path: root/drivers/media
2012-10-28media: au0828: fix case where STREAMOFF being called on stopped stream ↵Devin Heitmueller
causes BUG() commit a595c1ce4c9d572cf53513570b9f1a263d7867f2 upstream. We weren't checking whether the resource was in use before calling res_free(), so applications which called STREAMOFF on a v4l2 device that wasn't already streaming would cause a BUG() to be hit (MythTV). Reported-by: Larry Finger <larry.finger@lwfinger.net> Reported-by: Jay Harbeston <jharbestonus@gmail.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-13media: gspca_pac7302: add support for device 1ae7:2001 Speedlink Snappy ↵Frank Schäfer
Microphone SL-6825-SBK commit 97d2fbf501e3cf105ac957086c7e40e62e15cdf8 upstream. Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13media: rc: ite-cir: Initialise ite_dev::rdev earlierBen Hutchings
commit 4b961180ef275035b1538317ffd0e21e80e63e77 upstream. ite_dev::rdev is currently initialised in ite_probe() after rc_register_device() returns. If a newly registered device is opened quickly enough, we may enable interrupts and try to use ite_dev::rdev before it has been initialised. Move it up to the earliest point we can, right after calling rc_allocate_device(). Reported-and-tested-by: YunQiang Su <wzssyqa@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02media: Avoid sysfs oops when an rc_dev's raw device is absentDouglas Bagnall
commit 720bb6436ff30fccad05cf5bdf961ea5b1f5686d upstream. For some reason, when the lirc daemon learns that a usb remote control has been unplugged, it wants to read the sysfs attributes of the disappearing device. This is useful for uncovering transient inconsistencies, but less so for keeping the system running when such inconsistencies exist. Under some circumstances (like every time I unplug my dvb stick from my laptop), lirc catches an rc_dev whose raw event handler has been removed (presumably by ir_raw_event_unregister), and proceeds to interrogate the raw protocols supported by the NULL pointer. This patch avoids the NULL dereference, and ignores the issue of how this state of affairs came about in the first place. Version 2 incorporates changes recommended by Mauro Carvalho Chehab (-ENODEV instead of -EINVAL, and a signed-off-by). Signed-off-by: Douglas Bagnall <douglas@paradise.net.nz> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02media: cx25821: Remove bad strcpy to read-only char*Ezequiel Garcia
commit c854d8883fec59332f0662917f8c94dcfb1c405d upstream. The strcpy was being used to set the name of the board. This was both wrong and redundant, since the destination char* was read-only and the name is set statically at compile time. The type of the name field is changed to const char* to prevent future errors. Reported-by: Radek Masin <radek@masin.eu> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14USB: smsusb: remove __devinit* from the struct usb_device_id tableGreg Kroah-Hartman
commit d04dbd1c0ec17a13326c8f2279399c225836a79f upstream. This structure needs to always stick around, even if CONFIG_HOTPLUG is disabled, otherwise we can oops when trying to probe a device that was added after the structure is thrown away. Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Bjørn Mork <bjorn@mork.no> CC: Mauro Carvalho Chehab <mchehab@infradead.org> CC: Michael Krufky <mkrufky@linuxtv.org> CC: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Doron Cohen <doronc@siano-ms.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14USB: jl2005bcd: remove __devinit* from the struct usb_device_id tableGreg Kroah-Hartman
commit ec063351684298e295dc9444d143ddfd6ab02df8 upstream. This structure needs to always stick around, even if CONFIG_HOTPLUG is disabled, otherwise we can oops when trying to probe a device that was added after the structure is thrown away. Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Bjørn Mork <bjorn@mork.no> CC: Hans de Goede <hdegoede@redhat.com> CC: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14USB: spca506: remove __devinit* from the struct usb_device_id tableGreg Kroah-Hartman
commit e694d518886c7afedcdd1732477832b2e32744e4 upstream. This structure needs to always stick around, even if CONFIG_HOTPLUG is disabled, otherwise we can oops when trying to probe a device that was added after the structure is thrown away. Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Bjørn Mork <bjorn@mork.no> CC: Hans de Goede <hdegoede@redhat.com> CC: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14uvcvideo: Reset the bytesused field when recycling an erroneous bufferJayakrishnan Memana
