path: root/drivers/memory
2013-09-06Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This branch contains mostly additions and changes to platform enablement and SoC-level drivers. Since there's sometimes a dependency on device-tree changes, there's also a fair amount of those in this branch. Pieces worth mentioning are: - Mbus driver for Marvell platforms, allowing kernel configuration and resource allocation of on-chip peripherals. - Enablement of the mbus infrastructure from Marvell PCI-e drivers. - Preparation of MSI support for Marvell platforms. - Addition of new PCI-e host controller driver for Tegra platforms - Some churn caused by sharing of macro names between i.MX 6Q and 6DL platforms in the device tree sources and header files. - Various suspend/PM updates for Tegra, including LP1 support. - Versatile Express support for MCPM, part of big little support. - Allwinner platform support for A20 and A31 SoCs (dual and quad Cortex-A7) - OMAP2+ support for DRA7, a new Cortex-A15-based SoC. The code that touches other architectures are patches moving MSI arch-specific functions over to weak symbols and removal of ARCH_SUPPORTS_MSI, acked by PCI maintainers" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits) tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list ARM: dts: vf610-twr: enable i2c0 device ARM: dts: i.MX51: Add one more I2C2 pinmux entry ARM: dts: i.MX51: Move pins configuration under "iomuxc" label ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX ARM: dts: i.MX27: Disable AUDMUX in the template ARM: dts: wandboard: Add support for SDIO bcm4329 ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template ARM: dts: imx53-qsb: Make USBH1 functional ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module ARM: dts: imx6qdl-sabresd: Add touchscreen support ARM: imx: add ocram clock for imx53 ARM: dts: imx: ocram size is different between imx6q and imx6dl ARM: dts: imx27-phytec-phycore-som: Fix regulator settings ARM: dts: i.MX27: Remove clock name from CPU node ...
2013-08-15tegra: simplify use of devm_ioremap_resourceJulia Lawall
Remove unneeded error handling on the result of a call to platform_get_resource when the value is passed to devm_ioremap_resource. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression pdev,res,n,e,e1; expression ret != 0; identifier l; @@ - res = platform_get_resource(pdev, IORESOURCE_MEM, n); ... when != res - if (res == NULL) { ... \(goto l;\|return ret;\) } ... when != res + res = platform_get_resource(pdev, IORESOURCE_MEM, n); e = devm_ioremap_resource(e1, res); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-08-12memory: mvebu-devbus: Remove unused variableEzequiel Garcia
This variable is not being used anywhere and it's only forgotten garbage that should have been removed in the previous commit: commit 9b6e4c0a58e24c28bd757c9365824a37e80b751c Author: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Date: Fri Jul 26 10:17:38 2013 -0300 memory: mvebu-devbus: Remove address decoding window workaround Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06memory: mvebu-devbus: Remove address decoding window workaroundEzequiel Garcia
Now that mbus device tree binding has been introduced, remove the address decoding window management from this driver. A suitable 'ranges' entry should be added to the devbus-compatible node in the device tree, as described by the mbus binding documentation. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-06-17memory: tegra30-mc: Fix IRQ handler.Tuomas Tynkkynen
In Tegra30 any memory controller interrupt would cause an infinite loop in the IRQ handler. Additionally, a garbage pointer was used to read the MC status registers, which causes wrong values to be printed if a MC error occurred. Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17memory: tegra20-mc: Fix hang in IRQ handler.Tuomas Tynkkynen
In Tegra20 any memory controller interrupt would cause an infinite loop in the IRQ handler. Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-27Merge 3.10-rc3 into char-misc-nextGreg Kroah-Hartman
We want the changes in here. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-21drivers: memory: Introduce Marvell EBU Device Bus driverEzequiel Garcia
Marvell EBU SoCs such as Armada 370/XP, Orion5x (88f5xxx) and Discovery (mv78xx0) supports a Device Bus controller to access several kinds of memories and I/O devices (NOR, NAND, SRAM, FPGA). This commit adds a driver to handle this controller. So far only Armada 370, Armada XP and Discovery SoCs are supported. The driver must be registered through a device tree node; as explained in the binding document. For each child node in the device tree, this driver will: * set timing parameters * register a child device * setup an address decoding window, using the mbus driver Keep in mind the address decoding window setup is only a temporary hack. This code will be removed from this devbus driver as soon as a proper device tree binding for the mbus driver is added. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-18drivers/memory: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-03-25memory: emif: Load the correct custom config values from dtLokesh Vutla
