path: root/drivers/media
2013-12-10[media] videobuf2-dma-sg: fix possible memory leakGeyslan G. Bem
Fix the return when 'buf->pages' allocation error. Signed-off-by: Geyslan G. Bem <geyslan@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
2013-12-10[media] vb2: regression fix: always set length field.Hans Verkuil
Commit dc77523c5da5513df1bbc74db2a522a94f4cec0e ensured that m.offset is only set for the MMAP memory mode by calling __setup_offsets only for that mode. However, __setup_offsets also initializes the length fields, and that should be done regardless of the memory mode. Because of that change the v4l2-ctl test application fails for the USERPTR mode. This fix creates a __setup_lengths function that sets the length, and __setup_offsets just sets the offset and no longer touches the length. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
2013-12-09[media] mt9p031: Include linux/of.h headerSachin Kamat
'of_match_ptr' is defined in linux/of.h. Include it explicitly to avoid build breakage in the future. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-12-09[media] rtl2830: add parent for I2C adapterAntti Palosaari
i2c i2c-6: adapter [RTL2830 tuner I2C adapter] registered BUG: unable to handle kernel NULL pointer dereference at 0000000000000220 IP: [<ffffffffa0002900>] i2c_register_adapter+0x130/0x390 [i2c_core] Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-12-09[media] media: marvell-ccic: use devm to release clkLibin Yang
This patch uses devm to release the clks instead of releasing manually. And it adds enable/disable mipi_clk when getting its rate. Signed-off-by: Libin Yang <lbyang@marvell.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] ths7303: Declare as static a private functionRicardo Ribalda
git grep shows that the function is only called from ths7303.c Fix this build warning: CC drivers/media/i2c/ths7303.o drivers/media/i2c/ths7303.c:86:5: warning: no previous prototype for ‘ths7303_setval’ [-Wmissing-prototypes] int ths7303_setval(struct v4l2_subdev *sd, enum ths7303_filter_mode mode) ^ Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] em28xx-video: Swap release order to avoid lock nestingRicardo Ribalda
vb2_fop_release might take the video queue mutex lock. In order to avoid nesting mutexes the private mutex is taken after the fop_release has finished. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] usbtv: Add support for PAL video sourceGeorg Kaindl
Signed-off-by: Georg Kaindl <gkaindl@mac.com> Tested-by: Lubomir Rintel <lkundrak@v3.sk> Tested-by: Marcin Nowak <marcin.nowak@simplusnet.pl> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] media_tree: Fix spelling errorsJonathan McCrohan
Fix various spelling errors in strings and comments throughout the media tree. The majority of these were found using Lucas De Marchi's codespell tool. [m.chehab@samsung.com: discard hunks with conflicts] Signed-off-by: Jonathan McCrohan <jmccrohan@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] videobuf2: Add support for file access mode flags for DMABUF exportingPhilipp Zabel
Currently it is not possible for userspace to map a DMABUF exported buffer with write permissions. This patch allows to also pass O_RDONLY/O_RDWR when exporting the buffer, so that userspace may map it with write permissions. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] radio-shark2: Mark shark_resume_leds() inline to kill compiler warningHans de Goede
This mirrors the patch to the radio-shark driver by Geert Uytterhoeven. If SHARK_USE_LEDS=1, but CONFIG_PM=n: drivers/media/radio/radio-shark2.c:240: warning: ‘shark_resume_leds’ defined but not used Instead of making the #ifdef logic even more complicated (there are already two definitions of shark_resume_leds()), mark shark_resume_leds() inline to kill the compiler warning. shark_resume_leds() is small and it has only one caller. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-09[media] radio-shark: Mark shark_resume_leds() inline to kill compiler warningGeert Uytterhoeven
If SHARK_USE_LEDS=1, but CONFIG_PM=n: drivers/media/radio/radio-shark.c:275: warning: ‘shark_resume_leds’ defined but not used Instead of making the #ifdef logic even more complicated (there are already two definitions of shark_resume_leds()), mark shark_resume_leds() inline to kill the compiler warning. shark_resume_leds() is small and it has only one caller. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-12-04[media] af9035: unlock on error in af9035_i2c_master_xfer()Dan Carpenter
