i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Corrects the following checkpatch gripes:
WARNING: quoted string split across lines
#95: FILE: drivers/mfd/ab3100-core.c:95:
+ "write error (write register) "
+ "%d bytes transferred (expected 2)\n",
#139: FILE: drivers/mfd/ab3100-core.c:139:
+ "write error (write test register) "
#175: FILE: drivers/mfd/ab3100-core.c:175:
+ "write error (send register address) "
+ "%d bytes transferred (expected 1)\n",
#193: FILE: drivers/mfd/ab3100-core.c:193:
+ "write error (read register) "
#241: FILE: drivers/mfd/ab3100-core.c:241:
+ "write error (send first register address) "
#256: FILE: drivers/mfd/ab3100-core.c:256:
+ "write error (read register page) "
+ "%d bytes transferred (expected %d)\n",
#299: FILE: drivers/mfd/ab3100-core.c:299:
+ "write error (maskset send address) "
#314: FILE: drivers/mfd/ab3100-core.c:314:
+ "write error (maskset read register) "
#334: FILE: drivers/mfd/ab3100-core.c:334:
WARNING: please, no spaces at the start of a line
#374: FILE: drivers/mfd/ab3100-core.c:374:
+ return blocking_notifier_chain_unregister(&ab3100->event_subscribers,$
WARNING: Prefer seq_puts to seq_printf
#458: FILE: drivers/mfd/ab3100-core.c:458:
+ seq_printf(s, "AB3100 registers:\n");
#564: FILE: drivers/mfd/ab3100-core.c:564:
+ "debug write reg[0x%02x] with 0x%02x, "
+ "after readback: 0x%02x\n",
#723: FILE: drivers/mfd/ab3100-core.c:723:
+ "AB3100 P1E variant detected, "
+ "forcing chip to 32KHz\n");
#882: FILE: drivers/mfd/ab3100-core.c:882:
+ "could not communicate with the AB3100 analog "
+ "baseband chip\n");
#906: FILE: drivers/mfd/ab3100-core.c:906:
+ dev_err(&client->dev, "accepting it anyway. Please update "
+ "the driver.\n");
total: 0 errors, 15 warnings, 999 lines checked
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The usage of strict_strtoul() is not preferred, because
strict_strtoul() is obsolete. Thus, kstrtoul() should be
used.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
This implements device tree support for the AB3100 regulators
driver. The initial settings are moved out of platform data
and into the driver for the device tree case, as it appears
that there is no way to supply this as AUXDATA for an I2C
device. The style and bindings are heavily inspired by
Lee Jones' style for AB8500.
Acked-by: Lee Jones <lee.jones@linaro.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinitconst is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
The U8500 has its own set of separate header, so the abx500
becomes completely abstract. Do the same split for the AB3100
legacy ASIC.
Signed-off-by: Marcus Cooper <marcus.xm.cooper@stericsson.com>
Currently the MFD core supports remapping MFD cell interrupts using an
irqdomain but only if the MFD is being instantiated using device tree
and only if the device tree bindings use the pattern of registering IPs
in the device tree with compatible properties. This will be actively
harmful for drivers which support non-DT platforms and use this pattern
for their DT bindings as it will mean that the core will silently change
remapping behaviour and it is also limiting for drivers which don't do
DT with this particular pattern. There is also a potential fragility if
there are interrupts not associated with MFD cells and all the cells are
omitted from the device tree for some reason.
Instead change the code to take an IRQ domain as an optional argument,
allowing drivers to take the decision about the parent domain for their
interrupts. The one current user of this feature is ab8500-core, it has
the domain lookup pushed out into the driver.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random subsystem patches from Ted Ts'o:
"This patch series contains a major revamp of how we collect entropy
from interrupts for /dev/random and /dev/urandom.
The goal is to addresses weaknesses discussed in the paper "Mining
your Ps and Qs: Detection of Widespread Weak Keys in Network Devices",
by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman,
which will be published in the Proceedings of the 21st Usenix Security
Symposium, August 2012. (See https://factorable.net for more
information and an extended version of the paper.)"
Fix up trivial conflicts due to nearby changes in
drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c}
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits)
random: mix in architectural randomness in extract_buf()
dmi: Feed DMI table to /dev/random driver
random: Add comment to random_initialize()
random: final removal of IRQF_SAMPLE_RANDOM
um: remove IRQF_SAMPLE_RANDOM which is now a no-op
sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op
[ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op
board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op
isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op
pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op
omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op
goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out
uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op
drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op
xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op
n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op
pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op
i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op
input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op
mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>.
Cc: stable@vger.kernel.org
Allocate memory and irq for device state using devm_*
helpers to simplify memory accounting.
Many users of debugfs copy the implementation of default_open() when
they want to support a custom read/write function op. This leads to a
proliferation of the default_open() implementation across the entire
tree.
Now that the common implementation has been consolidated into libfs we
can replace all the users of this function with simple_open().