commit 8a3f0ede2b3f5477122060af1a816c6bbf09fcd2 upstream. Buffers marked as erroneous are recycled immediately by the driver if the nodrop module parameter isn't set. The buffer payload size is reset to 0, but the buffer bytesused field isn't. This results in the buffer being immediately considered as complete, leading to an infinite loop in interrupt context. Fix the problem by resetting the bytesused field when recycling the buffer. Signed-off-by: Jayakrishnan Memana <jayakrishnan.memana@maxim-ic.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15media: ene_ir: Fix driver initialisationLuis Henriques
commit b31b021988fed9e3741a46918f14ba9b063811db upstream. commit 9ef449c6b31bb6a8e6dedc24de475a3b8c79be20 ("[media] rc: Postpone ISR registration") fixed an early ISR registration on several drivers. It did however also introduced a bug by moving the invocation of pnp_port_start() to the end of the probe function. This patch fixes this issue by moving the invocation of pnp_port_start() to an earlier stage in the probe function. Signed-off-by: Luis Henriques <luis.henriques@canonical.com> Cc: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19media: dvb-core: Release semaphore on error path dvb_register_device()Santosh Nayak
commit 82163edcdfa4eb3d74516cc8e9f38dd3d039b67d upstream. There is a missing "up_write()" here. Semaphore should be released before returning error value. Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19media: cx231xx: don't DMA to random addressesDavid Dillow
commit a7deca6fa79d5c65575532e780f3c93f6bf8ddad upstream. Commit 7a6f6c29d264cdd2fe0eb3d923217eed5f0ad134 (cx231xx: use URB_NO_TRANSFER_DMA_MAP) was intended to avoid mapping the DMA buffer for URB twice. This works for the URBs allocated with usb_alloc_urb(), as those are allocated from cohernent DMA pools, but the flag was also added for the VBI and audio URBs, which have a manually allocated area. This leaves the random trash in the structure after allocation as the DMA address, corrupting memory and preventing VBI and audio from working. Letting the USB core map the buffers solves the problem. Signed-off-by: David Dillow <dave@thedillows.org> Cc: Sri Deevi <srinivasa.deevi@conexant.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16gspca-core: Fix buffers staying in queued state after a stream_offHans de Goede
commit af05ef01e9cde84620c6855a8d8ab9c8a1db9009 upstream. [Backport to linux-stable by Antonio Ospite <ospite@studenti.unina.it>] This fixes a regression introduced by commit f7059ea and should be backported to all supported stable kernels which have this commit. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16media: smsusb: add autodetection support for USB ID 2040:f5a0Michael Krufky
commit 3e1141e2ce5667301a74ca2ef396d9bd5e995f7f upstream. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01media: uvcvideo: Fix ENUMINPUT handlingLaurent Pinchart
commit 31c5f0c5e25ed71eeced170f113bb590f2f1f6f3 upstream. Properly validate the user-supplied index against the number of inputs. The code used the pin local variable instead of the index by mistake. Reported-by: Jozef Vesely <vesely@gjh.sk> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01smsusb: add autodetection support for USB ID 2040:c0a0Michael Krufky
commit 4d1b58b84472d1d300a66e1c5fd765b21e74ba15 upstream. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "For a some fix patches for v3.4, including a regression fix at DVB core" Fix up trivial conflicts in Documentation/feature-removal-schedule.txt * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] gspca - sonixj: Fix a zero divide in isoc interrupt [media] media: videobuf2-dma-contig: include header for exported symbols [media] media: videobuf2-dma-contig: quiet sparse noise about plain integer as NULL pointer [media] media: vb2-memops: Export vb2_get_vma symbol [media] s5p-fimc: Correct memory allocation for VIDIOC_CREATE_BUFS [media] s5p-fimc: Fix locking in subdev set_crop op [media] dvb_frontend: fix a regression with DVB-S zig-zag [media] fintek-cir: change || to && [media] V4L: Schedule V4L2_CID_HCENTER, V4L2_CID_VCENTER controls for removal [media] rc: Postpone ISR registration [media] marvell-cam: fix an ARM build error [media] V4L: soc-camera: protect hosts during probing from overzealous user-space
2012-05-08[media] gspca - sonixj: Fix a zero divide in isoc interruptJean-François Moine
