path: root/drivers/media
2011-11-07tuner_xc2028: Allow selection of the frequency adjustment code for XC3028Mauro Carvalho Chehab
commit 9bed77ee2fb46b74782d0d9d14b92e9d07f3df6e upstream. This device is not using the proper demod IF. Instead of using the IF macro, it is specifying a IF frequency. This doesn't work, as xc3028 needs to load an specific SCODE for the tuner. In this case, there's no IF table for 5 MHz. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-07uvcvideo: Set alternate setting 0 on resume if the bus has been resetMing Lei
commit d59a7b1dbce8b972ec2dc9fcaaae0bfa23687423 upstream. If the bus has been reset on resume, set the alternate setting to 0. This should be the default value, but some devices crash or otherwise misbehave if they don't receive a SET_INTERFACE request before any other video control request. Microdia's 0c45:6437 camera has been found to require this change or it will stop sending video data after resume. uvc_video.c] Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-08si4713-i2c: avoid potential buffer overflow on si4713Mauro Carvalho Chehab
commit dc6b845044ccb7e9e6f3b7e71bd179b3cf0223b6 upstream. While compiling it with Fedora 15, I noticed this issue: inlined from ‘si4713_write_econtrol_string’ at drivers/media/radio/si4713-i2c.c:1065:24: arch/x86/include/asm/uaccess_32.h:211:26: error: call to ‘copy_from_user_overflow’ declared with attribute error: copy_from_user() buffer size is not provably correct Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Acked-by: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-08bttv: fix s_tuner for radioHans Verkuil
commit a024c1a6b274e11596d124619e43c25560f64c01 upstream. Fix typo: g_tuner should have been s_tuner. Tested with a bttv card. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-08pvrusb2: fix g/s_tuner supportHans Verkuil
commit 50e9efd60b213ce43ad6979bfc18e25eec2d8413 upstream. The tuner-core subdev requires that the type field of v4l2_tuner is filled in correctly. This is done in v4l2-ioctl.c, but pvrusb2 doesn't use that yet, so we have to do it manually based on whether the current input is radio or not. Tested with my pvrusb2. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-08v4l2-ioctl.c: prefill tuner type for g_frequency and g/s_tunerHans Verkuil
commit 227690df75382e46a4f6ea1bbc5df855a674b47f upstream. The subdevs are supposed to receive a valid tuner type for the g_frequency and g/s_tuner subdev ops. Some drivers do this, others don't. So prefill this in v4l2-ioctl.c based on whether the device node from which this is called is a radio node or not. The spec does not require applications to fill in the type, and if they leave it at 0 then the 'check_mode' call in tuner-core.c will return an error and the ioctl does nothing. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13uvcvideo: Remove buffers from the queues when freeingSjoerd Simons
commit 8ca2c80b170c47eeb55f0c2a0f2b8edf85f35d49 upstream. When freeing memory for the video buffers also remove them from the irq & main queues. This fixes an oops when doing the following: open ("/dev/video", ..) VIDIOC_REQBUFS VIDIOC_QBUF VIDIOC_REQBUFS close () As the second VIDIOC_REQBUFS will cause the list entries of the buffers to be cleared while they still hang around on the main and irc queues Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09V4L/DVB: Add Elgato EyeTV Diversity to dibcom driverMichael Müller
commit 84e2f037ce9672d0fb118e3e82cecfe6122ace3f upstream. This patch introduces support for DVB-T for the following dibcom based card: Elgato EyeTV Diversity (USB-ID: 0fd9:0011) Support for the Elgato silver IR remote is added too (set parameter dvb_usb_dib0700_ir_proto=0) [w.sang@pengutronix.de: rebased to current linuxtv-master] Signed-off-by: Michael Müller <mueller_michael@alice-dsl.net> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> [bwh: Adjust context and numbering for 2.6.32] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09FLEXCOP-PCI: fix __xlate_proc_name-warning for flexcop-pciPatrick Boettcher
