path: root/drivers/mfd/tc3589x.c
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 464Thomas Gleixner
Based on 1 normalized pattern(s): license terms gnu general public license version 2 extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 11 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Enrico Weigelt <info@metux.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081202.373849232@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-29mfd: tc3589x: Improve function-level documentationJulia Lawall
Use the correct function name in one case and adjust a variable name to that of the corresponding function parameter in another case. Issue detected using Coccinelle (http://coccinelle.lip6.fr/) Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-08-11mfd: Kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-08-11mfd: Drop owner assignment from i2c_driversKrzysztof Kozlowski
i2c_driver does not need to set an owner because i2c_register_driver() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-22mfd: Constify regmap and irq configuration dataKrzysztof Kozlowski
Constify in various drivers configuration data which is not modified: - regmap_irq_chip, - individual regmap_irq's in array, - regmap_config, - irq_domain_ops, Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-03-26mfd: tc3589x: Enforce device-tree only modeLinus Walleij
All systems using the TC3589x multifunction expander uses devicetree, so don't clutter the place with a lot of and assume it is there. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-25mfd: tc3589x: get rid of static baseLinus Walleij
The TC3589x driver is now a device tree-only driver, so we want only dynamic IRQs and GPIO numbers from the tc3589x, no static assignments. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-09mfd: tc3589x: Translate onecell, not twocellLinus Walleij
Something changed in the OF parser in the v3.16 merge window making it be strict about passing the number of IRQ cells correctly and disturbing the irqdomain xlate function guard to crash when subdevices try to obtain IRQs like this: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 1 at /home/linus/linux-stericsson/kernel/irq/irqdomain.c:676 irq_domain_xlate_twocell+0x40/0x48() Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.15.0-07915-gf6d059821ce9-dirty #46 [<c0014660>] (unwind_backtrace) from [<c0011424>] (show_stack+0x10/0x14) [<c0011424>] (show_stack) from [<c0432630>] (dump_stack+0x9c/0xd4) [<c0432630>] (dump_stack) from [<c001d5c0>] (warn_slowpath_common+0x6c/0x88) [<c001d5c0>] (warn_slowpath_common) from [<c001d678>] (warn_slowpath_null+0x1c/0x24) [<c001d678>] (warn_slowpath_null) from [<c005acd0>] (irq_domain_xlate_twocell+0x40/0x48) [<c005acd0>] (irq_domain_xlate_twocell) from [<c005b658>] (irq_create_of_mapping+0x64/0x110) [<c005b658>] (irq_create_of_mapping) from [<c02e147c>] (of_irq_get+0x38/0x48) [<c02e147c>] (of_irq_get) from [<c01f8910>] (tc3589x_gpio_probe+0x38/0x1e4) [<c01f8910>] (tc3589x_gpio_probe) from [<c022eedc>] (platform_drv_probe+0x18/0x48) [<c022eedc>] (platform_drv_probe) from [<c022d80c>] (driver_probe_device+0x118/0x24c) [<c022d80c>] (driver_probe_device) from [<c022bf20>] (bus_for_each_drv+0x58/0x8c) [<c022bf20>] (bus_for_each_drv) from [<c022d6c4>] (device_attach+0x74/0x88) [<c022d6c4>] (device_attach) from [<c022cdac>] (bus_probe_device+0x84/0xa8) [<c022cdac>] (bus_probe_device) from [<c022b35c>] (device_add+0x440/0x520) [<c022b35c>] (device_add) from [<c022ec50>] (platform_device_add+0xb4/0x218) [<c022ec50>] (platform_device_add) from [<c0243508>] (mfd_add_device+0x220/0x31c) [<c0243508>] (mfd_add_device) from [<c02436a8>] (mfd_add_devices+0xa4/0x100) [<c02436a8>] (mfd_add_devices) from [<c024312c>] (tc3589x_probe+0x334/0x3c0) [<c024312c>] (tc3589x_probe) from [<c022d80c>] (driver_probe_device+0x118/0x24c) The TC3589x device trees specify the MFD core device as having one interrupt cell (cannot specify flags) so the twocell translation function is clearly wrong, changing it to onecell, as it should be, fixes the regression. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: tc3589x: Reform device tree probingLinus Walleij
This changes the following mechanisms in the TC3589x device tree probing path: - Use the .of_match_table in struct device_driver to match the device in the device tree. - Add matches for the proper compatible strings "toshiba,..." and all sub-variants, just as is done for the .id matches. - Move over all the allocation of platform data etc to the tc3589x_of_probe() function and follow the pattern of passing a platform data pointer back, or an error pointer on error, as found in the STMPE driver. - Match the new (proper) compatible strings for the GPIO and keypad MFD cells. - Use of_device_is_compatible() rather than just !strcmp() to discover which cells to instantiate. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-01-06mfd: toshiba: Constify struct mfd_cell where possibleGeert Uytterhoeven
As of commit 03e361b25ee8dfb1fd9b890072c23c4aae01c6c7 ("mfd: Stop setting refcounting pointers in original mfd_cell arrays"), the "cell" parameter of mfd_add_devices() is "const" again. Hence make all cell data passed to mfd_add_devices() const where possible. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-10-23mfd: tc3589x: Detect the precise versionLinus Walleij
Instead of detecting the "tc3589x" and hard-coding the number of GPIO pins to 24, encode all the possible subtypes and set the number of GPIO pins from the type. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-07-31mfd: Use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-04-08mfd: tc3589x: Use devm_*() functionsJingoo Han
