path: root/drivers/mfd/adp5520.c
2013-04-08mfd: adp5520: Restore mode bits on resumeLars-Peter Clausen
The adp5520 unfortunately also clears the BL_EN bit when the nSTNDBY bit is cleared. So we need to make sure to restore it during resume if it was set before suspend. Cc: stable@vger.kernel.org Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-04-08mfd: adp5520: Use module_i2c_driver()Sachin Kamat
module_i2c_driver() removes some boilerplate and makes the code simple. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-28mfd: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mfd: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mfd: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09mfd: Guard adp5520 PM methods with CONFIG_PM_SLEEPAxel Lin
This fixes below build warnings: CC drivers/mfd/adp5520.o drivers/mfd/adp5520.c:324:12: warning: 'adp5520_suspend' defined but not used [-Wunused-function] drivers/mfd/adp5520.c:333:12: warning: 'adp5520_resume' defined but not used [-Wunused-function] Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-12-20mfd: Set adp5520 bits if new value is different from the old oneAxel Lin
Current code checks if all the bit_mask bits are all zero is wrong. We need to write new value if the bit mask fields of new value is not equal to old value. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: Convert adp5520 to dev_pm_opsMark Brown
There is a move to deprecate bus-specific PM operations and move to using dev_pm_ops instead in order to reduce the amount of boilerplate code in buses and facilitiate updates to the PM core. Do this move for the adp5520 driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-13mfd: Staticise __adp5520_ack_bits()Mark Brown
The function is not exported as the __ indicates. __ Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Add ADP5520/ADP5501 driverMichael Hennerich
Base driver for Analog Devices ADP5520/ADP5501 MFD PMICs Subdevs: LCD Backlight : drivers/video/backlight/adp5520_bl.c LEDs : drivers/led/leds-adp5520.c GPIO : drivers/gpio/adp5520-gpio.c (ADP5520 only) Keys : drivers/input/keyboard/adp5520-keys.c (ADP5520 only) Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