of_get_property returns value in Big Endian format. Before using this value it should be converted to little endian using be32_to_cpup(). Custom configs of emif are read from dt using of_get_property, but these are not converted to litte endian format. Correcting the same here. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: errata i743: Prohibit usage of Power-Down modeGrygorii Strashko
ERRATA DESCRIPTION : The EMIF supports power-down state for low power. The EMIF automatically puts the SDRAM into power-down after the memory is not accessed for a defined number of cycles and the EMIF_PWR_MGMT_CTRL[10:8] REG_LP_MODE bit field is set to 0x4. As the EMIF supports automatic output impedance calibration, a ZQ calibration long command is issued every time it exits active power-down and precharge power-down modes. The EMIF waits and blocks any other command during this calibration. The EMIF does not allow selective disabling of ZQ calibration upon exit of power-down mode. Due to very short periods of power-down cycles, ZQ calibration overhead creates bandwidth issues and increases overall system power consumption. On the other hand, issuing ZQ calibration long commands when exiting self-refresh is still required. WORKAROUND : Because there is no power consumption benefit of the power-down due to the calibration and there is a performance risk, the guideline is to not allow power-down state and, therefore, to not have set the EMIF_PWR_MGMT_CTRL[10:8] REG_LP_MODE bit field to 0x4. This is applicable only for EMIF4D IP used in OMAP4 Soc's. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Vitaly Chernooky <vitaly.chernooky@ti.com> Signed-off-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: Fix the incorrect 'size' parameter in memcpyOleksandr Dmytryshyn
The issue was that only the first timings table was added to the emif platform data at the emif driver registration. All other timings tables was filled with zeros. Now all emif timings table are added to the platform data. Signed-off-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: use restart if power_off not present when out of specNishanth Menon
Some machine or kernel variants might have missed implementation of power off handlers. We DONOT want to let the system be in "out of spec" state in this condition. So, WARN and attempt a machine restart in the hopes of clearing the out-of-spec temperature condition. NOTE: This is not the safest option, but safer than leaving the system in unstable conditions. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: Handle devices which are not rated for >85CNishanth Menon
As per JESD209-2E specification for LPDDR2, http://www.jedec.org/standards-documents/results/jesd209-2E Table 73, LPDDR2 memories come in two flavors - Standard and Extended. The Standard types can operate from -25C to +85C However, beyond that and upto +105C can only be supported by Extended types. Unfortunately, it seems there is no info in MR0(device info) or MR[1,2](device feature) for run time detection of this capability as far as seen on the spec. Hence, we provide a custom_config flag to be populated by platforms which have these "extended" type memories. For the "Standard" memories, we need to consider MR4 notifications of temperature triggers >85C as equivalent to thermal shutdown events (equivalent to Spec specified thermal shutdown events for "extended" parts). Reported-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: handle overflow for timing for LP modeNishanth Menon
In case the custom timings provide values which overflow the maximum possible field value, warn and use maximum permissible value. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: setup LP settings on freq updateAmbresh K
Program the power management shadow register on freq update Else the concept of threshold frequencies dont really matter as the system always uses the performance mode timing for LP which is programmed in at init time. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ambresh K <ambresh@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25memory: emif: Fix the lpmode timeout calculationLokesh Vutla
The driver tries to round up the specified timeout cycles to the next power of 2 value. This should be done defore updating timeout variable. Correcting this here. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15drivers: memory: use module_platform_driver_probe()Fabio Porcedda
This patch converts the drivers to use the module_platform_driver_probe() macro which makes the code smaller and a bit simpler. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Aneesh V <aneesh@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15memory: tegra30: Fix build error w/o PMHiroshi Doyu
Make this depend on CONFIG_PM. Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-22memory: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: memory: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, and __devinitconst, from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-26memory: tegra{20,30}-mc: Fix reading incorrect register in mc_readl()Axel Lin
The code reading the register does not match the code writing to the register, fix it. Also fix the coding style in mc_writel() for better readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-26memory: emif: Add ifdef CONFIG_DEBUG_FS guard for emif_debugfs_[init|exit]Axel Lin
Add ifdef CONFIG_DEBUG_FS guard for emif_debugfs_[init|exit], and adds stub functions for the case CONFIG_DEBUG_FS is not set. When CONFIG_DEBUG_FS is enabled, debugfs_create_dir and debugfs_create_file return NULL on failure, fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by : Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05memory: fix build when CONFIG_OF && !CONFIG_DDRStephen Warren