We introduced a couple new error paths which are missing unlocks. Fixes: 7760e148350b ('[media] af9035: Don't use dynamic static allocation') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: stable@vger.kernel.org
2013-12-04[media] af9033: fix broken I2CAntti Palosaari
Driver did not work anymore since I2C has gone broken due to recent commit: commit 37ebaf6891ee81687bb558e8375c0712d8264ed8 [media] dvb-frontends: Don't use dynamic static allocation Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: stable@vger.kernel.org
2013-12-04[media] v4l: omap3isp: Don't check for missing get_fmt op on remote subdevLaurent Pinchart
The remote subdev of any video node in the OMAP3 ISP is an internal subdev that is guaranteed to implement get_fmt. Don't check the return value for -ENOIOCTLCMD, as this can't happen. While at it, move non-critical code out of the mutex-protected section. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-12-04[media] af9035: fix broken I2C and USB I/OAntti Palosaari
There was three small buffer len calculation bugs which caused driver non-working. These are coming from recent commit: commit 7760e148350bf6df95662bc0db3734e9d991cb03 [media] af9035: Don't use dynamic static allocation Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: stable@vger.kernel.org
2013-11-29[media] wm8775: fix broken audio routingHans Verkuil
Commit 5aa9ae5ed5d449a85fbf7aac3d1fdc241c542a79 inverted the mute control state test in s_routing which caused the audio routing to fail. This broke ivtv support for the Hauppauge video/audio input bracket (which adds additional video and audio inputs) all the way back in kernel 2.6.36. This fix fixes the condition and it also removes a nonsense check on the balance control. Bisected-by: Rajil Saraswat <rajil.s@gmail.com> Signed-off-by: Andy Walls <awalls@md.metrocast.net> Reported-by: Rajil Saraswat <rajil.s@gmail.com> Tested-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: stable@vger.kernel.org # for v3.10 and up Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] marvell-ccic: drop resource free in driver removeLibin Yang
The mmp-driver is using devm_* to allocate the resource. The old resource release methods are not appropriate here. Signed-off-by: Libin Yang <lbyang@marvell.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: stable@vger.kernel.org # for v3.12 and up Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] tef6862/radio-tea5764: actually assign clamp resultHans Verkuil
When adding frequency clamping to the tef6862 and radio-tea5764 drivers I forgot to actually *assign* the clamp result to the frequency. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Reported-by: Hans Petter Selasky <hps@bitfrost.no> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: stable@vger.kernel.org # for 3.11 and up
2013-11-29[media] cx231xx: use after free on error path in probeDan Carpenter
We dereference "dev" after it has already been freed. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] saa7164: fix return value check in saa7164_initdev()Wei Yongjun
In case of error, the function kthread_run() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] bttv: don't setup the controls if there are no video devicesHans Verkuil
The no_video flag was checked in all other cases except one. Calling v4l2_ctrl_handler_setup() if no_video is 1 will crash. This wasn't noticed before since there are only two card types that set no_video to 1, so this type of hardware is quite rare. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Reported-by: Lorenz Röhrl <sheepshit@gmx.de> Tested-by: Lorenz Röhrl <sheepshit@gmx.de> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] af9035: add [0413:6a05] Leadtek WinFast DTV Dongle DualAntti Palosaari
It is IT9135 dual design. Thanks to Michael Piko for reporting that! Reported-by: Michael Piko <michael@piko.com.au> Signed-off-by: Antti Palosaari <crope@iki.fi> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] cxd2820r_c: fix if_ctl calculationEvgeny Plehov
fixes tuning for DVB-C Signed-off-by: Evgeny Plehov <EvgenyPlehov@ukr.net> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] technisat-usb2: fix typo in variable nameFelipe Pena
The variable txlen was used instead of rxlen in boundary check. (copy-paste error) Signed-off-by: Felipe Pena <felipensp@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] dvb_demux: clean up whitespace in comments from previous patch (trivial)Michael Krufky
