path: root/drivers/message
2011-07-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (71 commits) [SCSI] fcoe: cleanup cpu selection for incoming requests [SCSI] fcoe: add fip retry to avoid missing critical keep alive [SCSI] libfc: fix warn on in lport retry [SCSI] libfc: Remove the reference to FCP packet from scsi_cmnd in case of error [SCSI] libfc: cleanup sending SRR request [SCSI] libfc: two minor changes in comments [SCSI] libfc, fcoe: ignore rx frame with wrong xid info [SCSI] libfc: release exchg cache [SCSI] libfc: use FC_MAX_ERROR_CNT [SCSI] fcoe: remove unused ptype field in fcoe_rcv_info [SCSI] bnx2fc: Update copyright and bump version to 1.0.4 [SCSI] bnx2fc: Tx BDs cache in write tasks [SCSI] bnx2fc: Do not arm CQ when there are no CQEs [SCSI] bnx2fc: hold tgt lock when calling cmd_release [SCSI] bnx2fc: Enable support for sequence level error recovery [SCSI] bnx2fc: HSI changes for tape [SCSI] bnx2fc: Handle REC_TOV error code from firmware [SCSI] bnx2fc: REC/SRR link service request and response handling [SCSI] bnx2fc: Support 'sequence cleanup' task [SCSI] dh_rdac: Associate HBA and storage in rdac_controller to support partitions in storage ...
2011-07-27[SCSI] mptfusion : Added check for SILI bit in READ_6 CDB for DATA UNDERRUN ↵Kashyap, Desai
ERRATA When READ_6 command is issued, the setting of SILI Bit in CDB is confirmed and if SILI bit is off, the processing of relavent Errata is executed. Earlier we did not have check for SILI bit in READ_6 CDB. As described in "ssc-r22", Now Driver is checking SILI bit for READ_6. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (110 commits) [SCSI] qla2xxx: Refactor call to qla2xxx_read_sfp for thermal temperature. [SCSI] qla2xxx: Unify the read/write sfp mailbox command routines. [SCSI] qla2xxx: Clear complete initialization control block. [SCSI] qla2xxx: Allow an override of the registered maximum LUN. [SCSI] qla2xxx: Add host number in reset and quiescent message logs. [SCSI] qla2xxx: Correctly read sfp single byte mailbox register. [SCSI] qla2xxx: Add qla82xx_rom_unlock() function. [SCSI] qla2xxx: Log if qla82xx firmware fails to load from flash. [SCSI] qla2xxx: Use passed in host to initialize local scsi_qla_host in queuecommand function [SCSI] qla2xxx: Correct buffer start in edc sysfs debug print. [SCSI] qla2xxx: Update firmware version after flash update for ISP82xx. [SCSI] qla2xxx: Fix hang during driver unload when vport is active. [SCSI] qla2xxx: Properly set the dsd_list_len for dsd_chaining in cmd type 6. [SCSI] qla2xxx: Fix virtual port failing to login after chip reset. [SCSI] qla2xxx: Fix vport delete hang when logins are outstanding. [SCSI] hpsa: Change memset using sizeof(ptr) to sizeof(*ptr) [SCSI] ipr: Rate limit DMA mapping errors [SCSI] hpsa: add P2000 to list of shared SAS devices [SCSI] hpsa: do not attempt PCI power management reset method if we know it won't work. [SCSI] hpsa: remove superfluous sleeps around reset code ...
