path: root/drivers/mfd/ab3100-core.c
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-28mfd: AB3100 register access change to abx500 APIMattias Wallin
The interface for the AB3100 is changed to make way for the ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson Analog Baseband chips. The register access functions are moved out to a separate struct abx500_ops. In this way the interface is moved from the implementation and the sub functionality drivers can keep their interface intact when chip infrastructure and communication mechanisms changes. We also define the AB3550 device IDs and the AB3550 platform data struct and convert the catenated 32bit event to an array of 3 x 8bits. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Renamed ab3100.h to abx500.hLinus Walleij
The goal here is to make way for a more general interface for the analog baseband chips ab3100 ab3550 ab550 and future chips. This patch have been divided into two parts since both changing name and content of a file is not recommended in git. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Fix dangling pointersWolfram Sang
Fix I2C-drivers which missed setting clientdata to NULL before freeing the structure it points to. Also fix drivers which do this _after_ the structure was freed already. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07mfd: Use AB3100 MFD core IRQ for interrupt randomnessLinus Walleij
This reintroduces the entropy sampling of the AB3100 IRQ as the IRQF_SAMPLE_RANDOM is going out according to the feature removal schedule. I'm trying to do this the right way then, so CC:ing some random people for a quick review. We add entropy for interrupt events in the AB3100 which are truly random in nature, like external cables being connected, voltages on batteries dropping below certain ranges, ADC triggers or overheating. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Robin Getz <rgetz@blackfin.uclinux.org> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Convert AB3100 driver to threaded IRQLinus Walleij
This converts the AB3100 core MFD driver to use a threaded interrupt handler instead of the explicit top/bottom-half construction with a workqueue. This saves some code and make it more similar to other modern MFD drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Don't abuse i2c_client.nameJean Delvare
The name field of struct i2c_client is for i2c-core's use, it should never be changed by the drivers themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-10-04mfd: AB3100 drop unused module parametersJean Delvare
The I2C_CLIENT_INSMOD_1 macro is only useful for i2c drivers which implement device detection. The ab3100 driver doesn't, so there is no point in calling it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Samuel Ortiz <sameo@linux.intel.com>
2009-09-22drivers/mfd/ab3100-core.c: fix powerpc build errorAndrew Morton
drivers/mfd/ab3100-core.c:647: error: ab3100_init_settings causes a section type conflict Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-17regulator: AB3100 supportLinus Walleij
This adds support for the regulators found in the AB3100 Mixed-Signal IC. It further also defines platform data for the ST-Ericsson U300 platform and extends the AB3100 MFD driver so that platform/board data with regulation constraints and an init function can be passed down all the way from the board to the regulators. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Fix ab3100-otp build failureSamuel Ortiz
ab3100.h should include linux/workqueue.h for otp to build properly. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: AB3100 disable irq nosyncLinus Walleij
This will make the worker fire interrupt disable the AB3100 IRQ without sync which resolves a race since the interrupt obviously cannot wait for itself to complete while being handled. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: AB3100 alter default settingLinus Walleij
This alters the default setting for AB3100_IMRB1 from 0xff to 0xbf. These registers are used for the yet unimplemented ADC and this new setting will deactivate ADC Trigger 1. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: AB3100 propagate errorLinus Walleij
This makes ab3100_set_register_interruptible() propagate the error code from suboperations properly so it can be handles properly. (A special case comes from signal interruption.) Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: AB3100 accessor function cleanupsLinus Walleij
This adds the _interruptible suffix to the AB3100 accessor functions on par with mutex_lock_interruptible() that's used for blocking simultaneous calls to the AB3100 acessor functions. Since these accesses are slow on a 100kHz I2C bus and may line up waiting for the mutex, we need to handle interruption by system shutdown or kill signals and may just as well denote that in the function names. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: fix ab3100 warning on x86_64Samuel Ortiz
The file_operations write prototype should return a ssize_t. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: add U300 AB3100 core supportLinus Walleij
This adds a core driver for the AB3100 mixed-signal circuit found in the ST-Ericsson U300 series platforms. This driver is a singleton proxy for all accesses to the AB3100 sub-drivers which will be merged on top of this one, RTC, regulators, battery and system power control, vibrator, LEDs, and an ALSA codec. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Mike Rapoport <mike@compulab.co.il> Reviewed-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
