commit c60503c1db76bd46577cc7ff4fafa033b675e0e5 upstream.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
commit 50e9d31183ed61c787b870cb3ee8f6c3db8c8a1e upstream.
This was found with a static checker and has not been tested, but it seems
pretty clear that the mutex_lock() was supposed to be mutex_unlock()
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Cc: Brandon Philips <brandon@ifup.org>
commit 518c8df77c21b7d1690dd8b96eb0e54c4ec1c9c1 upstream.
Signed-off-by: Rafal Milecki <zajec5@gmail.com>
Cc: Surbhi Palande <surbhi.palande@canonical.com>
commit c95a419a5604ec8a23cd73f61e9bb151e8cbe89b upstream.
The reg_pair2[j].reg was tested twice.
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Fixes:
v4l/dvb_frontend.c: In function 'dvb_frontend_stop':
v4l/dvb_frontend.c:707: error: implicit declaration of function 'init_MUTEX'
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14609
Reported-by: <tstrelar@gmail.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Edwin Török found the following:
In function ‘memset’,
inlined from ‘ir_input_init’ at drivers/media/common/ir-functions.c:67:
/home/edwin/builds/linux-2.6/arch/x86/include/asm/string_64.h:61:
warning: call to ‘__warn_memset_zero_len’ declared with attribute
warning: memset used with constant zero length parameter; this could be
due to transposed parameters
memset(ir->ir_codes, sizeof(ir->ir_codes), 0);
In actual practice the only caller I can find happens to already have cleared
the buffer before calling ir_input_init.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Trivial fix for this compile warning:
v4l/sh_mobile_ceu_camera.c:1789: warning: label 'exit_free_irq' defined but not used
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
(rev 1)
Address yet another regression introduced by the introduction of the zl10353
disable_i2c_gate field.
djh - I unmangled the patch which apparently got screwed up in the user's
email client.
Signed-off-by: Robert Lowery <rglowery@exemail.com.au>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
CC: stable@kernel.org
When building for Sun 3:
drivers/built-in.o: In function `smscore_unregister_device':
drivers/media/dvb/siano/smscoreapi.c:723: undefined reference to `dma_free_coherent'
drivers/built-in.o: In function `smscore_register_device':
drivers/media/dvb/siano/smscoreapi.c:365: undefined reference to `dma_alloc_coherent'
The vpif_config struct was renamed to vpif_display_config, but there
is still a stray vpif_config *config pointer in vpif_display.c, preventing
it from compiling.
Remove this old duplicate pointer.
Set device GPIOs only once. There is no need for .dvb_gpio to select
between analog and digital because device is digital only.
Signed-off-by: Antti Palosaari <crope@iki.fi>
pm_runtime_disable is needed if it failed or removed
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Commit ef373189f62413803b7b816c972fc154c488cdc0 "fix use-after-free Oops,
resulting from a driver-core API change" fixed the Oops, but didn't correct
missing device object initialisation. This patch makes unloading and reloading
of soc-camera host- and client-drivers possible again.
Double mutexlock found by the Linux Driver Verification project and
reported by Alexander Strakh.
The Hauppauge WinTV HVR-1150 retail boards require the FORCE_TS_VALID bit
to be set in order to function properly. This change will work on the early
revisions on the board as well, but the final revision will not function
without this change.
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
When FORCE_TS_VALID mode is enabled, the saa713x will accept MPEG TS input
without requiring TS_VALID set high. This is required for some new boards
to function properly, due to the hardware design implementation.
The configuration is toggled within the board setup configuration. Boards
that do not have this bit set will function as before with no change.
mismatch with abs()
The abs() macro has changed in 2.6.32 and returns a long instead of an
int. Fix the driver to avoid compilation warnings.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The FIX_BANDWIDTH quirk tries to work around cameras requesting the
maximum bandwidth regardless of the image size by computing a bandwidth
estimate. This works only for uncompressed frames.
Which is why I have always preferred sizeof(struct foo) over
sizeof(var).