2011-05-17[SCSI] mptsas: Fix annoying warningBorislav Petkov
Shut up drivers/message/fusion/mptsas.c: In function 'mptsas_event_process': drivers/message/fusion/mptsas.c:5015: warning: unused variable 'log_info' for configs with CONFIG_SCSI_MPT2SAS_LOGGING unset. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <jbottomley@parallels.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-01[SCSI] mptfusion: Bump version 3.4.19Kashyap, Desai
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-05-01[SCSI] mptfusion: Adding inline data padding support for TAPE drive.Kashyap, Desai
Adding support for inline data padding for TAPE drive when running U320. [jejb: whitespace fixes] Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-05-01[SCSI] mptfusion: Remove debug print from mptscsih_qcmd()Kashyap, Desai
Remove debug print from mptscsih_qcmd function call. This debug print cause flood of prints and difficult to debug other issues. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-05-01[SCSI] fusion: do not check serial_number in the abort handlerChristoph Hellwig
The SCSI midlayer stops all command processing when in error handling, which means there is no chance for command reuse when the abort handler is called. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-05-01[SCSI] remove cmd->serial_number litterChristoph Hellwig
Stop using cmd->serial_number in printks. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-21block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe driversTejun Heo
In-kernel disk event polling doesn't matter for legacy/fringe drivers and may lead to infinite event loop if ->check_events() implementation generates events on level condition instead of edge. Now that block layer supports suppressing exporting unlisted events, simply leaving disk->events cleared allows these drivers to keep the internal revalidation behavior intact while avoiding weird interactions with userland event handler. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-17message: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-09i2o_block: Convert to bdops->check_events()Tejun Heo
Convert from ->media_changed() to ->check_events(). i2o_block buffers media changed state and clears it after reporting. It will behave correctly with kernel event polling. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
2011-02-21Merge branch 'master' into for-2.6.39Tejun Heo
2011-02-12[SCSI] mptfusion: Remove bus reset for mptsas moduleKashyap, Desai
Bus reset is not required for SAS Controller. It is valid for mptspi and mptfc, but for mptsas it is not required. It is an extra work for Error handling escallation for mptsas. Removing bus reset from error handling will eventually speedup Error handling for SAS controller. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] mptfusion: Support SAS2.0 Devices with SAS1.0 ControllersKashyap, Desai
SAS1.0 Controller was not able to detect SAS2.0 Expanders due to Link RATE detection was limited to 1.5 Gbps and 3.0 Gbps for SAS1 controllers. Added detection for 6.0 Gbps link. Now, user can mix-up 6.0 Gpbs links with SAS1.0 controller. e.g SAS1.0 HBA <----> SAS2.0 Expander <------> SAS2.0 Expander <--------> SAS1.0 Drive. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] mptfusion: Bump version 03.04.18Kashyap, Desai
2011-02-12[SCSI] mptfusion: Fix Incorrect return value in mptscsih_dev_resetKashyap, Desai
There's a branch at the end of this function that is supposed to normalize the return value with what the mid-layer expects. In this one case, we get it wrong. Also increase the verbosity of the INFO level printk at the end of mptscsih_abort to include the actual return value and the scmd->serial_number. The reason being success or failure is actually determined by the state of the internal tag list when a TMF is issued, and not the return value of the TMF cmd. The serial_number is also used in this decision, thus it's useful to know for debugging purposes. Cc: stable@kernel.org Reported-by: Peter M. Petrakis <peter.petrakis@canonical.com> Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] mptfusion: mptctl_release is required in mptctl.cKashyap, Desai
Added missing release callback for file_operations mptctl_fops. Without release callback there will be never freed. It remains on mptctl's eent list even after the file is closed and released. Relavent RHEL bugzilla is 660871 Cc: stable@kernel.org Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-01i2o: use alloc_workqueue() instead of create_workqueue()Tejun Heo
This is an identity conversion. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
2011-01-24[SCSI] mptfusion: Fix memory leak in mptctl_getiocinfo()Jesper Juhl
A 'kfree(karg)' is missing in a failure path in mptctl.c::mptctl_getiocinfo() which can cause a memory leak. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-19drivers/message/, i2o: Remove unnecessary casts of void ptr returning alloc ↵Jesper Juhl
function return values The [vk][cmz]alloc(_node) family of functions return void pointers which it's completely unnecessary/pointless to cast to other pointer types since that happens implicitly. This patch removes such casts from drivers/message/ Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (84 commits) [SCSI] be2iscsi: SGE Len == 64K [SCSI] be2iscsi: Remove premature free of cid [SCSI] be2iscsi: More time for FW [SCSI] libsas: fix bug for vacant phy [SCSI] sd: Fix overflow with big physical blocks [SCSI] st: add MTWEOFI to write filemarks without flushing drive buffer [SCSI] libsas: Don't issue commands to devices that have been hot-removed [SCSI] megaraid_sas: Add Online Controller Reset to MegaRAID SAS drive [SCSI] lpfc 8.3.17: Update lpfc driver version to 8.3.17 [SCSI] lpfc 8.3.17: Replace function reset methodology [SCSI] lpfc 8.3.17: SCSI fixes [SCSI] lpfc 8.3.17: BSG fixes [SCSI] lpfc 8.3.17: SLI Additions and Fixes [SCSI] lpfc 8.3.17: Code Cleanup and Locking fixes [SCSI] zfcp: Remove scsi_cmnd->serial_number from debug traces [SCSI] ipr: fix array error logging [SCSI] aha152x: enable PCMCIA on 64bit [SCSI] scsi_dh_alua: Handle all states correctly [SCSI] cxgb4i: connection and ddp setting update [SCSI] cxgb3i: fixed connection over vlan ...
