path: root/drivers/mfd/ab3100-otp.c
2010-08-12mfd: Fix memory leak in ab3100_otp_probeAxel Lin
In current implementation, there is a memory leak if ab3100_otp_read fail. And in the case of ab3100_otp_init_debugfs fail, it does not properly remove sysfs entries. This patch properly handle above failure cases. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: AB3100 register access change to abx500 APIMattias Wallin
The interface for the AB3100 is changed to make way for the ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson Analog Baseband chips. The register access functions are moved out to a separate struct abx500_ops. In this way the interface is moved from the implementation and the sub functionality drivers can keep their interface intact when chip infrastructure and communication mechanisms changes. We also define the AB3550 device IDs and the AB3550 platform data struct and convert the catenated 32bit event to an array of 3 x 8bits. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Renamed ab3100.h to abx500.hLinus Walleij
The goal here is to make way for a more general interface for the analog baseband chips ab3100 ab3550 ab550 and future chips. This patch have been divided into two parts since both changing name and content of a file is not recommended in git. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07mfd: Fix debugfs code in AB3100 OTP driverLinus Walleij
This fixes the aged and unreachable debugfs code in the AB3100 OTP driver so that it's (A) reachable and (B) works. Bug detected in parallell by Christoph Egger using VAMOS and Robert P. J. Day by his kernel scanning script. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Cc: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: AB3100 OTP readoutLinus Walleij
This adds the ability to read out OTP (One-Time Programmable) registers in the AB3100 MFD ASIC. It's a simple sysfs file you can cat to prompt. The OTP registers of the AB3100 are used to store various device-unique information such as customer ID, product flags and the 3GPP standard IMEI (International Mobile Equipment Indentity) number. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