Cc: Antti Palosaari <crope@iki.fi>
Acked-by: Steven Toth <stoth@kernellabs.com>
Required for wakeup call.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
gspca_mr97310a: Change vstart for CIF sensor type 1 cams
This fixes the distortion at the end of the frame, and avoids the bad frame
dropping done because of this distortion, trippling the framerate!
Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu>
Adds a vflip quirk for the Fujitsu Amilo Xi 2528. Thanks to Evgeny for the report.
Signed-off-by: Erik Andrén <erik.andren@gmail.com>
Adds another vflip quirk for the MSI GX700.
Thanks to John Katzmaier for reporting.
Adds a vflip quirk for the Bruneinit laptop. Thanks to Jörg for the report
Since 2.6.32(-rc1), DVB core checks the return value of
dvb_frontend_ops.set_frontend. Now it becomes apparent that firedtv
always returned a bogus value from its set_frontend method.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
This solves a problem in firedtv that has become major for Swedish DVB-T
users the last month or so. It will most likely solve issues seen by
other users as well.
If the length of an AVC message is greater than 127, the length field
should be encoded in LV mode instead of V mode. V mode can only be used
if the length is 127 or less. This patch ensures that the CA_PMT
message is always encoded in LV mode so PMT message of greater lengths
can be supported.
Signed-off-by: Henrik Kurelid <henrik@kurelid.se>
waiting processes
The s2255 driver had logic which aborted processing of a video frame
if there was no process waiting on the video buffer in question. That
simply doesn't work when the application is doing things in an
asynchronous manner. If the application went to the trouble to queue
the buffer in the first place, then the driver should always attempt
to complete it - even if the application at that moment has its
attention turned elsewhere. Applications which always blocked waiting
for I/O on the capture device would not have been affected by this.
Applications which *mostly* blocked waiting for I/O on the capture
device probably only would have been somewhat affected (frame lossage,
at a rate which goes up as the application blocks less). Applications
which never blocked on the capture device (e.g. polling only) however
would never have been able to receive any video frames, since in that
case this "is anyone waiting on this?" check on the buffer never would
have evalutated true. This patch just deletes that harmful check
against the buffer's wait queue.
Signed-off-by: Mike Isely <isely@pobox.com>
Hauppauge USB IDs
Add support for three new Hauppauge Device USB IDs:
2040:b900
2040:b910
2040:c000
Because the counters were not reset when starting up streaming, they would
be reused from the previous run. This can result in cases such that when the
second instance of streaming starts up, the "cnt" variable in
em28xx_audio_isocirq() can end up being negative, resulting in attempting to
write to memory before the start of runtime->dma_area (as well as having a
negative number of bytes to copy).
The bttv driver function which handles switching of the video standard
(set_tvnorm() in bttv-driver.c) includes a check which can optionally
also reset the cropping configuration to a default value. It is
"optional" based on a comparison of the cropcap parameters of the
previous vs the newly requested video standard. The comparison is
being done with a memcmp(), a function which only returns a true value
if the comparison actually fails.
This if-statement appears to have been written to assume wrong
memcmp() semantics. That is, it was re-initializing the cropping
configuration only if the new video standard did NOT have different
cropcap values. That doesn't make any sense. One definitely should
reset things if the cropcap parameters are different - if there's any
comparison to made at all.
The effect of this problem was that a transition from, say, PAL to
NTSC would leave in place old cropping setup that made sense for the
PAL geometry but not for NTSC. If the application doesn't care about
cropping it also won't try to reset the cropping configuration,
resulting in an improperly cropped video frame. In the case I was
testing this actually caused black video frames to be displayed.
Another interesting effect of this bug is that if one does something
which does NOT change the video standard and this function is run,
then the cropping setup gets reset anyway - again because of the
backwards comparison. It turns out that just running anything which
merely opens and closes the video device node (e.g. v4l-info) will
cause this to happen. One can argue that simply opening the device
node and not doing anything to it should not mess with any of its
state - but because of this behavior, any TV app which does such
things (e.g. xawtv) probably therefore doesn't see the problem.