removes trailing whitespace and rebalance line length in comment block Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] dvb_demux: fix deadlock in dmx_section_feed_release_filter()Alexey Khoroshilov
dmx_section_feed_release_filter() locks dvbdmx->mutex and if the feed is still filtering, it calls feed->stop_filtering(feed). stop_filtering() is implemented by dmx_section_feed_stop_filtering() that first of all try to lock the same mutex: dvbdmx->mutex. That leads to a deadlock. It does not happen often in practice because all callers of release_filter() stop filtering by themselves. So the problem can happen in case of race condition only. The patch releases dvbdmx->mutex before call to feed->stop_filtering(feed) and reacquires the mutex after that. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] gspca_sunplus: Add new usb-id for 06d6:0041Hans de Goede
Reported-by: mjs <mjstork@gmail.com> Tested-by: mjs <mjstork@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] gspca-stk1135: Add delay after configuring clockOndrej Zary
Add a small delay at the end of configure_clock() to allow sensor to initialize. This is needed by Asus VX2S laptop webcam to detect sensor type properly (the already-supported MT9M112). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] v4l: vsp1: Fix error return code in vsp1_video_init()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-20Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine changes from Vinod Koul: "This brings for slave dmaengine: - Change dma notification flag to DMA_COMPLETE from DMA_SUCCESS as dmaengine can only transfer and not verify validaty of dma transfers - Bunch of fixes across drivers: - cppi41 driver fixes from Daniel - 8 channel freescale dma engine support and updated bindings from Hongbo - msx-dma fixes and cleanup by Markus - DMAengine updates from Dan: - Bartlomiej and Dan finalized a rework of the dma address unmap implementation. - In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus [Walleij] for their review. - Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. - Some minor fixes / cleanups to mv_xor and ioatdma" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (99 commits) dma: mv_xor: Fix mis-usage of mmio 'base' and 'high_base' registers dma: mv_xor: Remove unneeded NULL address check ioat: fix ioat3_irq_reinit ioat: kill msix_single_vector support raid6test: add new corner case for ioatdma driver ioatdma: clean up sed pool kmem_cache ioatdma: fix selection of 16 vs 8 source path ioatdma: fix sed pool selection ioatdma: Fix bug in selftest after removal of DMA_MEMSET. dmatest: verbose mode dmatest: convert to dmaengine_unmap_data dmatest: add a 'wait' parameter dmatest: add basic performance metrics dmatest: add support for skipping verification and random data setup dmatest: use pseudo random numbers dmatest: support xor-only, or pq-only channels in tests dmatest: restore ability to start test at module load and init dmatest: cleanup redundant "dmatest: " prefixes dmatest: replace stored results mechanism, with uniform messages Revert "dmatest: append verify result to results" ...
2013-11-18Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c changes from Wolfram Sang: - new drivers for exynos5, bcm kona, and st micro - bigger overhauls for drivers mxs and rcar - typical driver bugfixes, cleanups, improvements - got rid of the superfluous 'driver' member in i2c_client struct This touches a few drivers in other subsystems. All acked. * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits) i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe() i2c: i2c-eg20t: do not print error message in syslog if no ACK received i2c: bcm-kona: Introduce Broadcom I2C Driver i2c: cbus-gpio: Fix device tree binding i2c: wmt: add missing clk_disable_unprepare() on error i2c: designware: add new ACPI IDs i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH i2c: exynos5: Remove incorrect clk_disable_unprepare i2c: i2c-st: Add ST I2C controller i2c: exynos5: add High Speed I2C controller driver i2c: rcar: fixup rcar type naming i2c: scmi: remove some bogus NULL checks i2c: sh_mobile & rcar: Enable the driver on all ARM platforms i2c: sh_mobile: Convert to clk_prepare/unprepare i2c: mux: gpio: use reg value for i2c_add_mux_adapter i2c: mux: gpio: use gpio_set_value_cansleep() i2c: Include linux/of.h header i2c: mxs: Fix PIO mode on i.MX23 i2c: mxs: Rework the PIO mode operation i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller ...
