8878a142f81ea1b40d602c6360b752829437 upstream.
This patch is against the mainline v3.1 release (c3b92c8) and
fixes a compile error when building for OMAP3+DSS+VOUT
Signed-off-by: Gary Thomas <gary@mlbassoc.com>
Change-Id: Ief9a3646b41226da3aa5b7681e42a6e25a46e08b
Reviewed-on: http://git-master/r/74182
first set emc clock rate and then enable it to take effect of the
operation.
bug 882076
Reviewed-on: http://git-master/r/68611
(cherry picked from commit 57e48fefa323fabd2cfb52093e6b0a600a18e7b0)
Change-Id: I69ad717ccbfd020202ed2f12390ae8b535ff127e
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/73705
(cherry picked from commit 8751a59f5cfd2fe4c0ed88b5417ebab7f04a447e)
Reviewed-on: http://git-master/r/73966
