path: root/drivers/mfd/omap-usb-host.c
2011-07-05Revert "mfd: Add omap-usbhs runtime PM support"Keshava Munegowda
This reverts commit 7e6502d577106fb5b202bbaac64c5f1b065e6daa. Oops are produced during initialization of ehci and ohci drivers. This is because the run time pm apis are used by the driver but the corresponding hwmod structures and initialization is not merged. hence revering back the commit id 7e6502d577106fb5b202bbaac64c5f1b065e6daa Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Reported-by: Luciano Coelho <coelho@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Add omap-usbhs runtime PM supportKeshava Munegowda
The usbhs core driver does not enable/disable the interface and functional clocks; These clocks are handled by hwmod and runtime pm, hence insted of the clock enable/disable, the runtime pm APIS are used. however,the port clocks and tll clocks are handled by the usbhs core. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Fix omap_usbhs_alloc_children error handlingAxel Lin
1. Return proper error if omap_usbhs_alloc_child fails 2. In the case of goto err_ehci, we should call platform_device_unregister(ehci) instead of platform_device_put(ehci) because we have already added the platform device to device hierarchy. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Tested-by: Keshava Munegowda <keshava_mgowda@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Fix omap usbhs crash when rmmoding ehci or ohciKeshava Munegowda
The disabling of clocks and freeing GPIO are changed to fix the occurrence of the crash of rmmod of ehci and ohci drivers. The GPIOs should be freed after the spin locks are unlocked. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: stable@kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-11mfd: Fixed gpio polarity of omap-usb gpio USB-phy resetJuergen Kilb
With commit 19403165 a main part of ehci-omap.c moved to drivers/mfd/omap-usb-host.c created by commit 17cdd29d. Due to this reorganisation the polarity used to reset the external USB phy changed and USB host doesn't recognize any devices. Signed-off-by: Juergen Kilb <J.Kilb@phytec.de> Acked-by: Felipe Balbi <balbi@ti.com> Tested-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-02omap:usb: add regulator support for EHCIKeshava Munegowda
in case of ehci phy mode; regulator of phy should be enabled before initializing the usbhs core driver. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Tested-by: Steve Calfee <stevecalfee@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-05-02mfd: Fix usbhs_enable error handlingAxel Lin
In the case of missing platform_data we do not hold a spin_lock, thus we should not call spin_unlock_irqrestore in the error path. Also simplify the error handling by separating the successful path from error path. I think this change improves readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Tested-by: Steve Calfee <stevecalfee@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01usb: host: omap: common usb host core driverKeshava Munegowda
enabling and disabling the common clocks for ehci and ohci is implemented. usbhs is a common parent platform driver for EHCI and OHCI driver. This driver receives the clock enable and disable requests from ehci and ohci drivers.The UHH and TLL initialization is also performed. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