2013-11-18Merge branch 'topic/kbuild-fixes-for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media build fixes from Mauro Carvalho Chehab: "A series of patches that fix compilation on non-x86 archs. While most of them are just build fixes, there are some fixes for real bugs, as there are a number of drivers using dynamic stack allocation. A few of those might be considered a security risk, if the i2c-dev module is loaded, as someone could be sending very long I2C data that could potentially overflow the Kernel stack. Ok, as using /dev/i2c-* devnodes usually requires root on usual distros, and exploiting it would require a DVB board or USB stick, the risk is not high" * 'topic/kbuild-fixes-for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (28 commits) [media] platform drivers: Fix build on frv arch [media] lirc_zilog: Don't use dynamic static allocation [media] mxl111sf: Don't use dynamic static allocation [media] af9035: Don't use dynamic static allocation [media] af9015: Don't use dynamic static allocation [media] dw2102: Don't use dynamic static allocation [media] dibusb-common: Don't use dynamic static allocation [media] cxusb: Don't use dynamic static allocation [media] v4l2-async: Don't use dynamic static allocation [media] cimax2: Don't use dynamic static allocation [media] tuner-xc2028: Don't use dynamic static allocation [media] tuners: Don't use dynamic static allocation [media] av7110_hw: Don't use dynamic static allocation [media] stv090x: Don't use dynamic static allocation [media] stv0367: Don't use dynamic static allocation [media] stb0899_drv: Don't use dynamic static allocation [media] dvb-frontends: Don't use dynamic static allocation [media] dvb-frontends: Don't use dynamic static allocation [media] s5h1420: Don't use dynamic static allocation [media] uvc/lirc_serial: Fix some warnings on parisc arch ...
2013-11-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series include: - a new Remote Controller driver for ST SoC with the corresponding DT bindings - a new frontend (cx24117) - a new I2C camera flash driver (lm3560) - a new mem2mem driver for TI SoC (ti-vpe) - support for Raphael r828d added to r820t driver - some improvements on buffer allocation at VB2 core - usual driver fixes and improvements PS this time, we have a smaller number of patches. While it is hard to pinpoint to the reasons, I believe that it is mainly due to: 1) there are several patch series ready, but depending on DT review. I decided to grant some extra time for DT maintainers to look on it, as they're expecting to have more time with the changes agreed during ARM mini-summit and KS. If they can't review in time for 3.14, I'll review myself and apply for the next merge window. 2) I suspect that having both LinuxCon EU and LinuxCon NA happening during the same merge window affected the development productivity, as several core media developers participated on both events" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (151 commits) [media] media: st-rc: Add ST remote control driver [media] gpio-ir-recv: Include linux/of.h header [media] tvp7002: Include linux/of.h header [media] tvp514x: Include linux/of.h header [media] ths8200: Include linux/of.h header [media] adv7343: Include linux/of.h header [media] v4l: Fix typo in v4l2_subdev_get_try_crop() [media] media: i2c: add driver for dual LED Flash, lm3560 [media] rtl28xxu: add 15f4:0131 Astrometa DVB-T2 [media] rtl28xxu: add RTL2832P + R828D support [media] rtl2832: add new tuner R828D [media] r820t: add support for R828D [media] media/i2c: ths8200: fix build failure with gcc 4.5.4 [media] Add support for KWorld UB435-Q V2 [media] staging/media: fix msi3101 build errors [media] ddbridge: Remove casting the return value which is a void pointer [media] ngene: Remove casting the return value which is a void pointer [media] dm1105: remove unneeded not-null test [media] sh_mobile_ceu_camera: remove deprecated IRQF_DISABLED [media] media: rcar_vin: Add preliminary r8a7790 support ...
