path: root/drivers/memstick/core
2008-04-19memstick: convert struct class_device to struct deviceGreg Kroah-Hartman
struct class_device is going away, struct device should be used instead. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-19memstick: add support for 8-bit parallel modeAlex Dubov
Newer MemoryStick (HG) cards and hosts support 8-bit parallel mode of operation in addition to original 4-bit and 1-bit modes. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19memstick: automatically retrieve "INT" value from command responseAlex Dubov
MemoryStick storage cards, when in parallel mode, send several meaningful bits of their "INT" register as part of command response. This data is stored by host and can be used to spare invocation of "GET_INT" TPC on each data page transferred between host and card. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: try harder to recover from unsuccessful interface mode switchAlex Dubov
2008-03-10memstick: fix parsing of "assembly_date" attribute fieldAlex Dubov
2008-03-10memstick: add support for decoding "specfile" media attributesAlex Dubov
2008-03-10memstick: drop DRIVER_VERSION numbers as meaninglessAlex Dubov
2008-03-10memstick: make sure number of command retries is exactly as specifiedAlex Dubov
2008-03-10memstick: add memstick_suspend/resume_host methodsAlex Dubov
Bus driver may need to be informed that host is being suspended/resumed. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: introduce correct definitions in the headerAlex Dubov
Thanks to some input from kind people at JMicron it is now possible to have more correct definitions of protocol structures and bit field semantics. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09memstick: initial commit for Sony MemoryStick supportAlex Dubov
Sony MemoryStick cards are used in many products manufactured by Sony. They are available both as storage and as IO expansion cards. Currently, only MemoryStick Pro storage cards are supported via TI FlashMedia MemoryStick interface. [mboton@gmail.com: biuld fix] [akpm@linux-foundation.org: build fix] Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Miguel Boton <mboton@gmail.co> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
