Since regulator[0] is always checking in mfd driver, it results in
registration failure without regulator[0].
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Converted with coccinelle.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Remove unused code.
The genirq infrastructure is being converted to pass struct irq_data rather
than an irq number to irq_chip operations, update max8925 to the new APIs.
Remove original 3-second ONKEY event. Detect ONKEY changing event directly.
So both UP and DOWN event of ONKEY in max8925 are monitered.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
In max8925_irq_sync_unlock(), irq control bit is set at the same time.
Zero means enabling irq, and one means disabling irq.
The original code is:
irq_chg[0] &= irq_data->enable;
It should be changed to:
irq_chg[0] &= ~irq_data->enable;
Otherwise, irq control bit is mess.
Signed-off-by: Kevin Liu <kliu5@marvell.com>
Enable onkey feature in max8925 driver.
There're two IRQ pins output from MAX8925. One is PMIC interrupt, the other
is TSC interrupt. But they're sharing one irq chip.
After initializing MAX8925 interrupts, unexpected TSC interrupt may occur and
it can't be cleared if touch driver isn't loaded.
Now move the operation of masking TSC interrupt behind requesting PMIC
interrupt. If touch driver isn't loaded, this interrupt is always masked.
Update thread irq handler. Simply the interface of using thread irq.
Add subdevs in MAX8925. MAX8925 includes regulator, backlight and touch
components.
Basic Max8925 support, which is a power management IC from Maxim
Semiconductor.