2013-11-16Merge commit 'dmaengine-3.13-v2' of ↵Vinod Koul
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine changes from Dan 1/ Bartlomiej and Dan finalized a rework of the dma address unmap implementation. 2/ In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus for their review. 3/ Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. 4/ Some minor fixes / cleanups to mv_xor and ioatdma. Conflicts: drivers/dma/dmatest.c Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14dmaengine: remove DMA unmap flagsBartlomiej Zolnierkiewicz
Remove no longer needed DMA unmap flags: - DMA_COMPL_SKIP_SRC_UNMAP - DMA_COMPL_SKIP_DEST_UNMAP - DMA_COMPL_SRC_UNMAP_SINGLE - DMA_COMPL_DEST_UNMAP_SINGLE Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jon Mason <jon.mason@intel.com> Acked-by: Mark Brown <broonie@linaro.org> [djbw: clean up straggling skip unmap flags in ntb] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-11-13Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: "Quite a lot of other stuff is banked up awaiting further next->mainline merging, but this batch contains: - Lots of random misc patches - OCFS2 - Most of MM - backlight updates - lib/ updates - printk updates - checkpatch updates - epoll tweaking - rtc updates - hfs - hfsplus - documentation - procfs - update gcov to gcc-4.7 format - IPC" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (269 commits) ipc, msg: fix message length check for negative values ipc/util.c: remove unnecessary work pending test devpts: plug the memory leak in kill_sb ./Makefile: export initial ramdisk compression config option init/Kconfig: add option to disable kernel compression drivers: w1: make w1_slave::flags long to avoid memory corruption drivers/w1/masters/ds1wm.cuse dev_get_platdata() drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page() drivers/memstick/core/mspro_block.c: fix attributes array allocation drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptr kernel/panic.c: reduce 1 byte usage for print tainted buffer gcov: reuse kbasename helper kernel/gcov/fs.c: use pr_warn() kernel/module.c: use pr_foo() gcov: compile specific gcov implementation based on gcc version gcov: add support for gcc 4.7 gcov format gcov: move gcov structs definitions to a gcc version specific file kernel/taskstats.c: return -ENOMEM when alloc memory fails in add_del_listener() kernel/taskstats.c: add nla_nest_cancel() for failure processing between nla_nest_start() and nla_nest_end() kernel/sysctl_binary.c: use scnprintf() instead of snprintf() ...
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-13drivers/media/platform/coda.c: use gen_pool_dma_alloc() to allocate iram bufferNicolin Chen
Since gen_pool_dma_alloc() is introduced, we implement it to simplify code. Signed-off-by: Nicolin Chen <b42378@freescale.com> Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-11Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.13. Qualcomm msm targets had a bunch of code removal for legacy non-DT platforms. Nomadik saw more device tree conversions and cleanup of old code. Tegra has some code refactoring, etc. One longish patch series from Sebastian Hasselbarth changes the init_time hooks and tries to use a generic implementation for most platforms, since they were all doing more or less the same things. Finally the "shark" platform is removed in this release. It's been abandoned for a while and nobody seems to care enough to keep it around. If someone comes along and wants to resurrect it, the removal can easily be reverted and code brought back. Beyond this, mostly a bunch of removals of stale content across the board, etc" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (79 commits) ARM: gemini: convert to GENERIC_CLOCKEVENTS ARM: EXYNOS: remove CONFIG_MACH_EXYNOS[4, 5]_DT config options ARM: OMAP3: control: add API for setting IVA bootmode ARM: OMAP3: CM/control: move CM scratchpad save to CM driver ARM: OMAP3: McBSP: do not access CM register directly ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock ARM: OMAP2: CM/PM: remove direct register accesses outside CM code MAINTAINERS: Add patterns for DTS files for AT91 ARM: at91: remove init_machine() as default is suitable ARM: at91/dt: split sama5d3 peripheral definitions ARM: at91/dt: split sam9x5 peripheral definitions ARM: Remove temporary sched_clock.h header ARM: clps711x: Use linux/sched_clock.h MAINTAINERS: Add DTS files to patterns for Samsung platform ARM: EXYNOS: remove unnecessary header inclusions from exynos4/5 dt machine file ARM: tegra: fix ARCH_TEGRA_114_SOC select sort order clk: nomadik: fix missing __init on nomadik_src_init ARM: drop explicit selection of HAVE_CLK and CLKDEV_LOOKUP ARM: S3C64XX: Kill CONFIG_PLAT_S3C64XX ASoC: samsung: Use CONFIG_ARCH_S3C64XX to check for S3C64XX support ...