In case of short marker, the number of received packets was not incremented doing a zero divide when computing the filling rate. Reported-by: Hans Petter Selasky <hans.petter.selasky@bitfrost.no> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-08[media] media: videobuf2-dma-contig: include header for exported symbolsH Hartley Sweeten
Include the header to pickup the definitions of the exported symbols. Quiets the following sparse warnings: warning: symbol 'vb2_dma_contig_memops' was not declared. Should it be static? warning: symbol 'vb2_dma_contig_init_ctx' was not declared. Should it be static? warning: symbol 'vb2_dma_contig_cleanup_ctx' was not declared. Should it be static? Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Pawel Osciak <pawel@osciak.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-08[media] media: videobuf2-dma-contig: quiet sparse noise about plain integer ↵H Hartley Sweeten
as NULL pointer The function vb2_dma_contig_vaddr returns a void * not an integer. Quiets the sparse noise: warning: Using plain integer as NULL pointer Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Pawel Osciak <pawel@osciak.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-08[media] media: vb2-memops: Export vb2_get_vma symbolLaurent Pinchart
The vb2_get_vma() function is called by videobuf2-dma-contig. Export it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-08[media] s5p-fimc: Correct memory allocation for VIDIOC_CREATE_BUFSSylwester Nawrocki
The commit 3b4c34aac7abea4754059084d0eef667a1993ac8 "s5p-fimc: Add support for VIDIOC_PREPARE_BUF/CREATE_BUFS ioctls" added a handler for VIDIOC_CREATE_BUFS ioctl, but the queue_setup callback wasn't updated to properly interpret the pixel format. In this situation memory corruption may happen with VIDIOC_CREATE_BUFS ioctl. Update the queue_setup op to fix this. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-08[media] s5p-fimc: Fix locking in subdev set_crop opSylwester Nawrocki
When setting TRY crop on the sub-device the mutex was erroneously acquired rather than released on exit path. This bug is present in kernels starting from v3.2. Cc: stable@vger.kernel.org Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-08[media] dvb_frontend: fix a regression with DVB-S zig-zagMauro Carvalho Chehab
Changeset 5bfaadde broke zig-zag for DVB-S drivers that don't implement get_tune_settings() callback. Fix the code, in order to allow it to work as before, otherwise some channels may not be tuned anymore. Fix Fedora Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=814404 Cc: stable@kernel.org # for Kernel v3.3 Reported-by: Michael Heijenga <database.worker@googlemail.com> Tested-by: Michael Heijenga <database.worker@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-26[media] fintek-cir: change || to &&Dan Carpenter
The current condition is always true, so everything uses LOGICAL_DEV_CIR_REV2 (8). It should be that Fintek products 0x0408(F71809) and 0x0804(F71855) use logical device LOGICAL_DEV_CIR_REV1 (5) and other chip ids use logical device 8. In other words, this fixes hardware detection for 0x0408 and 0x0804. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jarod Wilson <jarod@redhat.com> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-26[media] rc: Postpone ISR registrationLuis Henriques
An early registration of an ISR was causing a crash to several users (for example, with the ite-cir driver: http://bugs.launchpad.net/bugs/972723). The reason was that IRQs were being triggered before a driver initialisation was completed. This patch fixes this by moving the invocation to request_irq() and to request_region() to a later stage on the driver probe function. Cc: <stable@vger.kernel.org> Signed-off-by: Luis Henriques <luis.henriques@canonical.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-26[media] marvell-cam: fix an ARM build errorJonathan Corbet
One of the OLPC changes lost a little in its translation to mainline, leading to build errors on the ARM architecture. Remove the offending line, and all will be well. Reported-by: Mathieu Poirier <mathieu.poirier@linaro.org> Cc: stable@vger.kernel.org Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-26[media] V4L: soc-camera: protect hosts during probing from overzealous ↵Guennadi Liakhovetski
