Adding core driver for the Powermanagement system device
RICOH 583.
bug 822562
Change-Id: I8a21b42800bd9043f901689ed354618165c42534
Reviewed-on: http://git-master/r/40035
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add mfd core driver for Maxim PMU MAX77663.
Bug 849360
Bug 854414
Change-Id: I6699540fd7d0f7b428a1be64cf06f7cd65b5b32e
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/41503
Adding core and regulator driver for the TI pmu device tps80031.
Following functionality is added:
- Basic core driver interface to access register.
- Regulator driver.
- gpio driver.
- interrupt support from pmu.
- clock 32 initialization.
bug 830904
bug 829658
Change-Id: I41e732c0b5d0472209798552b5264038e5a97ee4
Reviewed-on: http://git-master/r/33109
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Adding backlight, regulator and mfd driver for AnalogicTech AAT2870.
Bug 813111
Change-Id: I0621a25545708d260285545b184f4689a32fa16b
Reviewed-on: http://git-master/r/32366
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Adding regulator and mfd core driver for TI TPS6591x PMIC family.
Original-Change-Id: I65c0e4758094f211f7e9f0944423bd935c1893c4
Reviewed-on: http://git-master/r/16529
Tested-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: I2f82c178e3db0998e7c1a5a3b6b8e49832deaf59
Clean up portions of max8907c.c driver
Add capability for bulk i2c read and write
Add capability for second i2c bus for rtc
Add capability for irq handling for rtc and battery charger
Change-Id: I6c2c2c42591aee766635a2e32a7404bb2591f4a7
Reviewed-on: http://git-master/r/16613
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Add max8907c regulator and mfd driver.
Add max8952 regulator driver.
Change-Id: If63b724647d887a8088da0f2deb8af91e4fe3cfa
Reviewed-on: http://git-master/r/9902
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (22 commits)
regulator: Remove default DEBUG define from TPS6586x
regulator: tps6507x - add missing platform_set_drvdata in tps6507x_pmic_probe
regulator: tps6586x - add regulator_unregister() in tps6586x_regulator_remove()
mfd: max8998 - fix incorrect kfree(i2c) in i2c_driver probe callback handler
regulator: lp3971 - remove unnecessary ret value checking in lp3971_i2c_write()
regulator: max8660 - fix a memory leak in max8660_remove()
regulator: max1586 - fix a memory leak in max1586_pmic_remove()
regulator: Default GPIO controlled WM8994 regulators to disabled
max8998: fix off-by-one value range checking
regulator: tps6586x: fix millivolt return values and SM2 table
regulator: tps6586x: add dependancy on MFD_TPS6585x
regulator: add TPS6586X regulator driver
regulator: MAX8998: set_voltage bugfix. ramp_up delay and min/max voltage
regulator: add support for regulators on the ab8500 MFD
ab8500-mfd: add regulator support to ab8500 mfd device
tps65023: Allow registering similar TPS65021
drivers: regulators: depend on MFD_MAX8998
drivers: regulator: add Maxim 8998 driver
ISL6271A voltage regulator support.
Add mfd core driver for TPS6586x PMICs family.
The driver provides I/O access for the sub-device drivers and performs
regstration of the sub-devices based on the platform requirements.
In addition it implements GPIOlib interface for the chip GPIOs.
TODO:
- add interrupt support
- add platform data for PWM, backlight leds and charger
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com>
TWL6030 supports PWM (Pulse Width Modulator) which is used
to control charging LED. PWM allows for controlling brightness.
This patch implements the APIs required by leds-pwm driver.
Signed-off-by: Hemanth V <hemanthv@ti.com>
This patch adds a MFD driver for the JZ4740 ADC unit. The driver is used to
demultiplex IRQs and synchronize access to shared registers between the
battery, hwmon and (future) touchscreen driver.
Add support for the STMPE family of I/O Expanders from
STMicroelectronics. These devices include upto 24 gpios and a varying
selection of blocks, including PWM, keypad, and touchscreen controllers.
This patch adds the MFD core.
[l.fu@pengutronix.de: fix stmpe811 enable hook]
[l.fu@pengutronix.de: add touchscreen platform data]
Acked-by: Luotao Fu <l.fu@pengutronix.de>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch adds voltage regulator driver for Maxim 8998 chip. This chip
is used on Samsung Aquila and GONI boards and provides following
functionalities:
- 4 BUCK voltage converters, 17 LDO power regulators and 5 other power
controllers
- battery charger
This patch adds basic driver for voltage regulators and MAX 8998 MFD core.
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add a new driver to support the AB8500 Power Management chip, replacing
the current AB4500. The new driver replaces the old one, instead of an
incremental modification, because this is a substantial overhaul
including:
- Split of the driver into -core and -spi portions, to allow another
interface layer to be added
- Addition of interrupt support
- Switch to MFD core API for handling subdevices
- Simplification of the APIs to remove a redundant block parameter
- Rename of the APIs and macros from ab4500_* to ab8500_*
- Rename of the files from ab4500* to ab8500*
- Change of the driver name from ab4500 to ab8500
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
This reduces code clutter a bit and will ease an migration to genirq.