Use devm_*() functions to make cleanup paths more simple. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: tc3589x: Use simple irqdomainLinus Walleij
This fixes a regression in the TC3589x driver introduced in commit 15e27b1088245a2de3b7d09d39cd209212eb16af "mfd: Provide the tc3589x with its own IRQ domain" If a system with a TC3589x expander is booted and a base IRQ is passed from platform data, a legacy domain will be used. However, since the Ux500 is now switched to use SPARSE_IRQ, no descriptors get allocated on-the-fly, and we get a crash. Fix this by switching to using the simple irqdomain that will handle this uniformly and also allocates descriptors explicitly. Also fix two small whitespace errors in the vicinity while we're at it. Cc: stable@kernel.org Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-28mfd: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mfd: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mfd: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-17mfd: Enable the tc3589x for Device TreeLee Jones
Here we provide a means to probe and extract vital information from Device Tree when booting with it enabled. Without this patch sub-devices wouldn't be able to reference the tc3589x from Device Tree. Signed-off-by: Lee Jones <lee.jones@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-17mfd: Provide the tc3589x with its own IRQ domainLee Jones
In preparation for Device Tree enablement all IRQ controllers should control their own IRQ domain. This patch provides just that. Signed-off-by: Lee Jones <lee.jones@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-14mfd: core: Push irqdomain mapping out into devicesMark Brown
Currently the MFD core supports remapping MFD cell interrupts using an irqdomain but only if the MFD is being instantiated using device tree and only if the device tree bindings use the pattern of registering IPs in the device tree with compatible properties. This will be actively harmful for drivers which support non-DT platforms and use this pattern for their DT bindings as it will mean that the core will silently change remapping behaviour and it is also limiting for drivers which don't do DT with this particular pattern. There is also a potential fragility if there are interrupts not associated with MFD cells and all the cells are omitted from the device tree for some reason. Instead change the code to take an IRQ domain as an optional argument, allowing drivers to take the decision about the parent domain for their interrupts. The one current user of this feature is ab8500-core, it has the domain lookup pushed out into the driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Guard tc3589x PM methods with CONFIG_PM_SLEEPAxel Lin
Guard PM methods with CONFIG_PM_SLEEP and get rid of some unneeded #ifdefs. This fixes below build warnings: CC drivers/mfd/tc3589x.o drivers/mfd/tc3589x.c:361:12: warning: 'tc3589x_suspend' defined but not used [-Wunused-function] drivers/mfd/tc3589x.c:375:12: warning: 'tc3589x_resume' defined but not used [-Wunused-function] SIMPLE_DEV_PM_OPS already defines constant dev_pm_ops, thus also fix 'duplicate const' sparse warning. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-10-24mfd: Add missing #ifdef around tc3589x PM blockLinus Walleij
The CONFIG_PM code was unconditionally compiled in despite the dev_pm_ops only being included into the driver struct if used. Fix this by adding the missing #ifdef. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-27mfd: Cleanup irq namespaceThomas Gleixner
Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-12-29input/tc3589x: add tc3589x keypad supportSundar Iyer
Add support for the keypad controller module found on the TC3589X devices. This driver default adds the support for TC35893 device. Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> [Some minor fixups for compilation] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-20mfd: Use dummy_irq_chip for tc3589xSamuel Ortiz
This also converts tc3589x to the new irq API. Cc: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-19mfd/tc3589x: add suspend/resume supportSundar Iyer
Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-19mfd/tc3589x: undo gpio module reset during chip initSundar Iyer
Skip putting the GPIO module into a reset during the chip init. This makes sure to preserve any existing GPIO configurations done by pre-kernel boot code. Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-19mfd/tc3589x: fix random interrupt missesSundar Iyer
On the TC35892, a random delayed interrupt clear (GPIO IC) write locks up the child interrupts. In such a case, the original interrupt is active and not yet acknowledged. Re-check the IRQST bit for any pending interrupts and handle those. Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-19mfd/tc3589x: add block identifier for multiple child devicesSundar Iyer
Add block identifier to be able to add multiple mfd clients to the mfd core Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-19mfd/tc3589x: rename tc35892 structs/registers to tc359xSundar Iyer
Most of the register layout, client IRQ numbers on the TC35892 is shared also by other variants. Make this generic as tc3589x Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-19mfd/tc35892: rename tc35892 core driver to tc3589xSundar Iyer
Rename the tc35892 core/gpio drivers to tc3589x to include new variants in the same mfd core Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