commit b934c20de1398d4a82d2ecfeb588a214a910f13f upstream. This patch fixes the warning about bad names for sys-fs and other kernel-things. The flexcop-pci driver was using '/'-characters in it, which is not good. This has been fixed in several attempts by several people, but obviously never made it into the kernel. Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Cc: Steffen Barszus <steffenbpunkt@googlemail.com> Cc: Boris Cuber <me@boris64.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22video: sn9c102: world-wirtable sysfs filesVasiliy Kulikov
commit 14ddc3188d50855ae2a419a6aced995e2834e5d4 upstream. Don't allow everybody to change video settings. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27uvcvideo: Fix uvc_fixup_video_ctrl() format searchStephan Lachowsky
commit 38a66824d96de8aeeb915e6f46f0d3fe55828eb1 upstream. The scheme used to index format in uvc_fixup_video_ctrl() is not robust: format index is based on descriptor ordering, which does not necessarily match bFormatIndex ordering. Searching for first matching format will prevent uvc_fixup_video_ctrl() from using the wrong format/frame to make adjustments. Signed-off-by: Stephan Lachowsky <stephan.lachowsky@maxim-ic.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02radio-aimslab.c needs #include <linux/delay.h>Geert Uytterhoeven
commit 2400982a2e8a8e4e95f0a0e1517bbe63cc88038f upstream. Commit e3c92215198cb6aa00ad38db2780faa6b72e0a3f ("[media] radio-aimslab.c: Fix gcc 4.5+ bug") removed the include, but introduced new callers of msleep(): | drivers/media/radio/radio-aimslab.c: In function ‘rt_decvol’: | drivers/media/radio/radio-aimslab.c:76: error: implicit declaration of function ‘msleep’ Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02av7110: check for negative array offsetDan Carpenter
commit cb26a24ee9706473f31d34cc259f4dcf45cd0644 upstream. info->num comes from the user. It's type int. If the user passes in a negative value that would cause memory corruption. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17em28xx: Fix audio input for Terratec GrabbyMauro Carvalho Chehab
commit a3fa904ec79b94f0db7faed010ff94d42f7d1d47 upstream. The audio input line was wrong. Fix it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17radio-aimslab.c: Fix gcc 4.5+ bugMauro Carvalho Chehab
commit e3c92215198cb6aa00ad38db2780faa6b72e0a3f upstream. gcc 4.5+ doesn't properly evaluate some inlined expressions. A previous patch were proposed by Andrew Morton using noinline. However, the entire inlined function is bogus, so let's just remove it and be happy. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09V4L/DVB: ivtvfb: prevent reading uninitialized stack memoryDan Rosenberg
commit 405707985594169cfd0b1d97d29fcb4b4c6f2ac9 upstream. The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16 bytes of uninitialized stack memory, because the "reserved" member of the fb_vblank struct declared on the stack is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09V4L/DVB (13154): uvcvideo: Handle garbage at the end of streaming interface ↵Laurent Pinchart
descriptors commit c4ed8c66d79d707d89fe732ff5b97739edf1ba62 upstream. At least one 5986:0241 webcam model includes vendor-specific descriptors at the end of its streaming interface descriptors. Print an information UVC_TRACE_DESCR message and try to continue parsing the descriptors rather than bailing out with an error. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28V4L/DVB (13966): DVB-T regression fix for saa7134 cardsDmitri Belimov
commit 08be64be3d1e5ecd72e7ba3147aea518e527f08e upstream. Some customers has problem with quality of DVB-T https://bugs.launchpad.net/ubuntu/+source/linux/+bug/446575 After this patch http://patchwork.kernel.org/patch/23345/ This is patch for fix regression with DVB-T. Tested with many people. Signed-off-by: Alexey Osipov <lion-simba@pridelands.ru> Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28V4L/DVB: cx231xx: Avoid an OOPS when card is unknown (card=0)Mauro Carvalho Chehab