user-space If multiple clients are registered on a single camera host interface, the user-space hot-plug software can try to access the one, that probed first, before probing of the second one has completed. This can be handled by individual host drivers, but it is even better to hold back the user-space until all the probing on this host has completed. This fixes a race on ecovec with two clients registered on the CEU1 host, which otherwise triggers a BUG() in sh_mobile_ceu_remove_device(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-21Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: - Fixes a regression at DVB core when switching from DVB-S2 to DVB-S on Kaffeine (Fedora 16 Bugzilla #812895); - Fixes a mutex unlock at an error condition at drx-k; - Fix winbond-cir set mode; - mt9m032: Fix a compilation breakage with some random Kconfig; - mt9m032: fix two dead locks; - xc5000: don't require an special firmware (that won't be provided by the vendor) just because the xtal frequency is different; - V4L DocBook: fix some typos at multi-plane formats description. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] xc5000: support 32MHz & 31.875MHz xtal using the 41.024.5 firmware [media] V4L: mt9m032: fix compilation breakage [media] V4L: DocBook: Fix typos in the multi-plane formats description [media] V4L: mt9m032: fix two dead-locks [media] rc-core: set mode for winbond-cir [media] drxk: Does not unlock mutex if sanity check failed in scu_command() [media] dvb_frontend: Fix a regression when switching back to DVB-S
2012-04-19[media] xc5000: support 32MHz & 31.875MHz xtal using the 41.024.5 firmwareMichael Krufky
Rather than loading firmware specific for the xtal frequency, just use the standard firmware and set the xtal frequency after firmware upload. The modified firmware will never be released, so we're better off merging this now rather than waiting for v3.5. Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19[media] V4L: mt9m032: fix compilation breakageGuennadi Liakhovetski
Fix the following compilation failure: linux-2.6/drivers/media/video/mt9m032.c: In function '__mt9m032_get_pad_crop': linux-2.6/drivers/media/video/mt9m032.c:337: error: implicit declaration of function 'v4l2_subdev_get_try_crop' linux-2.6/drivers/media/video/mt9m032.c:337: warning: return makes pointer from integer without a cast linux-2.6/drivers/media/video/mt9m032.c: In function '__mt9m032_get_pad_format': linux-2.6/drivers/media/video/mt9m032.c:359: error: implicit declaration of function 'v4l2_subdev_get_try_format' linux-2.6/drivers/media/video/mt9m032.c:359: warning: return makes pointer from integer without a cast linux-2.6/drivers/media/video/mt9m032.c: In function 'mt9m032_probe': linux-2.6/drivers/media/video/mt9m032.c:767: error: 'struct v4l2_subdev' has no member named 'entity' linux-2.6/drivers/media/video/mt9m032.c:826: error: 'struct v4l2_subdev' has no member named 'entity' linux-2.6/drivers/media/video/mt9m032.c: In function 'mt9m032_remove': linux-2.6/drivers/media/video/mt9m032.c:842: error: 'struct v4l2_subdev' has no member named 'entity' make[4]: *** [drivers/media/video/mt9m032.o] Error 1 by adding a dependency on VIDEO_V4L2_SUBDEV_API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19[media] V4L: mt9m032: fix two dead-locksGuennadi Liakhovetski
Fix a copy-paste typo and a nested locking function call in mt9m032. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-18[media] rc-core: set mode for winbond-cirDavid Härdeman
Setting the correct mode is required by rc-core or scancodes won't be generated (which isn't very user-friendly). This one-line fix should be suitable for 3.4-rc2. Signed-off-by: David Härdeman <david@hardeman.nu> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-18[media] drxk: Does not unlock mutex if sanity check failed in scu_command()Alexey Khoroshilov
If sanity check fails in scu_command(), goto error leads to unlock of an unheld mutex. The check should not fail in reality, but it nevertheless worth fixing. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-18[media] dvb_frontend: Fix a regression when switching back to DVB-SMauro Carvalho Chehab
There are some softwares (Kaffeine and likely xine) that uses a DVBv5 call to switch to DVB-S2, but expects that a DVBv3 call to switch back to DVB-S. Well, this is not right, as a DVBv3 call doesn't know anything about delivery systems. However, as, by accident, this used to work, we need to restore its behavior, in order to avoid regressions with those softwares. Reported on this Fedora 16 bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=812895 Reported-by: Dieter Roever <Dieter.Roever@gmx.de> Cc: stable@kernel.org # for version 3.3 Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-11Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: - dvb core: there is a regression found when used with xine. For whatever unknown reason, xine (and xine-lib clients) wants that the frontend to