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-09-15scsi: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: linux-scsi@vger.kernel.org Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
2010-09-05[SCSI] drivers/message/fusion: Return -ENOMEM on memory allocation failureJulia Lawall
In this code, 0 is returned on memory allocation failure, even though other failures return -ENOMEM or other similar values. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression ret; expression x,e1,e2,e3; @@ ret = 0 ... when != ret = e1 *x = \(kmalloc\|kcalloc\|kzalloc\)(...) ... when != ret = e2 if (x == NULL) { ... when != ret = e3 return ret; } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-14fusion: add function parameter names to kernel-docRandy Dunlap
Fix fusion missing kernel-doc: Warning(drivers/message/fusion/mptbase.c:649): No description found for parameter 'func_name' Warning(drivers/message/fusion/mptbase.c:8010): No description found for parameter 'cb_idx' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14fusion: fix non-kernel-doc comment blockRandy Dunlap
Fix comment begin notation not to look like kernel-doc since it's not. Removes kernel-doc warnings. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (28 commits) [SCSI] qla4xxx: fix compilation warning [SCSI] make error handling more robust in the face of reservations [SCSI] tgt: fix warning [SCSI] drivers/message/fusion: Adjust confusing if indentation [SCSI] Return NEEDS_RETRY for eh commands with status BUSY [SCSI] ibmvfc: Driver version 1.0.9 [SCSI] ibmvfc: Fix terminate_rport_io [SCSI] ibmvfc: Fix rport add/delete race resulting in oops [SCSI] lpfc 8.3.16: Change LPFC driver version to 8.3.16 [SCSI] lpfc 8.3.16: FCoE Discovery and Failover Fixes [SCSI] lpfc 8.3.16: SLI Additions, updates, and code cleanup [SCSI] pm8001: introduce missing kfree [SCSI] qla4xxx: Update driver version to 5.02.00-k3 [SCSI] qla4xxx: Added AER support for ISP82xx [SCSI] qla4xxx: Handle outstanding mbx cmds on hung f/w scenarios [SCSI] qla4xxx: updated mbx_sys_info struct to sync with FW 4.6.x [SCSI] qla4xxx: clear AF_DPC_SCHEDULED flage when exit from do_dpc [SCSI] qla4xxx: Stop firmware before doing init firmware. [SCSI] qla4xxx: Use the correct request queue. [SCSI] qla4xxx: set correct value in sess->recovery_tmo ...
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-11fusion: fix kernel-doc warningsRandy Dunlap
Fix (delete) empty kernel-doc lines/warnings: Warning(drivers/message/fusion/mptbase.c:6916): bad line: Warning(drivers/message/fusion/mptbase.c:7060): bad line: Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11i2o: check return code from put_user()Kulikov Vasiliy
Check return value of put_user() and return -EFAULT if it failed. Original comment "We did a get user...so assuming mem is ok...is this bad?" is incorrect because memory can be read only. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11i2o: fix overflow of copy_to_user()Kulikov Vasiliy
If (len > reslen) we must not call copy_to_user() since kernel buffer is smaller than we want to copy. Similar code in this file is correct, so this bug was a typo. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11drivers/message/i2o/exec-osm.c: add missing mutex_unlockJulia Lawall
Add a mutex_unlock missing on the error path. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * mutex_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * mutex_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11mpt fusion: convert to seq_fileAlexey Dobriyan
Convert everything except ->proc_info() stuff, it is done within separate ->proc_info path series. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11drivers/message: move dereference after NULL testJulia Lawall
If the NULL test on dev->i2o_dev or i2o_dev is needed, then the dereference should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: James Bottomley <James.Bottomley@suse.de> Cc: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