The solution is to fix the sense of the if-statement. It's easy to
see how this mistake could have been made given how memcmp() works.
The patch is therefore removal of a single "!" character from the
if-statement in set_tvnorm in bttv-driver.c.
There is a subtle interaction in the bttv driver which can result in
fields being repeatedly processed out of order. This is a problem
specifically when running in V4L2_FIELD_ALTERNATE mode (probably the
most common case).
1. The determination of which fields are associated with which buffers
happens in videobuf, before the bttv driver gets a chance to queue the
corresponding DMA. Thus by the point when the DMA is queued for a
given buffer, the algorithm has to do the queuing based on the
buffer's already assigned field type - not based on which field is
"next" in the video stream.
2. The driver normally tries to queue both the top and bottom fields
at the same time (see bttv_irq_next_video()). It tries to sort out
top vs bottom by looking at the field type for the next 2 available
buffers and assigning them appropriately.
3. However the bttv driver *always* actually processes the top field
first. There's even an interrupt set aside for specifically
recognizing when the top field has been processed so that it can be
marked done even while the bottom field is still being DMAed.
Given all of the above, if one gets into a situation where
bttv_irq_next_video() gets entered when the first available buffer has
been pre-associated as a bottom field, then the function is going to
process the buffers out of order. That first available buffer will be
put into the bottom field slot and the buffer after that will be put
into the top field slot. Problem is, since the top field is always
processed first by the driver, then that second buffer (the one after
the first available buffer) will be the first one to be finished.
Because of the strict fifo handling of all video buffers, then that
top field won't be seen by the app until after the bottom field is
also processed. Worse still, the app will get back the
chronologically later bottom field first, *before* the top field is
received. The buffer's timestamps will even be backwards.
While not fatal to most TV apps, this behavior can subtlely degrade
userspace deinterlacing (probably will cause jitter). That's probably
why it has gone unnoticed. But it will also cause serious problems if
the app in question discards all but the latest received buffer (a
latency minimizing tactic) - causing one field to only ever be
displayed since the other is now always late. Unfortunately once you
get into this state, you're stuck this way - because having consumed
two buffers, now the next time around the "first" available buffer
will again be a bottom field and the same thing happens.
How can we get into this state? In a perfect world, where there's
always a few free buffers queued to the driver, it should be
impossible. However if something disrupts streaming, e.g. if the
userspace app can't queue free buffers fast enough for a moment due
perhaps to a CPU scheduling glitch, then the driver can get
momentarily starved and some number of fields will be dropped. That's
OK. But if an odd number of fields get dropped, then that "first"
available buffer might be the bottom field and now we're stuck...
This patch fixes that problem by deliberately only setting up a single
field for one frame if we don't get a top field as the first available
buffer. By purposely skipping the other field, then we only handle a
single buffer thus bringing things back into proper sync (i.e. top
field first) for the next frame. To do this we just drop the few
lines in bttv_irq_next_video() that attempt to set up the second
buffer when that second buffer isn't for the bottom field.
This is definitely a problem in when in V4L2_FIELD_ALTERNATE mode. In
the other modes this change either has no effect or doesn't harm
things any further anyway.
The lack of #include <linux/vmalloc.h> caused a compile error on some
architectures.
Signed-off-by: HIRANO Takahito <hiranotaka@zng.info>
change
Commit b4028437876866aba4747a655ede00f892089e14 has broken again re-use of
device objects across device_register() / device_unregister() cycles. Fix
soc-camera by nullifying the struct after device_unregister().
A missed conversion prevents correct pixel format negotiation with client
drivers.
Reported-by: Antonio Ospite <ospite@studenti.unina.it>
Fix a bug in cropping calculation, when the client is also scaling the image.
When we call gspca_frame_add, it returns a pointer to the frame passed in,
unless we call it with LAST_PACKET, when it will return a pointer to a
new frame in which to store the frame data for the next frame.