commit c10469c637602c2385e2993d8c730cc44fd47d23 upstream. As reported by: Carlos Americo Domiciano <c_domiciano@yahoo.com.br>: [ 220.033500] cx231xx v4l2 driver loaded. [ 220.033571] cx231xx #0: New device Conexant Corporation Polaris AV Capturb @ 480 Mbps (1554:5010) with 6 interfaces [ 220.033577] cx231xx #0: registering interface 0 [ 220.033591] cx231xx #0: registering interface 1 [ 220.033654] cx231xx #0: registering interface 6 [ 220.033910] cx231xx #0: Identified as Unknown CX231xx video grabber (card=0) [ 220.033946] BUG: unable to handle kernel NULL pointer dereference at (null) [ 220.033955] IP: [<ffffffffa0d3c8bd>] cx231xx_pre_card_setup+0x5d/0xb0 [cx231xx] Thanks-to: Carlos Americo Domiciano <c_domiciano@yahoo.com.br> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28v4l1: fix 32-bit compat microcode loading translationLinus Torvalds
commit 3e645d6b485446c54c6745c5e2cf5c528fe4deec upstream. The compat code for the VIDIOCSMICROCODE ioctl is totally buggered. It's only used by the VIDEO_STRADIS driver, and that one is scheduled to staging and eventually removed unless somebody steps up to maintain it (at which point it should use request_firmware() rather than some magic ioctl). So we'll get rid of it eventually. But in the meantime, the compatibility ioctl code is broken, and this tries to get it to at least limp along (even if Mauro suggested just deleting it entirely, which may be the right thing to do - I don't think the compatibility translation code has ever worked unless you were very lucky). Reported-by: Kees Cook <kees.cook@canonical.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB (13830): uvcvideo: add another YUYV format GUID for iSight camerasDaniel Ritz
commit 68f194e027ecfbbc8d5515bc40787e542eed59e9 upstream. For some unknown reason, on a MacBookPro5,3 the iSight sometimes report a different video format GUID. This patch add the other (wrong) GUID to the format table, making the iSight work always w/o other problems. What it should report: 32595559-0000-0010-8000-00aa00389b71 What it often reports: 32595559-0000-0010-8000-000000389b71 Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Leann Ogasawara <leann.ogasawara@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB: uvcvideo: Add support for V4L2_PIX_FMT_Y16Laurent Pinchart
commit 61421206833a4085d9bdf35b2b84cd9a67dfdfac upstream. The Miricle 307K (17dc:0202) camera reports a 16-bit greyscale format, support it in the driver. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB: uvcvideo: Add support for Packard Bell EasyNote MX52 integrated webcamLaurent Pinchart
commit f129b03ba272c86c42ad476684caa0d6109cb383 upstream. The camera requires the STREAM_NO_FID quirk. Add a corresponding entry in the device IDs list. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB: uvcvideo: Add support for unbranded Arkmicro 18ec:3290 webcamsLaurent Pinchart
commit 1e4d05bc95a0fe2972c5c91ed45466587d07cd2c upstream. The camera requires the PROBE_DEF quirk. Add a corresponding entry in the device IDs list. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB: budget: Select correct frontendsBen Hutchings
commit d46b36e7f927772bb72524dc9f1e384e3cb4a975 upstream. Update the Kconfig selections to match the code. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB: FusionHDTV: Use quick reads for I2C IR device probingJean Delvare
commit 806b07c29b711aaf90c81d2a19711607769f8246 upstream. IR support on FusionHDTV cards is broken since kernel 2.6.31. One side effect of the switch to the standard binding model for IR I2C devices was to let i2c-core do the probing instead of the ir-kbd-i2c driver. There is a slight difference between the two probe methods: i2c-core uses 0-byte writes, while the ir-kbd-i2c was using 0-byte reads. As some IR I2C devices only support reads, the new probe method fails to detect them. For now, revert to letting the driver do the probe, using 0-byte reads. In the future, i2c-core will be extended to let callers of i2c_new_probed_device() provide a custom probing function. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: "Timothy D. Lenz" <tlenz@vorgon.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02V4L/DVB: dvb-core: Fix ULE decapsulation bugAng Way Chuang