Use threaded oneshot irq handler instead of normal irq handler and a workqueue.
This adds a core driver for the AB3550 mixed-signal circuit
found in the ST-Ericsson U300 platforms. This driver
is a singleton proxy for all access to the AB3550 sub
functionality drivers which can be added on top of this one:
RTC, regulators, battery and system power control, vibrator,
LEDs and an ALSA codec.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The interface for the AB3100 is changed to make way for the
ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson
Analog Baseband chips. The register access functions are moved
out to a separate struct abx500_ops. In this way the interface
is moved from the implementation and the sub functionality drivers
can keep their interface intact when chip infrastructure and
communication mechanisms changes. We also define the AB3550
device IDs and the AB3550 platform data struct and convert
the catenated 32bit event to an array of 3 x 8bits.
The TC35892 I/O Expander provides 24 GPIOs, a keypad controller, timers,
and a rotator wheel interface. This patch adds the MFD core.
TPS6507x are multi function (PM, touchscreen) chipsets from TI.
This commit also changes the corresponding regulator driver from being
standalone to an MFD subdevice.
Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com>
The Janz CMOD-IO PCI MODULbus carrier board is a PCI to MODULbus bridge,
which may host many different types of MODULbus daughterboards, including
CAN and GPIO controllers.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Reviewed-by: Wolfgang Grandegger <wg@grandegger.com>
This patch adds a new MFD driver for the RDC321x southbridge. This southbridge
is always present in the RDC321x System-on-a-Chip and provides access to some
GPIOs as well as a watchdog. Access to these two functions is done using the
southbridge PCI device configuration space.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The WM8994 has an interrupt controller which supports interrupts for
both CODEC and GPIO portions of the chip. Support this using genirq,
while allowing for systems that do not have an interrupt hooked up.
Wrapper functions are provided for the IRQ request and free to simplify
the code in consumer drivers when handling cases where IRQs are not
set up.
This is the MFD driver for the DaVinci Voice codec, it has two clients:
* Voice codec interface
* Voice codec CQ93VC
Signed-off-by: Miguel Aguilar <miguel.aguilar@ridgerun.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Intel Poulsbo (SCH) chipset LPC bridge controller contains several
functions. Creating and MFD driver for the LPC bridge controller allows
simultaneous use of SMBus and GPIO interfaces on the SCH.
Signed-off-by: Denis Turischev <denis@compulab.co.il>
The WM8994 is a highly integrated ultra low power audio hub CODEC.
Since it includes on-board regulators and GPIOs it is represented
as a multi-function device, though the overwhelming majority of
the functionality is provided by the ASoC CODEC driver.
This change introduces a driver for the HTC PLD chip found
on some smartphones, such as the HTC Wizard and HTC Herald.
It works through the I2C bus and acts as a GPIO extender.
Specifically:
* it can have several sub-devices, each with its own I2C
address
* Each sub-device provides 8 output and 8 input pins
* The chip attaches to one GPIO to signal when any of the
input GPIOs change -- at which point all chips must be
scanned for changes
This driver implements the GPIOs throught the kernel's
GPIO and IRQ framework. This allows any GPIO-servicing
drivers to operate on htcpld pins, such as the gpio-keys
and gpio-leds drivers.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
Basic Max8925 support, which is a power management IC from Maxim
Semiconductor.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Rename 88PM8607 to 88PM860X in both Makefile and Kconfig under mfd directory.
Create 88pm8607-i2c driver to support all I2C operation of 88PM8607.
The timberdale FPGA is found on the Intel in-Vehicle Infotainment reference board
russelville.
The driver is a PCI driver which chunks up the I/O memory and distributes interrupts
to a number of platform devices for each IP inside the FPGA.
Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com>
asic3 also needs tmio_core or otherwise will fail to build.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
This patch abstracts out the CNF area code from tmio_mmc which
is not present in all hardware that can use this driver. This
is required so that we can support non-toshiba based hardware.
ASIC3 support by Philipp Zabel
Signed-off-by: Ian Molton <ian@mnementh.co.uk>
Signed-off-by: Magnus Damm <damm@opensource.se>
This patch adds support for phoenix interrupt framework. New iInterrupt
status register A, B, C are introduced in Phoenix and are cleared on write.
Due to the differences in interrupt handling with respect to TWL4030,
twl6030-irq.c is created for TWL6030 PMIC
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Balaji T K <balajitk@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reviewed-by: Tony Lindgren <tony@atomide.com>
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030
for OMAP3. The common modules like RTC, Regulator creates opportunity
to re-use the most of the code from twl4030.
This patch renames few common drivers twl4030* files to twl* to enable
the code re-use.
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
In preparation for refactoring - it's over 700 lines of well-isolated
code and having it in a file by itself makes things more managable.
While we're at it make sure that we clean up the IRQ if we fail after
acquiring it on init.
