path: root/drivers/mfd/altera-a10sr.c
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 201Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms and conditions of the gnu general public license version 2 as published by the free software foundation this program is distributed in the hope it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not see http www gnu org licenses extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 228 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Alexios Zavras <alexios.zavras@intel.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190528171438.107155473@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-07regmap: split up regmap_config.use_single_rwDavid Frey
Split regmap_config.use_single_rw into use_single_read and use_single_write. This change enables drivers of devices which only support bulk operations in one direction to use the regmap_bulk_*() functions for both directions and have their bulk operation split into single operations only when necessary. Update all struct regmap_config instances where use_single_rw==true to instead set both use_single_read and use_single_write. No attempt was made to evaluate whether it is possible to set only one of use_single_read or use_single_write. Signed-off-by: David Frey <dpfrey@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-04-27mfd: altr_a10sr: Add Arria10 DevKit Reset ControllerThor Thayer
Add Peripheral PHY Reset Controller to the Arria10 Development Kit System Resource Chip's MFD. Signed-off-by: Thor Thayer <thor.thayer@linux.intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-10-04mfd: altera-a10sr: Make it explicitly non-modularPaul Gortmaker
The Kconfig currently controlling compilation of this code is: drivers/mfd/Kconfig:config MFD_ALTERA_A10SR drivers/mfd/Kconfig: bool "Altera Arria10 DevKit System Resource chip" ...meaning that it currently is not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since builtin_driver() uses the same init level priority as module_spi_driver() the init ordering remains unchanged with this commit. [Note that there is no builtin_spi_driver macro, so we open-code what it would be via builtin_driver().] Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. We also delete the MODULE_LICENSE tag etc. since all that information was (or is now) contained at the top of the file in the comments. Cc: Thor Thayer <tthayer@opensource.altera.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-10-04mfd: altera-a10sr: Make altr_a10sr_regmap_config static constAxel Lin
It's only used in this driver and never get modified, make it static const. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Thor Thayer <tthayer@opensource.altera.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-06-29mfd: altr_a10sr: Add Altera Arria10 DevKit System Resource ChipThor Thayer
Add support for the Altera Arria10 Development Kit System Resource chip which is implemented using a MAX5 as a external gpio extender with the regmap framework over a SPI bus. Signed-off-by: Thor Thayer <tthayer@opensource.altera.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