commit 5c331fc8c19e181bffab46e9d18e1637cdc47170 upstream. Fix ULE decapsulation bug when less than 4 bytes of ULE SNDU is packed into the remaining bytes of a MPEG2-TS frame ULE (Unidirectional Lightweight Encapsulation RFC 4326) decapsulation code has a bug that incorrectly treats ULE SNDU packed into the remaining 2 or 3 bytes of a MPEG2-TS frame as having invalid pointer field on the subsequent MPEG2-TS frame. Signed-off-by: Ang Way Chuang <wcang@nav6.org> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05V4L/DVB: gspca - stv06xx: Remove the 046d:08da from the stv06xx driverErik Andrén
commit 55e0b489a39bb635a44f769d620e44c70d9c065b upstream. The 046d:08da usb id shouldn't be associated with the stv06xx driver as they're not compatible with each other. This fixes a bug where Quickcam Messenger cams fail to use its proper driver (gspca-zc3xx), rendering the camera inoperable. Signed-off-by: Erik Andrén <erik.andren@gmail.com> Tested-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12V4L/DVB: budget: Oops: "BUG: unable to handle kernel NULL pointer dereference"Bjørn Mork
commit 6f550dc08369ee0bc6402963c377e65f0f2e3b71 upstream. Never call dvb_frontend_detach if we failed to attach a frontend. This fixes the following oops, which will be triggered by a missing stv090x module: [ 8.172997] DVB: registering new adapter (TT-Budget S2-1600 PCI) [ 8.209018] adapter has MAC addr = 00:d0:5c:cc:a7:29 [ 8.328665] Intel ICH 0000:00:1f.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17 [ 8.328753] Intel ICH 0000:00:1f.5: setting latency timer to 64 [ 8.562047] DVB: Unable to find symbol stv090x_attach() [ 8.562117] BUG: unable to handle kernel NULL pointer dereference at 000000ac [ 8.562239] IP: [<e08b04a3>] dvb_frontend_detach+0x4/0x67 [dvb_core] Ref http://bugs.debian.org/575207 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01V4L/DVB (13961): em28xx-dvb: fix memleak in dvb_fini()Francesco Lavra
commit 19f48cb105b7fa18d0dcab435919a3a29b7a7c4c upstream. this patch fixes a memory leak which occurs when an em28xx card with DVB extension is unplugged or its DVB extension driver is unloaded. In dvb_fini(), dev->dvb must be freed before being set to NULL, as is done in dvb_init() in case of error. Note that this bug is also present in the latest stable kernel release. Signed-off-by: Francesco Lavra <francescolavra@interfree.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15V4L/DVB (13148): uvcvideo: Handle V4L2_CTRL_TYPE_BUTTON control type in ↵Laurent Pinchart
VIDIOC_QUERYCTRL commit f4eabafeb3ea41801260fba624cbf2da971d19f8 upstream. Return minimum, maximum and step set to 0 without querying the hardware. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15dvb-core: Fix DoS bug in ULE decapsulation code that can be triggered by an ↵Ang Way Chuang
invalid Payload Pointer commit 29e1fa3565a7951cc415c634eb2b78dbdbee151d upstream. ULE (Unidirectional Lightweight Encapsulation RFC 4326) decapsulation has a bug that causes endless loop when Payload Pointer of MPEG2-TS frame is 182 or 183. Anyone who sends malicious MPEG2-TS frame will cause the receiver of ULE SNDU to go into endless loop. This patch was generated and tested against linux-2.6.32.9 and should apply cleanly to linux-2.6.33 as well because there was only one typo fix to dvb_net.c since v2.6.32. This bug was brought to you by modern day Santa Claus who decided to shower the satellite dish at Keio University with heavy snow causing huge burst of errors. We, receiver end, received Santa Claus's gift in the form of kernel bug. Care has been taken not to introduce more bug by fixing this bug, but please scrutinize the code for I always produces buggy code. Signed-off-by: Ang Way Chuang <wcang79@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15V4L/DVB (13991): gspca_mr973010a: Fix cif type 1 cameras not streaming on ↵Theodore Kilgore