Base driver for Analog Devices ADP5520/ADP5501 MFD PMICs
Subdevs:
LCD Backlight : drivers/video/backlight/adp5520_bl.c
LEDs : drivers/led/leds-adp5520.c
GPIO : drivers/gpio/adp5520-gpio.c (ADP5520 only)
Keys : drivers/input/keyboard/adp5520-keys.c (ADP5520 only)
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
This adds core driver support for AB4500 mixed signal
multimedia & power management chip. This connects to U8500
on the SSP (pl022) and exports read/write functions for
the device to get access to this chip. This also registers
the client devices and sets the parent.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Reviewed-by: Mark Brown <broonie@sirena.org.uk>
Reviewed-by: Jean-Christophe <plagnioj@jcrosoft.com>
This adds a core driver for 88PM8607 found in Marvell DKB development
platform. This driver is a proxy for all accesses to 88PM8607
sub-drivers which will be merged on top of this one, RTC, regulators,
battery and so on.
This chip is manufactured by Marvell.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (137 commits)
sh: include empty zero page in romImage
sh: Make associative cache writes fatal on all SH-4A parts.
sh: Drop associative writes for SH-4 cache flushes.
sh: Partial revert of copy/clear_user_highpage() optimizations.
sh: Add default uImage rule for se7724, ap325rxa, and migor.
sh: allow runtime pm without suspend/resume callbacks
sh: mach-ecovec24: Remove un-defined settings for VPU
sh: mach-ecovec24: LCDC drive ability become high
sh: fix sh7724 VEU3F resource size
serial: sh-sci: Fix too early port disabling.
sh: pfc: pr_info() -> pr_debug() cleanups.
sh: pfc: Convert from ctrl_xxx() to __raw_xxx() I/O routines.
sh: Improve kfr2r09 serial port setup code
sh: Break out SuperH PFC code
sh: Move KEYSC header file
sh: convert /proc/cpu/aligmnent, /proc/cpu/kernel_alignment to seq_file
sh: Add CPG save/restore code for sh7724 R-standby
sh: Add SDHI power control support to Ecovec
mfd: Add power control platform data to SDHI driver
sh: mach-ecovec24: modify address map
This patch adds an MFD driver for the SuperH Mobile SDHI
hardware block. At this point the driver simply wraps the
tmio-mmc driver with some clock code. In the future this
driver is the place to put SDHI specific hotplug code.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
New MFD child to twl4030 MFD device.
Reason for the twl4030_codec MFD: the vibra control is actually in the codec
part of the twl4030. If both the vibra and the audio functionality is needed
from the twl4030 at the same time, than they need to control the codec power
and APLL at the same time without breaking the other driver.
Also these two has to be able to work without the need for the other driver.
This MFD device will be used by the drivers, which needs resources
from the twl4030 codec like audio and vibra.
The platform specific configuration data is passed along to the
child drivers (audio, vibra).
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
The TWL4030/5030 family of multifunction devices allows board-specific
control of the the various regulators, clock and reset lines through
'scripts' that are loaded into its memory. This allows for Dynamic Power
Switching (DPS).
Implement board-independent core support for DPS that is then used by
board-specific code to load custom DPS scripts.
Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com>
This adds the ability to read out OTP (One-Time Programmable)
registers in the AB3100 MFD ASIC. It's a simple sysfs file you
can cat to prompt. The OTP registers of the AB3100 are used to
store various device-unique information such as customer ID,
product flags and the 3GPP standard IMEI (International Mobile
Equipment Indentity) number.
This driver provides the core Freescale MC13783 support. It
registers the client platform_devices and provides access
to the A/D converter.
The PCAP Asic as present on EZX phones is a multi function device with
voltage regulators, ADC, touch screen controller, RTC, USB transceiver,
leds controller, and audio codec.
It has two SPI ports, typically one is connected to the application
processor and another to the baseband, this driver provides read/write
functions to its registers, irq demultiplexer and ADC
queueing/abstraction.
This chip is used on a lot of Motorola phones, it was manufactured by TI
as a custom product with the name PTWL93017, later this design evolved
into the ATLAS PMIC from Freescale (MC13783).
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com>
This adds a core driver for the AB3100 mixed-signal circuit
found in the ST-Ericsson U300 series platforms. This driver
is a singleton proxy for all accesses to the AB3100
LEDs, and an ALSA codec.
Reviewed-by: Mike Rapoport <mike@compulab.co.il>
Reviewed-by: Ben Dooks <ben-linux@fluff.org>
What the PCF05633 calls as a 'GPIO' is much more than the GPIO in the linux
sense and there are only 4 of them - which means, the gpiolib is not used
here.
Signed-off-by: Balaji Rao <balajirrao@openmoko.org>
Cc: Andy Green <andy@openmoko.com>
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
This patch adds basic support for the PCF50633 ADC. The subtractive mode
is not supported yet.
Since we don't have adc subsystem, it currently lives in drivers/mfd.
Acked-by: Jonathan Cameron <jonathan.cameron@gmail.com>