This replacement was done with the following semantic patch:
<smpl>
@ open @
identifier open_f != simple_open;
identifier i, f;
-int open_f(struct inode *i, struct file *f)
-if (i->i_private)
-f->private_data = i->i_private;
-return 0;
@ has_open depends on open @
identifier fops;
identifier open.open_f;
struct file_operations fops = {
-.open = open_f,
+.open = simple_open,
</smpl>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
With the pending module.h cleanup, these files will fail to compile,
unless they explicitly call out the include of this file.
[omap-usb-host addition courtesy of Anand Gadiyar <gadiyar@ti.com>]
With the addition of a platform device mfd_cell pointer, MFD drivers
can go back to passing platform data back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers
MFD agnostic. This is mostly needed for non MFD aware sub drivers.
Rename the platform_data variable to imply a distinction between
common platform_data driver usage (typically accessed via
pdev->dev.platform_data) and the way MFD passes data down to
clients (using a wrapper named mfd_get_data).
All clients have already been changed to use the wrapper function,
so this can be a quick single-commit change that only touches things
in drivers/mfd.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
The cell's platform_data is now accessed with a helper function;
change clients to use that, and remove the now-unused data_size.
Don't allow everybody to change device hardware registers.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
This switches the AB3100 core driver to using MFD cells for
subdevices instead of spawning common platform devices.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Since there is no discardable probe() function in the I2C device
framework, let's just tag it __devinit and take the footprint hit
rather than seeing the compilation warnings every day.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
The interface for the AB3100 is changed to make way for the
ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson
Analog Baseband chips. The register access functions are moved
out to a separate struct abx500_ops. In this way the interface
is moved from the implementation and the sub functionality drivers
can keep their interface intact when chip infrastructure and
communication mechanisms changes. We also define the AB3550
device IDs and the AB3550 platform data struct and convert
the catenated 32bit event to an array of 3 x 8bits.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
The goal here is to make way for a more general interface for the
analog baseband chips ab3100 ab3550 ab550 and future chips.
This patch have been divided into two parts since both changing name
and content of a file is not recommended in git.
Fix I2C-drivers which missed setting clientdata to NULL before freeing the
structure it points to. Also fix drivers which do this _after_ the structure
was freed already.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This reintroduces the entropy sampling of the AB3100 IRQ as the
IRQF_SAMPLE_RANDOM is going out according to the feature removal
schedule. I'm trying to do this the right way then, so CC:ing some
random people for a quick review. We add entropy for interrupt
events in the AB3100 which are truly random in nature, like
external cables being connected, voltages on batteries dropping
below certain ranges, ADC triggers or overheating.
Cc: Robin Getz <rgetz@blackfin.uclinux.org>
Acked-by: Matt Mackall <mpm@selenic.com>
This converts the AB3100 core MFD driver to use a threaded
interrupt handler instead of the explicit top/bottom-half
construction with a workqueue. This saves some code and make it
more similar to other modern MFD drivers.
The name field of struct i2c_client is for i2c-core's use, it should
never be changed by the drivers themselves.
The I2C_CLIENT_INSMOD_1 macro is only useful for i2c drivers which
implement device detection. The ab3100 driver doesn't, so there is no
point in calling it.
Cc: Samuel Ortiz <sameo@linux.intel.com>
drivers/mfd/ab3100-core.c:647: error: ab3100_init_settings causes a section type conflict
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: <stable@kernel.org>
This adds support for the regulators found in the AB3100
Mixed-Signal IC.
It further also defines platform data for the ST-Ericsson
U300 platform and extends the AB3100 MFD driver so that
platform/board data with regulation constraints and an init
function can be passed down all the way from the board to
the regulators.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
ab3100.h should include linux/workqueue.h for otp to build properly.
This will make the worker fire interrupt disable the AB3100 IRQ
without sync which resolves a race since the interrupt obviously
cannot wait for itself to complete while being handled.
This alters the default setting for AB3100_IMRB1 from 0xff to
0xbf. These registers are used for the yet unimplemented ADC
and this new setting will deactivate ADC Trigger 1.
This makes ab3100_set_register_interruptible() propagate the error
code from suboperations properly so it can be handles properly.
(A special case comes from signal interruption.)
This adds the _interruptible suffix to the AB3100 accessor
functions on par with mutex_lock_interruptible() that's used
for blocking simultaneous calls to the AB3100 acessor functions.
Since these accesses are slow on a 100kHz I2C bus and may line
up waiting for the mutex, we need to handle interruption by
system shutdown or kill signals and may just as well denote that
in the function names.
The file_operations write prototype should return a ssize_t.
This adds a core driver for the AB3100 mixed-signal circuit
found in the ST-Ericsson U300 series platforms. This driver
is a singleton proxy for all accesses to the AB3100
sub-drivers which will be merged on top of this one, RTC,
regulators, battery and system power control, vibrator,
LEDs, and an ALSA codec.
Reviewed-by: Mike Rapoport <mike@compulab.co.il>
Reviewed-by: Ben Dooks <ben-linux@fluff.org>