The frame pointer was not updated in stv06xx and ov518.
tda18271_rf_tracking_filters_init
While having tda18271 module set with debug=17 (cal & info prints) and
cal=0 (delay calibration process until first use) - I discovered that
during the calibration process, if the frequency test for 69750000
returned a bcal of 0 (see tda18721-fe.c in tda18271_powerscan func) that
the tuner wouldn't be able to pickup any of the frequencies in the range
(all the other frequencies bands returned bcal=1). I spent some time
going over the code and the NXP's tda18271 spec (ver.4 of it i think) and
adding a lot of debug prints and walking/stepping through the calibration
process. I found that when the powerscan fails to find a frequency, the
rf calibration is not run and the default value is supposed to be used in
its place (pulled from the RF_CAL_map table) - but something was getting
goofed up there.
Now, my c coding skills are very rusty, but i think root of the problem is
a signedness issue with the math operation for calculating the rf_a1 and
rf_a2 values in tda18271_rf_tracking_filters_init func, which results in
values like 20648 for rf_a1 (when it should probably have a value like 0,
or so slightly negative that it should be zero - this bad value for rf_a1
would in turn makes the approx calc within
tda18271c2_rf_tracking_filters_correction go out of whack). The simplest
solution i found was to explicitly convert the signedness of the
denominator to avoid the implicit conversion. The values placed into the
u32 rf_freq array should never exceed about 900mhz, so i think the s32 max
value shouldn't be an issue in this case.
I've tested it out a little, and even when i get a bcal=0 with the
modified code, the default calibration value gets used, rf_a1 is zero, and
the tuner seems to lock on the stream and mythtv seems to play it fine.
Signed-off-by: Seth Barry <seth@cyberseth.com>
Multiplication by 62500 causes an overflow in the 32 bit freq variable,
which is later divided by 1000 when using FM radio.
This patch prevents the overflow by scaling the frequency value correctly
upfront. Thanks to Henk Vergonet for spotting the problem and providing
a preliminary patch, which this changeset was based upon.
Cc: Henk Vergonet <Henk.Vergonet@gmail.com>
Fixing kernel oops when driver attemps to load xc2028 firmware.
Note by djh: the patch contribute by Martin is a port of a fix I made during
the PCTV 340e development. It's a temporary workaround that fixes a regression
(an OOPS condition) and the real fix should be in the code that manages the
i2c master on the dib7000p. But this fix does address the immmediate
regression and should be merged upstream until we do a cleaner fix.
Signed-off-by: Martin Samek <martin@marsark.sytes.net>
git commit db48138f6bc4d2b613b08731ffc8b319432ebc25 changed by accident the
assignment of certain USB IDs to their device-specific-handlers.
Thanks to Edward Sheldrake for finding this regression
Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com>
Fix build dependency on function, dib0070_ctrl_agc_filter
[mchehab@redhat.com: reverted the quick workaround 3f48258e50ef4]
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
[akpm@linux-foundation.org: fix KVM]
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB (13039): dib0700: not building CONFIG_DVB_TUNER_DIB0070 breaks compilation
V4L/DVB (13038): dvbdev: Remove an anoying/uneeded warning
V4L/DVB (13037): go7007: Revert compatibility code added at the wrong place
media: video: Fix build in saa7164
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
compilation
As reported by Ingo Molnar:
Here's another new build breakage that triggers in -tip testing:
drivers/built-in.o:(.data+0xb1f40): undefined reference to `dib0070_ctrl_agc_filter'
drivers/built-in.o:(.data+0xb1f80): undefined reference to `dib0070_ctrl_agc_filter'
triggers due to:
CONFIG_DVB_USB_DIB0700=y
CONFIG_DVB_TUNER_DIB0070 is not set
While working on a better approach, for now, let's just select tuner
dib0070 anytime we compile dib0700.
Cc: Patrick Boettcher <pboettcher@kernellabs.com>