Commit e6b42eb "memory: emif: add device tree support to emif driver" added drivers/memory/of_memory.c, which references tables defined in lib/jedec_ddr_data.c. of_memory.c is compiled when CONFIG_OF, whereas jedec_ddr_data.c is compiled when CONFIG_DDR. This breaks the build when CONFIG_OF is defined but not CONFIG_DDR: drivers/built-in.o: In function `of_get_ddr_timings': drivers/memory/of_memory.c:138: undefined reference to `lpddr2_jedec_timings' drivers/built-in.o: In function `of_get_min_tck': drivers/memory/of_memory.c:62: undefined reference to `lpddr2_jedec_min_tck' make: *** [vmlinux] Error 1 To solve this, only compile of_memory.c when CONFIG_OF && CONFIG_DDR, otherwise, stub out the functions. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04memory: emif: add device tree support to emif driverAneesh V
Device tree support for the EMIF driver. LPDDR2 generic timings extraction from device is managed using couple of helper functions which can be used by other memory controller drivers. Reviewed-by: Benoit Cousson <b-cousson@ti.com> Reviewed-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14memory: tegra{20,30}-mc: Remove empty *_remove()Hiroshi DOYU
Remove unnecessary empty functions. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14memory: tegra{20,30}-mc: Use dev_err_ratelimited()Hiroshi DOYU
Introduce a new dev_*_ratelimited() instead of pr_*_ratelimited() for better info to print. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-11ARM: tegra30: Make MC optional in KconfigHiroshi DOYU
For bare minimal system. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-11ARM: tegra20: Make MC optional in KconfigHiroshi DOYU
2012-05-11ARM: tegra30: MC: Remove unnecessary BUG*()Hiroshi DOYU
Accessing interleaved MC register offsets/ranges are verified. BUG*()s in accessors can be removed. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-11ARM: tegra20: MC: Remove unnecessary BUG*()Hiroshi DOYU
2012-05-10ARM: tegra30: Add Tegra Memory Controller(MC) driverHiroshi DOYU
Tegra Memory Controller(MC) driver for Tegra30 Added to support MC General interrupts, mainly for IOMMU(SMMU). Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-10ARM: tegra20: Add Tegra Memory Controller(MC) driverHiroshi DOYU
Tegra Memory Controller(MC) driver for Tegra20 Added to support MC General interrupts, mainly for IOMMU(GART). Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-04memory: emif: Add Kconfig dependency for TI EMIF controllerSantosh Shilimkar
Make TI_EMIF depends on ARCH_OMAP2PLUS to avoid build breaks on other architectures. In future if other TI non OMAP socs start using it, the dependency can be extended. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-02memory: emif: add debugfs entries for emifAneesh V
Add debug entries for: 1. calculated registers per frequency 2. last polled value of MR4(temperature level of LPDDR2 memory) Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-02memory: emif: add one-time settingsAneesh V
Add settings that are not dependent on frequency or any other transient parameters. This includes - power managment control init - impedence calibration control - frequency independent phy configuration registers - initialization of temperature polling Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-02memory: emif: add interrupt and temperature handlingAneesh V
Add an ISR for EMIF that: 1. reports details of access errors 2. takes action on thermal events Also clear all interrupts on shut-down. Pending IRQs may casue problems during warm-reset. Temperature handling: EMIF can be configured to poll the temperature level of an LPDDR2 device from the MR4 mode register in the device. EMIF generates an interrupt whenever it identifies a temperature level change between two consecutive pollings. Some of the timing parameters need to be de-rated at high temperatures. The interrupt handler takes care of doing this and also takes care of going back to nominal settings when temperature falls back to nominal levels. Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-02memory: emif: handle frequency and voltage change eventsAneesh V
Change SDRAM timings and other settings as necessary on voltage and frequency changes. We calculate these register settings based on data from the device data sheet and inputs such a frequency, voltage state(stable or ramping), temperature level etc. TODO: frequency and voltage change handling needs to be integrated with clock framework and regulator framework respectively. This is not done today due to missing pieces in the kernel. Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-02memory: emif: add basic infrastructure for EMIF driverAneesh V
EMIF is an SDRAM controller used in various Texas Instruments SoCs. EMIF supports, based on its revision, one or more of LPDDR2/DDR2/DDR3 protocols. Add the basic infrastructure for EMIF driver that includes driver registration, probe, parsing of platform data etc. Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-02memory: emif: add register definitions for EMIFAneesh V
Add register offsets and bit field definitions for EMIF module in TI SoCs Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