UHCI controllers commit 70136081fc67ea77d849f86fa323e5773c8e40ea upstream. If you read the mail to Oliver Neukum on the linux-usb list, then you know that I found a cure for the mysterious problem that the MR97310a CIF "type 1" cameras have been freezing up and refusing to stream if hooked up to a machine with a UHCI controller. Namely, the cure is that if the camera is an mr97310a CIF type 1 camera, you have to send it 0xa0, 0x00. Somehow, this is a timing reset command, or such. It un-blocks whatever was previously stopping the CIF type 1 cameras from working on the UHCI-based machines. Signed-off-by: Theodore Kilgore <kilgota@auburn.edu> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15V4L/DVB: cxusb: Select all required frontend and tuner modulesBen Hutchings
commit fc4a7f93087a48619005111895dcaa115f807399 upstream. cxusb uses the atbm8830 and lgs8gxx (not lgs8gl5) frontends and the max2165 tuner, so it needs to select them. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15V4L/DVB: bttv: Move I2C IR initializationJean Delvare
commit 2434466432464110b5307757e0285dd41f15512e upstream. Move I2C IR initialization from just after I2C bus setup to right before non-I2C IR initialization. This avoids the case where an I2C IR device is blocking audio support (at least the PV951 suffers from this). It is also more logical to group IR support together, regardless of the connectivity. This fixes bug #15184: http://bugzilla.kernel.org/show_bug.cgi?id=15184 Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15V4L/DVB: Video : pwc : Fix regression in pwc_set_shutter_speed caused by bad ↵Martin Fuzzey
constant => sizeof conversion. commit 53f68607caba85db9a73846ccd289e4b7fa96295 upstream. Regression was caused by my commit 6b35ca0d3d586b8ecb8396821af21186e20afaf0 which determined message size using sizeof rather than hardcoded constants. Unfortunately pwc_set_shutter_speed reuses a 2 byte buffer for a one byte message too so the sizeof was bogus in this case. All other uses of sizeof checked and are ok. Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15V4L/DVB: dvb: l64781.ko broken with gcc 4.5Richard Guenther
commit c1db53b36633e6a7511dbec7c372f01a31528f0c upstream. I'm trying to fix it on the GCC side (PR43007), but the module is quite stupid in using ULL constants to operate on u32 values: static int apply_frontend_param (struct dvb_frontend* fe, struct dvb_frontend_parameters *param) { ... static const u32 ppm = 8000; u32 spi_bias; ... spi_bias *= 1000ULL; spi_bias /= 1000ULL + ppm/1000; which causes current GCC 4.5 to emit calls to __udivdi3 for i?86 again. This patch fixes this issue. Signed-off-by: Richard Guenther <rguenther@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-23V4L/DVB: dvb-core: fix initialization of feeds list in demux filterFrancesco Lavra
commit 691c9ae099b9bcb5c27125af00a4a90120977458 upstream. A DVB demultiplexer device can be used to set up either a PES filter or a section filter. In the former case, the ts field of the feed union of struct dmxdev_filter is used, in the latter case the sec field of the same union is used. The ts field is a struct list_head, and is currently initialized in the open() method of the demux device. When for a given demuxer a section filter is set up, the sec field is played with, thus if a PES filter needs to be set up after that the ts field will be corrupted, causing a kernel oops. This fix moves the list head initialization to dvb_dmxdev_pes_filter_set(), so that the ts field is properly initialized every time a PES filter is set up. Signed-off-by: Francesco Lavra <francescolavra@interfree.it> Reviewed-by: Andy Walls <awalls@radix.net> Tested-by: hermann pitton <hermann-pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28V4L/DVB (13826): uvcvideo: Fix controls blacklistingLaurent Pinchart
commit 385097e08b9c24655626ed760bc67eb7e50115a0 upstream. The control blacklisting code erroneously used usb_match_id() by passing a pointer to a usb_device_id structure instead of an array of such structures. Replace the usb_match_id() call by usb_match_id_one(). Thanks to Paulo Assis for diagnosing the bug and providing an initial fix. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28V4L/DVB (13168): Add support for Asus Europa Hybrid DVB-T card (SAA7134 ↵Danny Wood