tell what frequency he is using even before the PLL lock (or at least, it expects a non-zero frequency). On DVB, the frequency is only actually known after a frequency zig-zag seek, done by the DVB core. Anyway, the fix was trivial. That solves Fedora BZ#808871. - ivtv: fix a regression when selecting the language channel - uvc: fix a race-related crash - it913x: fixes firmware loading - two trivial patches (a dependency issue at a radio driver at sound Kconfig, and a warning fix on dvb). * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] uvcvideo: Fix race-related crash in uvc_video_clock_update() [media] Drivers/media/radio: Fix build error [media] dvb_frontend: fix compiler warning [media] it913x: fix firmware loading errors [media] ivtv: Fix AUDIO_(BILINGUAL_)CHANNEL_SELECT regression [media] dvb_frontend: regression fix: userspace ABI broken for xine
2012-04-09[media] uvcvideo: Fix race-related crash in uvc_video_clock_update()Laurent Pinchart
The driver frees the clock samples buffer before stopping the video buffers queue. If a DQBUF call arrives in-between, uvc_video_clock_update() will be called with a NULL clock samples buffer, leading to a crash. This occurs very frequently when using the webcam with the flash browser plugin. Move clock initialization/cleanup to uvc_video_enable() in order to free the clock samples buffer after the queue is stopped. Make sure the clock is reset at resume time to avoid miscalculating timestamps. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-09[media] dvb_frontend: fix compiler warningHans Petter Selasky
has_get_frontend() should return a boolean, not a pointer. Signed-off-by: Hans Petter Selasky <hselasky@c2i.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-09[media] it913x: fix firmware loading errorsMalcolm Priestley
On some systems the device does not respond or give obscure values after cold, warm or firmware reboot. This patch retries to get chip version and type 5 times. If it fails it applies chip version 0x1 and type 0x9135. This patch does not fix warm cycle problems from other operating systems and indeed the reverse applies. Users should power off cold boot. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-09[media] ivtv: Fix AUDIO_(BILINGUAL_)CHANNEL_SELECT regressionHans Verkuil
When I converted ivtv to the new decoder API I introduced a regression in the support of the old channel select API. Thanks to Martin Dauskardt for reporting this. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-09[media] dvb_frontend: regression fix: userspace ABI broken for xineChris Rankin
The commit e399ce77e6e has broken the DVB ABI for xine: The problem is that xine is expecting every event after a successful FE_SET_FRONTEND ioctl to have a non-zero frequency parameter, regardless of whether the tuning process has LOCKed yet. What used to happen is that the events inherited the initial tuning parameters from the FE_SET_FRONTEND call. However, the fepriv->parameters_out struct is now not initialised until the status contains the FE_HAS_LOCK bit. You might argue that this behaviour is intentional, except that if an application other than xine uses the DVB adapter and manages to set the parameters_out.frequency field to something other than zero, then xine no longer has any problems until either the adapter is replugged or the kernel modules reloaded. This can only mean that the fepriv->parameters_out struct still contains the (stale) tuning information from the previous application. Signed-off-by: Chris Rankin <rankincj@yahoo.com> Cc: stable@kernel.org # for kernel version 3.3 Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-29Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This includes the cookie cleanup by Russell, the addition of context parameter for dmaengine APIs, more arm dmaengine driver cleanup by moving code to dmaengine, this time for imx by Javier and pl330 by Boojin along with the usual driver fixes." Fix up some fairly trivial conflicts with various other cleanups. * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (67 commits) dmaengine: imx: fix the build failure on x86_64 dmaengine: i.MX: Fix merge of cookie branch. dmaengine: i.MX: Add support for interleaved transfers. dmaengine: imx-dma: use 'dev_dbg' and 'dev_warn' for messages. dmaengine: imx-dma: remove 'imx_dmav1_baseaddr' and 'dma_clk'. dmaengine: imx-dma: remove unused arg of imxdma_sg_next. dmaengine: imx-dma: remove internal structure. dmaengine: imx-dma: remove 'resbytes' field of 'internal' structure. dmaengine: imx-dma: remove 