2013-11-08[media] platform drivers: Fix build on frv archMauro Carvalho Chehab
On frv, the following errors happen: drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_setup': drivers/media/platform/soc_camera/rcar_vin.c:284:3: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration] drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_request_capture_stop': drivers/media/platform/soc_camera/rcar_vin.c:353:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration] This is because this driver forgot to include linux/io.h. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-08[media] mxl111sf: Don't use dynamic static allocationMauro Carvalho Chehab
Dynamic static allocation is evil, as Kernel stack is too low, and compilation complains about it on some archs: drivers/media/usb/dvb-usb-v2/mxl111sf.c:74:1: warning: 'mxl111sf_ctrl_msg' uses dynamic stack allocation [enabled by default] Instead, let's enforce a limit for the buffer to be the max size of a control URB payload data (64 bytes). Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-08[media] af9035: Don't use dynamic static allocationMauro Carvalho Chehab
Dynamic static allocation is evil, as Kernel stack is too low, and compilation complains about it on some archs: drivers/media/usb/dvb-usb-v2/af9035.c:142:1: warning: 'af9035_wr_regs' uses dynamic stack allocation [enabled by default] drivers/media/usb/dvb-usb-v2/af9035.c:305:1: warning: 'af9035_i2c_master_xfer' uses dynamic stack allocation [enabled by default] Instead, let's enforce a limit for the buffer to be the max size of a control URB payload data (64 bytes). Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-08[media] af9015: Don't use dynamic static allocationMauro Carvalho Chehab
Dynamic static allocation is evil, as Kernel stack is too low, and compilation complains about it on some archs: drivers/media/usb/dvb-usb-v2/af9015.c:433:1: warning: 'af9015_eeprom_hash' uses dynamic stack allocation [enabled by default] In this specific case, it is a gcc bug, as the size is a const, but it is easy to just change it from const to a #define, getting rid of the gcc warning. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-08[media] dw2102: Don't use dynamic static allocationMauro Carvalho Chehab
Dynamic static allocation is evil, as Kernel stack is too low, and compilation complains about it on some archs: drivers/media/usb/dvb-usb/dw2102.c:368:1: warning: 'dw2102_earda_i2c_transfer' uses dynamic stack allocation [enabled by default] drivers/media/usb/dvb-usb/dw2102.c:449:1: warning: 'dw2104_i2c_transfer' uses dynamic stack allocation [enabled by default] drivers/media/usb/dvb-usb/dw2102.c:512:1: warning: 'dw3101_i2c_transfer' uses dynamic stack allocation [enabled by default] drivers/media/usb/dvb-usb/dw2102.c:621:1: warning: 's6x0_i2c_transfer' uses dynamic stack allocation [enabled by default] Instead, let's enforce a limit for the buffer to be the max size of a control URB payload data (64 bytes). Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-08[media] dibusb-common: Don't use dynamic static allocationMauro Carvalho Chehab
Dynamic static allocation is evil, as Kernel stack is too low, and compilation complains about it on some archs: drivers/media/usb/dvb-usb/dibusb-common.c:124:1: warning: 'dibusb_i2c_msg' uses dynamic stack allocation [enabled by default] Instead, let's enforce a limit for the buffer to be the max size of a control URB payload data (64 bytes). Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
