path: root/drivers/mfd/ab8500-debugfs.c
2011-07-31mfd: Use kstrtoul_from_user in ab8500Peter Huewe
This patch replaces the code for getting an unsigned long from a userspace buffer by a simple call to kstroul_from_user. This makes it easier to read and less error prone. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: ab8500: world-writable debugfs register-* filesVasiliy Kulikov
Don't allow everybody to interact with hardware registers. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-14mfd: Use NULL to initialise NULL pointers in ab8500-debugfsMark Brown
Partly for coding style reasons, but mostly because sparse warns on it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-14mfd: Fix ab8500-debug indentation errorsMattias Wallin
Replace spaces with proper tabs. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: AB8500 debugfsMattias Wallin
This patch adds the possibility to read and write registers via the debug_fs. It also adds ranges of registers sorted by bank which makes it possible to read all defined registers in a bank. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