'in_use' field of 'internal' structure. dmaengine: imx-dma: remove sg member from internal structure. dmaengine: imx-dma: remove 'imxdma_setup_sg_hw' function. dmaengine: imx-dma: remove 'imxdma_config_channel_hw' function. dmaengine: imx-dma: remove 'imxdma_setup_mem2mem_hw' function. dmaengine: imx-dma: remove dma_mode member of internal structure. dmaengine: imx-dma: remove data member from internal structure. dmaengine: imx-dma: merge old dma-v1.c with imx-dma.c dmaengine: at_hdmac: add slave config operation dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic dmaengine/dma_slave: introduce inline wrappers dma: imx-sdma: Treat firmware messages as warnings instead of erros ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - V4L2 API additions to better support JPEG compression control - media API additions to properly support MPEG decoders - V4L2 API additions for image crop/scaling - a few other V4L2 API DocBook fixes/improvements - two new DVB frontend drivers: m88rs2000 and rtl2830 - two new DVB drivers: az6007 and rtl28xxu - a framework for ISA drivers, that removed lots of common code found at the ISA radio drivers - a new FM transmitter driver (radio-keene) - a GPIO-based IR receiver driver - a new sensor driver: mt9m032 - some new video drivers: adv7183, blackfin, mx2_emmaprp, sii9234_drv, vs6624 - several new board additions, driver fixes, improvements and cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (295 commits) [media] update CARDLIST.em28xx [media] partially reverts changeset fa5527c [media] stb0899: fix the limits for signal strength values [media] em28xx: support for 2304:0242 PCTV QuatroStick (510e) [media] em28xx: support for 2013:0251 PCTV QuatroStick nano (520e) [media] -EINVAL -> -ENOTTY [media] gspca - sn9c20x: Cleanup source [media] gspca - sn9c20x: Simplify register write for capture start/stop [media] gspca - sn9c20x: Add automatic JPEG compression mechanism [media] gspca - sn9c20x: Greater delay in case of sensor no response [media] gspca - sn9c20x: Optimize the code of write sequences [media] gspca - sn9c20x: Add the JPEG compression quality control [media] gspca - sn9c20x: Add a delay after Omnivision sensor reset [media] gspca - sn9c20x: Propagate USB errors to higher level [media] gspca - sn9c20x: Use the new video control mechanism [media] gspca - sn9c20x: Fix loss of frame start [media] gspca - zc3xx: Lack of register 08 value for sensor cs2102k [media] gspca - ov534_9: Add brightness to OmniVision 5621 sensor [media] gspca - zc3xx: Add V4L2_CID_JPEG_COMPRESSION_QUALITY control support [media] pvrusb2: fix 7MHz & 8MHz DVB-T tuner support for HVR1900 rev D1F5 ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-21dmaengine/dma_slave: introduce inline wrappersAlexandre Bounine
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic() interfaces to hide new parameter from current users of affected interfaces. Convert current users to use new wrappers instead of direct calls. Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269]. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-20Merge tag 'driver-core-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches for 3.4-rc1 from Greg KH: "Here's the big driver core merge for 3.4-rc1. Lots of various things here, sysfs fixes/tweaks (with the nlink breakage reverted), dynamic debugging updates, w1 drivers, hyperv driver updates, and a variety of other bits and pieces, full information in the shortlog." * tag 'driver-core-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (78 commits) Tools: hv: Support enumeration from all the pools Tools: hv: Fully support the new KVP verbs in the user level daemon Drivers: hv: Support the newly introduced KVP messages in the driver Drivers: hv: Add new message types to enhance KVP regulator: Support driver probe deferral Revert "sysfs: Kill nlink counting." uevent: send events in correct order according to seqnum (v3) driver core: minor comment formatting cleanups driver core: move the deferred probe pointer into the private area drivercore: Add driver probe deferral mechanism DS2781 Maxim Stand-Alone Fuel Gauge battery and w1 slave drivers w1_bq27000: Only one thread can access the bq27000 at a time. w1_bq27000 - remove w1_bq27000_write w1_bq27000: remove unnecessary NULL test. sysfs: Fix memory leak in sysfs_sd_setsecdata(). intel_idle: Revert change of auto_demotion_disable_flags for Nehalem w1: Fix w1_bq27000 driver-core: documentation: fix up Greg's email address powernow-k6: Really enable auto-loading powernow-k7: Fix CPU family number ...