SubVendor ID: 0x1043 Device ID: 0x4847) commit e3c6e1aaa5db7822524f5b1355960fd732910068 upstream. Adds the device IDs and driver linking to allow the Asus Europa DVB-T card to operate with these drivers. The device has a SAA7134 chipset with a TD1316 Hybrid Tuner. All inputs work on the card including switching between DVB-T and Analogue TV, there is also no IR with this card. [mchehab@redhat.com: CodingStyle fixes] Signed-off-by: Danny Wood <danwood76@gmail.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28V4L/DVB (13569): smsusb: add autodetection support for five additional ↵Michael Krufky
Hauppauge USB IDs commit 20d15a200d34cfb7141fb4558895d7d5233db84b upstream. Add support for five new Hauppauge Device USB IDs: 2040:b980 2040:b990 2040:c010 2040:c080 2040:c090 Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-25V4L/DVB (13900): gspca - sunplus: Fix bridge exchanges.Jean-Francois Moine
commit 07d1c69b2dcfdd1b21e36af0ff8b9506234908ee upstream. A previous code optimization inverted bridge registers and values, doing a regression in kernel 2.6.32. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22V4L/DVB (13868): gspca - sn9c20x: Fix test of unsigned.Roel Kluin
commit c60503c1db76bd46577cc7ff4fafa033b675e0e5 upstream. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06V4L/DVB (13596): ov511.c typo: lock => unlockDan Carpenter
commit 50e9d31183ed61c787b870cb3ee8f6c3db8c8a1e upstream. This was found with a static checker and has not been tested, but it seems pretty clear that the mutex_lock() was supposed to be mutex_unlock() Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Brandon Philips <brandon@ifup.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18V4L/DVB (13116): gspca - ov519: Webcam 041e:4067 added.Rafal Milecki
commit 518c8df77c21b7d1690dd8b96eb0e54c4ec1c9c1 upstream. Signed-off-by: Rafal Milecki <zajec5@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Surbhi Palande <surbhi.palande@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18V4L/DVB: Fix test in copy_reg_bits()Roel Kluin
commit c95a419a5604ec8a23cd73f61e9bb151e8cbe89b upstream. The reg_pair2[j].reg was tested twice. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-01drivers/media/dvb/dvb-core/dvb_frontend.c: needs semaphore.hAndrew Morton
Fixes: v4l/dvb_frontend.c: In function 'dvb_frontend_stop': v4l/dvb_frontend.c:707: error: implicit declaration of function 'init_MUTEX' Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14609 Reported-by: <tstrelar@gmail.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-27V4L/DVB (13530): Fix wrong parameter order in memsetAlan Cox
Edwin Török found the following: In function ‘memset’, inlined from ‘ir_input_init’ at drivers/media/common/ir-functions.c:67: /home/edwin/builds/linux-2.6/arch/x86/include/asm/string_64.h:61: warning: call to ‘__warn_memset_zero_len’ declared with attribute warning: memset used with constant zero length parameter; this could be due to transposed parameters memset(ir->ir_codes, sizeof(ir->ir_codes), 0); In actual practice the only caller I can find happens to already have cleared the buffer before calling ir_input_init. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-11-27V4L/DVB (13481): sh_mobile_ceu_camera: fix compile warningHans Verkuil
Trivial fix for this compile warning: v4l/sh_mobile_ceu_camera.c:1789: warning: label 'exit_free_irq' defined but not used Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-11-27V4L/DVB (13436): cxusb: Fix hang on DViCO FusionHDTV DVB-T Dual Digital 4 ↵Robert Lowery
(rev 1) Address yet another regression introduced by the introduction of the zl10353 disable_i2c_gate field. djh - I unmangled the patch which apparently got screwed up in the user's email client. Signed-off-by: Robert Lowery <rglowery@exemail.com.au> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> CC: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
